View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22
  1. 6-71 blower ?
  2. Stroking a 509 casting 400 SBC?
  3. Variable Valve Timing on a Chevy V8?
  4. hot cam upgrade
  5. OT: Help me find a bolt or cap head screw. 7.5" long, 7/16 -20 fine thread
  6. Slicks are fun!
  7. Ordered AFR 210's RR
  8. Spirolocks!
  9. What is "Bob" weight ?
  10. Big Problems with Th400??? HELP!!!
  11. GM Gen 4 Engine
  12. Cyl pressures on 9/10 sec stock/forged short block SB C5s?
  13. those DCR friendly please help...hotrod 427 and others please advise
  14. Engine block question
  15. looking for a 355 ci racing engine
  16. piston to counterweight clearance????
  17. Cooler weather and an un-heated intake manifold question for carb. motors
  18. Some pics of my Dart sbc block....
  19. This spark plug heat ok for my 406?
  20. TBI from days gone bye
  21. scat connecting rods
  22. HP Potential for a 327?
  23. Ok, a painful series of dumb engine install ?s
  24. BOY DO I NEED HEAD[S]
  25. 6.535" BBC Rods
  26. How much power is needed to cut tires loose at 50+Mph?
  27. Motor plates ?
  28. Where's Merlin these days?
  29. Anyone,, ZZ-X cam from TPIS?
  30. Holley 750 vac sec tuning question....
  31. Question for experienced cam or engine guys
  32. New 427 SBC finally under way again.....
  33. ISO stroker Miniram dyno graphs....problem at 5000rpm.. intake related?
  34. Need a cam for a 406-CI Super Rram with AFR210's
  35. How much HP can be made?
  36. Gear drive settings.
  37. Videos of new 406 in action.
  38. Dyno results are in:
  39. 406 has glowing headers where the collector starts??? What could it be????
  40. Mechanical fuel pump for a 540
  41. Cam Question
  42. 572 Crate pricing is out
  43. Largest Hydraulic Roller cams ?
  44. which balancer?
  45. Confused...simple questions....feel smart
  46. question about building a 383
  47. New motor for me...
  48. 406 Cam Suggestions
  49. 10-20+ hp more with what mod?
  50. What Dynamic Compression Ratio are you running???
  51. low water temp loses HP
  52. AFR Results
  53. Leak Down results,,,OK?
  54. #8 ex. lifter and lobe worn again, anyone familiar with it?
  55. Anyone bought from Racers Outlet?
  56. Do blowers require "special" pistons?
  57. Anyone running Cranes new sportsman shaft-mount rocker arms?
  58. Camshaft experts, a few questions
  59. Any good links regarding engine building, machining, math, etc...?
  60. Can heads be ported to improve low end flow?
  61. Shipping an engine cross country, need a carrier
  62. Anyone using LPE headers with AFR 210s
  63. Hypertech Power Programmer III (HPPIII) for LT1 Info.
  64. 4 speed shifter mated to auto trans?
  65. Need help with 427 Connecting Rod
  66. Head gasket's... Repost question from C3 section and a power question!
  67. Oil Passages/damage After Using Engine Oil Leak-sealers
  68. L-98 Crank weight ?
  69. SuperRam w/215 CC heads, too big for the SR?
  70. New FelPro MLS (Multi-Layer Steel) Head Gaskets for SBC
  71. Plug wire routing
  72. [L-98 SWAP QUESTION]
  73. 96 Vortec 5.7L to 383. What do I need??
  74. Big Block options? DOHC?
  75. Knock sensors(noob)
  76. MORE POWER
  77. Trade FAST ecu for DFI Gen VII
  78. BB Push Rod Guide Plate alignment?
  79. 12 degrees of timing?
  80. picture of desired dyno, and a 383 build up list to boot.
  81. INTAKE $$$$$$$$$$$
  82. New Brodix Oval port Big Block head
  83. Crankcase Ventilation ideas.
  84. How much advance....
  85. Small Piston Ring end gap symptoms
  86. 4-2-1 Headers, or 4-1 (equal length) Long tube Headers, which is better?
  87. Valve Lash too tight?
  88. FS. Big block crossram w/Webers
  89. Engine temperature
  90. Is a bottom end just a bottom end???
  91. D.C. area dyno?
  92. Want to see C4 w/big block
  93. Intersting kit that converts your LT-1 into a LT-4
  94. Pictures of my new 406.
  95. Question on roller rockers?
  96. Just ordered AFR heads !!!
  97. DCR and big blocks (domed pistons)
  98. Using Vortec truck short block for build-up questions
  99. Few questions bout 383 and 396 engines
  100. looking for advice on 454 engine
  101. Just Received SCAT Rotating Assembly for 407!
  102. Lets talk oil pans, pumps, pickups, windage trays
  103. if the oil pickup is too close to the pan?
  104. Q: Is a 2 bolt block ok for this...
  105. had 383 now thinking of going 427sb???
  106. Is this a good way to go?
  107. Piston Power Rules!
  108. What does Piston Slap or a Wrist Pin Sound Like? Any Quick Diagnosis?
  109. For those with Copper Gaskets, What kind of Silicone did you use????
  110. 28pnd injector max output
  111. Motor did not like the .015 idle wire restriction
  112. Need advice for Air cleaner mod for Holley Adjust-a-Jet
  113. Timing Drives Chains, Gears, Belts Oh MY!.
  114. Will it live?
  115. Timing
  116. Spark question
  117. Ring end gap ?????
  118. MSD6AL Installed inside Glove Box.....
  119. First Impressions...Mcleod Street Twin
  120. [pa] need info on buying vortec heads
  121. Which new aluminum heads for my 69 -350 engine???
  122. mowtown heads ?
  123. Water in Oil - What does it look like?
  124. Moly piston rings, hard to get to seat well?
  125. Got new Mcleod Twin Disc!
  126. Break-in Question - Easy one!
  127. FREE Trans Case
  128. 3 or 6 Bolts on Torque Conveter to Flex Plate
  129. New engine(s) project - pair of Dart block 540 BBC's
  130. Can you flare aluminum tubing for AN fittings?
  131. Big cam and stock motor mounts causing trans linkage problems?
  132. Roller Lifter Tight Fit!!
  133. Vacuum cannister for distributer. What stamp to get 14 degrees?
  134. oh my god someone please help me understand
  135. Where to get Unbreakable Motor Mounts?????
  136. Where's my redline?
  137. Link to Custom Fuel Injection Intake Manifolds???
  138. What's the scoop on the GM 572 ci Crate Engine?
  139. anyone have info on new 6.0 l truck engines
  140. Duke: Distributor/Timing Related Question
  141. F.A.S.T. system price.
  142. TH350 Engine Combo
  143. Toughy Question
  144. PLEASE, What's Detonation???
  145. Die hard stick guy going to an automatic.
  146. What kind of HP gain should I expect if I....
  147. Please explain what a Transgo Shift Kit will do for my 86 Auto.
  148. Goal is: 350-400 HP engine. Need advice
  149. Pete Jackson gear drive installation. Help!
  150. Desk top Dyno Please
  151. Lakewood Bellhousing alignment and dowel pins.
  152. Need to confirm Ring Gap location
  153. It was a bent valve
  154. Where to install for vacuum T?
  155. Recommendations: Muncie 4 Speed/Rear End Lube ?
  156. Holley Help
  157. 502/502 GMPP shortblocks and crate engines
  158. Custom made EFI Systems ( HOlley 950 commander)
  159. Sorta of a weird thing happened in the valve trane
  160. Vacuum question on 406 with big cam...
  161. Chris's Twin Turbo update
  162. what displacement does a 350 like most?
  163. Who has done a 427 LT4?
  164. Sallee Chevrolet
  165. Water Pump Bypass hole on block
  166. AFR Heads Purchased!
  167. cam grinding company?
  168. Custom bent radiator hoses?????
  169. Anyone out there have experience with a 391ci engine??
  170. Fuel pump looses pressure upon take off, good pressure at idle.
  171. Has anyone bought an American Speed engine?
  172. Does anyone know where I can get .021 Silicone Copper Head Gaskets?
  173. Want to put a 400 in a 71
  174. Contrary to popular belief, 825 Hp IS streetable!
  175. roller rocker failure
  176. Rocker Stud Girdle?
  177. how do i find an old post
  178. Engine Temperature
  179. Oil pump, High volume or Low?
  180. Can I get by with putting only a Hotcam and roller rockers on a stock LT1?
  181. Benefits of a roller cam (and 383 buildup advice)
  182. HELP knoledge wanted
  183. Vortech carbureted supercharger kit
  184. LT1 dual plane intake for swap?
  185. Intake
  186. Is a 396 Worth It Over a 383?
  187. carburated 406ci for sale- solid roller
  188. Will a ZZ4 bolt up ......
  189. Edelbrock C4B
  190. 327 camshaft suggestions?
  191. Opinions on break-in
  192. IF IT WAS YOR ENGINE
  193. Thoughts on this cam for a 383 build.
  194. Stuck torque converter bolt!
  195. Help with intake decision please...
  196. 454 H.O. vs. 502 H.O.
  197. Went to track, went fast, broke tranny
  198. L48 or GM LM1 which is better?
  199. Gapless Rings and PCV system
  200. Race report
  201. For those with the F.A.S.T. EFI system
  202. FLAME or MSD
  203. More On Ring Gappng Theory
  204. 400 Engine Build
  205. Somethin' musta bit me, cuz I gotta mean case of the ENGINE crazies!
  206. [NY] FS 400 4 bolt block.
  207. FREE TCS WIDOWMAKER CONVERTER!!!
  208. Proper Order for Block Machine Work?
  209. Going to the track Thursday, need a few tips.
  210. Changing rocker ratio -- What's the impact on duration?
  211. Engine Build
  212. Ls6 painted Intake manifold
  213. Anyone else had problems with 1-pc blue silicon oil pan gasket?
  214. anyone using LPE 211 cam?
  215. Small Base Circle Camshafts?
  216. Help with heads for my 400
  217. 327 LT1 w/turbo?
  218. Hooker Side Pipes on 75 502
  219. GKULL's engine mods.......
  220. [should I make] Carbon Fiber body panels.
  221. Different Jets for Rochester Q jet?
  222. Anyone useing a MAIN STUD GIRDLE(pics)
  223. Harmonic Balancers?
  224. Torque for turning engine over (by hand)
  225. 496 BBC on engine dyno today
  226. Favored recipes for a 383? A healthy budget and modest goals-
  227. 400 sbc engine rebuild
  228. Stroker crank
  229. Collector Muffler? How can this be done?
  230. Accusump, who's using one? Good idea?
  231. New Engine Pic!
  232. Does this sound like the right stall for my combination (torque converter)
  233. Piston ring gapping discussion
  234. Clutch for street and a little strip. Have slipping centerforce whats a good diaphram style
  235. Epoxy modified GM BB intake ? (rect to rect-oval)
  236. Rebuild dilemma 427 or 454
  237. check list
  238. any info on swapping a big block into a c4?
  239. Got my parts back from the machine shop today.. I have some quesitons.
  240. 302 Chevy...best pushrod V8 ever designed?
  241. Flexplate question
  242. LT1 ignition upgrade info
  243. 443 ci or the 454 ci Bill Mitchell Small Block Crate Engine
  244. Tall valve covers on a C4?
  245. Help, mismatched cylinder heads: 3998920 & 3986336
  246. Does it Exist ?? LT4 Double Roller ?
  247. 400 head gasket/ steam hole question ?
  248. OT: Teflon Coated Engine Parts
  249. Fit valve covers on roller rockers
  250. Those of you with Lakewood scattershields
