View Full Version : C1 & C2 Parts
  1. WTB: C2 inside door latch
  2. WTB Jack
  3. Tach and Speedo cable
  4. WTB T10 for C1
  5. For sale: 1107320 starter
  6. what are these worth?
  7. Mid-Year Frame Question
  8. FS Complete 4.11 Dif (CA)
  9. FS All Alloy M22 (CA)
  10. WTB - 65 Knock Off Wheel
  11. western knock off wheels
  12. 1960L-62 Air Cleaner Assembly 1x4
  13. 1963 Corvette original GM door sills trim plates
  14. WTB-3859326 Water Pump
  15. Wanted 1957-58 #3737739# J,K,L..Need 1958 Dash pad,Carpet,doorpanels,seat covers?
  16. Rock
  17. Borg Warner Transmissions and parts
  18. WTB Molding clips
  19. whays it worth m22
  20. 62 complete front suspension
  21. 63 Lower Steering Column Bearing
  22. LOOKING FOR 2X4 Intake for C1
  23. Hurst part numbers needed
  24. 3844461 intake will sell or trade for hubcaps
  25. NOS GM Side Pipes & Covers
  26. Many '63 -'67 Parts For Sale
  27. Wtb Seats 1960
  28. WTB 59 tO 62 Shifter Handle
  29. FS 1967 bb intake 3883948
  30. 63 caps and rims
  31. Midyear Frt Bumper Brkts, Expansion tank, plus more
  32. 327 connecting rods SJ
  33. FS: 461 heads
  34. WTB Original warranty books and other misc glove book items
  35. WTB: Windshield Wiper Motor for 63
  36. WTB: 396 motor
  37. FS: 1965 Carter AFB 3721SB Carb
  38. 63 m/c, whats it worth?
  39. A Christmas Story
  40. Inventory! Must Go C1 parts
  41. WTB - Tele Column
  42. FS: '65 - '79 4.11 and 4.56 gear sets
  43. WTT Front monospring system 4 stock
  44. WTB: C2 Hardtop rear glass upper stainless trim
  45. FS: 63-67 4qt Oil Pan
  46. WTB: original 67 antenna mast
  47. WTB: 65 Coupe window trim
  48. F/S Big Block Short Block
  49. F/S 1963 Carter AFB 3461S
  50. F/S 461 Double Hump Heads - 327
  51. F/S-'63 Seat Belts
  52. WTB C2-C3 Orig. Upper control arms...
  53. 283 heads for sale
  54. 3731539 heads for sale
  55. 3748770 heads wanted
  56. FS/1959 hardtop
  57. Wanted org. 1967 small block Hood
  58. WTB 63-67 Driver side Wiper Vent Grille
  59. WTB 56-60 hardtop trim
  60. 65 4:11 Posi
  61. For Sale '858' Square Port Heads, Intake, Carb
  62. FS: 462 heads
  63. WTB 461 Heads
  64. WTB Tach drive Distributor
  65. 58 hood
  66. WTB 3873858 heads 9/65 or earlier
  67. Building 327/365hp motor
  68. 1958-62 NOS Corvette Grill Surround Mouldings
  69. WTB 64 Tilt Column
  70. 63-82 Vette Frt Koni Shox & VB Tie rod sleeves
  71. C1 parts will go on ebay unless...
  72. 66/67 Glovebox Door
  73. 1953, 54, 55 passenger side door moulding
  74. Help With Distributor Date Code
  75. 1110891 Dist Wanted
  76. WTB original 9 leaf rear spring 63-72
  77. WTB 1961 Rear Tail Light Sockets
  78. WTB 1961 Rear Tail Light Sockets
  79. 65 327 cast#f111ohf 68 350 cast#vo118hz
  80. F/s Rt Side Glass T/top
  81. WTB 1961 seatbelts
  82. Broach Buster Special Holiday Offer
  83. FS. Aluminum valve covers-off set holes.
  84. WTB 3782870 block
  85. 67 T.O arm wonted
  86. 65 parts F/S
  87. WTB: 63 Speedo & Tach Cones
  88. vent cables needed for a 66 both sides.
  89. Wtb: C2 Frame Or Rolling Chassis
  90. Vent Windows Needed
  91. WTB 1966 hubcaps
  92. WTB 1965 FI Choke
  93. Wanted Mid Year Air Cond. Duct
  94. FS 65 harnesses and taillights
  95. WTB: Need 67 Corvette Parts
  96. Still WTB a 1964 #3844459 intake manifold
  97. F/S SB Blower Motor & Nash 5sp
  98. FS 53-57 Brake Handle NOS Box
  99. Knock off removal tool
  100. 1963-67 parts for sale
  101. FS: 63 4spd Console and extensions
  102. '64-65 327 #461 double hump heads
  103. FS 2x4 intake 653
  104. For Sale: 1107889 Corvette Starter
  105. F/S Distributors
  106. WTB 1965 327 block date code june
  107. wtb 63 fuel inj air cleaner assembly
  108. wtb 63 fueblyl inj air cleaner assem
  109. C1 Corvette Parts for sale
  110. WTB: 870 Block Oct 63
  111. WTB 870 block Jan, Feb or March 62
  112. Wanted: 63 with AC, left side alternator brackets
  113. FS: '71 010 350 engine with '64 #461 double hump heads
  114. WTB 63 Headlight bucket and Shifter for T10
  115. FS 63 E outside mirror
  116. WTB 1963 seat belts.
  117. FS: 1963 Bellhousing
  118. Custom Banners - Order In Time For Christmas
  119. FS 58/60 taillight assemblies and rear bumpers
  120. WTB: 870 Block
  121. FS - (4) New in box 15X8 Corvette Rally's complete
  122. Body Lift For Sale
  123. WTB C5 Calipers (takeoffs?)
  124. FS: 61-62 antenna assembly
  125. WTB: 65 Coupe Vent Grills behind driver door
  126. For Sale: C2 Front-End, Hood and 'T' Armrest
  127. WTB - Various C1 Parts
  128. FS '65 block F0218HP
  129. F/S 1954 YH Carb Side Draft
  130. WTB Your old cracked steering wheel 1963-67
  131. 4-Sale Delco-Remy Voltage Regulator 7E
  132. wtb side pipes
  133. WTB 65 327 block casting date code June 65
  134. WTB mid year hardtop
  135. Weight of 327 block with crank and pistons
  136. Early Christmas?
  137. WTB 63-67 front bumpers/drivers
  138. WTB Repro KO
  139. WTB Headight motors, buckets & Switch for 1966
  140. WTB 66 Front Bumpers
  141. WTB: Noland Adams 1963-1967 Restoration...
  142. WANT TO TRADE: 1967 Bolt-on Knockoff wheels for 1966
  143. For Sale: 1100665 55 Amp. 4B21 Alternator Core
  144. WTB....63/64 rear clip
  145. FS midyear fiberglass dash support
  146. wtb C2 Ballast Resistor
  147. Want to buy or trade wC1 S/S upper windshield moulding
  148. TRADE my 63-7 speaker for your 58-62 speaker
  149. Wtb Carpet
  150. WTB C2 rear body harness
  151. C1 parts 1956-62 parts for sale
  152. 1963-67 Corvette parts for sale
  153. WTB AC Delco oil filter element A212CW
  154. Have Block & Trans For 67 #5814 and Block For 67 #160
  155. WTB 1958 door lock assemblys and driver window regulator
  156. F/S 1958 black seat covers
  157. wtb c1/c2 body
  158. wtb.....intake 3844459
  159. 66 rdstr wheels
  160. FS: C2 Fiberglass
  161. Car Jacket for sale
  162. Coupe outside window seal mouldings
  163. Flares are coming back
  164. WTB Driver's Side '65 Coupe Rear Corner Window Fuzzy
  165. For Sale 1965 vert black door panels
  166. 57-61 Chevy Dual Quad Intake Corvette
  167. WTB - '60 Rear Clip
  168. Wanted...cpe./vert birdcage
  169. '67 351 4 bolt short block, H296, JE code
  170. FS Edelbrock Pro Flo Fuel Injection system
  171. FS American Racing Torque Thrust Wheels
  172. WTB Rear inner door corner molding
  173. WTB Crank pulley
  174. WTB Crank Pulley
  175. WTB 1965 corvette front grille
  176. FS BB 69 Differential, HalfShafts, & Trailing Arms
  177. 58 3rd arm bearing
  178. FS: 100% cotton car cover for C2
  179. 1962 Sales Binder Featuring the Corvette and Corvair
  180. 327 heads 461 & manifold
  181. Newbie Checks In; Seeks Parts Wisdom
  182. Looking for 65 327/365 motor
  183. meanest muffler for 67 390 hp??
  184. USED 66 seat covers (black leather + foam)
  185. 1961L original factory 2x4 unit
  186. WTB American Racing Wheels
  187. Heater Box "Y" Duct?
  188. WTB Original Mid-Year Air Cond. Duct
  189. WTB 3756519 block late 59 date
  190. 56' intake manifold #3735448 w/carb
  191. F/S-'63-'65 Coupe Headliner
  192. F/S Corvette Original Aluminum Big Block Intake
  193. 1965 Corvette motor complete
  194. What are they worth? Sidepipe covers w/rockers
  195. shifter knob
  196. Defrost nozzle
  197. 61-62 Convertible Hard Top FS
  198. WTB Late 1960 Trunk Mat
  199. 1958 Corvette engine wanted:Must Be #3737739#I,J,K
  200. c2 body jig
  201. 66 roadster
  202. Steel wheels, rings, and caps, 67 dated door panels 4 sale
  203. '58 Parts Needed-WTB
  204. FS 63-67 Corvette steering damper w/ brackets
  205. 63 parts
  206. 1963 SWC coupe interior parts wanted RED
  207. WTB: '65 BB Hood & Grille
  208. WTB power top assembly cover
  209. for sale: 53 vette model car
  210. WTB: Rear Rotor
  211. F/S Car Covers, Book & Carpet
  212. F/S power convertible top for sale
  213. Original Owners Manuals 1958-1989
  214. WTB air cleaner, ignition shielding for 61
  215. Trade, Black 61 belts
  216. WTB: Mounting bracket for TI Module
  217. WTB late '64 or 65-66 LH Driver door Conv
  218. WTB 1964 Corvette Full Flares
  219. 1963 461 big valve heads for sale
  220. Corvette Junk
  221. 12+bare corvette engine blocks {small block 1959-1969
  222. WTB 65 front grill
  223. Wtb: '67 Bb Hood
  224. 1965 roller
  225. 1963 and 1965 Shop Manuals
  226. 67 bolt on lug cover clips
  227. FS: Rare convertible top fasteners
  228. Fender flare with big lips
  229. More Corvette/Big Block parts 4 sale
  230. 62 Hood
  231. F/S Delco voltage regualtor...January 1967
  232. WANTED 391 heads
  233. WTB fender flares
  234. 67 Big Block Stinger hood
  235. wtb air cleaner
  236. Corvette Original Aluminum Big Block Intake
  237. WTB: '58-60 Heater Delete Plates
  238. 62 Build Book $15 includes shipping
  239. WTB 870 block dec, jan, feb, mar 62
  240. WTB C-1 Parts
  241. 1964-67 Corvette clock for power brake booster
  242. Wanted, 63-67 flares or widebody fenders
  243. WTB Front Aluminum Generator Plate
  244. Body lift strap new $55 shipped
  245. F/S NIB Delco Volt Reg 1119512...'63 Corvette
  246. wtb '65 396 motor
  247. WTB SBC Tri Power unit
  248. F/S 63-67 soft top weatherstrip
  249. F/S Front Carpet Set - 65 Coupe
  250. F/S Rally Wheels & Tires
