View Full Version : C1 & C2 Parts
  1. WTB: Front Bumpers
  2. Various Parts for a C2
  3. FS: 1964 grill
  4. '60 - '62 Female Hood Latches
  5. Needed: Original 63 SWC Hood
  6. F/S C-2 parts with free delivery to Carlisle
  7. F/S '62 FI Cranking Signal Valve NOS
  8. F/S AC-44 Spark Plugs NOS
  9. WTB 56-57 Radiator Core Support
  10. F/S - 3858180 long block
  11. 3782870 327 blocks
  12. 1958 "739" short blocks
  13. WTB 66 4 speed console
  14. Wanted 67 BB Hood
  15. 1965 Spare Tire Tub
  16. wtb 64 hardtop outter header trim
  17. WTB 56-57 Driver side door
  18. New set of red vinyl seat covers 63
  19. 858 square port and 390 oval port BB heads
  20. 60-62 male/female hood latches
  21. 65 & 66 hubcaps, 66 wheels and tires
  22. WTB - Corvette Bolt-On Wheel Starburst
  23. WTB - 59 Front Left Lower Control Arm
  24. F/s N.o.s. 327 Alternator Pulley...
  25. Tail Lights--Sellable?
  26. WTB C2 Vertical Bonding Strip
  27. WTB - 66 Coupe Doors
  28. WTB Door end cap 57-58
  29. Delco AM/FM on eBay - seems cheap
  30. radiator shroud/exh pipes
  31. WTB '64 Seat Tracks
  32. FS: 59 - 62 Hubcaps Wheelcovers
  33. 1963 hardtop, disassembled.
  34. FS 490 aluminum intake L79
  35. WTB early 67 Expansion tank, Dated
  36. wtb Orig used 67 bright blue enteror
  37. WTB: 1961 2x4 air cleaner
  38. Wtb: 64 Rocker Panel Mouldings
  39. 66-67 LH Exhaust Pipe 2 1/2" (NEW) $30.
  40. WTB 9" housing for C1
  41. FS 1962 4.11 P carrier
  42. rrear iner bumper
  43. WTB Harry Mann License Frames
  44. 3855961 Block wanted
  45. WTB 54 dual pot air cleaners and assembly
  46. 62 lower glove box molding
  47. 66-67 Big Block Aluminum Griffin Radiator New In Box
  48. 63-67 Keisler TKO 600 5-Speed Trans. Kit New In Box
  49. WTB (Wanted To Borrow) C1 Convertible Top Installation Video/DVD
  50. Whats It Worth?
  51. WTB: Heat Shield for Intake Manifold (3844461)
  52. 1965 Corvette Tack drive Distributor
  53. WTB: (1) One Western wheel KO 65-66
  54. F/S-'63-'67 Speaker Grill
  55. Dg Rally Wheels
  56. WTB C2 Parts
  57. WTB C2 Parts
  58. FS: C2 Corvette Frame 63 64 65 66 67
  59. 57 Fuel Injection Unit and 64 Distributor
  60. Alum heads (1960) 3772895 dated 6-24-59
  61. WTB: The Complete Corvette Restoration & Technical Guide Vol. 2
  62. Want To Go 9:90's In A Midyear Vett??fen
  63. FS 65-67 seat backs
  64. FS 65-67 seat backs
  65. FS 65-67 seat backs
  66. WTB: 1967 Black tipped E-Brake handle
  67. WTB- armrest trim, seat trim, jack handle &...
  68. WTB 63-67 Windshield Frame/birdcage parts
  69. WTB- '63 Exhaust Manifold
  70. Repro KO'S For Sale w/ GY Tires
  71. FS Car Capsule
  72. Might need a rebuilt rear end or core. Anything available?
  73. 65-57 Clock Needed??
  74. Wtb: 858 Head
  75. 1965 roller FS
  76. WTB BB 65 396 Pully
  77. 1963 shift console
  78. WTB C1 Front Window Guide Left (Driver)
  79. knock offs listed craigslist.houston $850
  80. Need help with side pipe insulators
  81. FS-1964 RESTORED Gauge Cluster
  82. 1957-1961 factury aluminum dual quad intake
  83. Looking for 396 EX Manifolds
  84. Looking for a 174 block... found a 657
  85. WTB 58 Guages
  86. C2 Hardtop off a 66
  87. c2 coupe interior halo panel
  88. WTB 66 390 HP 427 Exhaust Manifolds
  89. Lost In The Weeds
  90. Lost In The Weed Nfs
  91. WTB Early '64 Differential
  92. 3737739 283
  93. WTB left (driver) door stuff 56-7 C1
  94. 56/57 9-Fin Valve Covers, worth?
  95. wtb-67 steering wheel
  96. WTT 1959-1960 Gauges Mint!!
  97. 63-67 Cowl Hood
  98. Fs 2 Cast Iron Distributors
  99. Fs 327 Gm Pistons
  100. Fs 58 Block And Crank
  101. Free: '68 original seat back foam
  102. Firestone Firehawk Indy 500 RWL tires & Craigers
  103. FS Borg Warner main transmission shaft
  104. WTB: Set of 15 x 6 Rally DC wheels
  105. 65 Model 4:11 Differential
  106. F/S-'66-'67 Radiator Shroud
  107. wanted;;60 shifter with linkage(correct) C1
  108. 1966 427 2 bolt block FS
  109. 1965 1966 crossed flags nose emblem
  110. Barry Grant Mighty Demon 650 CFM Carb
  111. FS: Allen's Side Exhaust Kit
  112. big block exhaust and rocker mouldings
  113. WTB 63 door
  114. WTB 2 orginal gm quarters for 66 or 67 corvette
  115. Orginal 67 Corvette green vinal seat covers and headliner wanted
  116. WTB: 327/300 HP Intake Manifold
  117. 1964-67 radio works
  118. Wanted to Buy: 62 Water Pump
  119. 58 Generator w/Tach Drive
  120. F/s 2 Chevrolet Corvette Chassis Service Manuals
  121. WTB 62 tach drive distributor
  122. WTB 62 hard top
  123. WTB: '60 Door
  124. Wtb 64 Parts
  125. '54 Carbs, Need Parts
  126. 1965 Intake manifold and a 1969 350/350hp motor
  127. For Sale: 1954 Frame
  128. Wtb 67 Seat Frames
  129. Midyear clock
  130. WTB 58-60 Corvette FRONT Bumpers
  131. WTB - Original (NOS) 1963 L-76 340HP AirCleaner
  132. 56-60 hardtop
  133. WTB 64 oil filler tube
  134. FS - 693 Alternator
  135. wtb 66' late vin # front windshield glass clear
  136. WTB: AFB 37215A Carter carb
  137. 1956-62 Corvette gauges gauge For Sale
  138. Eastwood Pro 1100 powder coating kit, unused
  139. C2 parts for sale
  140. 1958 283 Fuel Injected block
  141. for the love of dual quads............
  142. Value of Rochester F.I. and matching distributor???
  143. WTB #80 oil pressure guage for 63 Vette.
  144. holley 3721s 64-5 300hp m/t
  145. 65 corvette seat foam
  146. 1963-1967 VINTAGE AIR set up NEW in the BOX
  147. 1965-1966 NEW Interior WHITE Coupe
  148. Hurst Comp + Shifter
  149. WTB: 64, 65 or 66 seats
  150. Will pay $1000 apiece for 1960's Goodyear Blue Streak Stock Car Specials
  151. 58-60 radiator core support
  152. WTB 61 Ignition Wire Lower support rt side w/ PCV
  153. WTB 1962 3799349 Aluminum Intake
  154. Sell my Muncie M21 ???
  155. carbs/intakes/exhaust
  156. Some C1 Chrome For Sale-Used Parts
  157. C1,Borg Warner main Trans Shaft FS
  158. Midyear set backs
  159. WTB 58 To 62 F.I. Adaptor
  160. F/S 65-66 Repro Knockoff Wheels
  161. (1) 770 head FS
  162. 550 heads For sale
  163. 283 RUNNING Engine 3789935 4 Sale
  164. WTB: Original Clear Floor Mats
  165. 64 seat belts WTB
  166. 62-63 T-10 transmission
  167. Torq-Thrust II - Classic Custom Offset
  168. red seat covers wanted 60 corvette
  169. seats for a 66
  170. F/S 1963 Corvette Bellhousing
  171. Big thanks for John Lynch !!!!!!
  172. swap T-10 side cover
  173. Wanted: '62 - '64 Powerglide tailhousing
  174. Speedometer repair or WTB
  175. Aluminum 7-fin valve covers
  176. 65-65 power antenna
  177. 391 heads...
  178. WTB: 64 Trailing Arm
  179. WTB: 396 complete motor or block
  180. WTB: Spare Tire Tub for a 65'
  181. I Need these parts
  182. 1968 427 435HP Corvette Complete Motor
  183. WTB Offset Rear Control Arms
  184. FS 64 Hood
  185. 58-62 hubcaps and headlight rings for sale - Chicago
  186. knock off set 15 x 8 complete
  187. 1957-1961 aluminum dual quad intake
  188. 1963-66 knock off wheels for sale
  189. F/S 65 Repro knockoff wheels
  190. 461X heads (3782461)
  191. For sale: 548 Big Block. Dynoed at 778 HP. NA Setup for NOS
  192. [FS] two 255/60R15 tires
  193. [SOLD] four 15 x 7 Ralley rims with trim rings ( off '72 monte carlo )
  194. Needed: Original 63 SWC Hood
  195. 65 vette 327/350 HP motor
  196. Misc 66 parts
  197. FS: Burned '65 BB roadster
  198. WTB - 1966 427/425 Engine, bBock or Heads
  199. F/S 65-66 Repro Knockoff Wheels
  200. wanted spinners
  201. wanted rear end end caps
  202. birdcage
  203. orig 59 #519 f.i block with orig stamp
  204. NEW Goldline Radials for '65 and '66
  205. WTB: Red Seat Belts for a 62 Vette
  206. Cloth or vinyl air cleaner cover
  207. 65 -66 327 Engine Wanted !!
  208. 1956 Power top
  209. WTB Orig. C2 Side Exhaust Covers in Poor Condition
  210. C2 Parts and Frame F/S
  211. 63-67 Corvette Deck Lid $100.
  212. 64 vert rear clip w/decklid
  213. WTB-21/2 inch midyear side exhaust and covers
  214. Drivers side vent pull 1964
  215. WTB C2 Fiberglass Side Exhaust Covers
  216. WTB Center Bar and Bracket for Midyear
  217. wanted; 60 parts
  218. 54 replica body for sale, $4250.00
  219. WTB: Upper heater "Y" duct
  220. Paragon Repro rear bumpers
  221. Reproduction Master Cylinder '66 Power Brakes?
  222. '67 misc parts
  223. FS: 67 replica star wheel centers
  224. '67 small block hood
  225. FS: '67 Rams horn manifold
  226. 63 Corvette 4:11 posi $950.
  227. 66 Vette Carpet
  228. WTB 63 master cylinder
  229. Knock Off Wheels 15x8 In Texas
  230. Anybody Need 64 Parts?
  231. Garage sale Parts 1958-1967
  232. 1963 corvette clock restored with nos movement
  233. WTB Right Lower A Frame
  234. WTB Right Lower A Frame
  235. WTB Right Lower A Frame
  236. WTB: 55-60 Antenna, 58-60 wheels
  237. 1956-60 parts needed
  238. Corvette Knock Off Wheels 15x8 Complete Set - $1250
  239. Goldline Radials F/S
  240. 9 rib valve covers
  241. WTB 870 block and 461 heads
  242. NOS Third arm bushing stud
  243. Wtb 63-67 Tinted Vent Window Glass
  244. '67 seasts
  245. WTB 64 rear diff. could use some leads.........
  246. Brackets needed for my Project
  247. fs knock off wheels 15x8
  248. F/S- Hurst Shifter
  249. For Sale: C2 rear end parts.
  250. 63-67 various 2" exhaust manifolds
