View Full Version : C1 & C2 Parts
  1. wanted ; '58 seats
  2. For Sale 58 to 61 270 HP Set Up
  3. misc. C2 parts...
  4. 1965 Corvette Engine L-79 327 / 350HP Fresh Rebuild
  5. WTB or Trade American wheels
  6. Wanted:rh 3797902 Exhaust Manifold
  7. WTB headlight motor bracket foot
  8. WTB American Racing Wheels
  9. 64-66 461 S.B.C. Heads
  10. NOS C1 Mufflers, in GM Boxes
  11. F/S 327 heads #461
  12. WTB Copies of SACE club magazine
  13. wanted '67 steering wheel
  14. WTB 1966 Corvette voltage reg.
  15. FS or Trade: SBC 1.5 Roller Rockers
  16. Crane Cam & Lifter Set/ Chrome Cover,Tab
  17. FS- AFB Style 600 Carb/ Edel. Perf. Intake
  18. WTB Fiber glass part for 67
  19. WTB C1 Steering Box Parts - Sector Roller!
  20. WTB Back-up switch
  21. 1957 B&H bolt needs a mate.
  22. Fs Numerous Dated Jacks 1969 Thru 1981
  23. WTB very early dated 3247
  24. WANTED: '62 FI distributor
  25. Widened C1 quarters to run 10" wide wheels (C4 or C5 running gear)
  26. F/S - C2 Passenger Rear Quarter Panel & Bonding Strip $250
  27. F/S - Western Wheel 8" Knock Off Wheels with Tires $1,500
  28. 57 Fuelie Pics for sale
  29. F/S 3858403 Small block Bellhousing 8"
  30. F/s 396/ 427/ 454 Tall Chrome Valve Covers
  31. F/s 1963 - 1966 300hp Metal Valve Covers "new"
  32. WTB: 3890490 intake
  33. WTB 283 block
  34. For Sale: 1967 427 Intake 390HP - 3883948
  35. Seats
  36. BB square port Tarantula intake
  37. Early 56 oil pan
  38. WTB: 58 4 Spd T10 trans - FI Fuel Filter/Air Cleaner
  39. Air Cleaner Element -orig screen type-in stock
  40. Corvette Restoration by Noland Adams in stock
  41. F/S 63 thru 67 original Half Shafts
  42. WTB seats '53-56
  43. FS Widened quater panels 1958-60 for C5 Wheels
  44. A few parts...non-org. pieces....
  45. 59 Corvette Rolling Chassis 4 Sale
  46. F/S Used Holley Carb 650 double pumper 4150
  47. Wtb: '62 Hardtop.
  48. FS Original 66 327 Holley carb
  49. 60 Magazine Ads
  50. C2 windshield trim lower interior
  51. C2 Head light bezels L + R
  52. WTB 56 and 68 Parts
  53. WTB 56 and 68 Parts
  54. WTB Chrome Distributor cover..
  55. 63-67 Dash Hardtop trim
  56. 1963/4 Front Grille
  57. 434 sbc for sale
  58. For Sale, 1964 coupe frame
  59. 63-67 Headlight assy.s
  60. 427 Engine for sale
  61. F/S 3782461 Double camel heads 327
  62. C2 & C3 Parts For Sale
  63. C2 Mirror & Gas Tank
  64. Driver's Side Dash Pad-63
  65. Mid Year Hardtop $800
  66. NEW AFR eliminator series heads
  67. FS: New VBP trailing arm rebuild kits
  68. Fs 1959 3756519 Flint Short Block
  69. C1 Rear View Mirror Base
  70. C1 Wipe arm spacer NOS
  71. C1 Corvette shift knob
  72. C1 door lock knob set with clips
  73. C1 NOS Speedometer Cable
  74. C2 stuff FS
  75. WTB: Need 858 or 391 Head
  76. C1 Parts
  77. 1967 Camaro Center (hub) Caps
  78. WTB, headlight motor electric connector
  79. FS Black Dask Pads for C2
  80. 66 Grill
  81. wtb 59,62 deck lid
  82. WTB an Early 67 3904351 Block
  83. FS: ARP 2-Bolt Main Stud Kit 327/350/400 SBC
  84. FS: Eagle ESP H-Beam Connecting Rods & Keith Black Pistons for 5.7L 350ci SBC
  85. chassis and body parts catalog
  86. WTB; 56-62 NOS steering wheel
  87. 1967 Original Windshield Wipers & Blades
  88. F/S 1964 rolling chassis
  89. FS: Comp Cams Nitrous HP Camshaft & Comp Cams Lifters
  90. End of the Year Sale!
  91. FS 61/62 original Delco horns
  92. FS C2 center console
  93. FS C2 Cluster
  94. WTB 63 rims
  95. Brackets on Console to Radio Side Panel C2
  96. Uploaded photos of AL intake 340HP
  97. WTB C1 center console and dash parts and more
  98. Midyear Spare Tire Bolts
  99. Wtb - 1962 Body Parts
  100. FS - 58 Powerglide, Rear frame crossmember
  101. WTB 3797902 RH Manifold Original
  102. 1960 Grill Uper Mold.
  103. WTB '64 Transmission Mainshaft Ext. housing 3846428
  104. F/S 1954 Window Curtain Passenger side
  105. FS: 4spd console w/ power window hole
  106. FS-Set of Five ORIGINAL 1965 KH Aluminum Knockoff Wheels
  107. Intake Manifold 63 327-340HP, Corvette, AL, AFB
  108. Corvette 63 - 65 Carter WCFB 6-1672
  109. 66 Frame (chassis) $500!!
  110. FS-Drum brake spindles, knuckles, drums, more!
  111. 62 Windshield Part Needed
  112. WTB C1 wiper transmission - right
  113. FS Powerglide console
  114. Power steering pump
  115. WTB: 2 1/2" front pipes
  116. 1108400 Rare Dated Starter Dec of 1969
  117. N-11 "off Road" Exhaust N.o.s.
  118. FS: High Volume Oil Pump and Pickup
  119. All from a 1966
  120. WTB 65 roadster passenger fender and gills
  121. Wtb 1963 Orig Gm Cream Colored Fiberglass
  122. WTB Mid Year Headlight Motor(s)
  123. WANTED: '63 - '64 Power Brake Hose Fitting
  124. WTB- Orig. Expansion tank for '67
  125. 1960 Aluminum heads for sale
  126. 53-67 X-mas sale...
  127. Corvette Chambered exhaust System $100.00
  128. Brand New Al Knoch Black Ragtop for Jan 57 Corvette (dated)
  129. WTB door lock reflecter for 64
  130. 1962 461 X Heads
  131. F/S exhaust heat riser valve 2.5" new
  132. FS Fuel Injection parts
  133. FS - C2 Car Creations Frame w/Suspension, D44
  134. FS - 1966 C2 Convertable frame
  135. F/S 1962 Corvette finned balancer MINT
  136. F/S 1961 Corvette Parts
  137. F/S: 1960 hard top
  138. WTB 65 stock radio
  139. WTB 63 left door
  140. 427 Short Block for sale, "CE"
  141. 60's dash & hardtop trim
  142. K&N tri-power filter FS
  143. F/S NOS GF-90 Filter & 3x2 Air Filter
  144. WTB complete Vette Brakes Susp
  145. I Have 4 New Firestone red Lines
  146. F/S-'63-'64 Coupe Door Panels
  147. 63 Power Brake Booster&master Cylinder Ltb
  148. F/S 66 teak wheel
  149. WTB: expansion tank mounting bracket
  150. WTB Carter WCFB idle adjustment screw
  151. Car Cover FS 58-67
  152. 327 blocks FS
  153. Lots of C-2 parts FS
  154. c/1/2 sb factory cast iron intakes
  155. FS Brand new SFI 168 tooth Flexplate Made in USA
  156. 53 To 55 Soft Top Latches
  157. 1967 3903352 Engine block for sale
  158. Steering wheel from a 1962
  159. WTB - 1963 Steel Wheels
  160. 1965 Seat covers
  161. nos 2 1/2" exh man 3846563
  162. F/S-'62/'63 Intake Manifold
  163. 3858174 Block for sale K 3 5 date code
  164. Pi-Thon hose locks (new)
  165. 1963 transmission & differential
  166. WTB for '54
  167. 1966 427 Waterpump and Bellhousing
  168. F/S Carter AFB Carb 3721 SB 327/300 hp
  169. FS: Used Moroso Deep Sump 6 QT Oil Pan with Matching High Volume Oil Pump/Pickup
  170. Old Corvette Rear Shock Giveaway
  171. 67 vent window crank
  172. WTB Fram for 1966
  173. WTS 1958 through 1962 Gauges
  174. F/S 1960 gauge cluster
  175. WTB Halibrand Wheels
  176. WTB Vintage American Racing Wheels
  177. WTB unusable c2 front bumper cores
  178. Original '67 Bolt On Wheels
  179. F/S 1958 Fuel Injected Block Only
  180. *WTB-Ramhorn Exhaust Manifolds *
  181. F/S - Trailing Arms from '67 Corvette
  182. F/S '63/4 Disc Brake Conversion Kit (4 piston calipers) -never installed
  183. For Sale: Rear bumpers off my 65 coupe.
  184. Cans r-12 refrigerant
  185. 53-55 Convertible Top Value
  186. F/S 58 FI 283 High HP Block only
  187. New Rear Crossmember
  188. Wtb :3873858 427 425hp Heads
  189. www.epowershops.com CHECK US OUT!!!!
  190. Mallory dist.
  191. C2 Clear Plastic Cupholder...........
  192. wtb 63 swc rear window stainless.
  193. FS-2" Exhaust Manifolds
  194. F/S: Corvette Books:
  195. Help finding vendor...
  196. Restorable 1961/62 hardtop
  197. FS: Small Parts/Pieces Storage Bin with 4-Removable Drawers -IN OHIO
  198. Nice set of original 63/64 Western Knock Off Wheels F/S
  199. 66 removeable hard top
  200. Nice set of original 63/64 Western Knock Off Wheels F/S
  201. WTB - 1960 Harmonic Balancer
  202. WTB 901 & 902 Exhaust Manifold
  203. 56 hardtop
  204. WTB Fuel Pump for 67 L79
  205. F/S '66/'67 462 heads and other C2 parts
  206. Special 10% discount from Long Island Corvette Supply Inc.
  207. WTB Fuel Pump #4657 for '64 300hp vette
  208. Wtb Rear Frame Crossmember '61
  209. WTB: 3858174 Block
  210. FS: Used original dated '63 SWC Rear Glass
  211. 66, 67 rect port BB F/S
  212. FS:Edelbrock Performer RPM Aluminum Cylinder Heads with ARP Pro Series Bolts
  213. WTB : Carter AFB CARB : 3461S
  214. Wtb: 3873858 427 Heads
  215. Wanted rear window stainless
  216. WTB Original Firestones WW
  217. FS: C1 Interior Parts
  218. WTB Pre April 55 drivetrain/parts
  219. '66 Small Block Hood & 79-82 Modified Seat Shells
  220. NOS Spears
  221. 396 hood
  222. FS (PA): Kwiklift
  223. 1968-1971 Big Block Heads
  224. 1965-66 oval port heads
  225. Coil Spring Spacer
  226. FS-64 Vette misc
  227. WTB: 62 Intake Manifold #3795397
  228. WTB Exhaust Manifolds 3797942 & 3846563
  229. 1966 Corvette 427 390HP Cylinder Heads
  230. WTB Glove box door hinge
  231. 4 Sale - New Offset Trailing arms
  232. Fuel Pump
  233. 1962 serial #530-870 block! J of 1961 date code
  234. Big Block Dated Water Pump
  235. 66 Conv Frame
  236. WTB-Glas-Ra Fiberglas Book
  237. WTB April 1966 Starter and Alternator
  238. WTB 1966 Convert frame and top
  239. WTB 1966 Headlight assembly
  240. Original GM Quarter Panels $600
  241. F/S: 1963 Corvette auxillary hardtop....notched.
  242. F/S: K/O wheels and Coker redline radials.
  243. 64 exhaust wanted
  244. FS 4 speed shifter for Muncie
  245. WTB Power steering for '65 roadster
  246. WTB 61 Hardtop
  247. 1967 "948"" Intake Manifold 427/390
  248. WTB clean air tube 65 BB
  249. WTB Stahl tach
  250. WTB stock shifter for 4sp. '62
