View Full Version : C1 & C2 Parts
  1. 420+ HP/TQ 350 – Hot Cammed Full Roller Turn Key Motor - Never Fired
  2. WTS 1958 to 1962 Guages
  3. WTB 66 Big Block 427 Hood (no repros )
  4. inner fender skirt
  5. F/S 61 Harmonic Balancer
  6. 1969 3931063 Oval port cylinder heads - $250
  7. Need Help 63 Part
  8. windshield plus seal
  9. WTS 3782870 A55 block
  10. WTB: 1957 Harmonic Balancer
  11. WTB 66 ORIGINAL rt dash pad
  12. F/S Kelesy Hayes wheels.....
  13. 15% Off All Weatherstrip!
  14. WTB: 63-67 Convertible Deck Lid Hinges
  15. For Sale : Console plates 64-67
  16. For Sale : 67 back-up lamps
  17. WTB 64-66 Seat frames and tracks
  18. Wanted: pushbuttons and knobs for '58 Wonderbar radio
  19. WTB: expansion tank mounting brkt
  20. WTB 64-67 4-speed console
  21. 7 blade fan/clutch/Heater box parts/manifolds/steering wheel/bb valve covers/carb/alt
  22. FS: 60-61 red door panels
  23. Two tickets to Sebring - 4 days with Corvette Corral parking
  24. 63-7 misc parts
  25. Midyear Assorted
  26. harrison tranny cooler
  27. WTB 62 original Red seats or seat covers
  28. WTB C-2 left side headlight motor 63-67
  29. WTB: Starter for 65 396
  30. 59 frame dimensions and weight
  31. WTB - 1962 black seat bottom
  32. WTB 66 Gray quater panels
  33. F/S BBC #208 Head 396/425 Treasure!
  34. Free - 1963 Luggage Stop
  35. wanted dated 2818 for 65.
  36. WTB C-1 Parts
  37. f/s 64-67 dark blue seat belt webbing
  38. want to trade for bolt on wheel, lh 1/4 panel
  39. Borg Warner T-10 for 59 - source of supply?
  40. WTB 67 steering shaft
  41. F/ S metal 300 hp valve covers with new decals
  42. f/s 63-67 harrison expansoin tank
  43. F/ S 63 - 67 radiator support (small block)
  44. # 403 Aluminum Bellhousing (small Block)
  45. 66 -67 Fan Shroud (small Block)
  46. F/s 63 - 67 Harrison Radiator With Tag
  47. F/s 1965 - 1967 Small Block Hood
  48. New Parts for Original Ones
  49. FS: 1 65-66 repro KO wheel New $200.00
  50. WTB Exhaust Manifold #3750556
  51. FS Mid Year Pass Door Shell
  52. New balancer for sale
  53. new black 3-Point Seat Belt
  54. Holley 670cfm street avenger
  55. Want.bumper,brackets,vent.reg.
  56. WTB 64 Dual Snorkel Air Cleaner
  57. Water pump numbers
  58. WTT Delco 824 horn relay for Delco 837
  59. WTB one bias ply 7.75x15 redline
  60. WTB 1954 side windows + hardware
  61. 1959 radius arms and frame bracket
  62. 67 Redline radials and repro 15x6 Rallys
  63. WTB 63-67 RH Headlight Motor
  64. 67 repro bolt on Wheels and WW radials
  65. F/S 1966 427 #3869942 One Year Production For Corvette
  66. W T B 66 fan shroud
  67. FS: 66 vent window frames convertible
  68. Solid Axle and Mid Year Parts for sale (body & drivetrain)
  69. WTB - vent window regulator for '66 vert
  70. WTB: composite rear spring
  71. WTB: After Market C-2 Hood
  72. WTB: Set of 1965 Steel Wheels
  73. FS: 61 T-10 Close Ratio Transmission
  74. Rally Center Caps.
  75. let's try this again
  76. WTS 1965 3783870 327 Block Dated A55
  77. FS- Rebuilt 1963-1964 AM/FM radio
  78. FS 57-62 Gas Tank
  79. FS 1965-1967 4 speed shifter
  80. shifter knob
  81. powerglide trans.shifter for sale
  82. Fs 64 Hood
  83. WTB-Operating Instructions-Wonder Bar '62
  84. F/s 58 Parts
  85. f.s. 67 big block parts
  86. 2 new 65-82 rear brake rotors
  87. FS: Brake Packages for C2/C3 Corvettes
  88. rare dual quad setup 1956/57
  89. Door Hinges needed!
  90. Mid-Year front clip
  91. FS- TP Tools Gold Finish HVLP Paint System
  92. 1956 corvette factory bellhousing
  93. WTS Repo Knock Off Wheels
  94. 64 Corvette starter wanted
  95. Just When You Think There Are No More Deals Out There…
  96. Wanted: '66/'67 327/350 Throttle Spring Bracket
  97. WTB 66 Driver Front Fender
  98. WTB 65 Orig. bottom seat cover.....black vinyl
  99. WTS 1956-1966 NOS Corvette Owners Kit
  100. Direct Bolt Knock Off Wheels - DBKO
  101. WTB: 63-82 Lower A-Arm Bar
  102. wtd posi rear 56-64 chev
  103. C2 small block Hooker headers
  104. WTB 68 Tele coumn
  105. Wtb 63/64 Knockoff Rims
  106. WTB: 1960 Convertible Top Hardware
  107. 348
  108. FS: Misc. C2 parts $200/bo picked up in N. Fla.
  109. 63-67 HURST Shifter & Installation Kit
  110. F S - Big Block Stinger Hood Trim NOS ***NEW***
  111. WTB Windshield Weatherstrip
  112. 1960 front clip
  113. 692 heads needed before B-3-0
  114. WTB 65-66 CORVETTE CONVERTIBLE FRAME (Vette Products)
  115. 61 gages
  116. need tri carb/dave 351 c-4blot fs.
  117. F/S 1966 427/425hp 3869942 4 bolt block + crank & rods
  118. WTB: Hooker Sidepipes-Used or New
  119. 66 and other Corvette and GM parts: Cleaning out the garage!
  120. Wanted: 1100696 Alternator (66 425 Corvette)
  121. F/S C1 Parts
  122. Almost complete rebuilt rear suspension
  123. FS: '63 to '65 front license bracket
  124. FS 1963 4 Speed Console All Five Pieces
  125. W.T.B 66 bumpers
  126. 63-67 s/b exh mans
  127. Muncie M21
  128. WTB - 1957 radio bezel
  129. WTB Vent Window Gears
  130. F/S Delco Voltage Regulator-early 1965
  131. Lake Park Auto Machine , West Palm Beach, FL
  132. needed red seats for 57
  133. WTB, 1956 3731762 cylinder heads
  134. '66 Dash cluster FS
  135. Help identify this Holley
  136. WTB: AL Corvette Script Valve covers-No Casting Flaw thru O
  137. Dual point dist. for 62
  138. WTB 58-62 (3-4) gear Linkage, T-10
  139. WTB: pinch welts and window trim pieces
  140. Correct mesh on A212CW air filter?
  141. Free BB Headers
  142. WTB 66/67 Non/Air Inner Heater box
  143. Wanted to Buy for 66 427/390
  144. 1953/54 motorama hardtop corvette
  145. FS 3310 Holley
  146. 63 Corvette Luggage Stops (2) For Sale
  147. wtb rims for my 67
  148. nos exh man 3872778
  149. WTB. Cut up 67 Hood frame ..Wrecked Stinger?
  150. WTB 3815 Holley
  151. WTB Rim for my '62
  152. FS- BBC intakes and new Centerforce clutch
  153. 66 & 67 Posters
  154. F/S 1967 Corvette Block 3892657 April 67
  155. Wanted: Powerglide Yoke
  156. 1967 #462 Small block 2.02 valve heads
  157. 1963-67 Corvette Hardtop F/S
  158. C1 Parts for Sale
  159. 63 Vette Aluminum Radiator
  160. WTB '67 BB Valve Covers
  161. For Sale-Misc mid-year stuff
  162. WTB...61 Rubber Trunk Mat ...Black
  163. 283 heads needed 692 1960 a-0 or b-0
  164. F/S miscellaneous new C2 door panels
  165. WTB Pillar weatherstrip retainers for a 66.
  166. '58 through at least '63 exhaust manifolds
  167. WTB 1964-1967 Headlights
  168. WTB Correct Radio for 1963 Corvette
  169. Wanted: 1107365 Starter (67 435 Corvette)
  170. Wanted: '58 T-10 4 speed transmission
  171. Wanted: '54 Starter
  172. Need '58 antenna
  173. Mint L88 L89 Heads_ Ebay No Reserve Ends Tonite
  174. 1963 Corvette Dash Cluster
  175. 1965-67 Corvette Dash Cluster
  176. WTB: '66L-'67 seat belt retractor boots
  177. WTB - 1956 / 1957 Corvette body.
  178. 60 hood,hard to find
  179. Free 3783244 intake - P/U in High Point, NC
  180. Wanted: '57 FI axle link
  181. WTB: 2870 block
  182. FS - 1963 heater
  183. WTB 427 exhuast manifolds for 1967
  184. WTB White 67 Interior Parts
  185. WTB: Lacquer Paint, Marina Blue and Rally Red
  186. Tremec TKOs new,and related parts.....
  187. Factory Big Block Front Springs 1966 1967
  188. WTB 60 vette oil pan
  189. wtb various '66 parts
  190. WTB - Jack handle
  191. F/S Hockey sticks....
  192. Holley carbs
  193. Wanted: stock jack for 67
  194. wtb LH pincher trim cap
  195. f/s composite spring
  196. Front Coil Springs Needed for my 64
  197. Wtb Front Outer Bumper Braces
  198. WTB 2 1/2 Inch Exhaust Manifolds
  199. 1998 c5 LS1 for sale
  200. WTB or Trade: 3:55/3:70 Posi Differential
  201. wtb 61 parts
  202. WTB your old steering wheel 1963-67
  203. Saw this in houston Craigslist
  204. WTB 3755550 heads
  205. Set of 8 JE Dome Forged Aluminum 400 SBC Pistons
  206. wanted 6 cylinder engine mounts
  207. 65 / 66 power antenna core
  208. 65-67 Corvette B. B. Heat Riser Valve
  209. 65-67 Corvette Seat Back Chrome
  210. 63-67 Corvette License Plate Bar
  211. Wanted: 1962 complete engine
  212. Wanted: 67 Corvette Parts (Alternators, Starters, and A.I.R. Smog)
  213. WTB-'64 R.H.Inner fender skirt
  214. 1966 Corvette parts
  215. 1967 Corvette Block with Double Hump Heads
  216. WTB Seat Track
  217. WTB '63 Lower L.H. A-Arm
  218. wtb 67 rear fenders
  219. WTB 454 exhaust manifolds
  220. FS 1961?? 283 short block 3789935
  221. Want to trade 66 hubcaps for 65 hubcaps
  222. Tremec 5 speed driveshaft/yoke FS
  223. WTB: 2870 and/or 739
  224. 3904351 blocks for sale or trade
  225. WTB air cleaner assy
  226. WTB - vent window regulator for '66 vert
  227. After Market Parts. Any value??
  228. FS - Spark Plug Wire Set, Stainless Braid, BB
  229. F/s Wtb A/c Delco 12 Battery
  230. WTB: Jack for a '64
  231. WTB, Any 265 Chevy Motor
  232. WTB 66 Black Ca Plates
  233. C1 engine support
  234. 67 BB stinger hood original
  235. WTB: 63 Master Cylinder
  236. F/S: 2-1/2" Exhaust Pipes
  237. FS: Quanta Fuel sending unit
  238. 67 front clip- Sermershiems new
  239. FS: 67 4spd console w/ power window hole
  240. new red 67 roadster sunvisors and hardware
  241. FS: Widened rear quarters for C1 '56-60
  242. 1965-1966 Center armrest black original
  243. 1965-1966 White Interior
  244. 1965-1966 BB spark plug wires NEW
  245. 1964-1967 Stock 4 speed Shifter
  246. 1958 Texas License Plates for sale
  247. For Sale 64 Vert
  248. Shopping List of Parts Needed!
  249. 63-67 Caul Hood
  250. T.i. Distributor And Box
