View Full Version : C1 & C2 Parts
  1. meanest muffler for 67 390 hp??
  2. USED 66 seat covers (black leather + foam)
  3. 1961L original factory 2x4 unit
  4. WTB American Racing Wheels
  5. Heater Box "Y" Duct?
  6. WTB Original Mid-Year Air Cond. Duct
  7. WTB 3756519 block late 59 date
  8. 56' intake manifold #3735448 w/carb
  9. F/S-'63-'65 Coupe Headliner
  10. F/S Corvette Original Aluminum Big Block Intake
  11. 1965 Corvette motor complete
  12. What are they worth? Sidepipe covers w/rockers
  13. shifter knob
  14. Defrost nozzle
  15. 61-62 Convertible Hard Top FS
  16. WTB Late 1960 Trunk Mat
  17. 1958 Corvette engine wanted:Must Be #3737739#I,J,K
  18. c2 body jig
  19. 66 roadster
  20. Steel wheels, rings, and caps, 67 dated door panels 4 sale
  21. '58 Parts Needed-WTB
  22. FS 63-67 Corvette steering damper w/ brackets
  23. 63 parts
  24. 1963 SWC coupe interior parts wanted RED
  25. WTB: '65 BB Hood & Grille
  26. WTB power top assembly cover
  27. for sale: 53 vette model car
  28. WTB: Rear Rotor
  29. F/S Car Covers, Book & Carpet
  30. F/S power convertible top for sale
  31. Original Owners Manuals 1958-1989
  32. WTB air cleaner, ignition shielding for 61
  33. Trade, Black 61 belts
  34. WTB: Mounting bracket for TI Module
  35. WTB late '64 or 65-66 LH Driver door Conv
  36. WTB 1964 Corvette Full Flares
  37. 1963 461 big valve heads for sale
  38. Corvette Junk
  39. 12+bare corvette engine blocks {small block 1959-1969
  40. WTB 65 front grill
  41. Wtb: '67 Bb Hood
  42. 1965 roller
  43. 1963 and 1965 Shop Manuals
  44. 67 bolt on lug cover clips
  45. FS: Rare convertible top fasteners
  46. Fender flare with big lips
  47. More Corvette/Big Block parts 4 sale
  48. 62 Hood
  49. F/S Delco voltage regualtor...January 1967
  50. WANTED 391 heads
  51. WTB fender flares
  52. 67 Big Block Stinger hood
  53. wtb air cleaner
  54. Corvette Original Aluminum Big Block Intake
  55. WTB: '58-60 Heater Delete Plates
  56. 62 Build Book $15 includes shipping
  57. WTB 870 block dec, jan, feb, mar 62
  58. WTB C-1 Parts
  59. 1964-67 Corvette clock for power brake booster
  60. Wanted, 63-67 flares or widebody fenders
  61. WTB Front Aluminum Generator Plate
  62. Body lift strap new $55 shipped
  63. F/S NIB Delco Volt Reg 1119512...'63 Corvette
  64. wtb '65 396 motor
  65. WTB SBC Tri Power unit
  66. F/S 63-67 soft top weatherstrip
  67. F/S Front Carpet Set - 65 Coupe
  68. F/S Rally Wheels & Tires
  69. WTB Radio for 66
  70. WTB Full set soft top brackets
  71. w/b 63 Seat Tracks
  72. FS 1330 slip yoke (new)
  73. WTT: 66 TI AMP for Stock Tach Drive Dist.
  74. WTB w/s washer pump for 1962
  75. WTB Mid year wiper motor relay
  76. F/S anti-sway bars
  77. FS: 64 Knock Offs, So Cal pick-up.
  78. 58-60 Hardtop only deck lid.
  79. Bare Block 3782870 G134
  80. 1966 858's & other stuff
  81. Keisler Engineering
  82. FS- Lincoln Welder
  83. WTB or trade 63/64 coupe door
  84. WTB- '63 Water Pump Pulley
  85. wtb - 64 knock offs
  86. Holley Tri-Power Carbs: Help on date code/value
  87. WTB - One Western Knock Off Wheel - '66
  88. 61-62 Seats
  89. Dynomax Ceramic coated headers
  90. WTB: 65-66 Power Antenna mounting bracket
  91. Big Block Pulleys 4 sale
  92. WTB:Radio knobs/spacers
  93. WTS: New CC 61" tach cable for generator tach
  94. WTB 901 & 902 Exhaust Manifolds
  95. FI unit throttle bellcrank
  96. Ceramic Coated Headers for SB C2 & C3
  97. for sale - 63',64',65',66 steel valve covers
  98. WTB Heater fan switch/cable
  99. WTB 61 hood
  100. WTB several early 1964 engine components
  101. 1963-1967 parts for sale
  102. 1965-67 Corvette clock for sale
  103. F/S '65-'67 Exhaust Manifold
  104. Free '63 - ? rear spring giveaway
  105. FS YS code 67 rally wheel
  106. Non working 63 radio wanted!
  107. rear bumpers
  108. WTB - Carter 2X4
  109. WTB-(1) original 1965 Kelsey Hayes knockoff wheel
  110. '65 Maroon Sunshades for Convertible
  111. WTB 3.07 rear
  112. f/s...1963 rear end 4:11 gears original...$750.00
  113. 67 Date coded door panels and 67 rallye wheels F/S
  114. F/S-'63 Parts
  115. For Sale: C2 Front-End, Hood and 'T' Armrest
  116. For Sale: Two 1967 Press Molded Fiberglass Big Block Hoods
  117. WTB Early 63 fuel door assembly.
  118. WTB original clear floor mats for '67 survivor
  119. F/s Wipermotor....w/pic....
  120. WTB Set of Western Wheel Minilites
  121. F/S '63 NOS rocker trim
  122. Pair 1957 & (1) 59 head on e bay
  123. Buy or Trade: 61-62 for 56-60 Antenna
  124. WTB...orig. black 64-66 Seat belt webbing and 65-66 boots (receivers)
  125. F/S Orig. 53-62 Service Guide (manual)
  126. F/S New Repro White Sunvisors for 65-66 Coupe
  127. WTB...upper control arm shaft (square boss)
  128. F/S 54 Exhaust Tips & Carb
  129. '65-'66 RED seat belt boots (new)
  130. WTB 1962 Trunk Mat
  131. WTB 62 Main Harness
  132. WTB 65 Side Exhaust
  133. WTB '63 parts
  134. Wanted: Early Big Block Timing Cover
  135. Rc Scatter Shield
  136. WTB 57 Parking Brake Indicator Light
  137. Factory 2x4 setup for 61 283
  138. 66/67 Radiator Support
  139. WTB: 64-65 Coupe rear power vent cable
  140. WTB distributor
  141. 1963 Parking brake lever resto.
  142. F/S Voltage Regulator 5G Rebuilt
  143. WANTED: used chassis springs from '63 - '64
  144. WTB Good hood hinges for a 61 or info
  145. FS 283/327 Motors, blocks
  146. Wtb 66/67 T.i. Finned Exterior Housing
  147. WTB 66/67 BB Exhaust Manifolds-PAIR
  148. 327 blower engine, 400 transmission and Gearvender overdrive unit
  149. Looking for a few C1 parts....
  150. For Sale:2 1962 1107242 Restored Starters
  151. WTB: '58-'60 Rear Deck Lid - Hard Top ONLY
  152. FS: '56 rolling chassis
  153. NIB Corvette 427 Side Fender Emblem
  154. Wtb Mint '67 Vinyl Hardtop
  155. NOS Exhaust Manifold 2.5" Heat Riser Valve
  156. WTB: 65-67 Guages
  157. Wtb '67 Squareport "391"head
  158. needed 4:11 posi for C1 Corvette
  159. wtb 66 corvette smog diverter valve
  160. 1966 Exhaust Manifold
  161. F/S 1965 original rear compartment carpet.
  162. Seeking Rt. Front Bumper and question...
  163. WTB 53-4 Old Dead Battery Case/Cases
  164. WTB Holley float bowls
  165. WTB 1965 Coupe pass.side windsheild molding
  166. 67 Reproduction Bolt On Wheels Wanted
  167. 67 Corvette Hood Wanted
  168. 67 Corvette Wheels Wanted
  169. WTB-3737739 Block
  170. WTB 64-65 rear blower cable
  171. WTB '65 Coupe pass. side windsheild molding
  172. WTB: 4 goldline tires that will pass ncrs
  173. WTB - C1 upper windshield S/S moulding
  174. WTB 427 steel crankshaft
  175. old 55 only parts wonted
  176. WTB Reverse Idler Gear for Muncie M20
  177. Radiatior, you pay shipping
  178. WTB: '60 Hardtop
  179. 2818 Carb and 621 Bellhousing
  180. WTB more 56-57 parts
  181. 692 Heads
  182. WTB - 1960 hood
  183. 355 Posi Rebuilt W/ Spring cover Traction Bar and mounting hardware
  184. FS: '58 Hood (Aftermarket)
  185. FS c/1 parts
  186. FS 64/65 2 1/2" exhaust manifolds
  187. WANTED: '62 Corvette parts
  188. Engine Wiring Harness Inquiry
  189. WTB 62 kick panels deluxe
  190. 58-62 gauge housing
  191. WTB 67 A/C Receiver Drier
  192. FS 61/2 license plate bezel-58/60 lic lamp assembly
  193. Fs 64/65 Glove Box Door
  194. 327 cu. in.
  195. deleted
  196. Mid year chassis and parts
  197. Wanted: 1958-60 rear bumperettes
  198. F/S 65-67 inst. Cluster
  199. WTB: '65 Ignition Shielding
  200. WTS LS-5 Intake
  201. 1965 327 oil pan f/s
  202. Rolling 67 Frame with drive train.
  203. WTB: '67 427 hood scoop trim
  204. WTB 58 2x4 carbs F&R
  205. WTB 3748770 58 heads
  206. 58/62 Front Grille Moldings
  207. WTB C-1 parts
  208. FS: New Perma-Cool 10" Radiator fan
  209. WTB rear bumper support, 56-57
  210. 1962 Rolling Frame
  211. For Sale 56-61 Jack With Handle
  212. Wtb Orig. 1965 Dash Pads
  213. 66 327 block PN 180 Std Bore
  214. WTB Original 61 315 hp Harmonic Balancer
  215. Trade Tranny.
  216. 6bestvette5
  217. 519 Bare Block FOR SALE
  218. wtb - 63 shifter & 4 spped trany
  219. WTB air cleaner for 65
  220. Wanted C1 drive pulley for windshield washer
  221. 1957/8 3speed manual shifter
  222. 1964/67 manual shifter
  223. WTT: Your stock 65 radio. working or not for ...
  224. WTB..1107242 starter dated Sept, Oct, or Nov 1962
  225. Several C2, C3 and C4 parts for sale
  226. Aluminum B.b. Heads
  227. WTB 64 shifter and rear filler panel
  228. 4 Sale LS-6 454 Shortblock
  229. WTB Jack for 62 Vette
  230. WTB bellhousing
  231. Knock off wheel lock pins WTB
  232. Corvette News for sale
  233. misc. C-1 AND C-2 parts
  234. Original 65 taillights
  235. ORIG. Corvette Owner's Manual Bag
  236. C-1 Driveshaft F/S
  237. C-1 Driveshart F/S
  238. C1 Frame For Sale
  239. How Much Can I Get for 1962 Hardtop ?
  240. Brand new C-2 parts for sale
  241. 1958 T10 Trans
  242. WTB 2x4 intake 3739653 for 57-61
  243. mid year parts
  244. '65 - '66 parts for sale
  245. Trade 63 340 hp air cleaner for 64, 65 unit
  246. 1965 Dbl Hump Heads
  247. Wtb 1962 Doors
  248. WTB air cleaner
  249. FS-67 Corvette Emblem/E-brake Console/door sill plates
  250. FS -NEW Tach Drive HEI Distributor
