View Full Version : C1 & C2 Parts
  1. FS: Mildon aluminum water pump NIB
  2. WTB 300 horse intake....
  3. For sale rebuilt 1963-67 Corvette steering box
  4. f.s. 63 and 64 clutch housings
  5. WTB 57 FI air cleaner
  6. FS: 1964 Corvette Shop Manual Supplement
  7. WTB: ZZ4 heads... or?
  8. WTB Script Valve Covers
  9. BRAND NEW NOS Distributor #1110985
  10. Wanted Right (Pass) Tinted coupe Glass
  11. Holley 4160 Electric Choke for sale
  12. WTB 1965 Horn and Tire Jack
  13. Misc '63-'67 parts
  14. Hays 10-130 Billet Steel Flywheel 1955-1985 Chevy 30 Lb $175 Ship
  15. 1961 1962 Corvette seat foam
  16. 1963 Corvette interior parts
  17. '65 rear end pulled from a '68
  18. 1957 Grill Bar Installation Help
  19. WTB set of valve springs 3970627 / 12371061
  20. wanted starburst for bolt on
  21. F/s, l82 valve covers
  22. C1 Nos Parts
  23. Need To Buy Fast
  24. 63 corvette steering box
  25. Selling 60-62 Complete Fan Shroud
  26. 1953 Internal Engine parts needed
  27. 1963 Corvette master cylinder for sale
  28. 1963 only 421 bell housing....nice
  29. Orig 67/68 Jack, Restored, Dated 7E (May 67)
  30. F/S 67 Interior Parts, White Door Panels, Red Seat Backs, More
  31. WTB 1959 radiator shroud complete
  32. WTB: White 67 Convert Interior Door Panels
  33. WT Trade Midyear Latches for 56-62 Hardtop Latches
  34. 1963 vin 30867s110290
  35. WTB 1962 FI Distributor Shield
  36. Misc small parts; mostly midyear
  37. 65 FI engine
  38. wtb left window glass mounting bracket 67
  39. 1953-55 right upper fender repair piece
  40. 1967 Corvette tri power K&N air filter for sale
  41. 1966 427-425HP Heads
  42. Selling VB&P 330# spring & mounting kit.
  43. WTB 57 original engine
  44. fs-c2 vent & window glass
  45. For Sale: 3774962 CASTING HEADS
  46. 67 Turn Signal Handle
  47. 67 Birdcage
  48. WTB: '63 Horns
  49. WTB: A long shot need '65-67 Door Jamb
  50. F/S 1963 hood
  51. WTB: Intake Manifold L72 for early build 66
  52. 3747038X exhaust manifold
  53. 1961 Chevrolet Corvette Intake Manifold
  54. Wanted 1953-55 Transmission Yoke
  55. WTB Fan shrouds '60-'62 lower
  56. Wanted Single SB 327 L76 Push Rod
  57. WTB Jack For 1958 Corvette
  58. WTB: Kwiklift
  59. FS 67 427 4-Bolt Block and 67 "391" Square Port Heads
  60. 1956 1957 Corvette tail lights For Sale
  61. C2 Parts For Sale, Can Deliver To Gettysburg NCRS
  62. FS 66-72 Air Cleaner assembly
  63. 63 corvette steering column
  64. WTB 53-54 Trans Tailshaft Housing & Output Shaft
  65. F/S: DelcoAir axial AC compressor w/clutch & pulley - NOS
  66. WTB '57 Clock
  67. 62 Distributor 340 Hsp Dual Point
  68. Mid year parts for sale
  69. F/S MidYr fender emblems
  70. 1959-62 Al Knoch black dash pad for sale
  71. 1963-67 Corvette chambered exhaust
  72. Manley 6.0" H-Beam rods
  73. '64 vert rolling frame, engine, transmission
  74. midyr Glass
  75. New mid-year coupe glass cheap
  76. Wanted; Clutch parts
  77. f.s.--66 & 67 rocker moldings
  78. 1963 Hardtop
  79. FS: Repro 1964 Owners Manual & Bag
  80. Polished BDS 6-71 Blower for sale
  81. F/S Original park light lens.....late 71, all 72
  82. f/s 57-62 hooker super comp headers
  83. F/S original camber adjustment bolts
  84. fs 63 nos turn signal switch
  85. FS: Tail Lights
  86. Exhaust Bezel Help
  87. WANTED: NOS 1963 Z06 air scoops/ elephant ears.
  88. WTB: NOS NON DOT Black wall tires--6:70 x 15"
  89. For Sale '64 Seats
  90. 58 Corvette heads or sale 3748770 E148
  91. FS power pack heads f21 63 896 complete
  92. 56 rolling frame
  93. 54 corvette project
  94. WTB 1967 TI Amp and BB Fan and Clutch
  95. fsorg 66&67 rockers
  96. Trade steering column-67
  97. 1967 AM FM Radio
  98. WTB Late 1957 Posi Rear End
  99. WTB - '65 DS wiper arm
  100. Trade Radial Redlines for Goldlines
  101. wtb 67 tri carb
  102. WTB 67 Headlight Circuit Breaker
  103. Birdcage rear pillar upright source?
  104. '60 Fuelie Ballast Resistor Options?
  105. 1957-61 Corvette 2x4 for sale
  106. Complete 58 powerglide setup for sale
  107. WTB 62 Driver side door post.
  108. FS 73-74 Coil Capacitor
  109. F/S Vette Vues Fact Book 63-67 8th Edition
  110. WTB 56-62 convert top latch parts
  111. 63 oil pan plug wtd.
  112. F/S 1957 short block
  113. WTB - U-Bolt Yoke / Stub Axles - 14016436
  114. WTB - 1963 Glove Box Door
  115. F/S Dogdish Hubcaps-used
  116. F/S Exhaust #778
  117. AC Delco PF 141 Oil Filters
  118. 56 Original Corvette Steering Wheel and Hub
  119. WTB 1964 seat frames
  120. zz 383 crate motor
  121. WTB 65' one piece front end
  122. wtb
  123. WTB - 1963 Spare Tire Carrier Tub
  124. 265/283 engine parts
  125. FS- 327/350hp L79 parts
  126. ls7 shortblock
  127. WTB C-2 Hardtop Rear Window
  128. f/s licence plates
  129. Wanted: ONE OEM C2 horn contact plastic rivit
  130. OEM Valve Covers 100.00
  131. WTT 1965-66 power antena
  132. WTB fuel pump fitting
  133. 1965 Corvette Sales Brochure
  134. 63 shifter linkages
  135. 64, 4 speed tranny,indy craigd list
  136. WTS - 64-66 Corvette Steering Wheel
  137. 4 bfg radials
  138. Wanting to sell dual fours & distributor
  139. WTB: Oil Pan for C2 SB
  140. Wanted: 245/50/15 tires
  141. FS Set of 63-67 hardtop interior trim
  142. Rally Caps and Rings, new
  143. WTB Fuel Tank Support
  144. Smallest request of the year!
  145. black 1964 texas plates
  146. 1967 Western Wheel Bolt On
  147. 1966 427 425 hp Short Block Assy, nice!
  148. WTB 2 Barrel Rochester Carb
  149. 1963 corvette 327 motor
  150. Fs.black 1965 ca. Plates
  151. WTB 67 BB Valve Covers
  152. Who's going to pate?
  153. 1965 327 parts
  154. c1 hardtop columbus ohio cl
  155. FS 1967 Rocker moldings
  156. Need body dolly San Antonio, Tx-surrounding area
  157. f.s. 64 guage housing
  158. FS 1965/66 Restored Tele Column
  159. f.s.acrylic lacquer paint
  160. 3:55 GM ring and pinion
  161. FS '63-'64 tires
  162. Holley 2818 Carb Rebuild Kit
  163. WTB rear window glass 65 coupe
  164. WTB: set of cove spears for 60
  165. FS 67 ANCO "Peaked" Holders
  166. WTB 1957 Wiper Transmission LH
  167. FS C2 Parts
  168. Best Dealer for Goldlines
  169. Wtb 63 early 340hp fan clutch
  170. WTB 63 split outer door belt rubber
  171. soft top brackets needed
  172. WTB 6:70/15 Wide White Tires
  173. 283 for sale
  174. Wanted: outer stainless door trim
  175. 63 -64 parts
  176. f/s center section for C2
  177. 1961 Generator-To-Alternator Conversion
  178. Good quality 66 rocker panels wanted
  179. FS: U-joints
  180. Lester casting line 62-67 valve covers polished
  181. FS 1962 340Hsp. Distributor
  182. 1965-1967 NOS hood skin.
  183. 1963 Corvette Hubcaps & 64-65 Exhaust Bezels
  184. 1966 427-425HP Square Port Heads
  185. 58to62 WINDSHIELD POST
  186. 65-66 GM Steel Wheel (s)
  187. FS 1953-1955 Six Volt Radio & Speaker
  188. C1 valve cover 7 fin script
  189. WTB Column Hazzard Knob
  190. F/S 65-66 Window & vent crank handel set
  191. F/s 63-65 air cleaner lid
  192. F/s 65 rocker panel mouldings
  193. F/s 64-65 original glove box door
  194. 1953-1982 parts & illustration catalog
  195. 66 AM/FM Radio For Sale
  196. Paging John lynch
  197. wtb a/c dash bezel and a/c dash housing
  198. 1961 Windshield Washer System
  199. 3899621 Bellhousing Big Block 11"
  200. c2 parts
  201. Hub Caps
  202. Spring anchor plate C2
  203. Brake line blocks 63/64
  204. Brake rubber hoses 63-66 C2
  205. FS 1953-1955 Corvette Hubcaps
  206. VERY NICE 65 exterior door handles
  207. 58/62 Courtesy light (new)
  208. New 63-65 rear deck emblems (GM)
  209. F/S 1960 Corvette 283 Rebuilt Short Block
  210. 66 rocker panel-free
  211. WTB 65-66 3-speed shifter
  212. wtb 63-67 coupe deck panel
  213. WTB Soft Top for a 61
  214. 65 outside mirror wanted
  215. ps box conversion
  216. c2 fiberglass
  217. C2 parts for sale
  218. 1966 vert red interior
  219. trade fan blades
  220. FS: 327 genuine GM water pump & crank pulleys
  221. '63 rocker mouldings
  222. Wanted: Thermostat Housing 3877660
  223. '64-'66 steering wheel
  224. '63 seat covers
  225. '63 nose emblem
  226. '63 door panels
  227. '63 door handles
  228. WTB: Dog dish hubcaps
  229. WTB: need one 67 trim ring
  230. WTB clear coupe side glass and driver vent
  231. wanted.63-64 Dir Bolt-on Knock Off Wheels
  232. 63 door glass-
  233. midyear nose fiberglass, bonding strip, and rear diff for sale
  234. WTB package tray for 1959
  235. WTB 3.70 ring and pinion for 64 or rear end
  236. wtb 56-60 rocker panels
  237. 56 Original Corvette Steering Wheel and hub
  238. Wtb 1967 l79
  239. FS 1963-67 Corvette Hurst shifter and linkage
  240. FS Body Lift & Disassembly Video/Workbook
  241. Wtb 65-66 left fender
  242. WTB Half Shaft Outer Flange
  243. WT block for 1961 Fi oct 1960 car
  244. WT block for 1961 Fi oct 1960 car
  245. Wtb 56- 62 wiper arms and bades
  246. Wtb 1962 spare tire cover
  247. Wtb 63 swc parts
  248. 3869942, L176 Corvette block
  249. late 62 seat belt buckles?
  250. F/S Black and Gold California Lic Plate Pairs
