View Full Version : C1 & C2 Parts
  1. Fs 1958-1962 deck lid hinges (pic)
  2. '68 Corvette motor
  3. Intersesting 61 on C4 custom chassis
  4. C-2 Fuel Injection Plug Wires NOS
  5. C-2 headlights 95% complete
  6. 58-60 Front clip
  7. WTT-FI Distrubutor
  8. FS, 1967 BB Ignition Shielding
  9. Looking for a 1965 stv valve
  10. WTB--Knock Off Wheels
  11. WTB Carlisle space
  12. WTB: Original Distributor band 1111156 for 66
  13. Deleted
  14. wtb 62 rear springs
  15. 1955 corvette body for sale $4500 cash
  16. F/S Quartz Halogon headlights
  17. F/S small block hoods
  18. 62 trunk latch housing needed
  19. 63-7 rag joint bolt needed
  20. FS: 1967 Aluminum Heads PN 3904392
  21. FS: 1965 396 425 HP Aluminum Intake
  22. FS: Original rear valence 1965
  23. FS: 1967 Corvette Hardtop
  24. 462 Heads FS
  25. For Sale 56 to 62 Hurst Shifter
  26. For Sale 56 to 62 Traction Masters
  27. Comp cam
  28. 66 Big Block Radiator Support Needed
  29. wtb... 65 327 3859326 water pump
  30. WTB Original 62 Deck lid or upper skin
  31. FS: 63-67 New Sunvisors 63-64
  32. 1960 front & rear suspension complete
  33. Trade! Nassua Blue Lacquer for Marina
  34. Custom AutoSound USA-1 available really really cheap
  35. fs: New Black leather jacket--Size 46
  36. 58-61 Intake Manifold
  37. wtb 58-62 wiper motor mount plate
  38. 56 Original Corvette Steering Wheel and Hub
  39. FS 58-61 Upper Dash Fiberglass
  40. f/s 1966 427/425 alum intake
  41. f/s rochester 4bbl.#7019010
  42. F/S Tinted Driver's side Convertible Window
  43. F/S NOS Holley gasket set
  44. Trans shop in NJ
  45. '54 Plasticon Hard Top Medallions
  46. FS 4 NOS 1966 Wheel covers with new spinners and spacers
  47. ls conversion mounts
  48. WTB license plate light
  49. FS- 454 Complete Motor
  50. WTB: BB Pulleys
  51. F/S - Midyear Tire Tub
  52. Hard Top for Sale 63-67
  53. WTB: 1966 hubcaps
  54. WTB Automatic choke parts for Carter 3461
  55. 1956-60 Hardtop weatherstrip kit
  56. WTB Convertible Vent Window Frame
  57. REAL midyear parts (booster, rally caps, steering wheel)
  58. sidepipe headers
  59. WTB 63-65 inner fender
  60. FS Craigslist
  61. 57 f.i.set-up
  62. f/s 57 f.i.emblems and flags
  63. F/S Lower radio consloe bonding strip 58
  64. F/S C-1 pass. trapeze latch
  65. F/S 58-60 Taillight housing
  66. F/S Grey Tach cable housing C-1
  67. F/S 58-62 Drip Rails
  68. F/S Pass side C-1 Door Fire wall bracing 58
  69. F/S C-1 Cowl Vent lever &hinges
  70. F/S DR. side trunk deck hinge 62
  71. F/S Trans crossmember c-1
  72. F/S Defroster ducts 58-62
  73. F/S 61 Female Hood Latches at firewall
  74. For sale L-98
  75. photos of the inside of a '63 oil pan
  76. WTB .... Complete Heater assembly 64-67
  77. FS: Original 1967 4:11 Rear End Posi
  78. 63-67 original bumpers
  79. 63 steering column
  80. WANTED steering Rack complete C-1
  81. F/S 58-60 Style Guage Housing
  82. F/S 3774692 Heads
  83. FS 63 booster
  84. WTB: '66 Drivers lock pillar cover
  85. 3X2 intake-carbs-air cleaner---400hp
  86. FS: caliper cores
  87. F/S 67 391 Heads, Jack, Trim Rings, White Conv Door Panels; NCRS Nationals Delivery
  88. C2 Hardtop Stainless Blowout
  89. FS 68-69 #4055 Center Carb
  90. 1966-67 Square Port Heads and Tripower Carbs
  91. WTB. 1962 Aluminum Powerglide
  92. WTB ; 53-55 drivers seat frame and tracks
  93. wtb duramat fort c2
  94. wtb 66=67 front grill
  95. WTB Original 264 Coil
  96. WTB: 63 radiator support
  97. Generator parts
  98. 1963-1967 Parts For Sale...New, Used, Abused...I'm Gone
  99. C2 LH Window Regulator
  100. WTB:63 Z06 Master cylinder
  101. 55 power pack heads
  102. 1963-1967 Parts For Sale...Hundreds...New, Used, Abused
  103. For Sale 002E Voltage Regulator 1962
  104. FS: 1965 Corvette Hardtop for Vert
  105. Kwiklift w/two center bridges
  106. Rally Wheel Caps, repro's
  107. WTB: Kwiklift
  108. FS 68-69 #4055 center carb
  109. WTB Orig. 1111258 Distributor Band
  110. F/S - Hooker Super Comp Sidepipe SB Reverse Flow Muffler Inserts
  111. 7' T-3 headlights wanted
  112. F/S 327 Block "L 28 2"
  113. WTB 65-66 Big Block Spark Plug Shields
  114. WTB. 1957 Upper Rad Hose Clamps
  115. WTB 65/66/67 Original Bright Blue Front Carpet
  116. * * T R I - P O W E R * * Carbs For Sale 1967 1968 1969
  117. 1964 to 67 wheel tub
  118. 1961 Hartop for sale, dissasembled
  119. FS 1964 complete inst cluster and housing
  120. carbs-3059-3461-3721
  121. FS 58-62 finned valve covers
  122. 1961 283
  123. WTB 58-62 upper nose panel
  124. 1963 fuel injection unit /air cleaner / s tube forsale
  125. 1967 Trico wiper blade holders - FS
  126. All sorts of suspension parts FS
  127. WTB: Spare Tire Board for 1961 Roadster
  128. F/S '64-'66 Steering Column Collar
  129. Corvette Carlisle nice spots available at reduced cost
  130. F/S MidYear Headlight Supports
  131. F/S MidYear Hardtop Trim Piece
  132. WTB: GM motor mounts, GM # 6258154
  133. WTB 61 Parking Brake Switch
  134. F/S 1961 FI Unit+Distributor 7017320 Restored
  135. Wanted: 1963 Corvette L84 Fulie Dipstick
  136. FS intake manifold 3890490
  137. 63-7 front stabilizer bar mount brackets needed
  138. WTB: two 66 sb radiator shroud U nuts
  139. Wanted: Broken Headlight Micro Switches
  140. WTB 63-67 Big Block Exhaust
  141. 1965 SB Hood
  142. Own a pair of classics
  143. WTB: Hard top
  144. 283 heads
  145. FREE Head Gaskets, bearings, etc LAST CHANCE
  146. WTB 1961 wiring harness or fuse block
  147. Hooker headers and exhaust system
  148. Rare valve covers
  149. Willcox New Summer Sale Starts Today!
  150. WTB Rims / Rims with Tires for Paint Booth
  151. Bra for 1954
  152. looking for 6 quart oil pan 1965
  153. C-2 corvette L88 flares
  154. FS: Used grille from '66
  155. need rear torque bracket for c1
  156. WTB carpet 63 coupe
  157. FS: 63-67 Tail Lights
  158. '54 part questions
  159. WTB 64-67 Ignition Shielding
  160. WTT: Anyone need a new 66 vinyl seat cover
  161. Wanted: 1961 Welded Rim and Jack
  162. WTB: Blue Door Panels for 66 w/electric windows
  163. WTB 64 parts
  164. WTB fan and fan clutch 60-67
  165. Misc mid-year stuff
  166. FS - 3-bar rally caps
  167. 1973 lt1
  168. Looking for a complete Block, early '59
  169. 63-67 custom autosound usa 1 radio
  170. WTB original Big Block Braided Wires
  171. 64-67 factory type hurst shifter handle
  172. 1966 gas lid door like new! orig? cheap yes!
  173. Wtb steering colum bracket
  174. Wtb door lock escutcheon for c1 or c2
  175. wtb c2 gas tank lid
  176. wtb 66-67 grill
  177. FS big block Hooker side pipe headers
  178. WTB original '64 dark blue seat cover(s)
  179. C2 radio side panels fs
  180. C2 radio side covers fs
  181. WTB - C2 Floor Mats
  182. I know there are some great C1 and C2's that need this tile!
  183. WTB 63 master cylinder
  184. For Sale: set of midyear Knock offs
  185. WTB 63 Hubcaps
  186. Fs 67 conv delux door panels
  187. Fs 67 conv doors
  188. 57 Rear
  189. For Sale
  190. FS C-2 parts
  191. WTB 3:70 Ring and Pinion For My 67
  192. FS 63-67 right rear bumper
  193. WTB a right side wiper transmission
  194. C2 Driver's Side Window Convertible Glass...
  195. Wtb
  196. power steering parts
  197. WTB; Pulley for p/s pump
  198. Halda speedpilot sports special - Corvette!
  199. Wtb!!!!!!!!
  200. Wtb 61-2 right front bumper w/new chrome
  201. 1967 GM Mark of Excellence Door Jamb Decals
  202. 65 FI spark plug wires
  203. FS - Richmond 5 speed trans
  204. Rally Trim Rings 15 x 6 $145
  205. WTB: 1967 427/435 Hp Fan Shroud
  206. WTB: 58 hood NOS or press molded
  207. 3810 Holley Carb 1967 350hp
  208. 65-66 GM Steel Wheel (s) Show Ready
  209. 1968-69 BBC #840 Square Port Heads and Parts
  210. FS 1953-54 Wonderbar/Speaker Restored
  211. WTB: '65 s/b fan shroud attachment bolts
  212. FS carter wcfb 3191
  213. Wanted 1965 ac compressor
  214. WTB...X member from C1.....
  215. t-10
  216. FS Mid Year Tub, Firewall, birdcage, trim and title
  217. FS 67 conv doors and 67 Marina Blue Door Panels
  218. Fs 69 #3659
  219. WTB: 3755550 heads
  220. lilblueribbon
  221. Midyear steering wheel & fan clutch
  222. F/S SBC Heads
  223. 57 Intake Manifold
  224. 1965 Complete Engine and 4-Speed
  225. 1964 Full Suspension
  226. 66 327 intake to pan
  227. 403 SB bell housing FS
  228. 1964 engine block
  229. Early 64 Drivers Door RAISED PAD
  230. HARTOP Silver Pearl-everything is new, including paint
  231. Original 67 Bolt On Wheels (4) with Extra set of NOS Starburst
  232. FS 1953-54 PG Output Shaft
  233. nov 64 heads
  234. FS - 1964 intake and carb
  235. LF: 1963 master cylinder with P/B option
  236. WTB- knock off wheel for 66 spare
  237. NOS GM Weatherstrips 55 & other Years
  238. Wtb mid year conv top latch (rh)
  239. C2 mufflers and manifolds
  240. wtb front windshield 65 vert
  241. Wtb mid year firewall and floors
  242. For Sale: '64 Ignition Shielding Parts
  243. '58 rear clip +
  244. motor FS 350
  245. posi traction 308 ham
  246. Looking for 66 Coupe driver side 1/4 vent
  247. WTB 67 "B" code rally wheels
  248. F/S #3817173 Finned Harmonic Balancer
  249. For Sale - My 1967 Parts Collection
  250. WTB Misc 56 Parts
