View Full Version : C1 & C2 Parts
  1. Holley List 2818-1 For Sale
  2. WTB 1963 Vette Starter
  3. new repop corvette valve covers straight across holes
  4. Wtb 66 Conv top frame
  5. WTB-56-62 Seat Bottom Cushions or Covers
  6. F/S: 1957-1961 Complete 2x4 245HP setup
  7. 1967 427 #351 Casting Block, #391 Heads and 6223 Crank
  8. F/S 1966 tele column
  9. F/S 64 seats and tracks
  10. F/S 59-60 Hardtop (Excellent cond)
  11. FS: spray paint - Alumi blast, Shock Absorber Gray, Krylon 1613
  12. WTB Any Walters Chevy Items, Hebron, OH
  13. WTT NOS 691C PCV Valve
  14. FS - 66 Seat Backs Original + Repro - Green
  15. WTB Gordon Wilson or John Geer Chevrolet
  16. FS 58-62 front chrome parts & shifter
  17. Jackson chevrolet westbrook maine
  18. F/S 1960 aluminum bell housing #3764591
  19. New L79 factory engine components. Heads, pistons, crank...
  20. F.S. '64-'65 exhaust bezel
  21. WTB Walters Chevrolet License Bracket Or?
  22. WTB '60 bell housing
  23. aluminum edelbrock performer with 327 fill tube
  24. WTB Outer Window Seal Moulding for 63 verte
  25. 1967 Chevrolet Rinshed-Mason paint chart
  26. 1967 Stinger Hood/Rear quarter panels
  27. wtb c2 am/fm radio
  28. wtb c2 rear license plate bezel
  29. Wanted: #326 Water Pump and 1111196 Distributor
  30. FS - Rally wheel center caps w/ 3-bar
  31. 1965 Corvette Swag - Texas Deal
  32. FS misc. 1963 parts
  33. F/S 327 Cast Iron Intake #359 Dated L214
  34. Softtop Blow out Sale 1958-1967
  35. F/S 61-62 Black Knoch Soft Top Assembly
  36. F/S 67-68 Steering Wheel Repro "Plastic"
  37. F/S 63 Black Leather Seat Cover Set New
  38. 1960 aluminum bell housing #3764591
  39. WTB: door posts & side windows for 58 race car
  40. 1957 Corvette air cleaner for sale
  41. VIDEOS-ring and pinion, auto painting, and Brakes and suspension
  42. F S C1 NOS Rr Crossmember
  43. 58-60 Grille bar and teeth
  44. WTB original air cleaner stud for 66 Holley L79
  45. For Sale, Real 3904351 BBC date code A247
  46. WTB: 1962 LH Engine Mount Frame Bracket
  47. 58 Trunk Iron Question
  48. Hooker SuperComp SideTubes/Exhaust
  49. Lakewood Bellhousing, 502 flywheel&oilpan
  50. WTB Black 61 dash pad
  51. Early 64 Driver's Door with Raised pad
  52. 2818-1 Holley Carb and 461 Winters intake
  53. Two 1965 Corvette Rims
  54. 396 427 starter motor
  55. FS 63-67 Headlight bucket pivot supports
  56. 53-55 dash pad
  57. 61-62 front springs
  58. For sale 16X7 AR salt flats
  59. Wanted: One good used 1966 black seat bottom (cover)
  60. LOOKING for 64 spair tire carrier
  61. 60-62 air cleaner base? WTB
  62. F/s
  63. Wanted: 67 Corvette: 5 Rally Wheels Large DC andTires if available
  64. FS Gauge Set C1
  65. WTB - Johnson Chevrolet license bracket
  66. wtb: hood release cable....
  67. FS NOS 63 rocker moldings
  68. FS 53-78 body and chassis parts and illustration manuals
  69. 1963 1964 corvette parts
  70. misc c2 parts for sale
  71. WTB 67 parking brake
  72. WTB 53-55 tail light bezels
  73. WTT NOS 691C PCV Valve
  74. Wanted: 1107320 Starter
  75. st. louis CL, dual 4, 1956, $350
  76. Wanted: DC or DG '67 Wheel
  77. FS C1 & C2 Parts
  78. F/S 67 Nose Emblem
  79. WTB - 396 Air cleaner
  80. FS: trailing arm bushing kits
  81. f/s 65 org holley carb
  82. WTB 1953-55 Corvette Body Parts
  83. 63 aluminun faced gages wanted
  84. FS: 6412223 Tach
  85. FS: C-2 (63-64) disc brake conversion
  86. Looking for a C1 or C2 resto-mod project
  87. WTB wheel cylinder casting 5459528
  88. FS Disc brake setup for 63-64
  89. Nice Red Midyear Vinyl Floor Mats and Red Carpet Floor Mats
  90. REAL 1967 Corvette Headrest Seats
  91. F/S 66-67 Rear Deck & 66 Front Hood Emblem
  92. WTB 1964 Corvette Clock
  93. WTB Four Redline 775-15 Tires
  94. Wtt nos 691c pcv
  95. Wtd: (3) Carter AFB Chokes
  96. WTB 1962 gauge cluster housing
  97. 4:11 rear 64-65
  98. F/S Miscellaneous C1/C2 parts
  99. Western 30 spoke knock off's
  100. F/S, pair of nice used 63-67 parking lights
  101. 1960 283 engine f/s
  102. WTB 1966 original Blue leather seats and dark blue carpet
  103. Beware this could be a scam
  104. FS C2 gas tank
  105. WTB 63 original steel wheels
  106. WTB: 1967 Big Block Rearend
  107. 1958 Corvette Parts and Components
  108. WTB match set of 3909802 heads
  109. WTB Thermostat Housing Bolts for '65 L78
  110. Wtb
  111. FS: Nolan Adams book #2 63-67
  112. 1962 Fuel Injection Unit w/Dist
  113. WTB Original 67 Glovebox Striker Plate/Bulb Shield
  114. 65/66 steel wheels
  115. WTB: 1962 Front Clip
  116. used gas tanks
  117. 67 teal carpet carpet in the GM box
  118. WTB jack nut 1965
  119. Wanted 1963 -67 soft top complete
  120. WTB original 67 Jack storage cover
  121. FS Wonderbar radio Bezel and C1 repo radio
  122. Trade or Sale
  123. FS 1963 Factory Hood Grills
  124. WTB 57 fi exhaust manifolds, 64 shifter, 57 fuelie block
  125. 66 Corvette Parking Light Pigtails
  126. WTB 63-67 Backup Switch
  127. FS NOS 66 Ignition Switch
  128. FS Original 66 Big Block Radiator NICE
  129. Wanted 67 Tele Column parts
  130. F/S 67 435 Heads, Cast No. "391", Dates L126/K226
  131. F/S 67 427/435 4-Bolt Block H186
  132. Matching Set 1967 1968 3917215 BBC 427 Corvette Heads
  133. 502 ZZ502 Big Block Chevy BBC
  134. WTB Original 65 Dr Dash Pad
  135. wtb a set of 4 15 x 8 minilites
  136. wtb fuel pump part
  137. WTB 66-67 Fan Shroud U-Nuts
  138. WTB L78 clean air tube 396/425
  139. fs c /2 drive shaft
  140. T10-1B 1960 corvette trans
  141. WTB Window track for 60
  142. FS C2 Radio Panel Screw
  143. WCFB 270hp Front Carb F/S
  144. F/S Complete Side Pipe Assessmbly Kit off a 67 located in NH
  145. WTB Walter Chevrolet Info
  146. WTB 1963 Brake Booster Brackets (1964)
  147. WTB C1 Rear Springs
  148. 63/67 bumpers
  149. WTB Harry Mann license plate frame
  150. Wtb 63 fi air cleaner hose
  151. WTB 1960 Rear Leaf Springs
  152. aluminum edelbrock performer with 327 fill tube
  153. F/s 61 rear clip
  154. F/S - Brand New Door Lock Retaining Clips
  155. MORE C2 Parts - Hardtop, J56 Brakes etc
  156. F/S - 1964 Original Exhaust Bezels
  157. WTB 65 white interior
  158. WTB 1963 hood, preferably with Faux inserts
  159. WTB 1963 seats, preferably all redone, Black
  160. WTB 1963 Water Pump from early 63, 327/400, #3782609
  161. WTB 53-55 Steering Wheel
  162. WTT: Have 66 Power Brake Dual Master; Need 65
  163. 64 Restoration venders/suppliers
  164. WTT 66 wiper motor
  165. AM/FM Radio come with power Antenna ?
  166. WTB 56 Radio Antenna Origninal
  167. 3856208 heads
  168. WYB 1961 Radiator support used
  169. LOTS of C2 parts...New and Used Shelf #1
  170. 1959-62 Corvette 5456022 Brake Master Cylinder
  171. FS set of 770 heads
  172. wtb 62 welded wheels
  173. WTB 1960 tachometer for fuel injection car
  174. WTB: "Soft Ray" Glass
  175. Body Dolly
  176. WTB: Flexplate for my 57 Powerglide
  177. Need 58 hood advice
  178. WTB: special snap ring pliers
  179. 56-60 wide rear fenders
  180. Gear drive and Comp Cam/lifters - BBC
  181. WTB 1959 - 1960 Driver's Seat Back
  182. WTB 64 hubcaps
  183. corvette wheel?? C number
  184. WTB 62 corvette window crank handle
  185. Mid year parts fs
  186. WTB 63 original coil
  187. FS:1963-67 Corvette Bumber Brackets
  188. 63-67 fuel tank sender-NIB-$50 shipped
  189. F/S 1964 AM/FM radio
  190. F/S C2 Floor Pan Plug Set
  191. FREE - C2 Firewall Insulation Attachment Plugs
  192. 1964 Door Sills
  193. F/S Aftermarket Air Cleaner
  194. F/S C2 Headlight Bezel
  195. F/S C2 Gauge Cluster Backing Plate
  196. 1964 Gauge Cluster Housing
  197. C2 Tail and Parking Lights - FREE if you pay shipping
  198. FS - Restored/Mint/Original 9 Leaf Spring
  199. Fs:60 fuel injected big brake car 1of 119
  200. FS:1963 Corvette Heater Core
  201. WTB: Tri-Power Carbs & Misc Needs for a '67
  202. WTB - 1 RE-POP 1965 ko WHEEL FOR SPARE
  203. Holley 1967 L88 carb center section
  204. fs 62 wcfb 3191
  205. Willcox Winter Sale: Includes Free Seat Cover Installation Offer!
  206. WTB 1 67 rally wheel Denver area
  207. Parts For Sale
  208. WTB 63 Rockers
  209. WTB 1960 corvette carburator
  210. FS: 63-67 Rocker Panel Support Brackets
  211. WCFB choke housing
  212. F/S original 66 master cylinder Great Shape!!!
  213. F/S Original AC Delco 40083 fuel pump!!
  214. WTT For 67 Headlight Switch
  215. WTB- 58-62 axles
  216. C2 parts for sale
  217. C-2 parts for sale
  218. FS: Parts Interchange Manual
  219. FS: 1958 truck lid
  220. Looking For 67 Speed minder Dash
  221. FS. Telescopic Column
  222. fs,396 top ign.shield;license lite bezel
  223. fs.org 396,other B.B. 7/8 front susp. bar
  224. Special High Performance 67 Corvette 327ci. engine
  225. fs.1964 Texas plates
  226. WTB Washington license plate 1962
  227. WTB 1960 Corvette Transmission
  228. WTB 67 rear deck emblem
  229. FS 696 Alternator - 6M22
  230. WTB - 1965 Fuel Injection Motor
  231. 1967 corvette
  232. WTB 63/4 LH Inner Fender fwd corner section
  233. WTB 55 12V Headlights
  234. Wtb harbor chevrolet-ling beach license plate frames
  235. 56 WTB Heater Assembly
  236. Head Question #3890462
  237. Soft top hold downs
  238. F/S Mid Year Seat Belts
  239. FS:1963-64 Window Crank Door Panel Spacers OEM
  240. FS: 3786208 Water Pump dated F76
  241. WTB 61 NOS Hardtop Rear Weatherstrip
  242. FS Carter AFB 3720 SA D4 Core
  243. Misc. C2 parts f/s
  244. FS: Edelbrock dual quad intake
  245. F/s, '66 nos wheelcovers
  246. Wtb 63-66 nose
  247. WTB intake 3799349, '62
  248. Looking for Corvette 770 X58 heads
  249. WTB 65 outside heater box
  250. FS TKO-600 Perfect Fit (Va)
