View Full Version : C1 & C2 Parts
  1. WTB 64-67 NOS 4-Speed Shift Plate
  2. Doors
  3. F/s, pair of 66 corvette horns
  4. C2 Electrical - HELP
  5. WTB 3x2 Air Cleaner Base Bolts
  6. 1963 hub caps
  7. Wilwood Direct replacement 4 & 6 piston calipers Hawk Brake Pad Speicals
  8. Wilwood 4 & 6 Piston Direct replacement calipers and Hawk Brake Pad Specials 65-82
  9. New right hand headlamp bezel.
  10. wtb mid year frame
  11. 15 x 7 Rallys w/Trim Rings & Caps
  12. WTB: 1100696 alt for '65
  13. WTB 15" Steering Wheel and Car Cover for 61
  14. F/S: C2 parts
  15. Wanted 3 speed trans. for 57
  16. 1966 427 #3873858 Square Port Heads
  17. FS 67 Battery Tray & Shield
  18. Steeroids Rack & Pinion Steering C1/C2/C3 Get it Now before Price Increase
  19. F/S Altronics Red-Alert EGT warning system BNIB
  20. 66 conv bright blue door panels
  21. New 58-62 corvette Classic Auto Air #20-254 ac/heat/defrost complete system.
  22. FS: 63-67 Sunvisors NEW
  23. Mid Year Parts Lot 1
  24. 60 Drivers door for sale
  25. WTB: Rear valence panel
  26. Wtb 66 ignition, lighter, hood release, console
  27. FS: 66 427 valve covers Original
  28. pulley needed
  29. WTB 1964 breather lid for dual snorkel
  30. FS 4 Firestone Deluxe Champions 6.70-15
  31. Fiberglass Wanted ...Used or NOS
  32. 56-57 Window regulators f/s
  33. F/S Exhaust Manifold #965
  34. SHP 8" Vette timing cover WTB
  35. WANTED window glass regulator guide track 1956
  36. F/s nos #3860347
  37. Big Block stuff on craiglist
  38. JIg welded trailing arms
  39. FS: 1953-1962 Corvette Front Suspension
  40. FS 1957 WCFB 4 barrel intake manifold
  41. FS 1963-65 Air conditioning parts
  42. D-409 Distributor rotors
  43. FS 2 1/2 inch Exhaust Manifolds
  44. For Sale NOS / Used
  45. FS 1959 to 1967 valve covers
  46. 64 Exhaust System
  47. Spring Carlisle car corral spots
  48. WTB: Al Knoch C2 Soft Top Video
  49. WTB SHP 6 qt L84/L76 Big Oil Pan
  50. F/S Misc Parts
  51. WTB: 1956 Powerglide setup or parts
  52. FS - Corvette Restorer CD ROM - 1966 Edition
  53. 512 Block For Sale
  54. 67 splash pan for poweglide
  55. WTB 63 Door Stainless Bead Trim
  56. F/A pair of finned valve covers
  57. F/S 67 coupe black door panels
  58. 1962 parts
  59. Griffin radiator for '65 396 and L/88 - KY
  60. WTB: '56-7 drivers door panel
  61. FS 396 4 bolt 3855962 short block
  62. Edelbrock Performer Intake
  63. WTB 65 Black Interior
  64. C1 E-Brake warning parts needed.
  65. indy craig list, vette valve covers
  66. 1960 and 1961 Historic Documents for sale
  67. WTB Motor Trend Sept. 1968
  68. F/S - NON - DOT BFG Silvertown 660 Tire
  69. Wanted: 67 BB Hood
  70. FS: T3 Headlamp - Like New
  71. Eckler Fender Flares
  72. 64 hood,spare tire lower tray,wire harnesses etc.
  73. WTB: Used 56-57 front coil springs
  74. F/S '67 427 parts
  75. F/S '65 962 blocks/heads/components F/S
  76. F/S 63-67 Vent Window Assembly
  77. Oregon Dealer license frames for sale
  78. WTB 62 Auto Shifter
  79. 63 - 65 4 Barrel Intake and WCFB Carb
  80. FS: 65 Parts
  81. Rams Horn Manifold, Nice! Ready to Go, $20
  82. WTB 403 bell housing
  83. Parts 63-67 & up Delco /GM
  84. F/S: a few C2 mid year parts
  85. 65 67 Seat Covers
  86. WTB 62 clutch z bar ( crossshaft)
  87. 65 left rear fender flare repair hl, press form
  88. 61 vette parts fs
  89. WTB: 1967 PN 3904351 engine block
  90. FS: Headliner + Tire (Both New in wraping)
  91. F/S: Set of 4 American Racing Polished Aluminum Torq Thrust II Wheels and Tires
  92. Wtb: '64 wcfb
  93. 57-65 Rochester Fuel Injection Parts Plenums, Distributors, Fuel and Air Meters
  94. WTB - 4 bolt main caps sm jrnl, sm blk
  95. 66 427 for sale
  96. WTB '53-55 parts
  97. FS - C2 Hood Support & Pop Ups - CHROMED
  98. Wanted 58-62 gauge cluster
  99. Body Lifting Straps for sale
  100. Wtb: 1966 coupe inside windshield trim
  101. 53 Powerglide wanted
  102. WTB Original Backup Switch
  103. WTB C1 High Horsepower Harmonic Balancer
  104. FS 63-79 Composite Spring
  105. C2-Power booster/valve covers
  106. WTB 65 door stainless
  107. WTB 67 NOS Starburst and....
  108. C1 Parts in SW Ohio
  109. WTB Dist. grease Cap
  110. WTB bottom cushion seat cover, red for '62
  111. 65 frame for sale (update)
  112. Fs noland adams resto guide vol.2
  113. Fs noland adams resto guide vol.1
  114. 66 Seat FS
  115. Wtb 66 427/425 valve covers
  116. 58-62 Parts For SALE
  117. WTB: 56 R. bumpers/brackets & 265" distributor
  118. F/S: C2 Left soft top clamp & parts
  119. 1961 corvette
  120. 1961 - 62 Hardtop
  121. frame off body dolly
  122. 1959-1962 RPO Big Brake Drums for Sale
  123. 1960 trap door oil pan reproduced?
  124. WTB Tailights
  125. WTB 66-67 trans shifter bracket
  126. F/S - 1967 Corvette Horn Button
  127. F/S - 1100696 Alternator dated 6H31
  128. F/S - 7365 Starter dated 5D7
  129. F/S - Vintage DX Oil Gas Cans 1960's / 1970's
  130. Wanted - j-65 702 heads for 390hp
  131. 67 White Leather Seatcovers and foam
  132. WTB '67 435HP smog steup
  133. More C2 small parts (63-67)
  134. F/S 62 hardtop
  135. 63-67 Vintage Air Dash Side Ducts
  136. WTB rear bumper brkts 1960
  137. WTT: 67 Blue coupe sun visors for convertible
  138. WTB - one screw
  139. WTB: Front Bumpers and RH brace for 1966
  140. 1995 and 1996 Corvette Owner's VHS Videos For Sale...
  141. 327 Long Block
  142. Free Oval mufflers with welded pipes for C1
  143. WTB 63-67 LH Fresh Air Vent Grille
  144. OT--WTB 57 1/4 ton pickup wheels
  145. 996 Rear Wheel Cylinder Wanted
  146. WTB C-1 Bushing
  147. WTB C2 Automatic Brake Pedal
  148. BBC Head F/S or Trade
  149. 1967 NOS Top Surround Fiberglass
  150. speedometer is off
  151. BRAKE KIT--C1 or C2
  152. For Sale New 1967 Corvette Image Front End $1750
  153. C2 vintage Air
  154. 63-67 small parts
  155. 1967 427 powerglide trans needed
  156. 1967 correct ex. manifols needed 427
  157. 1967 tri power 427 intake and carbs needed
  158. WTB Original Bolts For 62
  159. 1962 461x heads for sale
  160. WTB: Courtesy lamp light socket '64
  161. Genuine GM NEW parts
  162. WTB Window crank escutcheon
  163. F/S 65 door panel stainless
  164. F/S Rear sway bar '64
  165. Wtb 63-67 washer pump for windshield wiper motor
  166. FS: Orig Delco '66 Rear 907 Shocks (Pair)
  167. 1963 hub caps
  168. Stock '65 front upper control arms for sale $50 + shpg
  169. WTB: 1 '64 K.O. Wheel
  170. for the 58 crowd
  171. Differential Carrier Rebuild Kit GM OEM Parts
  172. WTB 63-67 Dimmer Switch Grommet
  173. WTB 1967 Console 4 speed
  174. FS NOS 66 wheel covers and Auto transmission shifter cover
  175. Exhaust Manifold #
  176. Blocks and other motor parts
  177. 870 casting shortblock and 461 heads
  178. WTB 5047984 Wiper Motor
  179. 1962 327 SBC Block, Crank, Heads, Intake, Rods
  180. 1963 327 aluminum finned valve covers for sale
  181. WTB C2 Automatic Center Console
  182. claysmoker
  183. WTB: clutch pedal push rod bracket
  184. FS - C1 56 to 62 NOS, USED, & NEW Parts
  185. For Sale - Repro '67 Alloys with centers and lugnuts
  186. FS: (4) 1961-62 big brake option hubcaps
  187. F/s 63-67 corvette s.b. Power steering pump new
  188. L 66-67 corvette upper a-arm assembly new
  189. 63 thru 67 Headlight Motors
  190. C1,front crossmember
  191. WTB: 65-79 Differential Near N.J.
  192. F/S,C-1 restoration books,63-64 NCRS manual
  193. WANTED: Rallys + Michelin X Redlines
  194. 59-60 Hardtop For Sale
  195. WTB 62 Door Panel Stainless
  196. (1) Bias Belted Tire
  197. WTB 326 Water Pump Undated
  198. WTB 67 Column & BU Switch
  199. F/S American Racing Wheels & Tires
  200. WTB Power Window Motor parts
  201. Wts 67 dash cluster
  202. WTB C-2 Rear License Bezal
  203. WTB C2 frame
  204. 1966 Corvette transmission on Boston C/L
  205. WTB Midyear deck lid hinge
  206. WTB Knock off wheel spinners
  207. FS 60-61 Carb.
  208. FS 3877660 Thermostat
  209. wtb 63 water inlet
  210. F/S 2 BB blocks and parts
  211. Still looking for a Used set of Bolt on Knock-off wheels
  212. WTB 64 auto lower shift boot
  213. '58 red door panels and armrests, $750
  214. WTB 65 muncie tail shaft housing
  215. wanted wcfb top for front carb non choke
  216. WTB: 66 427 BB side exhaust headers
  217. FS 1964 Master Cylinder
  218. FS Shifter and linkage '64-'67
  219. FS: Delco Shocks 500 series orig replacements
  220. 67 Water Pump Restored 3859326 J 20 6
  221. WTB 67 - Original GM J56 Brackets
  222. FS 62 Seats
  223. For you go fast guys (gen1 sbc)
  224. Luggage rack
  225. 1963-7 Parts
  226. WTB 67 Seat Covers
  227. WTB T-3 Headlights w/o DOT
  228. WTB 56/57 Seat Material
  229. Wtb luggage rack
  230. Wtb luggauge rack
  231. FS Misc C1 & C2 parts
  232. wtb c2 headlight parts
  233. WTB: 63-66/67 pedal box
  234. F/S 63-67 Misc Parts
  235. wtb 3 speed shifter detent spring
  236. 327 Fuel Injection engine model
  237. Seat foam anyone?
  238. WTB C2 right rear bumper
  239. WTB wcfb 049 fuel bowl
  240. f/s 58/62 radio
  241. WTB Rear deck top latches
  242. 1965 convertilbe door glasses
  243. Wanted 66 427-390 carb.
  244. Looking for direct bolt on wheels 64
  245. 1966 Telescopic Steering Column
  246. 65 vent glass regulator
  247. wtb 63 side glass
  248. F/S Original glove box door....'66-'67
  249. FS 1967 Corvette 427 Holley
  250. F/S '63 Glove box doc's
