View Full Version : C1 & C2 Parts
  1. Rare Dated Early 66 Corvette 427 BBC Matching Heads 3872702 $499
  2. WTB Power Window Conduits
  3. WTB 1963 rims
  4. WTB: '56-'57 door knob & door panel top pad
  5. Wanted Driverside 1963 Vette roadster window channel
  6. FS 1967 Corvette Telescopic Steering Column
  7. Fikse Wheel Announces Spring Anniversary Sale. Starting May 1
  8. WTS 2 water( head) temp & fuel press gauges
  9. WTS sb hooker headers
  10. WTS original starter from my sb 1966
  11. F/S 1960 seat covers
  12. Early 63 461X Heads
  13. Wtb 64-65 glove box emblem
  14. Spal high performance 16" puller fan for sale.
  15. WTB 63 Glove box contents
  16. WTB Mid year hardtop
  17. FS muncie 4speed trans,shifter and drive shaft 64
  18. F/S Knock Off Western Wheels for 65
  19. WTB Orig Bolt On Wheel Screwdriver and
  20. FS - 1957 1X4 Intake Manifold
  21. 63 hood,63 grill, 64 hard top
  22. FS: NCRS Corvette Restorers and Drivelines
  23. FS: trans yoke 65-70 genuine GM
  24. 66 Inst Cluster
  25. 63-67 Misc. Interior Parts
  26. 67 68 NOS Antenna Mast F/S
  27. c-2 clutch-brake pedals& bracket assy.
  28. WTB Glove box contents
  29. WTB Original 65-67 350hp valve covers
  30. WTB or trade for 61-62 soft top ass'y
  31. WTB:BB ALT Bracket
  32. F/S Non Dot tire for 67
  33. For sale: 58 CORVETTE 283 ENGINE - GENUINE 230HP CODE CQ
  34. 64 corvette hood
  35. Wtb
  36. Wanted Holley 3810 Carb for 67 Vette
  37. WTB 66-67 fan shroud small block
  38. WTB 1963 Corvette Hood
  39. F/S Scatter shield / Hurst shifters
  40. F/S = Bran New Midyear Antenna Cable
  41. WTB: '60 Black Trunk Mat - Late Style No Power Top
  42. Wtb / 1961-62 tach
  43. F/S L79 Original INTAKE
  44. WTB /C-1 Convertible top strap
  45. For Sale C 1 2x4 intakes (4)
  46. Fikse Wheels the leader in custom fit wheels 6061-T-6 Aircraft Grade Billet Aluminum
  47. WTB 1966 black seat belts with original 66 buckles
  48. Looking for 65 bolt on wheels (KO style)
  49. WTB: '63 shifter and linkage for T-10
  50. FS: 1967 427 435 HP TI Distrib PN 1111258
  51. WTB Original 67 Corvette Antenna Mast
  52. Need 327 Vette 8" Timing Cover ASAP!
  53. F/S 62-67 Powerglide tail housing
  54. 66 Wheelcover Spacer wanted
  55. For Sale 1955 4 barrel intake manifold
  56. 1958 Distributor
  57. 1964 327 engine needed
  58. F/S C1 Replacement Master Cylinder New in Sealed bag
  59. 1957-61 2x4 intake for sale
  60. WTB 1963 Rear Deck Lid
  61. 1956-58 Corvette hubcaps for sale
  62. 1962 340 H.P. Intake
  63. FS - 3782461 - 2.02 Heads
  64. FS set of 65 horns
  65. 66 seat covers and foam
  66. FS 9 inch power brake booster 63-67 $100
  67. F/s, corvette engine pullys
  68. F/s, original 202 coil
  69. WTB 64-65 Air Cleaner 350-365 HP
  70. WTB: Rosenthal Chevrolet Documentation
  71. WTB John Geer or Gordon Wilson Chevrolet
  72. WTB set of c4 half shafts
  73. F/s, 65 corvette seat covers
  74. F/s, pair of 66 corvette horns
  75. 1966 Radiator
  76. 53, 54 55 Antenna ground cover
  77. 1959 corvette hood
  78. F/S 1964 clock
  79. WTB C1 Posi third member 3 series
  80. WTB AC 4150 fuel pump
  81. wtb 65 seat covers and door panels,
  82. WTB Carter Carb master catalog/book
  83. WTB Water Pump Pulley#3890419
  84. F/S or Trade 1962 C1 Brake Hoses New
  85. WTB- 63 F.I. Adapter Manifold with the Snowflake and the Casting Number in the Middle
  86. 61/62 #553 Aluminum Bellhousing
  87. WTB 2 1/2" sidepipes
  88. WTB 56 washer bag bracket
  89. 67 Front Hub
  90. WTB Midyear Coupe Tinted Vent Glass Both Sides
  91. 57 four speed transmission
  92. WTB '56 transmission tunnel
  93. F/s 63 fi block,,64 365 block
  94. 64 carpet and foward harness FS
  95. 1960 Corvette 283 ENGINE F/S
  96. 64,65 restored alternators for sale
  97. steering wheel
  98. WTB: valve cover
  99. Need 1962 jack and handle, etc.
  100. 58 To 61 F.I. Air Cleaner, Repo
  101. F/S 64-67 original shifter and linkage
  102. Wanted: original master cylinder cap for 67/68
  103. WTB Weather Stripping
  104. need lower ps pulley for 63-65 327 300 hp
  105. wtb 65/66 bb hood
  106. Need correct crank and cam for 4351, corvette block!
  107. 65/66 Door panel stainless
  108. dead or alive
  109. Help Identifying RPO Parts
  110. Fikse Wheels now available and on SPECIAL thru April
  111. F / S ....G M Highway Emerengcy Kit
  112. WTB 56-62 Door Posts
  113. WTB 56-62 Door Posts
  114. wtb 1965 interior
  115. FS: GM #621 bellhousing
  116. 1960-1962 Upper C1 Fan Shroud, 55-59 Lower
  117. wtb c2 hardtop in tenn
  118. owners manual 67
  119. 66 corvette clutch pedal and linkage
  120. WTB 1963-67 Corvette Convertible Vent window assemblies
  121. WTB 64-67 Original 4-Speed Backup Switch
  122. F/s 1965 #208 396 heads
  123. Want to use Script Valve Covers on your Early Corvette?
  124. F.S. Throttle cable bracket fits holley/ demon
  125. F/S Vintage Cal Custom Aluminum Valve covers
  126. FS New 67 Repro Parts
  127. WTB Air Filter Base for 1966 Big Block car
  128. 64-67 original shifter
  129. WTB: gold or redline radials
  130. Wanted-wonderbar nuts
  131. F/S 1963 340 hp intake
  132. WTB Original #264 Coil
  133. X Heads F/S
  134. 1966 427 intake
  135. Iron intake
  136. Looking for a 427, 67 Corvette 4351 Block
  137. Knock Off wheels, 63. In New Jersey
  138. '67 Rally Wheels
  139. looking for 7 blade fan
  140. WTB '62 hood
  141. WTB 58 hood
  142. Searching for original big block hoses and clamps
  143. Looking for a 67 bright blue emergency brake consule
  144. looking for original 67 shocks not f41s
  145. Looking for an original 67 rear end 3:70 with june date
  146. Looking For Original 427 Engine
  147. '60 692 heads
  148. WTS 391 heads
  149. 1963 original hood trade for a 1967 stinger hood?
  150. 53-54 Corvette carbs
  151. 3.36 open rear gear C1
  152. Hardtops for sale/63-67 and 58-60
  153. Dec. 1963 block ?
  154. C1 Brake Booster?
  155. Like New BF Goodrich red line tires
  156. WTB 65 window crank bezel
  157. Looking for a set of Halibrand looking wheels???
  158. FS: Edelbrock 600CFM carb w/elec choke
  159. Want to Swap - Brand New 63-64 Vert Sunvisors
  160. Turbo Wax Car Care Kit Level 1
  161. Need a pointer for a 67 Corvette speedminder
  162. c1/c2 extra parts
  163. Whats it worth? 54 Door RH
  164. 1967 Door Latch Mechanism
  165. F/s disc brake rotors & pads
  166. Wtb steel wheels '65-'66
  167. pair 2" manifolds FS
  168. 1963 Corvette Engines 340hp Long Block and 360hp FI Short Block
  169. WTB 3873847 Power Steering Pulley
  170. Wtb: 1966 coupe inside windshield trim
  171. WANTED Early 63 F I Plenum Lid.
  172. 61 heater core and heater cover
  173. NCRS shirts L
  174. WTB - C2 Hardtop
  175. Wilwood Brakes 6 Piston Direct Bolt on 65-82 Corvette Front Replacement Caliper Kit
  176. 63-82 Corvette, NEW integrated merge spike design by Stainless Works on all C2-C3
  177. F/S old Motors manuals
  178. New under hood NOS harness for sale
  179. WTB - 63 Corvette Air Conditioning System - Suction Throttling Valve Needed
  180. C1 Wheels, 1956-62 Steel Wheels
  181. FS midyear headlight door open switch on dash
  182. WTB: 327 365hp Engine (1964 Corvette)
  183. F/S 66 nose emblem
  184. WTB 65-66 Steel wheels
  185. 67 tranny reverse switch
  186. LuK clutch and muncie input shaft bearing
  187. F/S 63-64 Tech and Judging Guide
  188. orginal lead hammer for 65 knockoffs
  189. wtb 62 clutch throwout fork
  190. 66 Front Grill Forum members $225.00
  191. 1967 Chevrolet 427 Block
  192. Redline Radials
  193. SUPER HUGE garage sale cleanout- tons of GOOD stuff- OEM and RACE
  194. FS-63-67 front bumpers
  195. F/s aem wideband 02 $150
  196. F/S lot of c2 parts
  197. Timing light for sale
  198. WTB 3.36 Rear
  199. WTB - '65 hardtop latches & other items
  200. Fikse Wheels now available and on SPECIAL thru April
  201. Wanted 1956 front bumber & radio antenna
  202. WTB 1967 Mint console and Steering Wheel
  203. Trade my repro '65 PS Door handle for '63
  204. Wtb
  205. 1962 Borg Waner T 10
  206. 1960 corvette parts misc?
  207. 63 Corvette hood
  208. Holley list 3810
  209. 50's 60's 70's & 80's Vette Parts
  210. Wanted C2 Heater Block-off Plates
  211. Wanted C2 Heater Block-off Plates
  212. WTB / C1 master cylinder
  213. WTB used 66 soft top
  214. C1 and C2 FI units and parts for sale
  215. C2/C3 Handling & Steering Package VanSteel & Steeriods
  216. FS Eckler's 64-67 Conv Body Mount Kit
  217. Mass -Flo EFI MASS AIR fuel injection system & complete fuel system
  218. WTB - original fan clutch to water pump bolts; grade 8
  219. 67 rolling chasis
  220. WTB NOS Black 1967 Fiberglass
  221. WTB - 1962 Hardtop
  222. 1967-68 Corvette Brake Proportioning Combination Valve
  223. WTB - '65 Fuel Injection
  224. wtb 66 keys
  225. Wtb : Goldline tires
  226. 1962/63 Rebuilt T-10 Trans listed on eBay
  227. F/S 1965 425 HP Intake
  228. 1962/63 Rebuilt T-10 Trans listed on eBay
  229. F/S #3817173 Finned Harmonic Balancer
  230. 427 carb
  231. 68-69 BB 840 cylinder heads value?
  232. Intake and WCFB Carb. 63 thru 65 For Sale
  233. Corvette swap meet at BUDS this Sunday 4-3
  234. 66 Corvette 427 exhaust manifolds needed
  235. f/s 65-66 power antenna with original switch
  236. FS Noland Adams Resto books vol 1 & 2
  237. 64 corvette exhaust
  238. FS GM Compass
  239. Western Wheels
  240. FS '63-'67 Convertible striker plates
  241. Looking for any Salina Motors memorabilia
  242. WTB Goodyear White letter tires
  243. WTB Used 66 Glove Box Door For Tire Decal
  244. WTB 66 convertible left door top stainless trim
  245. Stainless Works Sidepipes 304SS/Aluminized on Sale
  246. Wilwood 6 Piston w/Slotted Rotors 65-67 Corvette
  247. WTB 64-67 NOS 4-Speed Shift Plate
  248. Doors
  249. F/s, pair of 66 corvette horns
  250. C2 Electrical - HELP
