- 9 leaf spring
- Cleaning out the garage
- FS- Dual snorkel air cleaner 1972 SB
- FS- Factory AM/FM radio from 1972 Coupe
- FS-(4) Rally Wheels 15x8 $200 OBO
- WTB- American Eagle Alloy Series 146
- WTB 77 Horn Button
- FS 77-79 original steering wheel silver/gray
- DeWitt 69-72 SB damage sale
- WTB 69 Radiator support
- FS: power slot front rotors (NEW)
- WTB Set of T-Tops
- WTB 1968 Door lock Bezel
- WTB / banners. What do you have?
- WTB or trade 1968-1969 parts
- Radiator Support question
- 81 engine computer
- 74 corvette owners manual
- c3 part too move
- WTB 76-79 AT Transmission Crossmember
- F/s 72 corvette m-20 muncie 4 speed rebuilt
- F/s 68 nos grill moulding
- NEW front brakes
- WTB 1968 Steering Column Cover (Black)
- F/S: Vintage 1970s Lakewood/Ansen 2 Piece Bellhousing (Fits Small or Big Block)
- WTB 29199 diverter valve core for rebuild
- WTB 5 Speed Tremec for C3
- WTB rear window louvers for 1978 C3
- WTB 80 lower alternator mounting bracket
- Richmond 5 speed transmission retrofit kit
- FS 68-79 336 diff w/housing
- Richmongd 5 speed transmission retrofit kit
- Clutch Pedal Assembly For Sale
- Parting out my '81 (a1sensei)
- FS: 1974 1975 Corvette NOS Rear Bumper Corvette Letter Set Emblem w/Nuts *Picture*
- F/S Gas tank filler unit assembly
- WTB 72 vette parts, small items.
- 1970 Coupe Black Seat belts Wanted
- WTB rear window lovers for 1978 C3
- "We set the pace" poster
- GM OEM Date Coded BBC Intake Manifolds 67 68 69 70 71 72 73
- GM OEM Date Coded Original BBC Heads 66 67 68 69 70 71 72
- F/s 434 sbc 470 rwhp engine
- Parting 1972 Coupe
- fs deck lid assemblies
- WTB 72-76 radio bezel that is already cut
- L81 Parts
- FS: Rear 6x9 Kenwood speakers
- FS: Radio/8 track from 80 Vette
- 74 corvette speedometer and tac for sale
- 3899621 Bellhousing
- 1970 Muncie M20
- Centerforce DFX, installed but not used
- Big Block Factory Aluminum Intake
- FS 72 Tach and Speedo "Willcox checked"
- WTB rt side parking lamp pigtail assembly
- F/S little things you might need for your restoration
- 1968-69 3919840 Square Port Heads 427-435HP L71
- 1976-1977 Corvette EGR TVS Switch #364788
- Borg Warner 4 Speed FS
- Wtb radio gauge bezel
- FS Clutch & brake pedal assembly
- Wanted 68 to 75 window pillars
- WTB C2/C3 big block 3 groove water pump pulley
- 1975 l82
- WTB Hardtop Rear Window SS Trim Pieces
- F/S - Aluminum Upper Control Arm - Shark Bite
- F/S - Slotted cross-drilled rotors
- F/S - Hedman Headers sbc for sidepipes - powder coated
- WTB Holley #6333 and #4519 Metering Block
- FS new SB coil springs and new complete offset trailing arms
- Tools and toolboxes F/S
- WTB Dome light for 72
- 68/73 rear bumpers
- WTB Original Exhaust clamps
- WTB - BB Chevy rods
- F/S New c-3 muffler
- FS Original footman loops
- FS: Complete show chromed 70-72 Bumpers with guards
- Wtb tri-power for 350
- Wtb
- FS 63-82 front control arm bushings Poly
- L-46 motor for sale
- F/S 70-74 Rear Side Marker Lamps
- F/S: Original '69 Corvette Hood, Lemans Blue
- WTB: 1969 Steering Wheel Hub, Horn Button Guts NON tilt/tele
- For sale TH350 high proformance
- 3:55 Rear Differential; Fits 63-79
- WTB or WTT for..... Carburetor
- Haynes repair manual
- F/S: 76-78 seat covers dark blue - $225
- wtb t-top headliner panels and rear emblem to fit 1979
- FS...cat 'test pipe'
- Willcox New Spring Sale. Weatherstrips, Wire Harness, Soft tops, 10% off and More!
- WTB Manual Steering Relay Rod
- 1971 T-TOPS and Carrying Case **FOR SALE**
- Anyone interested in some FREE used door panels
- WTB power window regulator
- WTB: 1977 horn button assembly
- F/s 5 x NEW SHELBY SERIES 1 ONE WHEELS
- Power Slot Slotted Rotors' Vac-U-Slot vents 63-82 Corvette Front Left & Right
- 63-82 Tubular A-Arms W/Coilovers 550# Springs- Car Set
- 68-82 C3 HIGH PERFORMANCE STREET SERIES Composite Leaf Spring Rear EZ Ride by Hyperco
- walbro 255 external fuel pump
- F/S STS Baffles (New, never installed)
- WTB Low Fuel Warning circuit Board
- FS parts from my 73
- '69 WTB Heater control part
- best 69 repro door handle assemblies?
- Door trim parts F/S
- F/S Little parts, for your restoration
- WTB 950 or 1000 cfm carb.
- F/S original 68-76 console reinforcement and trims
- F/S NOS GM Original Small Block 350 Choke Spring and Cover
- Vintage Style Offenhauser Mid Rise Dual Quad Small Block Intake
- WTB 69 Side Exhaust Insulator Kit
- 76 rear bumper cover
- WTB : B28 vacuum advance canister
- WTB or TRADE for stock 74 LS4 manifiolds
- F/S ZZ4 Complete Top End & More. $1,400.00
- Front and Rear Pace car spoilers-$100
- 1982 vette hood toair cleaner gasket/retainer $25.shipped
- Freshly powdercoated black 1981 aluminum l81 intake!
- Brand new Indy style front spoiler/airdam for 73-79
- WTB:1969 rear CORVETTE letters
- FS: Turbo TH350 Built Transmission
- FS: Holley 4150 Double Pumper 4-barrel carb
- 77 Stock Headers
- Brand NEW!! Ecklers C3 Corvette Side Skirts, Rear Skirts & Fender Louvers 30% OFF
- Edelbrock Small Block Cross Ram Intake Manifold and Carbs
- Vintage 9 Fin Cal Custom Small Block Chevy Valve Covers
- Need: rear name emblem 76-82
- FS: 1980 fan shroud (76L-82)
- 1973 Tach Drive Distributor w/coil 1112098
- Looking for Right Lower Fender Vent
- Wanted 68 water deflecting Rubber strip
- 68 Wiring harness- $40
- WTB: 69 Black Seat belts
- GM Corvette clutch fork/68 neaut.safety switch
- 68 Gauges-$200
- Rare SB A/FX valve covers
- Pair of headlights 76- $500 obo
- 4 stainless brake calipers $200
- Be Cool radiator 62029 (auto trans) for C3
- 1968-82 Corvette Parts, Some NOS
- FREE - 76 Body and rolling chassis
- 1968 Steering Wheel (16", wood finish)
- F/S Carpet Set 69-69 Acc color code 07 Dark Blue Coupe__ ** Clearance **
- Need 1971 LS6 engined
- F/S Carpet Set 1980 Full Set in 8023 Oyster ** Clearance **
- 69 Shift Plate
- L82 Aluminum Intakes 50.00 each
- WTB Chrome Carpet Strip
- FS 1973 ramhorns, heat riser, front pipes
- 17" black and chrome torque thrust style wheels with BFg g force tires! Great shape
- WTB: set of locks (doors, alarm switch, spare tire lock)
- WTB: 77 Starter Extension Wiring Harness
- 209 carb stamp photo
- 427 Square Port Factory Heads and Aftermarket
- F/S Carpet Set 1970 Full set Blue Cut Pile ** Clearance **
- Valve Covers
- 72-76 Corvette Radio
- Wing
- WTB blue seat belt halves
- WTB: Seat track and shoulder belts
- '72 Original Radio
- Trailing arms/brakes/rotors/shafts out of a 71
- WTB 81-82 Radio Knobs
- BBC SBC March Pullies,Alternator, Flex fan Etc.
- FS: 4 Rubber Lower Control Arm Bushings
- F/S, Sector Gear, Vacuum Relay and more C3 parts
- F/S Harmonic Balancer and Free Flexplate
- 1968 Convertible Top Assembly Needed
- 1977 parts:
- Vinyl T-tops
- Hood from my '72
- Holley 650 CFM Carburetor
- FS Mirror Glass t-tops for 78-82 $800 + s
- F/S: Original 69 Passenger Door Panel, Black
- 78 antenna
- 78 antenna
- F/S: Original 70-72 Seats, Black
- Wanted : 1968 Outside Mirror
- TH350 and parts for sale
- '75 original steering wheel (thin), wood finish
- WTB QuadraJet 7028209
- WTB 1975 Door Pieces
- WTB metal side exhaust covers, rusty ok
- 76 Corvette Storage Doors on Craiglist
- WTB One piece top 78=82
- Free to a Good Home, 1974 454, LS-4 Intake
- C3 parts F/S
- pair of flowmasters
- Free side pipes
- F/S 1981 Corvette Shop/Service Manual
- Vintage Mickey Thompson BBC Valve Covers
- 1969 Camaro Z 28 Intake Manifold - good for Corvette street/strip car
- Frt.Stabilizer
- BB Chrome Frt/Rr sway bars/hardware
- L88 FGregg Racing frt. spoiler....
- Found these parts:
- Old School Style Weiand Big Block Intake
- Old School Style Weiand Small Block Intake
- Pair of 70'-72' Seats, Saddle
- Original 69' Seats with Headrests, Black
- wtb holley 1850 650 cfm double pumper to be transformed into a blow thru carb.
- FS 68 oem brake light switch & headlight knob
- Spare Tire Carrier TWO SETS for $100
- Corvette Camel Hump 492 Chevy Heads - $250 (Irving, TX)
- Free
- Driver's side T-Top from '80 Vette
- Misc parts for sale 81
- 1971 side louver LH
- WTB 1100900 alternator for Feb 3rd build
- Need fan 1970 L-46 fan shroud
- FS 1970 corvette SB hood "skin only" local pick up only (So.Cal.-sfv)
- WTB Fiberglass Side Exhaust Covers
- FS: 1970s smog pump setup
- Hooker Super Comps - Silver Ceramic
- FS: Hurst 4speed shifter and linkage - 750miles
- FS. March Big Block Serpentine Assembly Billet alluminum pulleys, brackets, PS Pump
- Brand New 81'-82' Blue Carpet, in box
- need to buy fan shroud for '79
- FS: Scoggin Dickey Clutch Pivot Ball Bracket for Corvettes
- F/S 68-69 Big Block Stainless Welded Exhaust System
- Comp Cam for sale
- Looking for advice - Valve covers
- WTB: black 69 headrests
- '68-74 RH mirror - NOS GM
- Corvette 113 Aluminum Cylinder Heads, Nice, Lots of work done!
- for sale 63-74 sb oil pans
- WTB 3:70 rear or gear set
- c3 parts for sale
- '68 Convert Top/Frame...??
- F/S Dash Pad, Firethorne 1976 ** Clearance **
- Wanted: '70 Power Steering Pump Bracket For Big Block
- WTB: 1969 Jack dated 9H, 9I
- FS: BB CompCams Pro Magnum roller rockers NEW
- WTB 68 vacuum reserve tank
- F/S late 79-82 mirrored t-tops
- C3 corvette targa top
- Parts 72 BB
- FS: 74(?) coupe pass. door, halfshafts
- WTB: small piece of 68-9 quarter panel
- WTB Stub Axles Big Block 1971
- F/S - C3 Steering box with pitman and rag joint
- WTB - 68 convertible door glass
- WTB - Rally Wheels for '74
- F/S 1969 Corvette Seats
