View Full Version : C3 Parts for Sale/Wanted
  1. C3 Parts For Sale
  2. WTB/ no.2 auto crossmember
  3. 4 into 1 sidepipes-chrome
  4. WTB 2 dust caps
  5. WTB: 69-75 tilt steering column
  6. F/s Door Handels For 76
  7. Exhaust for a 1975 Corvette
  8. WTB Seat belt (Harness/Retractor) Red for 1976
  9. 1978 L82 short block
  10. WTB: Good working Q Jet for my '75
  11. AFR 190 SB Chevy Heads FS
  12. steering gear box flaming river 16:1
  13. wtb/gm#356989
  14. 78-82 Fan shroud w/electric Fan FS
  15. Miscellaneous 68 parts
  16. Wtb- '71 Front Clip
  17. WTB:ORIG A/C BB Shims
  18. Auxiliary Hardtop '68-'75
  19. 1969 seat belts needed!!!
  20. WTB 1981 Vette fuse box
  21. F/S My original T-Tops Perfect Condition
  22. WTB-Original Power Antenna 79 L82 Vette
  23. WTB intake
  24. 454 Bored .030 over, heads, two intakes.
  25. F/S Lap belts from a 1972 coupe
  26. Wtb 76 Warning Buzzer And Timer
  27. F/S: Speedo Gear - light blue NOS - $6 shipped
  28. WTB - Early 70's left rocker panel
  29. F/S Complete Serpentine Belt
  30. Rochester quadrajet carbs for sale
  31. Bought parts from Fastvette00
  32. Back in a Stingray!!!
  33. WANTED: 17.5" 7 blade fan
  34. HP Iron Pully for Power Steering pump
  35. FS pair of 1974 sill plates
  36. F/s Corvette Seat Tracks Late 81-82
  37. Fs Headlamps And Retainer Rings
  38. GM Serpentine Set-up for sale
  39. WTB 69 Lower Dash Side Mounting Tabs
  40. WTB 69 Lower Dash Side Mounting Tabs
  41. Trade, 70-73 rear valance without cut-outs for with
  42. FS/ NOS ANTENNA pn 3943654
  43. Set of 5 IROC Wheels & Goodyear Eagle Tires
  44. Brand new Comp Cams Valve springs, 10 deg. retainers and caps 1.437" Hydraulic roller
  45. 2- 3927186 double hump SBC heads Rebuilders
  46. FS: C3-'74 Steering Wheel, Air Cleaner, Wheel Trim Rings
  47. For Sale: 68-82 Cigarette Lighter
  48. Leftover screws and items. Some stuff free!
  49. WTB:driver side lower dash pad for 76
  50. Wtb, Camel Tan Steering Wheel,81
  51. looking for hose from air cleaner to radiator
  52. FS: '69 & '76 GM Chassis Manual
  53. Wanted: Radiator Support for a 75
  54. FS: 78 Frame/74 Body
  55. Misc 78-82 Corvette stuff for sale
  56. Holley Carburator/ Performer Manilfold Combo....Ready to bolt on
  57. Expired 5 point belts?
  58. L 82 Air cleaner
  59. Looking for 1972 Corvette 454 parts. Fan blade & Carburetor
  60. Looking for Holley Avenger 670 carb
  61. W T B - 1977 non A/C fan / heater core box.
  62. WTB: 69 T Top molding
  63. Master cylinder core F/S
  64. Would love
  65. F/S: KwiklLift on LI, NY
  66. Original 2 1/2" half shafts in Very good condition
  67. Original Rally wheel center caps
  68. wtb upper rocker panels for 69
  69. BB Manifold
  70. 68 Stop Light Switch
  71. WTB Dash for an 81
  72. F/S: BB Hooker Headers and sidepipes, JetHot coated - brand new
  73. Need 1968 427 390 hp long block
  74. WTB: dated GM original 1970 rally rims
  75. 1981 carb and numbers
  76. WTB 68 wiper motor
  77. 69 shift plate
  78. WTB 68 seat back hinges
  79. FS- strut rods,brake booster,gear set
  80. WTB - Hood latches
  81. VB Poly Adjustable strut rods
  82. For Sale: New Stainless Steel Calipers
  83. WTB: 4-Torq Thrust II's polished 18x8
  84. LOOKING for dated 1969 rally rims
  85. WANTED: Painted 1969 Hardtop
  86. F/S: Aluminum Intake Manifold, '68 427/390
  87. Free: Radiator seal / FS: T-top headliners, alt brackets
  88. Fs Single Half Shaft
  89. FS 1967 Late Production 396/427 Q-Jet
  90. FS: Exhaust tips, inside mirror, shocks, brake shields
  91. FS: Half shafts, radio, seat belts, parking lights
  92. Hoods F/S L88 short and Motion Long
  93. WTB early 70's TT column
  94. Wanted: Bronze 82 CE T-tops, Sell: Mirror T-tops
  95. FS- Chrome pieces and 68 Air Dam
  96. WTB: Manual Steering Drag Link
  97. Need Upper Dash Pad Dark Blue For 77
  98. WTB - 1977+ Evaporator Housing (Blower Motor) Assembly
  99. wtb power steering brace
  100. WTB L-79 Intake
  101. BF Goodrich T/A's Wanted
  102. Goodyear Eagle 1 yellow nascar tires
  103. [Gauging Interest] Door inserts
  104. 1978 - 1982 Fiberglass T-Tops For Sale
  105. Wtb- Alt And Power Brackets
  106. Wanted: 1982 Corvette AM/FM Stereo Radio
  107. WTT: C4 Car Cover for C3 Cover (TX)
  108. WTB 1968 Push Button Door Lock Assy...
  109. FS MECH TACH. year???
  110. WTB Rims for '77 corvette
  111. WTB Headlight Switch 93
  112. WTB Black Plastic Distributer Shield 78-82
  113. C3 Rear Caliper Wanted
  114. FS: Automatic Pedal Assembly
  115. Front Bumper Support/ Vacuum Tank 75-79
  116. TPI parts etc.
  117. FS/ Parts from 76-?
  118. FS: 3.7 diff
  119. WTB Carbon fiber dash kit
  120. 73' Distributor F/S
  121. Rik's Corvette Parts
  122. wtb 73 radiator shroud
  123. FS: Book - Original Corvette: The Restorer's Guide 1968-1982
  124. F/S Quadrjet from 76 L-82 stick
  125. WTB 68 Wiper Vacuum Canister, Coffee Can type
  126. Side pipes
  127. WTB: Console filler piece
  128. 4 Wheels and 4 mounted racing slicks
  129. 1980-1982 nose bra
  130. 1980-1982 nose bra
  131. F/S 75 Hood
  132. F/S: Used long style hi-rise hood for 68-72 Vette
  133. F/S: Used Stock rear struts with Poly bushings
  134. F/S: Used BBC Edelbrock Torker II manifold
  135. F/S: Tall BBC Valve Covers
  136. WTB 68 tele column
  137. 1982 ce jack
  138. WTB 81 cruise transducer
  139. FS Corvette Floor Pan, Left, 1975 Late-1982
  140. looking for a good 3.70 rear end
  141. FS: Lower ignition Shields - Used
  142. FS: stainless steel brakes, exhaust tips
  143. FS/Free: center guage cluster, tail lights
  144. FS/Free: Seat belts, air cond, radiator hoses, fue line
  145. Original "turbine" Hubcaps & Tires
  146. FS 74 wiper arms and blades
  147. Fan Shroud 69-72 SB
  148. Lower A arms
  149. 1982 Crossfire
  150. 68 riveted rotors and ball joints
  151. WTB BB oil pan
  152. Sport Mirror Motors
  153. Paint For Engine Brackets
  154. F/S - Super T10 + Hurst Shifter
  155. Seats for my buddy's bottom '80
  156. FS fan and clutch 74 to 76
  157. F/S Parts
  158. Polished aluminum ribbed oil pan with trap door and windage tray
  159. Steering wheel, 14 in Black leather in great shape
  160. New Comp Cams Hi-Tech retro roller pushrods 5/16 7.300
  161. New melling stock oil pump pickup. SBC
  162. New MSD bronze gear
  163. F/S 73-75 Pillar Post left side Medium Saddle
  164. F/S 73 Dark Saddle seat covers
  165. F S - 1977 A/C Evaporator.
  166. window shelf brackets
  167. Driveshaft loop
  168. 74 radiator support
  169. Wtb 72 Deluxe Door Panels
  170. wtb rear spindle flange and halfshaft outer flange
  171. F.S.-Ecklers one piece front spoiler
  172. WTB '68-'72 big block/LT-1 hood +
  173. Doors & Rear Spoiler
  174. WTB '72 Corvette Original Rally Wheels And Tires
  175. wtb 350 short block
  176. New SBC Cometic MLS .040 head gaskets.
  177. 72 Distributor ignition conversion
  178. WTB Torque Thrust 2 wheels and tires
  179. FS: 700r12 trans
  180. WTB - Solid fiberglass rear bumper 77'
  181. WTB: 74 front used bumper cover
  182. NEW LS Block, Crank, Rods
  183. FS: Flowmaster exhaust setup with highflow catalytic converter.
  184. FS: Stock Sway Bar 63-82
  185. FS: 6 Speed (T56 LT1) SLP Clutch and Pressure Plate Assembly
  186. FS: Distributor/ Spark Plug Wireloom Cover
  187. FS: Shifter Boot Black 77-82
  188. FS: Rear Main Seal
  189. FS: New Chrome Air Cleaner Lid 14"
  190. FS: Poly Locks for 3/8 Stud Rockers
  191. FS: Radar Detector
  192. FS: Air Cleaner Riser
  193. FS: Moroso Valve Cover Baffle
  194. FS: Brand new rubber VBP ball joint dust boots.
  195. FS: K&N Air Filter for the stock air cleaner assembly.
  196. FS: 76-78 Seats
  197. FS: 76L-82 Fan Shroud
  198. FS Diff Parts from 78
  199. FS: 70LT-1 ignition module
  200. FS: 74 Body
  201. Wtb 69 Bb Fan Shroud
  202. Wtb Flowmasters For 1982
  203. 69 CORVETTE 454 Factory Carb
  204. Q About Washer Tube And Clamps For 69 Wipers
  205. WTB 72 a/c wiring harness
  206. looking for bolts for spare tire cover
  207. F/S Edelbrock Mechanical fuel pump and regulator (New)
  208. F.S 69 Distributor
  209. Good Transaction with BackN70
  210. I need a Rear Bearing Shim(.121), Castle Nut, & Die
  211. F S - C3 Subwoofer / Component Set Box.
  212. WTB: 75-77 Tach
  213. WTB - '68 Throttle Cable
  214. F/S- 1976 L82 q-jet
  215. forged TRW blower pistons and forged crank.
  216. Smooth transaction with Syco79
  217. gauging interest- headlight relay repair kit
  218. WTB 1980 quadrajet and distributor (4-spd)
  219. Looking for Info. on C3/ '68 Windshield
  220. F/S: Richmond Gear Road Race 5-speed Transmission
  221. Fs: 78-82 Center Gauge Cluster
  222. WTB rear carb bracket for accelerator cable linkage for 350
  223. For Sale-454 Corvette Head,
  224. For Sale-1980-1982 Aluminum Wheels
  225. WTB An Original 69 Antenna
  226. FS: 74 parts
  227. FS: 78 suspension parts
  228. FS 72 Tach drive distributor
  229. WTB Fan Shroud for 73 350
  230. Fs - 69 Bb Original Hood
  231. WTB: Set of Used F70x15 RWL Tires
  232. WTB - QA1 rear adjustable shocks
  233. WTB- brackets that hold speakers in dash 71 vert
  234. WTB - Non cracked fan shroud for late '76
  235. Wanted- Brackets
  236. wtb: intake 3937793 69 427/390
  237. WTB Some Engine Pieces For an 82
  238. FS: 1971 and 1972 Seatbelt Sets
  239. Wanted 1972 Corvette 454 with air, Fan blade with fingers
  240. '68 update-couple of questions
  241. WTB : Seat + vaccum actuator Vette 1980
  242. Fs "840" Heads
  243. WTB 68 exhaust
  244. WTB good left door panel
  245. WTB - 3 Point Retractable Seat Belts for 69
  246. [WTB] A/C parts
  247. wtb speedo gear and clamp
  248. Still looking for - LH Vert Door Glass
  249. WTB Weiand 7525 Intake
  250. FS 1981 seat belts. silver
