- WTB Fox Rain Coat for 68-72
- Frame for 79 manual vette close to Minnesota
- Finned wheel covers / hubcaps
- looking for 1982 Pinion Yoke
- 68-77 Soundbar speaker system
- Expansion tank dated 71M
- WTB 4 alum slots 15 x 10 unilug or 41/2 bolt pattern
- Milodon 1.5 full roller rocker arms for 3/8 studs, non SA
- WTB radiator caps and gas caps
- 1975 sand blasted and painted parts
- WTB L88 Hood For 81
- Anyone selling a 68 or 69 front clip at Carlisle
- wtb 80-82 lower valance- no fiberglass
- F/S - PYPES X-Pipe (new) - $100
- F/S - 1981 Vette car cover - $20
- F/S - 1974 Engine Wiring Harness (new) - $110
- WTB 1971 Black Carpet
- Wtb
- ACI Fiberglass UP To 40% Off
- 69-76 4sp shifter complete assbly w/linkage
- FS fact manual shift assembly(missing reverse)
- FS factory manual shift assembly
- FS 955 carter wcfb
- wtb passenger side trailing arm
- WTB Original 1969-76 Parking Brake Console
- WTB 1971 Door Panels Black
- WTB Vapor canister assembly for 75
- wtb/ gas lid spring.....
- 69-77 LH Inner Door Handle
- F/S 70-77 Standard Door Panels
- FS 73-75 factory air cleaner assembly
- 1975 corvette front 5mph bumper
- ----- corvette windshield ------
- WTB crossmember bushings
- WTB Overflow tank, bracket and straps
- 81 vette parts (last call)
- overflow tank
- '69 HiPerf 427 FS
- WTB rear view mirror glass for 72 drv/pass
- F/S 2 1/2" Half Shafts ('72) DFW area
- WTB Left rear trailing arm assembly complete
- Custom built 383 short block/rotating assembly
- F/S Carbon Fiber Spreader bar
- WTB: 68 Driver Side Floorboard
- Anyone have 2 black seat back carpets for a 1980??
- New Comp Cams R Series Lifters
- 1968 ONLY RH Dash pad, CAN DELIVER TO CARLISLE
- Solid roller double springs w/ dampner
- Solid roller lifters used
- MSD Noise Filter
- Adjustable Strut Rods NEW 80-82
- F/S: brand new leather '69 seatcovers
- Corvette Fiberglass Front Clip
- Wanted 1975 Hood Insulation
- Centerline Auto Drags and NEW TIRES! $550
- FS complete 1968 survivor motor
- 78 vett parts for sale
- Discount Pricing This Week Only!
- WTB T-10 Main case
- 7161 Edelbrock Performer RPM Intake for BBC
- WTB 17"/18" wheels for 75
- WTB parts for 75
- Wtb cheap th350 trans pan ins/e wisconsin
- 1975 Goodyear Steelgard GR-70 original tires
- FS: BBC windage tray, SBC valve cover hold downs
- Original GM T-top carrier with box
- F/s 71 454 #512 engine block
- WTB: Big block air cleaner base
- Carlisle 2011
- WTS Upper and Lower CHROME hood latch assemblies 70-76
- C3 Corvette parts for sale
- VDO Tach with Shift Lite
- Painless remote hidden battery cutoff
- SBC Parts for Sale
- FS: Muncie 4 speed
- FS: 1-1/8 front sway bar 63-82
- Parting out 1980 corvette
- 1971 454-425HP 8 Inch Timing Cover
- 76 air cond ducts
- 1976 washer plastic bottle
- Various Big Block Chevy Parts
- Corvette Carlisle ""Vendor Spaces""
- ##Corvette at Carlisle "VENDOR SPACES"
- 69, 427, vette engine, for sale, indy craig list
- F/S 69 Front Bumper Guards
- Softtop Blow out Sale! 1956-1967 and 1968-1975!
- FS 69 and 71 parts
- FS - 12 Chrome Bolts
- WTB 68 AC condenser and brackets
- Nice Hurst 4 speed shift ball
- WTB: '78 seatbelt/key-in/headlight buzzer
- F/S Used Cup Holder
- wtb used 27" copper radiator for '69 427 w/ manual trans. .
- WTB: 1971 dated starter 1108400
- WTB: '78 partial right front fender section
- WTB: 1970 Corvette jack
- WTB: Date coded alternator for '82
- *** Method to report a bad seller or concern ***
- 70ish brake calipers
- fs hayden 2711 fan clutch new in box
- FS: Hughes Performance GM20 2000-2200 Stall converter
- Parting out a 1979 Corvette Silver on Black
- For Sale: Glass T-Tops
- F/S NOS Switch
- 1980 Parts for Sale
- T-tops 78-82 Corvette Stock&Folding canvas
- More 81 parts to offer
- Need alternator bracket- borrow or buy
- FS Rocker Panel Pair from a 1972
- Little Vettes F/S
- WTT DIN Mount Dash Bezel
- c3 parts can deliver to carlisle
- F/S Gas lid emblem
- WTB nice used aftermarket exhaust
- WTB custom rally wheels 17 to 20 inch
- Original spark control solenoid (tcs switch)
- Tachometer out of 1974
- F/S RFI Shield
- 74 Bottom Schroud Extension
- 1980 Smog Pump
- FS---** 70-72 front side grilles***
- Badass topend kit for Gen 1 sbc
- 53-76 GM Parts Catalog
- Transmission linkage and brackets needed!!
- FS: 73-74 Metal Front Grilles
- FS Vapor Canister from a 1979 L48 auto
- FS: Front Bra
- WTB/Trailing Arm Bushing Staking Tool C3
- Cigar Lighter Light Bulb Socket
- Comp Cams Magnum pushrods 7695-16 8.000"
- FS: Hays 30 lb steel flywheel all redone can bring to carlisle
- Van Steel 5/8" Rear Sway Bar and Hardware
- F/S 1982 Corvette Shop Manual
- FS: 69-77 Door Pulls
- Radio Wanted for 1973 Convertible..
- Beware of member/seller "06z06_427"
- FS 67-74 BB wire sheild plug set. new
- FS 71/2 distributor 1112050
- F/S NOS 68-72 Upper Fenders
- fs NOS OWNERS MANUALS
- WTB: Heater Hose Metal Hold Down Clamp (Located on RH Fenderwell) -- see pic
- For Sale: Original Half Shaft
- For Sale: Brand New Wagner Low Beam Headlights
- F/S - Sparco Seat - OMP Steering wheel
- FS: 74-76E Rear View Mirror NEW
- info-AM/FM/CB repair cables
- Wanted 71 454 GM rebuild kit
- Edelbrock RPM Air Gap Polished Intake Manifold for Vortec Heads
- 1970 Hood Latches, Male, Female
- FS:`80 Corvette stuff
- WTB driver side ball vent housing/tube
- F/S astro ventilation driver,pass. windows
- WTB: T-Top Center Stainless Chrome Molding
- FS-Early 68 Frame w/Damage to Right Front
- FS 70-72 radiator metal expansion tank
- 82 Only Front "Y" Pipe (NEW)
- C3 Air conditioning brackets
- For Sale - Richmond 3.55 Gear Set - New
- For Sale Engine Parts - 73-74
- Flaming River Steering column
- Wtb- 1969 rad. Surge tank
- 81 original urethane bumpers (2 available)
- WTB Radiator Shroud for 1975 Stingray
- spare tire tub
- Right side trailing arm rebuilt with e brake hardware
- FS: Holley Spread Bore Carb
- 15X8.5 American Racing Wheels
- WTB Parts for 78
- wtb 78 and up bircage near central florida
- WTB: 68-82 C3 Door Hinge Pin Repair Kit, Stainless Steel
- WTB: 13 inch rotors with bracket
- custom c3 floor mats
- WTB ScrewKits for original Sidepipes
- 502 540 555 BBC Engine Block Big Chevy
- want corvette header
- FS: Corvette News C3 Lot 73-77
- Lot of Big block chevy parts 454, 427, 402 !!! LOOK !!!
- 1974 corvette to sound louder
- NEW Recaro Sport Black Leather & Suede Seats-NICE
- Willcox Summer Sale Inclds: Interiors, Weatherstrips, Carpet and 10% off Still On!
- WTB" 17" polished wheels and tires for 69 vette
- 1963-1979 Corvette Stub Axles, GM HD Threaded New
- F/S Sheep Skin Seat Covers
- WTB F70-15 Bias ply tires
- WTB early 77 A/C box, and heater Box
- FS Petronix Electronic Ignition
- Fs: Big block exhaust manifolds with air tubes
- WTB: 68-73 windshield corner trim moulding
- WTB 1970 LS-5 Fan 3993889
- need 69 parts
- Turbo 400 Driveshaft, brand new U Joints
- Hyperco 200# Composite Spring & Long Rear Bolts
- carbon fiber gas lids
- WTB 81 Wooden Shift Knob
- Original Wheels For Sale (Set of 4)
- FS: (68-82) spare tire tub, lid & temp spare tire
- Thumbs up to C69vete
- FS 68 to 73 left rear bumper
- Aluminum intake manifolds +++
- WTB alignment shims
- Wtb working speedometer & tach
- FS- 68-69 Front Bumperettes Rechromed
- F/S Brake Calipers
- Holley 750 DP with Holley HP body
- WTB 68-74 Accelerator cable
- '69 fender louvers inserts
- WTB: 72-73 A/C wiring harness (damaged OK)
- Suspension parts for sale
- Air Cleaner Lid
- FS: Anniversary Emblems
- 74-79 corvette tilt steering column
- WTB 4 speed Inspection cover
- FS: Super T-10 4spd
- 76-77 buckskin seat covers foam and sunvisor new 450 shipped
- 79 Stock Hood for FREE, SF bay area
- FS Sway bar end links and bump stops
- WTB T Top bag
- Looking for an 82 CE Hubcap tool
- 4 speed clutch/brake pedal assembly
- Need ignition coil
- F/S 1973 corvette parts
- Wanted: Rocker moulding screws
- 81 parts ( still many to unload)
- F/s 79 rolling chassis $1000.
- 68-69 Corvette nose for sale
- MT slicks 26x8.5x15 great shape
- WTB hood that will fit my 82 (southern california only)
- 69 427 Side Exhaust Mufflers (Stainless)
- 90 Degree adapter
- 1970 vette 300hp parts
- Steeroids: What's the Value?
- MSD blaster coil with HEI convert cap.
- Rear spindles
- Vacuum relays, tested ok.
- Correction - 1963 Turn Signals Wanted
- wtb seat tracks and maybe black seats
- FS Red carpet set 78/9
- '68 Coupe parts for sale
- 78 vette upper spring for emergency brake
- FS 69 corvette hood aftermarket high rise
- FS Holley 4150
- For Sale - New Uniroyal Tiger Paw GTS Tires
- WTB A/C Liquid Line
- 1975 corvette front clip
- Black polyurethane sway bar bushing set
