- Wanted power window motors 1976
- FS 80-82 tail lights (prior ones sold) have 1 other set
- 68 82 splash shields NOS
- Clutch for sale
- Flywheel for sale
- 71 AC Evaporator Heater Core (used + free)
- WTB: 78 air cleaner
- Fs 74 fan shroud pt # 339175
- F/S 1973/74 454 Intake Manifold
- FS 4 Western Turbine
- Want: 1982 Brochure and owner's manual
- WTB Hurst comp. shifter for 80 vette ?
- WTB: Air Cleaner Duct - '79 L-82
- 69-82 corvette bearing front kit
- FS 1980-82 tail lights (stop lights)
- 73 original steering wheel
- WTB 82 front bumper
- WTB after market high rise hood for 1974 Corvette
- WTB: stainless steel luggage rack
- 1970 Comfort Weave Seats
- WTB Th400 driveshaft.
- WTB - Weber carbs
- 74 oem front and rear bumpers
- FS - Complete 1978 Pace Car Decal Set
- F/S: 63-82 Spreader Bar NOS
- WANTED - Input shaft for a t-10
- FS 3932491 Exhaust Manifold Set - Jet Hot Coated
- Need original 1969 RC-26 surge tank cap
- 1969 sb exhaust system, complete, best offer takes em
- WTB Small Block Exhaust Manifolds
- 1968 Hard Top
- C3 clutch/brake pedal setup
- C3 parts for sale
- WTB:5 speed tranmission conversion
- c3 original mag wheels
- Trade: My Sweet Thunder 2.5", your reverse flows
- FS- BB engine cradle - modified
- F/S: McLeod 153T Aluminum Flywheel w/ Steel Insert
- 77-82 Daytona Style Hood,63-82 Hooker Super Comp Headers,T-Top Suitcase ALL FOR SALE!
- Early 1971 QUADRAJET part #7041213 DM, dated 341O
- F/S Holley Fuel System
- Need 6.950" long 5/16 hardened pushrods
- WTB 77 vette frame
- wtb 77 front lower grills
- WTB - Overdrive trans
- SBC Forged rotating assy for sale
- Wanted Seat Covers 1976
- Mini Starter, Alternator, Pulleys
- F/S - '68-69 427 400/435 Center Carb
- FS-NOS Inner Fender - 73-79 $175.00
- WTB SBC 350, streetable
- 418
- F/S New 68-82 front clip
- WTB the indicator for an auto transmission
- 1969 left rear quarter panel
- 1980 White Door Panels & Seat Covers. $350.00
- Parting out 74 small block
- WTB: '80-'82 tail lights
- 81 parts/signing off
- WTB l88 air cleaner base
- Chambered exhaust FSBO
- * JOIN US * Official check presentation to St. Jude Children's Research Hospital **
- WTB: Harrop Hurricane 55 mm ITB Intake for LS3
- WTB headlight / window switches for 75
- WTB radio for 75 (does not hhave to work)
- WTB ox blood seatbelts for 75
- F/S Misc parts for 72 vette
- WTB 63-79 Differential
- FS 68-71 Gauges (Green Faces)
- WTB 73 #413 interior trim parts
- 81 reverse lights
- Wtb spindle setup tool
- 3919840 Square Port Heads
- F/S 81 drivers power seat unit
- FS: New Motor Mounts, Poly Sway Bar Bushings, Header Alternator Bracket
- Goodyear Eagle GT P225/70R15
- 1968 ONLY Wiper Bezel
- Rare option - T-top carrier on rear deck
- Ignition Shields F/S
- FS: Front & Rear Shocks NIB
- WTB: SB rams head exhaust manifolds
- Early 70's Starter #1108430
- Need expansion valve A/C hose
- 82 radio knobs
- F/S 1974 Corvette Front clip and hood. 1pc front clip
- 330545 heads
- FS Richmond 5 speed trans
- Wtb motofeet
- FS 17 original owners manuals
- WTB Plug wire clip/holder '77
- 1976 early parts needed, missed carlisle
- WTB: fuel vapor can , 1971
- Found on Craigsist
- New Expansion Tank dtd 71M, Bracket, Straps, Cap
- 68-73 Rear Bumper chrome Corvette
- Autolifters Made in the USA drive-on tilt lift
- FS - McJacks small block headers !!!
- FS uncommon parts
- 74-75 Silver Sunvisors
- 4 Speed Muncie P9S02
- Original Goodyear Eagle GT Tires & C3 Rims
- License Plates Wanted
- 69 thru 73 master cylinder cover (NEW)
- FS: McJack manifold replacement headers
- WTB Vacuum Storage Can 1980
- FS - Goodyear Polyglas GT E60's
- For sale Hurst Competion Plus Shifter
- Holley main body
- WTB: '68-69 center grille
- **wtb a supercharger or supercharger kit***
- WTB - AC Duct, Left Side for 71
- WTB '70 LS-5 fan, P/N 3969926
- FS: New Hooker headers & sidepipes
- Wanted 68-72 rear pop out window date code i.n.
- FS: 69 side exhaust panel, genuine GM
- 82 wiper linkage clip kit
- Wanted: driver side Blue t-top M1131 for 81 vette
- WTB: Hooker headers (1980)
- I need parts for my 82 Corvette (bumper & headlight Bezel)
- Parting out another '79 Vette
- front grills
- 1969 350 /350 hp
- WTB carb or carb base - 4801
- WTB:(PA) 78 Windshield
- WTB: Left and Right Headlight Support Frames
- FS - Like new TT2's with Nitto's
- WTB Radio for 78
- wanted: caliper dust shields
- WTB Original Exhaust Tips for '72
- Caliper Set FS
- WTB: 1972 Side Mirror (passenger)
- WTB - 1971 Interior Pieces
- Motorsport Tech - The finest Wheel Adapters, Wheel Spacers, and Hub Rings.
- WTB Under Dash Speaker Bracket
- WTB - 68-72 frt fender lower section
- 1974 RH metal grill
- wanted.stock exhaust manifolds and 15*10 rear wheels
- Corbeau seat tracks
- 1973 Muncie M20 transmission for sale
- WTB: '73 Coolant Expansion Tank
- WTB an original AM/FM Mono Radio for '72
- Carlisle Left Overs (mostly '77)
- F/S 76 Early Rear Bumper Cover Priced to Sell! Damaged in shipment
- FS: Valve Covers 1978-1982 Aluminum (Picture)
- F/S 041 + 186 Heads
- Complete '68-'72 headlight assemblies (minus lamps) restored
- Selling out of the country
- Glass t top latches
- 1977 corvette engine and tranny
- 68 Door Panels . . Who to buy from?
- Turn signal lever
- Need red leather seat cover for 82
- WTB-Original F-70-15 firestone Whitewall Tires
- WTB convertible decklid latch controls
- Body dolly for C3
- F/S NIB Lens 6480852
- 69 350/350
- 69 side exhaust rear panel/valence wanted
- power dl wiring 79
- C3 Caliper Covers??? Anyone make them?
- Hoods for sale
- Balls felt for FREE!
- 81 factory service manual
- 1968 steering column
- 1972 Speedo/Tach FS
- FS - Early C3 parts (68-73+)
- FS: '68 strut rods
- 1968 owner's manual
- 81 remaining parts
- 80-82 Frame
- Original owners manual, 1976
- Cylinder heads f/s
- WANTED 1969-1972 Bird Cage
- WTB..breather and valve covers..SBC
- FS: 1978-1982 Weatherstripping New
- WTB Vinyl Hardtop 69'
- WTB - 68-69 BB Side Assembly
- Paul Kaulas
- fs 68/9 front bumperettes
- 1968-71 427 & 454 Square Port Heads and Parts
- WTB - 69 to 71 Hood Support
- 68 to 72 vett hood
- Holley Steath Commander Fuel Injection
- fs earlly 70's nos lap seat belts
- fs 69/70 &72 new shift plates and all others used
- fs 73/4 factory radio
- Speedometer
- WTB/Trade BB Side Exhaust/Pipes system
- Dewitts 26 inch core radiator
- WTB: Splash Shield 70 - 77
- 68 date coded 327 / 350 L79 Q-Jet carb
- WTB 69 thru 72 Corvette Rolling Chassis / Frame
- WTB Radio
- WTB ASAP, steering column retaining plate and C-clip.
- Hardtop for sale
- 1974-82 Rear Bumper
- Holley 6239 Carb dated 244 & 750 Double Pumper
- 20% Off Sale: VetteNuts Insulation Kits w/New Premium Layer!
- 68 Upper Radiator Baffle
- '69 Seats to give away
- wtb or trade 700r4 slip yoke
- Customized Wall Clocks - now at DD MODS!
- WTB - Tripower Primary Bowl
- F/S: BBC tall deck bare block, machined
- Parts 4 Sale:
- f/s 1979 headlight system
- WTB 68 Astrovent ball felt seal - no AC
- Chrome oil dip stick
- Carlisle PARTS for sale
- 68-72 Mufflers (NEW)
- Looking for an Oldie T-shirt(S) JOE BLOW TEES NOS?
- wanted rear bearing tools
- Stainless fuel line/clamps
- WTB: 1980 Corvette Steering Coupling
- WTB 70-75 Convertible under Dash Brackets Braces AC Type
- Selling: New in Box X Pipe, 81 Mainfold Exhaust, Smog Stuff
- Wanted: 68-77 Center cluster air duct - no AC
- garage cleanout,C3 parts
- 1963-1982 Strut Rod Camber Bolt Kit
- 1963-1982 Left & Right Rear Shock Mounts
- Van Steel 1963-1974 Strut Rods - Pair
- FS Corvette Rear Disc Brake Brackets
- [WTB] GT 460lbs front spring
- FS: American Racing Vector Wheels and BFG T/As
- WTB - 72 w/washer bottle neck extension
- F/S BB Hood, & exhaust manifolds
- FS Stainless Brake Hoses (3)
- Wanted: Radiator Core Support, 1973-76early
- F/S 73-74 Front Bumper Cover (has tiny chip) Priced to Sell!
- FS 68-77 fuel lines new in box
- WTB: 69-71 Gauge Bezel
- WTB 79 fan shround
- wtb c3 3rd member with 4.11 and posi!!!!!
- WTB Fox Rain Coat for 68-72
- Frame for 79 manual vette close to Minnesota
- Finned wheel covers / hubcaps
- looking for 1982 Pinion Yoke
- 68-77 Soundbar speaker system
- Expansion tank dated 71M
- WTB 4 alum slots 15 x 10 unilug or 41/2 bolt pattern
- Milodon 1.5 full roller rocker arms for 3/8 studs, non SA
- WTB radiator caps and gas caps
- 1975 sand blasted and painted parts
- WTB L88 Hood For 81
- Anyone selling a 68 or 69 front clip at Carlisle
- wtb 80-82 lower valance- no fiberglass
- F/S - PYPES X-Pipe (new) - $100
- F/S - 1981 Vette car cover - $20
- F/S - 1974 Engine Wiring Harness (new) - $110
