View Full Version : C3 Parts for Sale/Wanted
  1. WTB : '71 Lap belts (blue) and Idle Stop Solenoid bracket
  2. WTB, 78 L-82 carb
  3. WTB: '71 TCS Relay Asm Bracket: p/n 3990852
  4. F/S T-Tops White
  5. WTB: BBC Rocker Arms
  6. FS - 68 only gas lid emblem
  7. Good Dealing with NSTY C5
  8. WTB: '68 Big Block Power Steering Hoses
  9. 68 doors wont fit
  10. F/S 1969 date code small block timing cover
  11. FS: 72 Rear frame Crossmember w/ frame Crossmember & Vette Brakes Extras
  12. WTB: BB Rt Hand Exhaust Manifold W/A.I.R.
  13. HELP!!! 81 visor light and mirror
  14. BB sidepipes headers,
  15. WTB 1980 L-82 exhaust manifolds
  16. FS: GoodYear F70 x 15 Custom Wide Treads
  17. F/S misc. parts new & used.
  18. WTB: list for "68 427/390"
  19. Possible FS: 1980 Factory Hood
  20. Excellent Transaction with 33Chevy
  21. Cowl Vent Bracket (72 coupe)
  22. 383 Engine,Hydraulic Roller,Etc,$2500 in NC
  23. new bummpers needed!!!
  24. WTB spring compression tool
  25. WTB: One Kelsey Hayes factory slotted 15 x 8 aluminum wheel...
  26. WTB - Center bezel stub. Early C-3
  27. 1969 427 L88 shortblock setup
  28. Need 75 Bumpers
  29. wanted rims
  30. wtb 68-69 Seats With Headrests
  31. Fan Blade & Clutch Fan from 1969 350/300 A/C car
  32. F/S 69 Bright blue door panel inserts
  33. WTB 68-69 TI AMP Bolts
  34. WTB 69 -72 front bumper brackets
  35. wtb 74 Fan Shoud
  36. FS Various Parts
  37. WTB: Hood hinges, light switch, seats, seatbelts
  38. WTB 81 350 lower rad hose s/s spring
  39. WTB: SS License Frames
  40. wtb 68-69 Quarter Panels
  41. Inserts for side openings on a 78???
  42. FS 68 Documents
  43. WTB White door panels
  44. WTB E Brake handle for 77 cupe
  45. WTB 1968 BB exhaust manifold
  46. Rev limiter for 68 427
  47. WTB: 1973 Quadrajet 7043213
  48. 79 Hood Insulation-new
  49. WTB - 68/69 Wiper actuator
  50. F/S 1970 Radio power Plug & support and dash lenes
  51. Good Experience With Dave Witmam
  52. Good Experience With Langg
  53. w/b throttle cable bracket 70-350
  54. F/S QTP Electronic Exhaust Cutout Controller
  55. If someone is looking for a 7042216 carb
  56. WTB 71 bumperettes - both sides
  57. 69-72 Big Block Fan Shroud 427/454
  58. wtb l88 style oil pick-up tube/pump
  59. For sale 1969 Big Block stock 4-speed shifter complete
  60. FS:1969 windshield frame
  61. WTB 72-80 Exhaust manifold set (L&R)
  62. WTB - Small block wanted
  63. All Corvette Car Covers 15% Off!
  64. F S - Serpentine Brackets, & Pulleys
  65. Need a New Transmission
  66. F S - My barely used sub in custom box.
  67. FS: VBP HD camber strut rods (63-79)
  68. WTB: 77' Frame fuw Auto Trans
  69. WTB right front bumper guard
  70. WTB: '71 Generator #1100950
  71. WTB:'77 Cruise control servo
  72. WTB: '77 Ant and lug nuts
  73. WTB - 68 Ft Bumper Horseshoe Bracket
  74. WTB: 1972 Air Cleaner dual Complete in LN Condition
  75. 525 Big-Block Chevy-$5500
  76. Jack with Handle
  77. interior parts
  78. WTB 1979 (or 78, not pace car) rocker panels
  79. A few C3 things for sale...
  80. valve covers
  81. Radio, Upper & Lower dash, radio bezel, Just saying Thank You
  82. F/S T-Tops 78
  83. WTB Radiator Core Support
  84. WTB 1979 59C Light Beige Cloth seat material
  85. 1969 350-350HP block and #041 2.02 heads
  86. WTB:Rear Control Arm Frame Bracket
  87. WTB 79 T-Top Weather strip
  88. F/S 8" Timing chain cover 302/327/350
  89. Want to buy: Flywheel for automatic trans.
  90. 1982 Mapp Sensor
  91. WTB-68 oil filler tube
  92. Wtb. New 76 Nose Emblem
  93. 81 power seat control
  94. WTB - Big Block Smog system for 1968
  95. WTB wiper switch plate for non-AC 68,69?
  96. WTB 1968 convertible drivers side floorboard/footwell
  97. a/c housing, heater box, lines, blower, etc.
  98. WTB: other small parts for 71
  99. F?S 71 BB Painted Valve covers OE
  100. WTB: gas tank overflow hose and related
  101. WTB: rear shock bolts, nuts
  102. WTB: dark saddle A pillar trim and RH kick panel, etc.
  103. WTB: clutch linkage parts
  104. wtb 68-75 vert hartop rear glass
  105. F/S Shark Bar Harness Bar '78-'80 model
  106. 1982 hood for sale
  107. WTB: SB pushrods, rockers, motor mounts,
  108. WTB: Front bumper '74
  109. F/S 69 - 77 T-Top Seal
  110. F/S 73-79 Lower Fiber Glass Valance
  111. Swing Arm And Bearing tools
  112. FS: Hooker sidemount reverse flow mufflers, unused
  113. FS:caliper cores/set of four
  114. WTB 1972 3 port vacuum tank
  115. FS: 1971 Vette Wiring Harness
  116. WTB Driver's side fender for '71 (D/FW area preferred)
  117. '78 indy front spoiler
  118. '74 2 piece 'glass rear bumper
  119. WTB Rocker Panel Molding 1970-1977
  120. WTB:dual hump crossmember for 81
  121. F/S 1975 Smog Pump W/ Pulley
  122. FS: 2-1/2" Wheel Adapters
  123. Art's has no more - cannot find this anywhere else - please help
  124. WTB 81 cyl. heads
  125. 1979 Corvette, For Parts
  126. 1969 dated replacement block and parts
  127. 1969 dated replacement big block and parts
  128. WTB Gas Tank for 1979
  129. WTB: SB chevy used stock parts
  130. wtb: 79-82 red armrest
  131. WTB/Q-Jet 7040212-1971
  132. Leads on a smog pump for a '72 LS5?
  133. 33Chevy/Ed: Excellent transaction
  134. Wtb Nos Firestone Tires Gr70-15
  135. WTB: 1969 Wiper Door Limit Switch parts
  136. side pipes
  137. WTB Sidepipe Covers
  138. %$#% load of small block intakes F/S
  139. WTB 68 Drivers side footwell
  140. F/S Bowtie Overdrive Crossmember
  141. WTB 69 bb hood
  142. WTB Qjet 7043213 1973
  143. Corvette A-Arms shafts
  144. FS: 1" Front Sway Bar with poly bushings
  145. FS: Edelbrock #1711 Victor Series Fuel Pump
  146. Radio Instructions
  147. Pin on L88 hood
  148. Need Drivers Side M-1131 T-top
  149. FS: Parts from 1968 BB
  150. 1969 Quarter Panels - Driver quality
  151. Mics Parts
  152. FS: Hooker big block headers
  153. WTB: Misc. Interior Parts for '70
  154. WTB: '68 Seat Back Screws & Power Steering Hoses
  155. 69 Fuel Line Kit - 3 Piece
  156. 1969 Aluminum Valve Covers
  157. WTB: '68 Dark Orange Interior Pieces
  158. F/S Jegs Engine Storage Stands
  159. L88 Short Hood with air box & fgregg spoiler F/S
  160. WTB Side Pipes For A 1979/Dark Interior
  161. WTB: 69 seat belts
  162. WTB: 73 rear glass and saddle interior parts
  163. Need 74 350 Flex plate
  164. Need 68 backup light housings?
  165. FOR SALE: C3 Seatbelt Buckles / Receivers
  166. 71 Sider Marker Lenses only??????
  167. Wanted: '68 Front Bumper Guards
  168. WTB - 68 base engine valve covers
  169. F/S Intake Manifold '72 350 sb Auto
  170. F/S Exhaust Manifolds 350 SB
  171. F/S Rochester Quadrajet 7042208
  172. WTB good working 72 wiper motor
  173. WTB: Aluminum valve covers
  174. remote mirror
  175. F/S M1131 Passenger mirrored T Top
  176. 4 sale: ceramic coated headers SB C-3
  177. WTB: Headlight trim rings for a '70
  178. WTB:gunmetal Interior pieces for 69
  179. WTB: Lap Belts for 71
  180. Engine Painting
  181. WTB 79' Dash
  182. T-Top trim parts for sale
  183. FS Edelbrock performer 2101 intake/ Rear metal deck vents
  184. New SBC Hi Volume Oil Pump and welded pick-up
  185. BBC Edelbrock 427X Square port Intake
  186. BBC Engle Cmas
  187. FS 81 auxillary fan and shroud
  188. FS Spare tubs with tire and rim-free air inside!
  189. FS Power Window Regulators, motors, wiring harnesses
  190. WTB- 1982 Corvette tail lights
  191. WTB 68 Parts
  192. FS 68 Windshield Wiper Cowl Vacuum Can
  193. Any C-3 17x8 wheels for sale
  194. one pair saddle shoulder harness
  195. When your selling corvette parts...
  196. Big Block Engine For Sale PA $4000 OBO www.ALLVETTE.net
  197. good transactions/etc...Dave Witman
  198. Need one more TKO order!!!!!!
  199. For Sale! -New,unused MSD ignition parts....................
  200. Strut Rods & Bracket
  201. Catylitic Converters -TWO
  202. FS: Almost New MOSER 3 Inch Wheel Studs
  203. FS: Glass T-Top set (pics)
  204. Speaker setup Parting 1979 L48 (continued)
  205. WTB- Stock Alum. Wheel
  206. Excellant Stroker Crank
  207. cool rims for a 75
  208. F/S 7 Corvette Books
  209. WTB: SS License Plate Frames
  210. F/S Manual & Book
  211. WTB: Stingray emblems and T-Top bag/suitcase
  212. WTB 68-69 Portion Fenders Fenders and Quarters
  213. 71 Rocker Pannel Moldings?
  214. 70-74 ignition shielding set on Ebay
  215. Have a donatable item for the CF Picnic?
  216. WTB White door panels and blue carpet, blue dash pad for a 1977 Corvette
  217. WTB; License Light Assembly, 1972-1973
  218. WTB 69 Fan Clutch
  219. 68 interior door panel
  220. FS: SBC Longtubes
  221. FS: factory tach drive distributor
  222. 1982 door panels
  223. 1982 door panels
  224. FS: Coated Blockhugger Headers
  225. small part needed
  226. For Sale - 5 Original Alternators
  227. F/s: 1971 350/270hp Sb Exhaust Manifolds
  228. WTB Front and Rear Bumpers 74 Coupe
  229. wtb- T-top carrier bag for 82ce, maint book
  230. F/S 1975-79 corvette front bumper cover***pic***
  231. F/S: 770 CFM Holley
  232. Freon????
  233. F/S 1971 Chassis Overhaul Manual
  234. Wiper Motor/ washer pump for sale
  235. WTB: Firestone wide oval F 70 15
  236. WTB: Working am/fm stereo for 1971
  237. Bumper cores
  238. C3 parts
  239. For Sale! -New,unused MSD ignition parts
  240. Carbon fiber NX n2o bottle
  241. Interior dye spray can 1970-1972 Light Saddle & 1976-1977 Buckskin
  242. VDO speedo (cable driven)/ gas gauge
  243. WTB 2 1970 Center caps
  244. WTB NOS 73 tail lamp lens
  245. WTB... 81 power seat control..HELP......
  246. FS: SB chrome valve covers
  247. 1968 Corvette ralleys one year only 15x7 vette off set
  248. WTB 79 Spare tire & rim
  249. Wtb: Nos Firestone Tires Gr70-15
  250. Wtb Front Bumper Cover For 1976
