View Full Version : C3 Parts for Sale/Wanted
  1. FS / set knock-off wheel adapters $200 OBO
  2. WTB - 1975 L48 - 2" Pass Exhaust Manifold
  3. TKOS ......free shipping..AND..group purchase!
  4. BFG drag radials on 15" wheels in New Jersey
  5. FS: Complete front clip and rear suspension 79 Vette
  6. i need to buy actuators for 79-i have ???
  7. WTB front frame supports for 68-72
  8. WTB Good 80-82 frame near Arkansas
  9. F/S: 1973 Chevrolet Service Manual
  10. Still interested in a functional astrotop
  11. WTB Oil pan for 68 SB
  12. Alittle 68 stuff...327/350 short block,etc...
  13. FS shift plate, tail lite lens, hard-top tips
  14. WTB: LH and RH spindles
  15. WTB: Glas-Ra Body Work Book Vol. 3
  16. 68-75 removable hardtop
  17. WTB 71 Rallye Wheel
  18. 1982 Rear Y pipe new $60
  19. WTB: Seat back trim with hole for seatbelt
  20. 76 Wiring harnesses
  21. WTB under dash air ducts for Astro vents.
  22. lt1 big block hood
  23. For Sale: 1974 Parts Car $1200, Florida
  24. WTB 68 Corner Fender Trim
  25. WTB 68-75 Deck Lid
  26. A/C parts for 1982
  27. Still Waiting
  28. Still Waiting
  29. Still Waiting
  30. WTB Lid for cowl induction air cleaner
  31. WTB Lid for cowl induction air cleaner
  32. Locating a Q-Jet for '69
  33. WANTED: 1970 Soft top mounting bolt
  34. 77 air cleaner
  35. 1975 Corvette parts FS
  36. FS: 68-82 Roof Housing set
  37. Clutch and Brake Pedal...common to other GM Cars? 1975 L-48
  38. 69-75 tilt tele column
  39. WTB Driver Side Wiper Arm for '73 Convertible
  40. free sumped gas tank for 78-82
  41. Centerforce DF271675 Dual Friction FS
  42. WTB pistons...
  43. WTB Negative battery cable, fender piece
  44. WTB nonpower window regulators for 1970
  45. WTB/ 80-82 drivers side marker lens
  46. F/S Starter #1108430
  47. 68 AC brackets with 291 heads
  48. head light assy
  49. 75-79 Bra
  50. WTB...RH rear caliper
  51. WTB Rebuildable 78-80 AM/FM/CB with microphone for 78-80 Corvette
  52. TH350C Lockup Tranny with EXTRAS
  53. F/S Radiator Support No Rust
  54. FS: (2) BFG Radial T/A Tires
  55. 1974 Assembly Manual
  56. For Sale or Trade: 500-Piece Stingray Kit
  57. F/S 78 Rear security shade
  58. Wtd...ecm#16159278
  59. WTB double alternator pulley and armature
  60. list of pats
  61. FS: tach drive distributor core
  62. c3 parts forsale
  63. 78 plus parts forsale trying pictures
  64. WTB 68 center gauge housing and 68 radio knobs
  65. NOS Corvette horn button 1969-1976 with T/T
  66. nice 15 " rally wheels with new tires
  67. time to break up the 82 parts car
  68. WTB: 1972 Horn
  69. Need engine side bare heater box
  70. 73 l82,,2-69-386 long blocks,,
  71. WTB a compleete heating system
  72. Wtb-rear Sway Bar End Links & Brackets
  73. WTB - 68 driver side courtesy light.
  74. WTB 68 -69 Valve Cover TR bolts
  75. FS: Bare frame from 79
  76. WTB sidewall piece of a scrap 427 CI block
  77. F/S: T-top liners, starter motor, water pump
  78. F/S: Exhaust tips, master cyl, brake kit, fan
  79. big block 468 built trade for ls1 setup
  80. 1970 steering column
  81. F/S Cast aluminum Cal Custom Big Block Chevy Valve covers
  82. F/S 781 Big Block Cylinder Heads
  83. WTB: '74 A.I.R. pump pulley
  84. ground ring
  85. WTB:68 valve covers
  86. WTB Shoulder Belt Mounts for 69 Vert
  87. 81 horns
  88. Rebuild starter and water pump.
  89. WTB: '79 Pass. Side Front Fender
  90. WTB - ZZ4 Engine parts, heads, etc.
  91. F/S - Billet wheel set up for L88 flared car.
  92. '75 left lower dash pad?
  93. WTB: NJ or near: 80-82 Rear Frame Section
  94. Need C3 Side Frame 48" Rails Delaware Valley Area
  95. WTB Kick Panels
  96. New list NOS 68-72 small parts
  97. Used Hooker sidepipes (Small block)
  98. WTB: '68 Wiper Motor Assembly
  99. WTB: Good spindle for 79
  100. F/S van steel strut rods
  101. Muncie M-21 out of a '69
  102. F/S 70 Corvette SB rebuilt radiator
  103. 81 parts-air cln/gears.
  104. WTB: Kick Panels, 68-77
  105. wtb-power seat switch bezel
  106. Correct 68 AC & heads for 327/350HP
  107. Spring Cleaning Sale
  108. Steering Column Parts for Sale
  109. WTB: V-Shaped Crossmember at Nose of 70
  110. WTB Seatbelt Grommets
  111. Tremec T-5R Transmission
  112. 68 Distributor
  113. F/S Bilstein Sports "NIB"
  114. WANTED: Chevy 400 block
  115. Wtb: 1977 Seats
  116. c3 corvette headlights
  117. Need Ft Bumper For '71
  118. WTB: A/C Duct, Drivers Side Kick Panel, Windshield washer tank and pump for 77
  119. wtb-71 bb vaccum reservoir
  120. WTB - C3 Seat Tracks
  121. WANTED 80 81 82 tan / D fawn vinyl from seat covers
  122. Need 1972 horn
  123. corvette side exhaust mufflers-aluminized steel
  124. WTB - Torch Red C5 Seats
  125. Where can I get the little knob for the glove compartment on an 80?
  126. WTB an Indy Rear Spoiler
  127. wtb rally wheel
  128. 1969 parts for sale - big list
  129. 77 small block intake carb and aircleaner
  130. WTB: 68 carb base plate
  131. 7042216 Q-jet needed
  132. C3 front frame section..need anything from it?
  133. 7041204 Q-jet needed
  134. Lectric limited breakerless -SE- points conversion
  135. 1108429 starter needed
  136. WANTED-74 T-Tops
  137. 287 B-R ignition coil needed
  138. WTB: Intake Vacuum Fitting
  139. 75 exhaust and gas tank .......
  140. 1968 427-435HP block and #840 Square Port Heads
  141. 355# composite spring
  142. F/S Delco Remy Coil
  143. 80 parts for sale
  144. Want To Buy... C3 Headlight Cover
  145. 78 corvette parts forsale
  146. 1969 Corvette Big Block Smog Pump System 427 L88
  147. FS : New centerforce flywheel
  148. F/s 302 Chevy Crank
  149. need bb pulley
  150. WTB rear quarter trim (black)
  151. Need a piece of weatherstrip
  152. WTB: 'Stop' for the door glass tracks
  153. WTB Manual Steering Drag-link/Relay Rod
  154. New Alternator from my '80 L48, dont know what else it fits...
  155. FS: 1978 Corvette Assembly Manual
  156. More Misc 79 Parts for sale w/pics
  157. 350 engine
  158. wtb affordable rally wheels for 77..
  159. WTB: Wiper door/headlight vacuum relay valve
  160. 4 sale 1978 1979 good year gt radial tires
  161. For sale BBC 505 Stroker Wi $4900.
  162. F/S Brand New Rocker Arms from 385 Fast Burn Crate Motor
  163. glass t-tops (broken glass)
  164. 1969-1970 427/454 4 bolt block
  165. Needed... 79 Door hinges & window Reg
  166. Center gage set - 1969
  167. 72 Tach drive distributor
  168. WTB: 1970 CTN or CTH 350/350 4-speed
  169. WTB-70 350/350 exhaust manifolds
  170. wtb bumper 76 rear
  171. Brand New Dart Iron Eage SS SBC heads assembled!
  172. 1982 Black Seats + tracks $400 + shipping
  173. 1978 parts exhaust, spare tire, seats, etc.
  174. WTB - 68 PVC valve and grommet
  175. 1971 Radio Mono W/ Amp
  176. Brand New Accel Plug wires, $25 shipped.
  177. I need some wheel help
  178. FS Spindle Tools
  179. Hooker sidepipes
  180. Big Block & 400 Trans
  181. Willcox Forum Sale Interior Items and Weatherstrips!!!
  182. WANTED-Charcoal Canister to fit a 79
  183. F/S: VB&P Smart Struts w/HD Rod Ends
  184. WTB: Body
  185. wtb 68-69 Seats With Headrests
  186. FS 68 top frame
  187. WTB TT II Wheels
  188. FS - 68 Wiper motors
  189. Free Shipping
  190. WTB Holley Throttle Bracket for a 68-72 corvette
  191. WTB 350 ci or larger motor / engine
  192. WTB: Sidemount Headers
  193. WTB shroud top bracket ?
  194. hooker headers
  195. Wtb Set Of 79 Black Seat Belts
  196. WTB: Temp Guage for a 77'
  197. Fore sale: 900CFM Holley throttle body
  198. For sale: Low profile rectangular port intake
  199. WTB VBP Smart Struts Strut Bracket
  200. F/S Fox Raincoat
  201. FS "BRAND NEW" 1978-1979 NCRS Technical Information Manual & Judging Guide
  202. Free BB Water Pump Bypass Hose, new
  203. **WANTED** 80-82 Glass Ttop (Blue) Driver side
  204. Wtb; Rear Window Moulding
  205. WTB 69-72 front frame brackets/core support.
  206. Hooker sidetubes for sale:
  207. WTB: Q-Jet 7029207 any date
  208. WTB Used 68 -67 Delco Distributor Cap
  209. WTB: pedal assy. parts
  210. FS 68 vert deck lid
  211. FS 68 Wiper Door Assembly
  212. FS PS pump&brackets
  213. F/S '73 '74 GM Front bumper
  214. WTB: '81 Seatbelt /Tan color
  215. F.S. LS6 intake
  216. good working turbo350 from '79 vette
  217. Looking for a good repro fan clutch...
  218. 350 in NC ,Double hump heads,solid lift cam,etc Engine Ran 6s $1300
  219. 75/79 GM front clip
  220. Still looking for 1970 LT1 hood
  221. WTB holley Carb 4489 1970
  222. For Sale 1979 rear body with glass
  223. 1978 Corvette Service Manual
  224. F/S Speedo/Tach Cable Lubricator
  225. wtb/fs/trade '69 Fenders / Quarters
  226. Wanted 1982 corvette auto shifter complete
  227. Wanted 1970 454 starter #1108400
  228. Wanated 1970 454 water pump #3856284
  229. WTB Rear Package Tray '80 Hatchback
  230. Wtb: 1966-1973 New York License Plates
  231. F/S Coil Spring Compressor Tool NEW
  232. WTB: Small Guage Cluster Part, 73
  233. Vacuum Over ride switch
  234. looking for an engine or short block
  235. WTB: 68 corvette parts
  236. 74 Stingray
  237. BBC LS6 Replacement Heads FORSALE:
  238. 468 street motor with a 1969 427 corvette block
  239. FS or Trade - AC Delco RC 15 Radiator Cap
  240. W/T/B BACKUP LAMP HOUSING 68-73 (back up lens housing)
  241. F/S 68 Wiper Motor & fromt fender
  242. 80 assembly manual.
  243. need 2 '68 seat back frames
  244. f/s still more 68-72 parts
  245. F/s Nos 75 76 Dealer Brochures Nos Original
  246. WTB: Heater/AC ducting under dash
  247. FOR SALE-Glass M1131 (blue) T-Tops
  248. 1981 parts for sale (may fit others)
  249. 68/69 driver side frt inner fender needed
  250. 1974 front bumper needed/ parts going to swap meet
