View Full Version : C3 Parts for Sale/Wanted
  1. 1973 jack trade for 1969??
  2. Pot metal/chrome for 73
  3. WTB 79 Dr. Blue Seat Cushion
  4. WTB-1974 Underseat Lap Belt Covers
  5. BBC road race dry sump setup.....
  6. 72 LT1 Exh manifolds...#386711
  7. rubber front suspension kit
  8. Wanted: 1970 Wiper override knob
  9. WTB: One exhaust manifold for 74
  10. WTB Quartz clock for 71 C3
  11. F/S late 68 early 69 BB Oval port heads
  12. FS: Black Leather Seats, '70 - '73
  13. 1050 cfm Dominator/ Complete Nitrous system
  14. F/S Parts
  15. WTB 68 Wiper Blade Frames
  16. WTD: Wiper Door Trim & 68-69 Items
  17. Mighty Demon 750 Annular DP - Like New
  18. FS: 68-81 SBC sidepipes
  19. M-20 transmission
  20. Brand new OEM AC Delco Spark Plugs
  21. WTB: Body lift straps
  22. WTB: SB oil pan reinforcement
  23. FS: 69 rally wheel with firestone tire
  24. Wtb:lower dash pads 68
  25. WTB Fan Shroud, Fan and Fan Clutch for a 73
  26. WTB 74 frame auto
  27. Wtb 1982 corvette collector edition ecm
  28. Some parts for sale......
  29. WTB: Rear window Chrome Mould 78
  30. Who wants to put an ls1 in thier c3?
  31. WTB interior door handle
  32. WTB-Q-Jet Carb Accelerator Pump Rod
  33. Wtb c3 doors
  34. Blocks, Heads, and other castings
  35. WTB/Parts 73 Coupe
  36. I got 76' seats for sale... (hawaii)
  37. Rear window tint
  38. Wanted: 68 Wiper control bezel
  39. BBC Hooker Super Comp Headers
  40. Sell: Hedman C3 Sidepipe Headers
  41. 69 427 on Craigs list
  42. F/S 74 BB Intake and Carb
  43. WTB - hooker sidepipe heat shields.
  44. '77 factory roch qjet
  45. c/3 factory gas tank cover
  46. 73-76 nos a/c evaporator
  47. F/S 68 - 69 Bumper guards - a pair
  48. Various Badges
  49. W T B - Used Connecting Rods.
  50. F/S 72 Factory A/C Parts
  51. Presentation from France and search parts !!
  52. I need a new windshield wiper motor, as my old one
  53. Sunroof bag
  54. Best pricing on TT2s - who has it?
  55. Bloomington Gold patches, rare
  56. WTS: Exhaust Manifold for 72-80 Vettes
  57. F/S 3:36 1970 rear.
  58. Obi
  59. 4 AZ Rallys Wheels, Rings & Caps w/Same Date
  60. WTB: Front Pace Car Spoiler for a 1978
  61. offset trailing arms all new parts
  62. powdercoated spindalls for 82
  63. NEW Rear Dual-Mount Spring System
  64. 80-82 smart struts
  65. swaybars
  66. 72 Alarm lock tumbler with key
  67. steeroids for 80-82
  68. 72 Hood hinges
  69. Black powder coated 82 frame
  70. Body mount #3 cover plates
  71. 82 REAR END 336 Gear
  72. Big block valve cover hold downs
  73. 72 350 200 horse automatic radiator and fan shroud support brackets
  74. 72 Gas pedal rod clip, spring and pedal
  75. 69-77 Transmision to steering column cable and brackets
  76. FS: BBC Heads and Intake
  77. F/S: numerous parts from 68 suspension
  78. WTB 70 convertible under dash braces
  79. 65 327 Block
  80. F/S- 71 350/270 Left & Right Vert. Ign. Shielding
  81. FS: Headlight Assemblies from a 79
  82. wtb: 78-79 fixed steering column
  83. FS: Coil Springs $30.00
  84. FS: Front wheel hub and rotor $35.00 ea
  85. 4 sale, Newly manufactured Quardrajet Carb & other parts, CHEAP
  86. Newly remanufactured Quardajet Carb & other parts CHEAP!!!!
  87. WTB-Fan Shroud for 79 L82 Vette
  88. FS: Fan Shroud/electric fan, A-arm bushing kit, 1977 Assebly Manual
  89. FS: Zippered t-top carrier
  90. WTB: 73 454 Fan
  91. WTB - 1 AG coded 15x7 rally wheel
  92. Looking for a SBC, watcha got?
  93. Does anyone have the 73 Center Cluster assembly for DIN radio available?
  94. Edelbrock Performer RPM Nitrous Kit , Dominator flange plate system
  95. WTB 1980 wiper switch!
  96. WTB Power mirror adjusting switch (1980-1982)
  97. tech cable (USED) $10 dollars
  98. wood carburator spacer
  99. Hood support and hinges
  100. optima battery (red top)
  101. battery cable positive
  102. FS: New Autolite Racing plugs AR3933
  103. C6 Seats
  104. F/S NHRA Memphis Tickets
  105. '68-'73 Accelerator Cable, New $35 shipped
  106. Pop out rear window conversion kit, new carb, & more
  107. WTB 1982 (CE) Owner's Manual
  108. WTB 75-82 Windshield washer fluid bottle and pump
  109. BB Valve cover hold down
  110. Dual quad crossram for SBC.....
  111. WTB: '74 front and rear bumpers
  112. *1980 Parts For Sale*
  113. 65-early 67 J56 calipers....
  114. Motorhome - 4 sale
  115. F/S 1978 Pace Car Decals
  116. F/S Two K&N Filters for a crossfire
  117. '68 L71 Miscellaneous Items
  118. Small Block Heads for Sale 1968-1973
  119. WTB Distributor Weights
  120. 69 Corvette body - $500
  121. WTB: driver side under dash courtesy lamp socket
  122. Wtb-- 1979 rear speaker mounting brackets
  123. WTB Factory stereo Delco for '76
  124. WTB Ralley Wheel Rim date July 28, 70-Jan 28,71
  125. WTB removable window '77
  126. Radiator for Sale New
  127. LSx Headers & Motor Mounts For C3
  128. TKOs...free shipping.....
  129. WTB 70 seat belt brackets, on lower seat front
  130. 6 5/8" High Performance Crank Pulley
  131. F/S: 82 differential
  132. 82 throttle bodies, manifold
  133. WTB CE Pin Striping Pieces
  134. wtb headlight relay bracket
  135. FS: '70 seat covers bottoms only!!!!
  136. Wtb rear end
  137. F/S Parts
  138. Wolf car cover c3 $50
  139. WTB wiring harness, seat mounting brackets for 68
  140. Passenger Side Wiper Arm Wanted!
  141. WTB 68 body
  142. Holley 3660 center carb
  143. WTB: Heat shield for composite / fiberglass rear spring
  144. WTB 1982 Fuel Tank Sender Bracket
  145. LT1 shortblock for sale
  146. F/S REAL 4x6 1979 front speakers L@@K
  147. 81 glass t-tops
  148. Need Throttle Cable for 69...
  149. Billet specalties wheels and falken tires
  150. ******delete******
  151. *77-82 Aluminum Rad*
  152. WTB 80-82 hi/lo horns
  153. F/S C3 Convertible top frame
  154. Looking for 72 dash brace
  155. F/S L88 Hood 68-72
  156. 1968 427-435HP Block
  157. FS Black/Black Hard Top
  158. WTB: 68 427 390hp short block
  159. ATI Procharger 12 rib crank pulley sbc
  160. WTB Interior paint Med Red
  161. C3 parts for sale take a look all prices obo
  162. Hey guys!! Female in need of help! LOL
  163. R12 full 30lb can $400
  164. F/S Front Brake Calipers off 71 Stingray
  165. F/S Door Panel Trim Parts
  166. WTB: C3 Front Hub, 1969 & Up
  167. WTB Sidepipes
  168. WTT Rims
  169. F/S 570 Holley Street Avenger Carb
  170. Stock looking handle for Hurst Shifter $65 shipped
  171. Rally Wheels
  172. for sale:time sert, repair stripped out threads in rear cover
  173. WTB: 73-74 Air Cleaner BB ring
  174. WTS Covercraft car cover
  175. WTB A-pillar black only drivers side 71-74
  176. WTB 68 radiator support
  177. Hood release cable & latches, door hinges
  178. Tach, Speedo, Gauges, Lower Dash, Antenna, etc.
  179. T tops, alignment housings, chrome center
  180. WTB - Hood Surround Panel Braces
  181. WTB heads and trans
  182. Elklers canam body kit for C3
  183. FS: 75-82 headlight assemblies
  184. FS: 65-75 Trailing arm bump stops
  185. FS: rear strut rods 63-82
  186. FS: 63-82 strut rod camber adjusting bolts
  187. FS: 63-77 center rear spring mount plate
  188. FS: rear differential/spring heat shield
  189. FS: NEW 4.11 gear set
  190. FS: 3.08 gear set
  191. WTB 69 under dash flexible air ducts
  192. WTB: 1969-1975 steering column
  193. F/S- Windage Tray Bolts
  194. WTB air cleaner 73/74
  195. F/S Q-Jet off 78 L48 auto #17058204
  196. F/S Sport Mirrors
  197. F/S Two Seat Backs and Center Bezels
  198. F/S - Seat Cover Foam
  199. F/S - Leather Seat Covers
  200. F/S 1979 fiberglass T-Tops (silver) w/Oyster liners
  201. F/S 1977 Tilt/Tele Turn Signal Harness - New
  202. 1969 sidepipe covers rechromed $1600
  203. FS PPG Red Base Clear Paint System
  204. wtb:78 Pace car decals.....
  205. 1970-1977 Early T-Top Weather Stripping
  206. WTB complete differential
  207. WTB 73/74 stock air filter
  208. WTB: 77 Drivers side seatbelt
  209. f/s 1968 Only 4spd Shift Plate with AC
  210. WTB Lakewood Bellhousing
  211. Original Carpet? WTB
  212. 25" Battery Tender extension cords
  213. WTB '69 427 Intake Manifold
  214. WTB 1980 Black Dashboard (Not just Cover)
  215. GM Part Book
  216. 1972 LT1 Complete Drive Train-Engine, Trans, Etc.
  217. F/S Seat Tracks 75? all 4
  218. New 73-79 Corvette Inner Fenders - Lt & Rt
  219. WTB Rear window louver
  220. Assembly Manuals PDF CD format 68-72 73-82 are back on the Forum Special Section
  221. F/S 68 factory mono radio w/Amp (not working)
  222. Wanted 76 seat upholstery
  223. WTB 69 - 77 cowl back body
  224. Free/New 1968-69 SS Exhaust Tips
  225. F/S- 71 OEM 350 Orange valve covers
  226. WTB Centerline Autodrag Centercaps
  227. LT1 350/370HP Long Block for sale
  228. BB Engine Parts
  229. Wtb
  230. WTB 73 Smog Tubes
  231. WTB 68 400 tri power
  232. 327 motor $1000
  233. Edelbrock Carb, EDL-1407 750 cfm $105
  234. 1980 L-82 Cooling system parts
  235. 68/69 Front Clip
  236. WTB-72 Coupe Rear Carpet Only
  237. FREEBIE 2" Aluminized Exhaust System - 1976
  238. AutoTwirler Plus Rotisserie Wanted
  239. [WTB] Radiator support
  240. *VBP 63-79 Rear Dual-Mount Spring System*
  241. 1.6-1 rr's
  242. F S - Vortec Heads.
  243. F/S 69-77 Seat bottoms MINT! Pictures
  244. WTB: fast idle solenoid for 1979
  245. WTB 67/ 68 Antenna Mast
  246. WTB Fan shroud, extension & rad support
  247. wtb 74 front urethene bumper
  248. WTB a '69 Tansmission
  249. F/S C-3 Parts
  250. Seat Backs 70-77 FREE!!
