View Full Version : C3 Parts for Sale/Wanted
  1. FS bumper, speedo and tach, and others
  2. WTB: center cap, horn button, pass. door pull
  3. F/S New A/T Cooling lines for 82
  4. F/S TH350 Transmission with stock converter $200.00
  5. wtb pr of torq thrust d's 15 x 7 Used in nice shape reasonable
  6. Wanted: window motors for '81
  7. T-top storage bags for sale
  8. F/S misc parts
  9. Pro Comp / DUI HEI Tach Drive Dist 62-74
  10. MSD Pro Billet Distributor NEW PN 8572
  11. WTB: 68-73 rear bumper brackets
  12. C3 68-69 Carb and rally wheels for sale
  13. rear lower shock mount brackets
  14. FS: left rear bumper 68-73
  15. FS: rear window for 73 (or maybe late 72)
  16. For Sale: 1969 Corvette standard steering column
  17. WTB: 1969 horn button for tilt/tele
  18. fs 76 AC Parts
  19. WTB: Passenger side metal floor heat shield for '72
  20. FS 69 tripower
  21. FS: Rear Fiberglass Bumper
  22. c3 headlights for sale
  23. FS,Painted tops,1978-1982.
  24. FS,N.O.S. gage set.1978-1981.
  25. WTB: 1973 Big Block 454 Manual Exhaust System
  26. I'm looking for an original set of the corvette seat mount bolts to body.
  27. besd blasting cabinet f/s
  28. S/B parts for sale!!!!
  29. WTB nose protector/bra for 77
  30. WTB 403 or 383 bellhousing
  31. F/S Rear Crossmember Mount Bushings
  32. F/S Complete antenna assembly from a 77
  33. 70 corvette doors with glass $50 for both
  34. Pre-86 Valve Covers FS Balled Milled Design
  35. parts..parts...parts....
  36. WTB 1971 454/365 auto. carburettor
  37. BB PS complete/conversion....
  38. WTB - 69 R Fender Upper Mldg & R Upper 1/4 Trim
  39. Lunati BBC springs FS -brand new!
  40. F/S - 68 - 69 shifter console with fiber optics
  41. F/S PO2-Heads-Intake-Carb-hood
  42. F/S new carpet
  43. WTB - complete headlamp assemblies for -69
  44. WTB - Pace rear spoiler
  45. Wanted - SS Intake Washers
  46. ***Important Information from FLATOUT IMAGING please read!***
  47. LT-1 1970 Aluminum intake
  48. wtb-vacume check valve,pw relay
  49. F/s 78-82 rear window
  50. For Sale:Red powder coated L82 valve covers
  51. 1969 Dealers Brochure & Chassis Manual FS
  52. WTB: One 69 RH Fender Grille Louver
  53. WTB:1976 Corvette Owner's Manual
  54. L82 Valve covers for sale
  55. F/S - 69 door panels with power windows
  56. F/S GREAT DEAL!!!!LOT DEAL on parts /DOOR PANELS/HOOD EMBLEMS and MORE!
  57. wtb rear tail light panel 1973
  58. FS: Parts from my '69
  59. 70 - 75 Dark Saddle deluxe door panels * NEW*
  60. L-88 on boston craigslist
  61. FS: 1979 L-82 Y pipe & converter
  62. WTB Jack Storage liner for a 70
  63. wtb power window connector
  64. FS: 81/2 red leather/DS power
  65. 77-82 Radiator Overflow Tank & Cap
  66. WTB:Power steering pump for 76
  67. Looking for 71 Green hood, and T-Top
  68. FS - Set of Trim Rings & Caps & Set of P02's
  69. F/S Aluminum intake & 750cfm quadrajet
  70. Dual Snorkel Air Cleaner
  71. WTB - Original STEREO Radio for 1971
  72. various bushings and misc.
  73. new 69 4 speed shifter $ 80
  74. FS, Complete Set (3 parts) Original 1971-72 Front Grilles
  75. WTB '69 427 Main Engine Components
  76. WTB: P/S pump bracket 454
  77. LT1 and SBC stuff
  78. C3 pn 14011819 lh door handle assy
  79. FOR SALE: Used 2004-r Transmission
  80. WTB - Fresh air door assembly
  81. FS: Christmas Stocking Stuffer -19 Bloomington Gold & Funfest Pins 1996 - 2006
  82. F/S 63-82 HPC coated SB Headers $200 BIG PICS
  83. WTB BRODIX SB heads
  84. 435 Carbs For Sale
  85. WTB:70 Ignition shield L brackets and Misc.
  86. 71 BB heads casting 820 with 396 (961)
  87. 68 69 Corvette Speed Warning Gauge Needle NOS GM 6481210
  88. WTB L-88 Hood 68-72
  89. WTB: 1970 LT-1 fan & fan clutch
  90. wtb 1978 ignition cover
  91. [PRINTS]FINAL CHRISTMAS SALE! Corvette Christmas for 20$[PRINTS]
  92. Have 4:11 Posi Want 3:36/3:08 - Swap??
  93. need alum intake for 68' 427
  94. M21 & parts....800.00 shipped
  95. corvette side pipes - $300 - craigslist ad
  96. rear end parts for sale
  97. WTB - 1971 Set of 4 15x8 Rally Wheels
  98. WTB - 1971 15x8 Rally Wheels
  99. New ACC black carpet for 70-75 50% off
  100. Wanted alarm horn for a 73
  101. WTB: Bumper brackets
  102. F/S - Durablock 007 HVLP spray gun
  103. WTB: 5 Port Washer Pump White Valve Body
  104. NEW Half set (eight) Trick Flow full roller rocker arms
  105. looking for a window motor
  106. F/s 78-82 corvette rear window $50
  107. FS: L82 valve covers original OEM
  108. FS: Bumper extension
  109. F/S YJ8 Aluminum Wheels
  110. looking for 69 radiator support for factory aluminum radiator.
  111. body lift strap
  112. WTB 1970 BBC Radiator fan shroud
  113. WTB 1970 BBC Hooker Headers – Right side only – Chrome side mount style header manifo
  114. WTB 1970 Front cross member under radiator
  115. WTB Stock 82 oil pan
  116. F/S 454 Air Cleaner Adapter Ring w/seal
  117. FS corvette 68-77 radio working-listen video
  118. WTB Fiberglass t-tops
  119. WTB: 12-bolt differential
  120. WTB: Rear roof molding retainers & screws
  121. 1970 - 71 454 Intake Manifold
  122. 1969-75 Original Steering Wheel
  123. Sportsman II heads SBC
  124. WANTED....BFG 295/50/15s...
  125. F/S 68-72 Front Bumper 68-73 Rear Bumper
  126. F/S Parts
  127. 70 lti intake and carb
  128. WTB 1974 C3 rooftop luggage rack
  129. WTB: Jack for an early 69
  130. WTB 69 driver side fender center of wheel well forward
  131. WTB-72-BB Tach 5600 Redline
  132. F/S Poly control arm bushings
  133. F/S 2 x 17x11 VWW V48's with tires, you'll need flares
  134. WTB odd request vacuum switch cover
  135. FS - (4) P02 Wheel Covers
  136. C3 parts
  137. WTB Conv door guide receiver mounting brackets
  138. misc parts for early c3
  139. 70-72 Front Grills
  140. 68 thru 72 Hardtop
  141. FS: NOS Parts (LIST in Ad)
  142. FS: T-tops
  143. cleaning garage-parts must go
  144. C3 rear diff
  145. Edelbrock EDL-2101 PERFORMER MANIFOLD , EDL-2102 PERFORMER CAM KIT
  146. WTB: 1969-1972 T/T horn button
  147. F/S 1967-8 Tele Steering Column
  148. F/S Parking Brake Console 1968 Pwr Window
  149. Rubber Oil Filler Cap GM NOS 71-74
  150. wtb upper windshield frame c3
  151. Clock Core
  152. WTT 68-75 Black Canvas Top For White
  153. Moroso Valley baffle New in Package
  154. Cast Aluminum Valve covers, PCV, breather
  155. Chevy Large Bellhousing for 12" clutch
  156. SBC balancer
  157. WTB: 68 LH convertible top rear latch
  158. Wanted to Buy: '69 storage door latch bezels
  159. F/S Black Aftermarket lap Belts w/Chrome Buckles
  160. WTB C5 Seats
  161. WTB: 70 Winshield trims
  162. WTB 1975-76 Gas Door Sunburst Emblem
  163. Chilton's 63-79 and assembly manual '72
  164. 72 LT-1 complete drive train FS/Craigs list
  165. New 1969 Engine Harness, from Lectric Limited.
  166. FS: New set of 77 to 82 Horn Button parts
  167. FS: Lower A-Arm Bumper
  168. FS: New Sway Bar Links. W/Urethane Bushings
  169. FS: New A-Arm Bushings. 8 Piece Polyurethane
  170. FS: New set of upper and lower ball joints
  171. F.S. 1982 front clip, front bumper, rear bumper
  172. WTB--Body Lift Kit Straps
  173. Small block dual quad setup
  174. 1974 corvette rolling frame
  175. 68-74 BB PS setup...complete...575.00 SH
  176. Parting out 75 350-4spd coupe
  177. WTB. convertible cowl brace kit
  178. Need late 69 186/414 heads for LT.....
  179. WTB: 1969 Dash Support
  180. WTB: 70 V shields
  181. WTB: original 69-76 Ebrake console w/PW
  182. Smog Pump Hose 81 'vette
  183. WTB: GM/ NOS Air Cleaner Lid for '68 BB
  184. WTB 1972 seat trim
  185. Wtb hooker side pipes bb auto 1974
  186. WTB rear end for 1979
  187. 3927186 heads and other top end parts
  188. 3927186 heads and other top end parts
  189. F/S: Brand New Sealed Gas Cap
  190. WTB or Trade for Procharger Set up for sbc
  191. F/S: 68-77 LH and RH Vertical Ignition Shielding
  192. Poly Trailing arm bushings for 63-82
  193. Borla Exhaust
  194. WTB 68 Hardtop
  195. -*FS: Kenwood KRC-405 stereo*-
  196. F/S Complete SBC Top End - Proven HP & Performance
  197. 1966 Big Block #390 Oval Port Heads
  198. For Sale: 1972 Corvette coupe body
  199. WTB edelbrock 3701
  200. LT-1 cam
  201. F/S '81 parts - Low prices, cleaning out garage
  202. WTB 1979 chevrolet warranty manual
  203. 1975 rolling frame for sale.
  204. 68 ORIGINAL L 79 Valve Covers
  205. shifter hurst
  206. F.s.brand new track day helmet,cheap!!
  207. wtb rear window kit
  208. 73 cowl induction air cleaner
  209. Looking for NOS Non-AC wiper bezel for 71 and interchangable years.
  210. WTB Dash pad for 81
  211. Balanced 468 rotating assembly big block
  212. Willcox New Sale Launched! New Items for Forum members Only.
  213. Anyone heading from NJ up to New England?
  214. Rear glass for a 79 L-82
  215. For sale - 4 Goodyear Eagle ST w/mag rims - Like New
  216. ****Customer Testimonials! FLATOUTIMAGING.COM Prints!****
  217. For sale rear clip for 74 up C3
  218. Wtb... '78/82 drivers side seatbelt retractor
  219. Mallory Dual Point Distributor w/ tach drive
  220. corvette rolling frame
  221. WTB:1977 Driver side window glass
  222. 850 holley Double pumper
  223. 850DP Holley carb
  224. stock 69 shifter
  225. 1972 LT1 Engine Trans Rear End Complete Drivetrain
  226. Trade: Centerforce dual friction 10-spline for 26-spline
  227. For Sale NOS vinyal seat material.
  228. SBC Solid Roller cam...excellent conditon!!
  229. 1968 990 Big Block Heads
  230. F/S - 69 Interior parts- great shape
  231. Wilwood Holiday Special!
  232. wtb weather stripping above windows
  233. Small block intake and ignition
  234. WTB: Vented Gas Cap for '70
  235. F/S: zz4 Small Block Crate Motor...
  236. 68-72 inside mirror
  237. 1968 Corvette seats with tracks
  238. charcoal cannister and all hardware 1982
  239. FS Original 68 Driver Side Mirror
  240. f/s 1965 diff housing
  241. WTB Non A/C Duct
  242. wtb upper windshield frame c3
  243. Anyone have a pair of "catches" for 68 seats, not sure what other yrs have them.
  244. F/S---Spare Tire Carrier Parts
  245. WTB: Working Lap Belts for a 1973
  246. WTB or Trade shifter
  247. WTB '69 BB Parts
  248. Dear Mr. Willcox...
  249. Side Pipe rear panel and Bubble tail light lens
  250. Durango_Boy Where are my Vortec Heads???
