View Full Version : C3 Parts for Sale/Wanted
  1. fixed headlights
  2. Want to buy rear camshaft plub for '73 350
  3. For Sale LT1 motor
  4. WTB Used TriPower Air Cleaner Base
  5. Mirrored T-tops
  6. Stock/origninal engine parts for sale
  7. WTB 69 Spark Plug Shields for SB 350
  8. WTB - Sun Visor
  9. Restoring 1978 Vette
  10. one pair original shoulder harness
  11. Any intrest in some used reverse flow inserts?
  12. WTB Lower passenger hinge for a 79.
  13. Nostalgia wheels and radial tires
  14. FS Poly A arm bushings
  15. WTB: Used L82 valve covers, air cleaner, ducts etc.
  16. WTB hooker max flow side pipe inserts
  17. 1970 Owners Manuel
  18. WTB:75 Rear Quarter Panel Retainers-Coupe,upper parts!!!
  19. sidetubes wtb
  20. FS - C3 Sway Bars
  21. Free smog equipment from a 77
  22. wtb: hurst shifter and linkage for 81
  23. C-3 Polyurethane Body mounts
  24. F/S 1970 Shift Plate 4 speed No A/C Real Nice
  25. F/S 70 coupe quarter trim R&L Black
  26. Polyurethane Front Control Arm Bushings
  27. WTB rear crossmember bushings
  28. WTB.....1974 Door Panels - OXBLOOD
  29. FS C3 Mirror-Like Plaque
  30. seat belt parts
  31. PO2 Emblems
  32. WTB: '69 Driver's side window
  33. rear spring poly bushings new
  34. E-68 Stainless convertible header trim FS
  35. 68-72 L-88 hood FS
  36. Update for total restored 1970 Roller/w/ motor
  37. WTB - Windshield Left Upper Corner Molding Trim
  38. WTB: Electric chain fall (winch)
  39. Wtb 1974 wiper console
  40. 78 Misc. Parts for Sale
  41. Disc Brake set up for sale
  42. Exciting C3 Corvette Art Ads Posters Prints Giclees at CruiserBlvd.com!
  43. 3" X Pipe
  44. WTB 74 coupe seatbelts
  45. WTB smog pump
  46. wtb L88 style hood for 77 vette
  47. 69 Rear window latches---Rebuildable?
  48. 68-69 factory upper dash support
  49. FS Mickey Thompson Polished Valve Covers
  50. FS NEW BLACK Lap Seat Belts
  51. Original (Used) 73-75 hood Insulation
  52. FS 68-82 Interior Weather Boots these are great...
  53. WTB 1970 T/T steering column......
  54. F/S New polished aluminum TTII’s 17X8 and 18X10 with tires.
  55. WTB 75-77 Tach
  56. WTB: Intake Manifold Vacuum Fitting (Pic)
  57. WTB rim for 69
  58. WTB: Edelbrock Air Gap Intake (part#7501)
  59. WTB 75 Starter Motor
  60. FS Case of R134 Freon
  61. Wtb amtops
  62. vbp front susp. and rack & pinion for sale
  63. Wtb headers
  64. I need rocker molding for a '79.
  65. 68 to 71 T tops
  66. Hooker Sidepipes and Headers- Big Block
  67. WTB <-------- 1976 Door panels ---------> WTB
  68. T-Tops off a 72 I think???
  69. 69-72 stainless molding for wiper door
  70. Wanted C3 steering weel 69/75
  71. 1968 Chrome front grills
  72. 1972 Vette aircleaner Ram Air type
  73. F/s efe switches & misc
  74. L88 Style Hood for 1978 Wanted
  75. WTB tilt front end clip Flares custom stuff..
  76. WTT Big Block H70 Finger Fan for G through L71
  77. WTB rear spoiler for 79
  78. Wanted to trade or buy original instrument bezel
  79. WTB 1970 AZ rally rims
  80. Wanted Qjet 7042203 for 72 350/200 mt
  81. WTB 70 conv rear body tub area
  82. WTB - Holley fuel block and lines for LT1.
  83. '74-82 Junction Block
  84. Dimmer Switch Pedal & Hood Alarm Bracket
  85. '74 Proportioning Valve, Master Cylinder & Booster
  86. '74 Steering Column Bracket & Support
  87. '69 Coil Springs and Front Sway Bar
  88. Need R12
  89. WTB - Composite rear spring for '71
  90. Wtb: Jack/handle for 69
  91. Good complete seats from a 1976 for sale
  92. 68 Suspension and drive parts FS
  93. 82 BODY Good Title
  94. Build your own C3 for $800!
  95. 1976-1979 OEM urethane rear bumper cover
  96. FS - 1968 Correct 4sp Shifter
  97. F/S 68-69 red Shift Console New
  98. 1965-1979? Trailing arm assemblys
  99. Wanted Custom parts
  100. '79 Half Shafts for Sale
  101. Anyone have a pair of 487x heads for 72?
  102. W.T.B. power plug for delco radio 68-7---
  103. WTB Speedometer or Tachometer Bezels
  104. WTB: '73 A/C Condenser Mounting Brackets
  105. 1979 Steering box Corvette low mileage For Sale
  106. WTB: 68-73 Rear Defogger switch
  107. WTB: Hooker Headers and sidepipes
  108. F/S Hydraulic Release Bearing
  109. WTB: 1977 Floor Pan
  110. Horn Relay Well Nuts?
  111. Misc 81 Parts
  112. Who has a 68 parts car?
  113. 1968 427 - 390 aluminum intake #3919849
  114. Parting out 76 & 79
  115. WTB Original Rear Spring for a '69!
  116. New Autogage Monster Shift-Lite Tach for sale......
  117. New Autogage Monster Shift-Lite Tach for sale......
  118. F/s 82 nose-gas door emblem
  119. 1980 seat hinges
  120. WTS: 1964 Rear Wheel Spindles
  121. Modulator "pipe" - 73
  122. 69 SB Accelerator Bracket
  123. 66 radiator, not a leaker
  124. WTB 2 groove power steering pump pulley 65-74 BB
  125. 1982 CE Corvette Hatchback Window
  126. Want to buy Tom's Diff outer axles (spindles)
  127. 427 block for sale
  128. FS Big Block Chevy engine
  129. wtb 1974 Air Cleaner assembly
  130. FS: 81-2-RedLeatherSeats/DS-Power
  131. FS - C3 VB&P Aluminum Hub Rotors
  132. Original dated 1969 aluminum radiator
  133. 70-76 CHROME hood latch components L&R side
  134. Frames for sale 70 SB,71 BB, & 80 sb
  135. FS "Corvette Dr" Roadsign
  136. RESTOROD- Complete brake package!! C6Z51 rotors/brackets, C5 Calipers, and pads!!!
  137. F/S or TRADE: 1968 and earlier alternator
  138. Lost a 'T'
  139. WTB: 75-77 Tach
  140. C4 Side View Mirror Bras
  141. looking for a 69-72 SB radiator support for alum rad.
  142. Wanted: Holley carb off 71 LT-1 with number 4801.
  143. Wanted lt1 intake 3959594 off 1971
  144. 70-72 Center Grill and 69-76 Speaker Mounting Brackets
  145. FS 1969 427 351 Bare block
  146. WTB Rear Valance Panel
  147. Need Help
  148. 74 Cowl, $75
  149. WTB: 1968-1969 Good Body - Unhit for restoration
  150. WTB Aeroquip socketless hose
  151. Super T-10
  152. 1977 Corvette Parts
  153. NEW DATED overflow tank- 1969, 1970
  154. WTB: Hooker Sidepipe Mufflers
  155. 82 Collector edition rims with tires
  156. WTB: Delco Air Shocks
  157. used performance parts 4 SALE
  158. For Sale Polygraphite bushings $50
  159. For Sale, front brake hoses $20
  160. WTB: Early c3 t-top or t-tops
  161. F/S 82 Air Filters (4)
  162. WTB exhaust mainfolds 68 big block
  163. WTB:GM Distributor Connector
  164. ** Kenwood Excelon KVT-915DVD-TV NEW **
  165. Corvette emblem fell off my 1980 vette..need one
  166. Vette magazine Zora memorial edition
  167. origional Rally rims and tires off a 1976 for sale
  168. F/S 5 F70 15 Goodyear Polyglas tires
  169. Nice Rally's for sale cheap!
  170. CruiserBlvd.com sale ends tonight March 8 - 20% off + Buy 5/1 Free Corvette Art Ad
  171. 1968 BBC Heads and Aluminum Intake
  172. WTB-rear window lock latch bezel trim part for a 70-pic of what I'm looking fork
  173. FS- 3M soft foam masking tape- 3/4 of a Box
  174. ***wanted: '69 l88 hood***
  175. 70 aluminum radiator, 68-69 metal shroud
  176. FS: NOS Weather Strips for 69 - 75 Coupe
  177. 1970 convertible
  178. original speakers wanted - 73
  179. Hookers and a couple motors
  180. FS: C3 Tail Lights
  181. Radiator Support
  182. Rotella 15-40
  183. FS: 330813 water pump for small block
  184. FS: front exhaust pipes for LT-1
  185. Wtb power mirror switches
  186. WTB '70-72 Orig. Exhaust Bezels
  187. WTB - ZZ427 BBC cast valve covers
  188. WTB:GM Distributor
  189. 1979 Rims & Center Caps - Charleston, SC
  190. C3 NOAH Outdoor Cover, near new $ 75.00
  191. C3 Indoor Flannel Cover $ 75.00
  192. 1972 Parts - WTB
  193. Q-jets for sale
  194. fs: 1969 427 512 4 bolt block
  195. 291 Double hump heads
  196. F/S 78 parts - carb, manifolds, intake, a/c, fan, etc.
  197. WTB V-strap for tire tub
  198. Hooker Side Exhaust
  199. FS,Painted T-tops,78-82.
  200. WTB Luggage Rack Mounting 8 Bolt Kit
  201. WTB Black Door Panels for a 75 w/power windows
  202. FS `71 black door panels/original GM
  203. 1976 Vette AirCleaner Ram Type
  204. C3 700 R4 crossmember For Sale
  205. WTB: Left side Exhaust tip - 1971
  206. New H4 Xenon & Halogen light conversion kit
  207. Anniversary Edition Console Plate
  208. Black Leather C5 seats (look good in C3s)
  209. WTB:T-clip for washer hoses
  210. WTB - Little L-bracket that holds the 68 Fan shroud
  211. Pop Out Rear Window
  212. Nostalgia wheels and radial tires
  213. FS Holley 650 Dual Feed Spread Bore
  214. FS B&M Deep Aluminum TH350 Pan
  215. Fs new tci trans temp gauge
  216. F/S Used 1980 Red Mounted Seat Covers on Foam
  217. F/S HOLLEY 3367 CARB for '66 327 DATED MAY '66
  218. Speed Direct Rod Links Clutch Linkage (New)
  219. 1970 misc parts
  220. Smog Pump: Probably a dumb question, but...
  221. 1982 collector edition rims for sale or trade
  222. Wanted to buy or trade for: Bright Blue Interior '69
  223. FS - MSD 7AL Ignition
  224. 76-79 fiber rear bumper
  225. 1977 parts car F/S
  226. 1982 Corvette harness cover
  227. WTB Corvette Fever Aug '94 issue
  228. WTB 82 700r4 auto trans dipstick and dipstick tube.
  229. F/S 4 speed shifter mounting bracket
  230. FS rebuilt a-frames
  231. WTB:1975 left side or the set door wheaderstrip (new)??
  232. WTB:1975 Font spoiler air dam????
  233. WTB:1975 Spare tire carrier tray UPPER????
  234. Trade 1971 Vert top for 1967 Vert top
  235. WTB Shark Bar for 69 vert
  236. WTB Dash Pad for 76
  237. WTB Luggage Rack
  238. WTB Side Exhaust
  239. WTB original type luggage rack tips
  240. For Sale Halogen Headlight
  241. 15X7 ralleye rims refinished
  242. "Original" GM Air Conditioning Belt
  243. For Sale 70-73 Exhaust Bezels
  244. For Sale A 348 C
  245. WTB - Lower spark plug sheilds
  246. 63-82 Prothane Poly Control Arm Bushings
  247. 68-77 Trip Odometer Reset
  248. Original AC PF 25
  249. Center Cap
  250. 1977 Corvette Service Manual
