View Full Version : C3 Parts for Sale/Wanted
  1. 1970 454 RPO LS6 heads
  2. For Sale 72 454 Intake manifold
  3. WTB:76 driver side lap shoulder belt
  4. FS: 77 Lower Dash Pads & Center Console W\Inst.
  5. Stereo amp
  6. 68/69 quarter trim pieces....
  7. WTB - 2 Lower Control Arms
  8. lots of parts for sale cheap! C3, C4, C6
  9. F/S: 4 New Coker 215-75R 15 Redline Radials & Repro Rallys
  10. F/S 1969 Corvette Interior Door Panels
  11. FS: (4) 255/45/17 & (2) 295/35/18 Firestone Firehawk Wide Oval Tires
  12. WTB 15X8 Rally Wheels (2)
  13. WANTED-15X8 Rallys-Chicago Area
  14. WTB vacuum holding tank for 71
  15. label vehicle certification
  16. FS: 77 Tail Lights
  17. FS: 77 Trim Rings & Center Caps
  18. FS: 2 1/2" SB exhaust manifolds and pipe
  19. Trim Rings
  20. WTB Blue Kick Panels and
  21. Rally Rim ?
  22. F/S '68 427 390hp intake
  23. looking for plastic piece of dual snorkle air cleaner 79-81
  24. Windshield polishing kit
  25. lf headers
  26. F/S: C3 1973 corvette parts
  27. 68-76 Black T/Top Liners
  28. Well Nuts - 82 Collector
  29. FS Muncie M20
  30. F/S:Hurst Comp Plus Shifter
  31. F/S: RH Headlight Assembly
  32. C3 Steering Wheels
  33. WTB 68 Rocker Panels
  34. NOS Delco R59 Battery 68 & 69
  35. 69 512 427
  36. WTB Leaf spring ( 7 Leaf)
  37. Wtb wiper door actuator and bracket 69 late-72
  38. 1982 Collector Edition T-tops Clear/Bronze
  39. WTB Door Vapor Barrier
  40. M22 on Craigslist in Atlanta area
  41. 1980 L-82 Side Fender Emblems
  42. FS 1 Goodyear goldline 7.75x15 belted on steel wheel
  43. dash light holders
  44. NEW ITEM: C3 Insulation Kit!!! $100
  45. intake #14044836 for sale
  46. Looking for hookers and heads from our supporting vendors
  47. aluminum intake, late 70s/early 80s
  48. F/S - New in Box AGR High Performance Power Steering Pump
  49. F/S Original GM Sidepipe Covers
  50. F/S Front Brake Dust Shields
  51. LT-1 engine for sale
  52. Wanted 74 silver interior parts
  53. F/S - Rear Differential
  54. WTB - Rear Tail Light Housings for 1969
  55. F/S: 70 or 71 AM/FM RADIO
  56. F/s: 72 am/fm radio
  57. F/s: 73 am/fm radio
  58. L82 Alum Intake
  59. F/S 1978 steering wheel
  60. WTB 77 C3 LH Lower Ign. Shield
  61. F/S Heavy Duty Kwik Lift
  62. WTB Original 1972 Small Block Parts
  63. F/S 1975 Parting out
  64. F/S: 427 12pc Heater Hose Clamp Kit
  65. 77 used Break booster and master
  66. 77 used window motors with gears
  67. F/S 82 Rear end DIFF with Half shafts
  68. Baldwin Motion Wheels Fronts only
  69. WTB: Drivers Side A/C Duct
  70. WTB:Walnut or Wood Auto Shift Knob for CE
  71. F/S: SS Exhaust Stud Kit
  72. F/S: Rear Strut Rod or Transmission Mount Kit
  73. F/s: 68/69 427 intake manifold nipple
  74. F/S: New Side Exhaust Muffler Attaching Kit
  75. F/S: BB Heat Riser, New From Paragon
  76. F/S NEW Power Steering Pulley 75-82
  77. WTB: 1969 water temp gauge
  78. speedometer and tachometer
  79. 76 Stingray Interior Parts
  80. F/S - Turbine Air Fed Hood/respirator
  81. FS-'69 AM/FM radio, amp, wire harnesses
  82. LOTS 82 Collector Edition PARTS, ENGINE, 700R4, Rims, MORE!!!!!!
  83. WTB wiper door parts (68-71?)
  84. 78 donor car
  85. Free A-6 Compressor
  86. F/S NOS 69-82 Door Handles
  87. FS 1974 Corvette Doors
  88. FS: (ks) NEW 73-82 Body mounting kit
  89. FS: (ks) new 68-77 inside door controls
  90. F/S New Spare Tire Carrier w/ Hardware
  91. FS: (KS) NEW black rear compartment door assembly 78-82
  92. Seats for sale, custom upholstery
  93. F/S Dated Jack 9K25
  94. 76-82 New 7 Blade Fan
  95. SPEEDOMETER TACHOMETER Corvette Bezel
  96. F/s 69 vette parts
  97. F/S 69 vette convertible top
  98. FS, 79-82 power antenna
  99. FS, NOS 78-e79 power antenna
  100. 69 vette parts for sale
  101. Where is a good place to purchase chrome sidepipes
  102. WTB Blue '72 Seat Belt and Buckle
  103. WTB Original Early 68 427 Fan Clutch
  104. NEW 68-82 Jack and Handle
  105. WTB Edelbrock SY-1 intake
  106. F/S C3 Airconditioning kit New in Box
  107. Free to good home! Seat cover
  108. WTB 78-82 fixed mast antenna assembly
  109. F/S 1968 telescoping steering column
  110. 78 passenger door
  111. For sale long hood with vent
  112. 1980 Assembly manual
  113. Free shipping for PayPal customers this week at CruiserBlvd.com >> Corvette Posters
  114. For Sale AC PF 25 Non Duraguard
  115. For Sale A 348 C
  116. Original Air Cond. Belt
  117. F/S - Brand new Corbeau Forza seat
  118. F/S - 68-75 New Carpet Insulation Kit
  119. FS - Seat Frames/"Clam Shells" - 1979-1982
  120. wtb 1968 interior parts, black
  121. FS:NOS A329C Air Filter
  122. WTB - Door Hardware Screw
  123. Various Parts
  124. WTB - Shoulder Strap Seatbelts in "Oxblood" Color to match interior of 1973 Vette
  125. FS: 78, 79 Rocker Panels
  126. 1969-72 Smog Pump Pulley
  127. LS6/ LS7 BBC heads - Pair
  128. FS: muncie four speed shifter
  129. FS: Smog pump and diverter valve 68 style with relief valve
  130. FS box of rear end peices
  131. FS: smog system from 72 LS5
  132. Fs 462 fuelie heads
  133. WTB - Convertible Top Installation DVD
  134. 75-79 Corvette Frame
  135. F/S Big block oil pan....original GM
  136. WTB: ALL Stainless Steel Interior Screws....
  137. Want To Trade: Rubber body Mounts for Poly Body Mounts
  138. F/S 1968 Heads 3917291 B 5 8 and B 7 8
  139. FS - 1974 Rolling Chassis/Frame VGC
  140. FS: Complete 700r4 set-up
  141. GM Goodwrench Engine: $500
  142. Kwik-lift
  143. WTB: fiberglass piece from front top surround
  144. WTB: 70 -75 Convertible Deck Lid
  145. FS: C3 misc
  146. WTB center grill, '74 anyone?
  147. wanted 390 or 411 gears for 70
  148. Original 1966 corvette small block radiator
  149. WTB Chassis or Frame for 69 Coupe
  150. 1978 spare tire carrier complete
  151. BBC fuel pump
  152. N.O.S. Tail Light Assy's
  153. WTB: Original black lapbelts for a 1970
  154. F/S OEM Powersteering Replacement Pump
  155. F/S - 3/4" Rear Sway Bar & Poly Bushings
  156. 74 birdcage/parts FS
  157. Wanted for 1973 Corvette, Phoenix or Denver area..
  158. FS 73-82 A/C Condenser
  159. FS: Parting out 77 Notchback Coupe
  160. FS 1978 parking brake handle-wheel assy
  161. WTB 1980 Corvette Glass T Tops
  162. F/S - Trans Output Yoke
  163. WTB oil pressure gage for 72
  164. WTB 77 C3 Ignition Shield part
  165. New 427 bbc screamer make offer
  166. WTB: #3 body mount access covers
  167. '72 gas tank clamp ring.....
  168. New Deluxe door panels !!!
  169. 1975 chev corvette
  170. Torq Thrust II
  171. 80/82 frame/roller....800.00
  172. 77 parts....
  173. WTB: for 1973 coupe vette
  174. F/S 1980 Frnt Side Marker/Cornering Lights
  175. Posi unit EDB-30117 for sale
  176. Oil drain pan for 350 auto tranny wanted
  177. 68-72 Alluminum radiator.
  178. Rack & Pinion
  179. WTT: 15 x 8 rally wheels
  180. 1968-69 l 88 distributor cap
  181. WTB Delco Freedom Battery Card from 78 Corvette
  182. WTB 72 Service and Owners Manual
  183. F/S 1974 Corvette Misc Parts
  184. FS: Beginners guide to EFI tuning on DVD.
  185. WTB 6 Bolt Luggage Rack
  186. Value of '65 461 "Fuelie" heads?
  187. WTB: Seat Back for a 70, black
  188. Looking for a lot of parts for 70
  189. 53 back issues CORVETTE MAGAZINE - every issue #1 - Present
  190. free - Differential plug tag (and cover?)
  191. WTB 78-82 wiper switch with pulse, drivers door handle and more.
  192. WTB interior for 1980 complete or pieces
  193. WTB 4 speed set up for 77
  194. Wanted 400sb
  195. F/S - Ratchet Shifter
  196. WTB: Inner Door handle assembly
  197. F/S - 70 - 72 Center Grill
  198. fixed/ recessed headlights f/s
  199. 69-82 4 Speed Shifter Complete W/ linkage, interlock
  200. '68-'69 Original inner 1/4 panel trim FS
  201. Complete power steering unit FS
  202. FS 69-71 tachometer
  203. Lower hinge birdcage repair piece FS
  204. Center caps FS
  205. 70-74 Gas Tank Separator
  206. '68-E-'76 T-top interior trim
  207. Original '68 column parts FS
  208. gutted 77 roller/cowl back.....
  209. 76L-79 rear GM bumper.....
  210. 70-77 rocker mouldings...
  211. W.T.B. 80-82 front bumper Honeycomb
  212. FS: Hydroboost & MC
  213. Original C3 Seat Belts (Near New)
  214. forward exhaust 2.5"
  215. WTB offset a arm shaft
  216. Wtb: Bezel that fits '73
  217. Current available C3 parts list
  218. wanted front clip for 73
  219. Tail lenses for sale!!!
  220. 1968-1973 Removable rear window PICS
  221. F/s 70-72 front bumper guards
  222. 68-77 T-TOPS For Sale (Good Cond) PICS
  223. WTB Trailer hitch for 1978
  224. C3 Rear Axles & Studs
  225. F/S - C3 Rear Axles & Studs
  226. F/S - C3 Rear Axle Setup Tools
  227. 76 parts for sale
  228. Willcox New Sale
  229. 82 radiator
  230. F/S: 80-82 Front bumper
  231. Radiator out of 1980 Corvette
  232. Tank Sticker Confusion?
  233. WTB Rear Bearing Support
  234. WTB - Rochester Q-Jet Part Number 7041212
  235. WTB Manual steering relay rod
  236. Wtb rack & pinion c3
  237. WTB 68-73 rear clip/parts car
  238. FS: 1 Goodyear goldline 7.75 DOT
  239. Wanted: Rally wheel center cap
  240. Want To Buy - '78-81 L-82 Dual snorkel Air Cleaner
  241. Free motor & stand...
  242. Used C3 Parts
  243. Wtb 68 interior door panel
  244. Deep V LT-1 Alternator Pulley for sale
  245. LS6/LS7 Holley Carb
  246. 460#Front and 420# rear VB&P springs
  247. FS complete original 1 bolt Hurst comp plus shifter assy
  248. FS - 79 AM/FM/CB Radio
  249. FS - Texas License Plates
  250. Anyone have a piece of old saddle carpet?
