View Full Version : C3 Parts for Sale/Wanted
  1. 18" rims and tires NEW
  2. FS:...140 MPH speedo gauge cluster.
  3. WTD...crank pulley's #346290 & 14023153
  4. FS: 1969 Dated 4:11 Rear End Posi
  5. WTB:69-74 fuel filler neck
  6. FS 7044507 rochester qjet for 74 manual sb
  7. WTB Wire connector for the tach in a 75 vette
  8. Starter issues
  9. FS 70-72 front grilles
  10. Small gauge printed circuit plug/connectors
  11. GM OEM Red Floor Mats For Sale '68 - '82
  12. 69 up TT steering column
  13. Racing seat and race harness
  14. C3 roll cage set up
  15. spare tire and carrier $200
  16. BB water pump pulley and other random parts
  17. FS 3972110 intake manifold
  18. F/S Original LOF Grey T-Top Matching Set NEW!
  19. WTB Left Lower Seat Frame
  20. For sale...1980 original seat back
  21. traling arm
  22. Going to need a lot of parts
  23. wtb 69 radiator core support
  24. C3 LH Kick Panel
  25. WTT or WTS Hayden fan clutch 2711
  26. Borgeson conversion P/S hoses-$40
  27. 1969 427 Square Port Heads Rebuilt #840's
  28. 80 Aluminum Wheels and Tires
  29. WTB: Offenhauser Cross Ram 360 Base or Complete for Small Block
  30. 78-82 Rear Speaker box
  31. FS: 4 ea BF Goodrich Radial TA 245 60 15 w/ 4k miles $300
  32. Misc Chassis Suspension Parts Big Sway Bar R Spring
  33. F/S Lower Grilles,Headlight Bezels
  34. super-mega tire wheel package deal
  35. 1968 1969 Corvette 435HP Tri power For Sale
  36. Matt Slap Chevrolet Memoribilia wanted Philadelphia Pa
  37. F/S: Solar Powered Battery Charger/Maintainer
  38. FS Upscale Steering Wheel 63-82
  39. hurst comp plus
  40. F/S 20 Year Collection Of Original Corvette Paperwork
  41. FS 80 Corvette Radio AM/FM 8-Track
  42. C3 Chassis, 350ci engine and transmission
  43. Big Block and Small Block: blocks, crankshafts, pistons, intakes
  44. Wanted: Original Alt. Belt 350SB w/ AC
  45. Parts needed for my budget big block swap
  46. differetial
  47. NEW parking brake/ emergency brake hardware - stainless steel
  48. Looking for 1981 ECM standard PROM
  49. 1969 thru 1972 vacuum tank
  50. Corvette Shop Manuals For Sale
  51. FREE: Pair of 333882 heads dated K153 (November 15 1973)
  52. 3.55 Differential/Rear End - Complete
  53. 69 Brake Proportioning Valve - Brand New
  54. 8" Long rear spring bolts
  55. Rear Bilstein Sport Shocks
  56. Rear Differential U-Joint Billet Caps - By Dragvette
  57. Part needed
  58. Fiberglass Rear Clip ....... Cheap
  59. TRADE: pair of `67 3659 tri-power end carbs
  60. fs 73-75 complete cowl induction assembly
  61. FS: SB Chevy Hyd. cam.
  62. New Front and Rear Suspension mono leaf
  63. 1973-75 Radiator Fan Shroud Extension
  64. 1980 Turn Signal Stalk
  65. Suspension parts (brand new).
  66. Mirrors/Manual/Sheilding
  67. Wtb OE fan for 73
  68. Headers and Side Pipes for Sale
  69. Wtb sidepipes
  70. F/S Hard Blok short fill
  71. Delco GM Stereo Cassette Player: FS
  72. Still looking for rectangle headlight conversion
  73. 1100901 Alt 42A 1970 Vette
  74. L82 Aluminum Intakes 78-79-80
  75. OE spare tire carrier
  76. FS: Barry Grant Road Demon 650cfm ($200)
  77. Willcox - can you recommend appropriate part in your catalog?
  78. FS 72/3 hood support
  79. FS various lights
  80. FS 68-75 complete conv decklid assembly
  81. Zemco Performance Timer NOS from the 80's
  82. 72 hood and new A/C compressor make an offer
  83. Various Holley Carbs - came off running, 3 are nearly new!
  84. Center Caps
  85. FS: Targa Top Covers
  86. Holley 650
  87. FS: 1982 Seat Covers
  88. 1970 GM Corvette Camaro LT1 #3927186 Heads For Sale
  89. FS: Edelman Locking Gas Cap Chrome
  90. FS: % GM original rally wheel derbys
  91. FS: 68 69 Corvette Rear Clip / Front Clip
  92. 77 Hood
  93. WTB Corvette Firewall Insulation, 1976-1979
  94. 82 corvette rear end
  95. FS: "80" radio
  96. [WANTED] 3.55 and up differential for 81 vette
  97. 68-72 Parts For Sale: Thanks!
  98. F/S Assorted parts in New Zealand.
  99. C3 power window motor
  100. wtb: 1- NOS 63-82 tie rod tube.
  101. Looking for Seat Foam 74
  102. 10 Bolt 3.08 Gear Set
  103. WTB 68-69 taillight lenses
  104. 98mm C3 turbo kit 1500hp
  105. WTB blue 72 lap belts
  106. In search of Santa pay off.....parts
  107. WTB: 1969-1971 shift plate
  108. Wtb: '70 hood engine emblem number "5"
  109. F/S New 68-90 Drive shaft U joints, Set of Two (2)
  110. FS '75 frame suspension
  111. F/S Switches, wiring, HEI Distributor.
  112. F/S 69-77 Original Steering Column Covers
  113. Factory Mechanical Fan (have 2 of them for sale)
  114. Original 66 - 70 Corvette Fan Blade
  115. WTB QJet, electric choke
  116. WTB Mid to late dated 327 1962
  117. WTB: Vacuum Relay
  118. 15x10 Torq Thrust D
  119. want to buy a lower dash pad for my 75 vette
  120. Corvette Collector's Edition Rear Window Hinges
  121. FS, 1970-72 Front Center Grille
  122. WTB: '70 front grill, rear/rear bumpers and other trim parts
  123. F/S C3 Body dolly San Antonio $60
  124. F/s holley 4150
  125. All Stainless Works Headers Systems side pipes 20% off
  126. F/S C3 Parts LQQK
  127. WTB AC Idle Stop Solenoid for 69 427/390
  128. WTB SX Marked Courtesy Light Pin Switches for 69
  129. MSD Distributor Digital E-Curve
  130. Edelbrock 800CFM Carburetor
  131. Rear trailing/control arm assembly NEW IN BOX
  132. HD Clutch linkage brackets
  133. Calipers and master cyclinder cores
  134. NON Corvette - Small Block Big Block Performance Parts Vintage Parts
  135. F/S 72-74 Original Refurbished Auto Shift Plate
  136. 1974 Seat belt interlock override relay
  137. FS: stainless sleeved o-ring calipers
  138. 1977 seats, carpet & seat belts for sale
  139. WTB 68 big block upper core support hood seal bracket
  140. 65-82 corvette rear brake rotors.
  141. 69 power steering control valve, used. $60 obo
  142. power steering hoses from borgeson $40 obo
  143. 1982 Corvette ORIGINAL sales brochure $9 each
  144. WTB tilt/tele column for 1970 Vette
  145. looking for diff
  146. Complete EFI BBC.Ramjet style intake & ECM.
  147. Willcox December Sale:
  148. Corvette Tilt cruise steering column
  149. FS 1972 amber front turn signal lenses
  150. FS 68-73 taillights and backups
  151. Needing Back Glass for '78
  152. F/S 68-73 Rear Letters
  153. F/S 69 thru 72 rear window
  154. [Hou,TX] WTB - 5spd trans for '79
  155. [Hou,TX] WTB USED or FREE 15" tires
  156. 75 - 79 L-82 Emblem, Trim Parts
  157. 69-73 Stingray Emblems - Trim Parts
  158. WTB 1968 upper dash
  159. SOLAR battery charger:
  160. WTB fiberglass t-tops for 1980 corvette
  161. 70 Small Block with Factory Air Fan Blade (3955182)
  162. F/S: 1970 Exhaust manifold & car cover.
  163. FS, 69 Steering Wheel
  164. FS, 67/68 Steering Wheel
  165. Looking for 1976 parts...
  166. 76 donor car and extra parts
  167. FS 350 engine 1971
  168. FS 70-71 egg crate louvers
  169. Question on value- NOS Emblems
  170. FS: 1972 4 Speed Shifter and Linkage out of Big Block Car
  171. FS: Hooker Big Block Chrome Headers, Sidepipes, Mufflers, T Bolt Kit 2 months old!
  172. LED Tail lights
  173. 82 Corvette Collector Edition Parts
  174. 1982 corvette used parts deals
  175. WTB: Factory Fixed Headlights & Hooker Side Pipes
  176. Wheelskins Leather Cover. Black. 1975-85
  177. WTB 1972 seat belt retractor floor covers
  178. F/S some more C3 parts
  179. avalonjohn
  180. 63-82 Corvette, NEW integrated merge spike design by Stainless Works on all C2-C3
  181. WANTED - 1981 / 1982 turn signal lever w/ cruise control
  182. F/S Late 76 - 79 Rear Emblem
  183. WTB: FIA headlights
  184. WTB Original 72 pass comp fiber door
  185. Rear View Mirror Lever
  186. WTB: Headlight bulb retaining cup set
  187. FS 1968 Heater/Defrost Controls with Cables
  188. FS-NEW C3 Corvette Front Mask 1975-1982 Mini
  189. [Want to Buy] 4 post lift, will pick up 500 m from ATL.
  190. WANTED: Single 1.60 Small Block Exhaust Valve
  191. WTB:68 smog pump
  192. Headlight conversion kit:
  193. 4 Sale- 1980 Claret Seats
  194. WTB -'78-79 rear Spoiler
  195. Want to buy 1971 big block oil pan
  196. fs factory cowl induction assembly for hood
  197. WTB 77 Horn Button
  198. F/S Front Bumper 1969.... Soon
  199. FS: 1969 Tri-power Carbs Restored
  200. FS: 1969 840 heads Square Port
  201. Custom leather steering wheel wraps now available + Black Friday sale!
  202. WTB: 1973 complete jack setup/wrench
  203. Need a few interior pieces
  204. 1968-69 Factory Aluminum Intake 3933163
  205. 1982 thigamajig
  206. Late 77 AC Wire harness
  207. F/S - VBP Small Block Power Steering Component Kit
  208. '69 front clip needed
  209. Door panels wanted...
  210. 77 Corvette emblems wanted
  211. Pigtail connector for an 81 Electric Choke
  212. FS - OK Kustom headers, BB Corvette
  213. wtb used a/c delete cover for firewall
  214. Electric Radiator fan setup for c3
  215. WTB: Lord Fusor Application gun ~~ 2tube calk gun
  216. 1969 corvette steering box, 100 obo
  217. WTB: Windjammer Air Deflector
  218. Willcox Black Friday Sale Starts Now!
  219. WTB used 15" tires near Philly
  220. WTB 73 C3 exhaust pipes in PA
  221. 71 Big Block Exhaust Manifolds Wanted
  222. FS...NOS 78-early79 power antenna.
  223. 1969 L88 or ZL1 carb on CL
  224. WTB 78-80 Ignition Shield & Ground
  225. WTB - '69 Speedo assembly
  226. 2 c3 radiators
  227. FS: 1977 / 1978 GM Parts Division OEM 8-track concert stereo
  228. WTB: 68-76 automatic shifter handle
  229. Need 1977 EFE actuator with bracket and rod.
  230. Frame for sale in Tulsa, OK! $200
  231. Lakewood scattershield
  232. WTB 1971 Steering Box
  233. WTB - 1980 Left Front Side Marker Light
  234. WTB*** Rigid A/C Lines by Radiator Support ***
  235. WTB: 75-77 tach wiring harness connector
  236. FS. Late79-82 AM/FM/CB power antenna. NOS
  237. FS: (1972) 60 YEARS OF CHEVROLET, coffee table book
  238. FS: vintage 1975 Orange spray paint can / Dupli-Color
  239. WTB Carburetor
  240. F/S - Two BFGoodrich T/A 245/60R15
  241. Parts For Sale
  242. identify please
  243. FS Complete set NCRS Corvette Restorer Magazines
  244. Eaton posi diff carrier
  245. 1969 427 4 bolt main block for sale + Parts
  246. 79 L82 Air Cleaner Complete System
  247. wtb - ss lines, spicer joints, gas tank, wires...
  248. WTB Front Bumper & Bumperettes 70 Vert
  249. weather strips
  250. '73 C3 Parts For Sale - great condition
