View Full Version : C3 Parts for Sale/Wanted
  1. 1979 Carburetor (Original)
  2. FS: 1973 Corvette coupe parts
  3. New T top bags C3
  4. C3 Car Cover Custom Fit Great Deal.......
  5. WTB Rear End Carrier
  6. 1975 tan seat belts needed
  7. FS - Two (2) Nearly new 275-60-15 BFG tires
  8. FS - Two (2) Nearly new 225-70-15 BFG tires
  9. FS: 76 Console Shifter Plate
  10. FS - Painless TPI Harness & ECM
  11. F/S Buckskin Header trim
  12. WTB 80-82 front lower valance/air dam
  13. FS: Corvette News Magazines, 1972 to 1980.
  14. 73 interior
  15. FS BTO 700r4 bracketry and cam for Holly/Speed demon
  16. FS: T-Top Bags
  17. FS: 79-82 Radiator Brackets CHROME
  18. N.O.S. Parking Lamp Assy's & used Lug Wrench
  19. N.O.S. Parking Lamp Assy's
  20. F/S 1968 Heat Thumbwheel Climate Control unit
  21. Steering wheel, 1969-1975
  22. WTB Power Steering Cap Circa 60's
  23. 350 engine
  24. WTB drivers side door panel 1981
  25. WTB BB alum. radiator, headers & pulley system
  26. F/S Thermostat Housing
  27. 78-82 New Door Sill Plates
  28. F/S SBC Rams Horn Casting# 336711
  29. WTB 4 speed conversion parts
  30. 1970 1971 corvette 454 3963512 4 bolt ls5 ls6
  31. 1971 corvette 3994026 uu 454/425hp heads
  32. 69 shoulder belt guides?
  33. WTB: '79-82 T-Top Rear Lock Plate
  34. Wtb air vent control levers and brackets for a 1968
  35. FS: Trick Flow Twisted Wedge heads all NEW w intake rockers
  36. F/S 1974 Steering Wheel
  37. FS: SB Aluminum Valve Covers
  38. Fs: 700r4
  39. FS: 1970 Rear Bumpers SHOW RECHROME
  40. WTB: Drivers power seat switch/assembly '98 Coupe
  41. C3 Parts For Sale
  42. Wanted, Original Antenna solid mast for a 72 Corvette
  43. 68 convert
  44. Aluminum Roller Rockers for sale
  45. 74 hood 76 rear 78-83 glass tops
  46. FS Single dual axle car hauler. GA
  47. taillights wanted for 74
  48. FS MSD Pro Billet tach drive distributer
  49. F/S - Original 69 rear bumpers
  50. WTB Door part
  51. F/S 1968 Tailight Assembly's
  52. WTB - 350 Intake Manifold 73 or 74
  53. WTB 1970 Gas tank door lid
  54. 75 good used gas tank good bladder
  55. WTB: 1969-73 Headlight Assembly Bracket
  56. FS Delco gas charged shocks
  57. F/S speakers
  58. WTB 1969 corvette center console
  59. 1969
  60. FS - 72 service manual, assembly manual, etc
  61. '73 Wiper Switch lens
  62. wtb raised hood for 1980
  63. Hawk HP Plus Brake Pads
  64. 1977 reverse back up light lenses for sale
  65. WTB.front bumper -73-74
  66. 1072 Egg Crates
  67. WTB > Front Bumper Cover
  68. FS: Motorized Antenna - Motor
  69. FS: Various Parts
  70. oem rallys centers set of 4
  71. ***WTB 1968 Corvette starter 1107365***
  72. Wanted 68-75 convertible door glass
  73. FS: 1978 Corvette Hat / Lapel Pin
  74. FS: 25th Anniversary Emblems & Flags
  75. wtb rear vertical weatherstrip retainer for 73
  76. Trade power steering for manual
  77. F/S 1978 l82 heads and few other parts
  78. wtb - Air cleaner retaining nuts for 82 Crossfire
  79. WTB 69 broken clock, need second/min hands
  80. Edelbrock Performer RPM Aluminum Heads for sale
  81. WTB: 2.5" wheel adapters
  82. 68 parts F/S....Atlanta pickup
  83. FS: Pair of Halfshafts
  84. FS: JL Audio & Kenwood stereo equipment
  85. WTB:Genuine GM non-EGR alum. intake
  86. F/S Vintage Wheels
  87. Fs 1966 462 heads, bare
  88. F/S - 69 Front and rear bumpers
  89. 64/65 intake manifold price question
  90. WTB: Static Collector for 1968
  91. WTB: Bottom of battery box for very early 1968
  92. WTB:69-73 Headlight Assembly
  93. Wanted BBC Connecting Rod
  94. Wanted - 1970 seat belt buckle
  95. FS - Front suspension parts
  96. FS - Auto transmission crossmember
  97. FS - (used) Fan blade & clutch
  98. FS - (used) #339175 Fan shroud
  99. FS - Misc. hard top anchor nuts/bolts
  100. FS - Eckler's vacuum hose kit
  101. FS - Antenna parts (new in box)
  102. FS - Centerline Convo Pros and tires
  103. WTB SBC Lifter bore grooving tool
  104. FS: Comp Cams Degree Kit #4796
  105. WTB: 1977 Splash Shields
  106. WTB: Good condition black seats for '79 (seat covers)
  107. holley carb 650 cfm dp fs
  108. 75-79 Front Grills and Turn Signal Markers
  109. L88 aluminum heads 3946074 casting number for sale!
  110. 3 NOS Sidepipe Chrome headers
  111. Corvette Rear Strut Rods adjustable NEW!
  112. WTB: 1971 Headlight Bracket
  113. Intake Manifold
  114. Corvette professionally rebuilt Auto transmission
  115. Wanted Red Passenger Seatbelt
  116. FS various interior parts
  117. F/S 77 Bumper Covers $20
  118. FS- '68-72, 4-speed transmission interlock cable
  119. FS: '69 SB Hood
  120. Corvette Rear Factory Sway Bar C3
  121. FS: Edlebrock RPM SB intake
  122. WTB 68 Left dash
  123. FS Differential Rebuild Kit, 1963-1979
  124. WANTED: 3.90 Factory GM Gears
  125. FS:1969 Aluminum Intake 427 #3947801
  126. 76 Speedo
  127. WTB: Interior rear quarter panel 69-73
  128. F/S C3 Steering Wheel
  129. Wanted - piece of the rear deck from a 68 - 73
  130. C2/C3 BB Hooker Side Mount Headers, CHEAP
  131. 73/74 frontend/clip&rust free doors
  132. wtb-pw reg. LH,some interior things
  133. 72 blower motor wiring harness plugs needed
  134. 1968 3919840 Big Block Chevy Heads
  135. New over the counter 430hp small block
  136. wtb 327
  137. Corvette/Camaro GM 882 Casting Cylinder Heads SBC NEW
  138. 3.08 Ring and Pinion Rear End Gear Original GM
  139. '63-'79 3.70 Ratio Corvette Rear End for Sale
  140. Wtb 77-79 fender emblem
  141. WTB torsional damper
  142. One NOS 1969 SB Corvette Side Pipe - $85
  143. Muncie M20 4 Speed dated 1974
  144. FS:Hurst Shifter, New SS Tips, Etc.
  145. FS: Headlight Bezels
  146. WTB: 68 Inside Door Mirror Mounting Bracket
  147. wtb, i know it's a stretch
  148. fs 4 emergency brake shoes
  149. C2 Hood 1964 For Sale
  150. fs 3947801 intake 69 vette
  151. 3931063 oval port heads for sale
  152. alternator for sale
  153. 8808327 BB headers
  154. 2 Q 74 plug wires
  155. 81 red steering wheel
  156. WTB tail and back-up lenses for 71 vette.
  157. Are any rebuilders buying cores ?
  158. F/S Parts
  159. 80-82 Vanacor Inner Fenders FS:
  160. 75 Assembly Manual
  161. 77 diff.
  162. WTB 81 Corvette Rear window trip/molding
  163. FS early 73 diff/case
  164. CoverKing C3 custom fit car cover
  165. FOR SALE: Glass T Tops
  166. FS: SB Hedman Side Exhaust Headers
  167. WTB Firestone RWL F-70-15 Orig. Tire
  168. AC Delete cover
  169. WANTED > Early '76 Rear Bumper Emblem
  170. HVAC components from a 74
  171. BB intake
  172. WTB March or April 1970 010 350 block
  173. FS painted tops for 78-82.
  174. LS-6 454/450 hp complete
  175. F/S C3 5 guage center instrument bezel
  176. F/S C3 T-Tops
  177. F/S C3 Wiper motor and arms
  178. 2 Window motors C3 1975
  179. WTB: Lustine Chevrolet license surround
  180. Wtb ls5 oil pan
  181. Wtb ls5 exhaust manifolds
  182. WTB Storage Frame
  183. 1968 Tripower 435HP Intake
  184. 1969-73 Corvette standard steering column for sale
  185. WTB - C3 T-Top Locks
  186. WTB: '71 Dark Saddle interior trim below rear window
  187. FS 1969 Big Block Hood $400 29360
  188. FS,N.O.S. gage set,80-81.
  189. Looking to Buy.......
  190. 77-82 High Flow Water Pump
  191. 77-82 AC compressor / condensor
  192. Need a 1968 Drivers door
  193. WTB: 1968 Hardtop/Soft top Rear Bow Lock Pins
  194. C3 misc. Parts
  195. C3 gauges & cluster
  196. wtb steering coupler for 68 vette
  197. 70-77 t-top sets
  198. F/s c3 emblems
  199. 69-82 trim rings & center caps
  200. FS: 1969 door panels
  201. 1968 Corvette parts
  202. wanted 68-72 windshield frame
  203. WTB black leather seat covers for 70
  204. WTB: 1968-1972 original hood support bolts
  205. 72 vette gage pack
  206. Fresh 468 Big Block Chevy with rectangle ports
  207. WTB Rear Suspension Locating Kit (1963-1979)
  208. 1979 Corvette
  209. racr car fiberglass
  210. For Sale---Complete Wiring Harness
  211. WTB: American Racing 200s Daisy 15x8.5
  212. FS Chrome Hooker Header Side Exhaust
  213. 78-82 New windshield in NJ
  214. F/S - 1968 Rally Wheels
  215. 1968 Rally Wheels Original
  216. WTB center rear compartment bulb protector
  217. FS BB Finger Fan
  218. WTB Stock Tach Drive Distributor
  219. f/sale trailing arms L+R USED
  220. Some C3 stuff: roadster window, smog pully, etc
  221. wtb sbc headers for old cast angle plugs
  222. ***WTB - Original air cleaner wing nut and oil cap***
  223. FS Set of 8 Inch Rally Wheels with Redlines!
  224. WTB rear glass trim mldgs (complete)
  225. WTB 1982 c3 emblems (all of them) and
  226. FS BB Hooker header sidepipes
  227. WTB 75-76 Tachometer
  228. Fs 78-81 air cleaner flex duct
  229. 68 original doors
  230. 1968 stock radio knob set
  231. WTB gas gauge for a 74
  232. WTB '81 Tank lid and front Emblems
  233. FS Driver quality 77 C3 Windshield
  234. F/s - 3 Monza/ Cobra Gas Caps
  235. Side Pipe Mufflers Unused $125
  236. 79 Gas Tank $100 local pick up only
  237. FS 1979 Dated JACK 9E07
  238. FS (DFW) - Poly engine and trans mounts
  239. Interior Door Pulls
  240. WTB '68 Back up lights
  241. Anyone need a complete differential??
  242. FS: Guldstrand bump steer kit/like new
  243. Late 1969 427 engine Fan Blade assembly
  244. 70-72 Air cleaner Base (Duel Snorkel)
  245. WTB 1969 SBC heads
  246. bubble tail lights
  247. AM/FM radio
  248. FS:4 BFGoodrich Radial T/A Tires 255/60/15
  249. WTB: one center cap 76-79
  250. Stainless LS1 swap headers for C3
