View Full Version : C3 Parts for Sale/Wanted
  1. F/S Holley 4-V Accelerator Cable Bracket
  2. WTB: 68 eyeball holder and heater knob
  3. rear window stortage deck f/s
  4. 1982 Corvette Collector Parts
  5. black hooker sidepipe header
  6. WTB- Rocker mouldings
  7. WTB: Standard Steering Column Parts
  8. 1973 Radiator Core support
  9. 69-82 Brand New Oil Cooler Kit fits both BBC and SSC Flex-a-lite - 65 shipped
  10. New L&R Chrome Lower Ignition Shielding 63-69
  11. Original Black T/top Headliners
  12. F/S 78 Driver's side Armrest, Black $60
  13. 68 headlight knob and eyeball vent rear holder
  14. WTB: Side Exhaust Kit with Fbgls. Covers
  15. F/S 71-76 Original RH Lower Dash Pad
  16. F/S Original Dash Speakers and Support Brackets
  17. WTB: 1971 factory am/fm radio
  18. FS: Hedman Side Exit Headers $50 obo
  19. WTB QJET CARB for 1971 454
  20. 7041205 FD with a 3050 date code (November 1970).
  21. WTD rear view mirror glass with map light
  22. Used 1978-1982 Seat foam
  23. Used 1979 Corvette Black Seats and Tracks
  24. Holley 650 Double Pump Dual Feed - came off running
  25. Holley 600 Double Pump Dual Feed - came off running
  26. ***WTB*** 1972 Engine and A/C Parts for a 350 Car***
  27. C3 Headlight Bezels
  28. F/S 70-74 Rear Side Marker Lamps
  29. C3 Flannel Car Cover for Sale
  30. '77 part out in MI/IN
  31. New Corvette Central Interior Insulation Kit '68-'77
  32. 69 corvette resistor
  33. '79 Complete gas tank and accesaries
  34. WTB: Brake Light Switch Striker Plate for MB
  35. Chevrolet Chrome Valve Covers SBC
  36. March SBC Outward Mount Serpentine Kit
  37. WTB 73 T Top Center Roof Panel
  38. Looking for this one nut...
  39. WTB: Forward Shift Console Reinforcement
  40. WTB Hard Top headliner
  41. Front Park Lamp Extensions 70-77
  42. Corvette Shifter Rebuild Kit, Minor, 1968-1976
  43. 77 corvette alternator bracket
  44. WTB - For My 1971 with Air (Sparty)
  45. 72-76 Center Guage Bezel OEM
  46. 69-71 Center Guage Bezel for DIN Stereo
  47. WTB Rubber Boot for Upper Ball Joint
  48. WTB: Holley 4011
  49. WTB door lock knobs
  50. F/S 75-82 460# Front Springs
  51. FS misc interior parts
  52. 1980-81-82 front bumper cover black
  53. F/S Headman Headers
  54. 69 hood
  55. ***WTB***Fake Knock-OffsFor 68-82***
  56. WTB: Headlight Buckets & Adjusters
  57. parting out 78
  58. C3 parts, fit '73 and other years
  59. Tail Light question
  60. WTB 73 thermostat housing
  61. 1976 corvette wheels
  62. FOR SALE: 1982 CE Corvette Rear Hatch Glass
  63. WTB Rally Wheel Trim Rings - 15x8
  64. WTB: 70-74 Windshield Washer Reservoir + Extension
  65. Big Block exhaust Manifolds. Need these gone.
  66. Stinger hood scoop
  67. WTB 17x8 torq thrust II ...had to ask.
  68. F/S Hawk HPS Brake Pads
  69. wtb Valve Covers for a 81
  70. Brand new BBC 496 Stroker.
  71. Corvette two pc. Sweat suit xl workout/lounging
  72. Drivers side mirror
  73. Steering wheel (aftermarket)
  74. Holley intake SBC
  75. Rear Exhaust Panel-side pipe car 1969
  76. 1968-72 Ecklers Spoiler -new
  77. WTB- Drivers door for 1970 Convertible
  78. 1111926
  79. F/S some C3 parts
  80. Holley 4175
  81. F/S - Wheel and Tire Spare for 1972
  82. WANTED/ Ignition Shield for '69
  83. 1973 Corvette Smog System Parts Wanted
  84. FS....79-82 NOS AM/FM/CB power antenna
  85. 1973 Hood
  86. NEED P/S pump witn brackets 1974
  87. F/S Book Big Block chevy engines by Tom Wilson
  88. WTB/ Need EFE and Bracket!
  89. Trans Cooler / Oil Filter relo Kit/Elect. Rad Fan/H2O & Oil gauges + Misc For Sale
  90. Looking for 15x5 skinnies-Weld/Centerline
  91. 1971 Interior Door Pulls - Saddle color- For Sale
  92. Distributor Cross Shaft Gear - For Sale
  93. Headlight Actuator Vacuum Relay For Sale
  94. Rear Differential Crossmember Mounting Bushing, Pair. For Sale
  95. Under Car Exhaust Center Hanger Bracket - For Sale
  96. Front Park/Turn Signal lens - Amber-1972 - For Sale
  97. Harrison Expansion Tank dated 71M For Sale
  98. WTB - 1980 Half Shaft - Automatic
  99. 72 lt1 6239 holley carb
  100. FS: Two 78 Pace Car Tee Shirts Medium
  101. 1974 Engine
  102. 2818 carb
  103. ***WTB***1972 Alternator #1100544 on A/C Cars
  104. 1968-1969 Frame needed MAYBE
  105. WTB 2.5 inch heat riser valve for 69 427
  106. T-tops $200
  107. F/S New side pipes stainless/ heat shields for sb
  108. 1990 L98 w/ 6speed
  109. F/S 1979 Corvette Shop/Service Manual
  110. F/S L-82 Engine Pulleys
  111. WTB: t-top stainless t-bar trim
  112. F/S C-3 Radiator Fan Shroud
  113. WANTED 1969 Rochester (urgent)
  114. F/S - Set of Horns
  115. F/S - Vacuum Canister - Three Tab - P/N 3966704
  116. FS: 73-76 Cowl Hood Flapper
  117. FS: 80 & 81 Emblems
  118. WTB Good used 1969 stock radio
  119. F/S Parting out a '78 and convertible parts
  120. 82 elec fan & shroud
  121. F/S New C3 Parts
  122. WTB 70-71 LT-1 Hood
  123. WTB 1974 radiator
  124. F/S NOS 1974-75 rear bumper letters
  125. side pipes
  126. AM Tops
  127. Black dye-non aerosol
  128. F/S 1968 ?? Outer Heater Box...Excellent
  129. F/S Restored Front Steering Linkage....Nice
  130. 1978 corvette literature
  131. 1969 Early 427 4 Bolt Block & Parts
  132. Corvette C3 OEM SB Side Pipes
  133. side pipes
  134. Hooker SS side pipes complete with STS baffles
  135. 69 roadster door glass
  136. Need 73-75 350/454 fan shroud
  137. Need One 8 Inch Rally Wheel
  138. F/S - springs and A arms
  139. wtb 69 400hp, ps, ac, correct motor pulley that runs ac and ps.
  140. Need Goodyears
  141. WTB:68 smog pump
  142. looking for some parts for my 75 corvette project
  143. 82 Dual crossfire air cleaner
  144. WTB 72 Coupe shoulder harness mounting plates
  145. WTB: Trans shift lever and dipstick, cable bracket
  146. WTB 72 Coupe shoulder harness mounting plates
  147. WTB: Steel Rally Wheels
  148. WTB 1969 center guage bezel. OEM
  149. FS: 1977 / 1978 GM Parts Division OEM 8-track concert stereo
  150. New Complete Poly Suspension Kit
  151. Brand New Chrome Valve Covers from Zip 1965-1974 427 or 454 for Power Brakes
  152. M21 gears needed
  153. WTB: AC Delco Reactek Shocks
  154. C3 Front Right Fender NEW OEM
  155. Super T10,and conversion parts....
  156. NEW VB&P 330# rear spring
  157. WTB 69/72 rear window
  158. F/S intake manifold, bar, spring
  159. 71 Big Block Exhaust Manifolds Wanted New Fuel lines Wanted too
  160. FS 68-71 T-3 headlights
  161. *** WTB - 1968 P/S pump ***
  162. FS 70-72 side grilles excellent
  163. 69-72 tail light and back up light lens set FS
  164. F/S Nice original 69 seats
  165. Front bumper brackets
  166. '68 only grill brackets
  167. Ignition shielding
  168. '69 only wiper motor/headlight washer pump
  169. Vintage cross ram intake manifold
  170. '68 gas pedal asemblies
  171. Big block exhaust manifolds
  172. '68/'68 front parking light
  173. C 3 rear compartment door assembly
  174. F/S NOS 1969 back up lamp assembly
  175. '69 t/t column--restored
  176. '69 t/t column--restored
  177. '68 only a/c dash vent
  178. wiper door stainless
  179. Misc. hard top stainless for sale
  180. '68/'69 rocker moldings for sale
  181. '68 Wiper motors for sale
  182. '68 and '69-'72 doors for sale
  183. '68 only conv. headder stainless
  184. TI dist./amps/harnesses/etc FS
  185. '68 steering column (s)
  186. C 3 front headlight support bar
  187. Misc. fiberglass pieces
  188. t-top and convertible top latches
  189. Rear pumkin--'68--3:55:1 posi
  190. '68--'71 tail light cans
  191. Looking for a Left Headlight Housing support for 1980
  192. F/S side louver trim set
  193. 1982 used parts christmas sale
  194. Built 406 small-block and th400 trans
  195. 69 427 side pipes NOS
  196. 1972 Assembly manual and Service manual
  197. Black console cushion
  198. Stingray floor mats and rear cargo mat
  199. C3 Need both headlight actuators/and cans
  200. 76 driver's side duct and shut off
  201. 75-79 grilles,parking lights,wiring
  202. WTB: 69 side marker lights
  203. t-tops $200
  204. Wanted - 1968 Driver's side "Left" Door Latch Lock
  205. F/S NOS GM Original Small Block 350 Choke Spring and Cover
  206. FS: 1969 Square port heads PN 840
  207. Set of 79 Aluminum rims with 2 new Yokohoma 255 tires
  208. Need '69 to '70 windshield frame
  209. Factory '69 side pipe covers
  210. Assorted parts Racing parts
  211. Main battery diconnect switch
  212. WTB 81-82 Oil temp gauge
  213. F/S Leftover parts (Northern CA.)
  214. Sold My 82 Coll. Ed. / Lots of great C3 Parts for sale
  215. F/S Little parts, for your restoration
  216. New poly trailing arm kit
  217. 68-74 SB smog bracket
  218. BB chrome frt/rear sway bars n hardware...
  219. FS: 68-69 Tail Lights
  220. WTB dust cover for 77 4 spd transmission
  221. FS mid 70's nos lap belt assembly
  222. FS 70-73 nos lap seat belt assemblies
  223. FS 68/9 front bumper guards
  224. late C3 aluminum slots and tires
  225. 1974 Vette Rear Bumber - One Piece for Sale
  226. FS: 1974 Gas Tank Parts
  227. NEW Ken Harrison JVC Radio 68-76 w/ wiring/speakers
  228. 68-69 original black upper dash pad
  229. tilt front end
  230. L88 Hood - short style hood, L88 Scoop Molded In
  231. Holley Ultra hp 650cfm w/ discount codes!
  232. For Sale: Lots of 1969 Corvette Parts
  233. FS: 1969 C3 Corvette Passenger Side Door Panel Black
  234. Need 3932461 RH 17 if possible
  235. WTB: Conversion parts auto - man
  236. C-3 Pro Street Chassis and parts project
  237. Assorted chassis and suspension parts
  238. NEW Trail Arm Bushing Install Tool
  239. WTB C3 Body Dolly for my 75
  240. WTB '70 Bumper Guards
  241. Wtb ls6 intake 3963569
  242. I'm looking for a new or rebuilt carburater
  243. F/S Under the hood fasteners & clips, for your restoration
  244. F/S 68-82' Custom Speaker Box w/Alpines -NEW
  245. SS 69 Fule Line Tank to sending Unit NEW
  246. ***WTB 1972 Power Brake Line ***
  247. 18" rims and tires NEW
  248. FS:...140 MPH speedo gauge cluster.
  249. WTD...crank pulley's #346290 & 14023153
  250. FS: 1969 Dated 4:11 Rear End Posi
