View Full Version : C4 Parts for Sale/Wanted
  1. WTB:'85 targa top
  2. F/S: Energy Suspension Bushings (pics) - Balljoint Boots - Sway Bar Links
  3. wtb:C4 fuel door hinge
  4. AFR Competition 220cc Small Block Chevy Racing Cylinder Heads
  5. LT1-4 AFR Heads
  6. Great dealing with grinditout
  7. WTB front black outs
  8. WTB front black outs
  9. F.s. 84 Ecu
  10. WTB: Fuel pressure gauge
  11. WTB:Phantom ABS Taillight Louvers 91-96
  12. F/S New GM LT1 Crate engine
  13. F/S LT4 Valve Springs GM Performance Part NEW in box Part Number 12551483
  14. FS: Factory GM VHS Owners Tape
  15. Fs A/c Evap Core And Case
  16. WTB Rollbar For Early C4!
  17. 58 mm Air foil needed for 96 LT4 carb
  18. FS-March Racing Pulley set
  19. Not so good dealings with gregm999 and FedEx
  20. FS-Prothane Total Kit
  21. Need C4 luggage rack
  22. Want to upgrade with C5 parts?
  23. GoodYear Eagle GSC P275 40 ZR 17 Left
  24. FS: Edelbrock 3860 High-Flo TPI base lower intake manifold
  25. FS Body Kit
  26. WTB Accusump Elec Valve and Oil Adapter
  27. Looking for an early Dana 44
  28. 85 Wheels and Bose Radio
  29. WTB-4 lug nuts for 92
  30. WTB - Chrome C4 exterior emblems GS or CE
  31. WTB-Stock Throttle Body for 90
  32. C4 Collectors, Misc Interior parts pakage!
  33. FS: BRAND NEW GM Throttle cable
  34. WTB.......95-96 fenders
  35. FS Various L98 Parts
  36. F/S: Two 1988/89 wheels
  37. trade 1.5 roller rockers for 1.6 roller rockers
  38. F/S Dana 36 - 2.73:1
  39. FS parts from an 86
  40. WTB 1994 - 1996 Standard Seat Buckets
  41. WTB: OEM Composite Valve Covers 96 LT4
  42. Free items in the southern LA/MS area
  43. FS-Polyurethane Bushings
  44. WTB: 1 FX3 Front Shock actuator
  45. FS: TPI NOS kit
  46. C4 Daytime Running Lights
  47. Parts needed for a 90 coupe
  48. FS: 1988 Exhaust Manifolds.
  49. WTB Driver Side Door Handle..
  50. F/S 84-90 Rear Bumper
  51. Parts for sale
  52. WTB FRONT Bracket to mount targa top
  53. Melling high volume high pressure 10555 oil pump/pickup
  54. F/S: 101 Projects for your Corvette Paperback Book
  55. F/S: 96 GM Service Manuals
  56. F/S: Hypertech Power Programmer III for 96 Automatic
  57. FS: Protorque Race starter
  58. [WTB] Evaporator Housing
  59. HVAC Door Clips
  60. F/S Rear glass w/ defroster
  61. F/S Kwiklift in San Antonio TX
  62. F/S All 4 tire pressure sensors from a 95
  63. FS: 1993 black sill panels and speaker covers
  64. FS: black/black 1993 door panels
  65. FS: Cyberdyne tranmission tempature gauge and sender
  66. FS: Single A-Pod Piller gauge mount
  67. FS: 8 stock LT1 Fuel injectors
  68. FS: Aluminum tranmission pan - 700R4 automatic
  69. F/S R-D Racing CAMBER-BRACE L-98 85-89 models
  70. WTB: 16" Sawblades(NJ Area)
  71. Great dealings with cmashark...
  72. need egr solenoid 85
  73. FS: Rocker panel 1996
  74. WTB OEM fuel regulator for a 1988
  75. Targa Hardtop brackets
  76. WTB drivers side speaker grill
  77. wtb 1993 zr-1 17x11 saw blades rims
  78. Excellent dealings with Pete Kane and his new converters !!
  79. brakes
  80. VERY used seats from 1984 C4 in Alabama
  81. Super Price on C4 Carpet Sets on E-Bay
  82. FS- Breadbox from a 1989
  83. Wtb Air Filter Element Cover For '95
  84. F/s Almost Brand New Stater
  85. WTB 88 Front Bumper Cover
  86. What is a 92 ZR1 worth??
  87. WTB: Camber Strut Rod Eccentric Adjusters
  88. WTB 85 drivers seat
  89. WTB knock sensor for an 84
  90. wts 86 rims/tires
  91. F/S 4 GOODYEAR GSC-EMT RUN FLATS and 96 OEM DIRECTIONALS ZERO miles
  92. Excellent transaction with forum member "Chatman"
  93. WTB: Rear Spring @ 39.9 N/mm Rate...
  94. WTB: BBK / Edelbrock TPI PLATE (Black)
  95. FS Beige Standard seats out 96 coupe
  96. lloking for used parts 86
  97. 96 Artic white targa/MagnaflowSS mufflers
  98. WTB: Sun visors for a 1996
  99. PnP LT4 intake manifold
  100. PnP LT4 intake manifold
  101. Wtb: 1996 Ce Speedo / Tach
  102. 88 TPI plenum, runners and manifold
  103. wanted: C4 break parts & 17 X 11 wheels
  104. Show me your coils / super coils High performance coils ...i want one !
  105. WTB 1997-1998 SDM / Air Bag Control Module
  106. WTB LT1 Water pump Broken/Used or NEW
  107. FS: Black 1996 PS Inside Door Panel...
  108. F/S 1 3/4" Stainless Steel Headers LT1 LT4
  109. Chrome C4 sawblades with LTPWS sensors in So Cal $500
  110. FS: RD Racing Cross-Frame (X-Brace) never used
  111. WTB LT4 fuel rails
  112. F/s Hooker Headers Lt1 Lt4 Ceramic Coated
  113. Complete Cat Back 96 Corvette
  114. Dana 36 Rear Complete
  115. Wtb: C4 Front Spindles.
  116. Some good C4 Parts F/S
  117. F/S catback(sort of) w/stainless mufflers
  118. F/S:B&B resonator 3" in/out
  119. WTB Lower Shift Boot { Rubber One } ZF-6
  120. FS: C5 front Calipers/adapter brackets>>
  121. WTB:95% Plus Condition Rear Calipers for J55
  122. WTB Mounting braces for alternator-A/C
  123. WTB: Rt. Side Dash A/C Vent Assy' a 95'
  124. Applause for forum vendor Vette2Vette
  125. Parts Discounts?
  126. F/S Stock 1989 oil cooler sandwich adaptor.
  127. 1993 Targa Top For Sale
  128. Corvette Recycling E-Brake Handle Sale
  129. WTB Stock LT1 catback 92-96
  130. F/S Vigilante convertor
  131. F/S Stock air box filter and K&N filter with breathles open top
  132. WTB LT1 timing cover from 1995 Corvette
  133. WTB: 1.6 Rockers Self-Aligning 3/8
  134. F/S LT4 Valve Springs GM Performance Part NEW
  135. WTB: Rear speaker grills for a 91' Coupe
  136. WTB: MAP sensor and plenum bracket
  137. ZR1 parts F/S
  138. FS - 93 3 pc Front Spoiler & Trunk Plastic
  139. Passive Entry Module
  140. WTB: FPR & Stock Valve Covers
  141. WTB/ '94 Radio receiver and abs module
  142. F/S (2) 1990 ZR-1 rims 11" inch
  143. wtB: Goodyear F1 Tires - 19" Rear 18" fronts.
  144. 1990-1996 C4 LT1 LT4 Corvette Complete Front Suspension! Rare Setup!
  145. 1984-1996 C4 ZR1 LT4 Collector 17" Wheels and Tires! OEM
  146. WTB EGR valve solenoid for 84 w/Auto Trans
  147. WTB C4 6 Speed Transmission Case/Housing!
  148. WTB,1991 ZR-1 right rear wheel...................
  149. WTB: 86 A/C bolt
  150. WTB good front hubs for a 90
  151. SLP Pipes
  152. WTB Plastic piece that computer sets on 1996
  153. 1984 power mirror rocker switch. L-R,center off
  154. Cleaning Out Garage
  155. Fs '96 Style Front Bumper Nose Cone
  156. 26k miles- 113 heads, Tpi, 2kmiles injectors..
  157. msd opti for 93
  158. I need 1 injector clip
  159. FS-Service manuals 94 and 95
  160. Wtb C4 Jack
  161. Wanted: Air pump (smog pump) from LT1
  162. Wanted Cold Start Injector assemby
  163. Slp Intake F/s
  164. Firestone Wide Ovals For Sale
  165. FS Right Front Park/Turn Lamp 84-90
  166. Wanted power antenna bezel 85
  167. Misc 85 parts
  168. Wanted: fuel bib - fits around gas fill
  169. WTB: 1993 Corvette 700R4
  170. F/S RANDOM TECHNOLOGY HIGH FLOW catalytic converters LT1 LT4
  171. F/S SLP Headers LT1 LT4
  172. F/S: Set of 17x9.5 ZR-1 wheels with Kumho V710's
  173. F/S B&B Exhaust Pipes LT1 LT4
  174. F/S: Harness Bar + 5 point harness for C4
  175. F/S: Reese Shadow II hitch for C4
  176. F/S SVO #30 injectors
  177. needed asap driver side headlight assembly!!!
  178. FS- Engine Load Leveler
  179. FS- Mityvac 6820
  180. FS-Motive Power Bleeder
  181. Need 84 power steering bracket asap! help!
  182. Free Mufflers for 84 and 96
  183. 87 TPI parts for sale
  184. FS (NM): 0 Bal 400 hp Al/clutch
  185. 2 new Vredestein tire 315/35/17
  186. WTB 1985-1987 A/C Compressor Bracket
  187. f/s black targa top
  188. WTS: 3" B&B Triflow Mufflers (Georgia)
  189. WTB/Stock Exhaust Manifolds/88 TPI...
  190. 96 Wheels and tires
  191. FS: Brand new Mcleod Slave Cylinder for T56 transmission
  192. Tire Sale!!! Over 15 Brands To Choose From
  193. 87 camaro 305 TPI parts for sale
  194. For Sale: RD Racing X-Brace - BRAND NEW!
  195. FS: Fuel rail/Injector cover hold down bolts
  196. FS: Proform Valve Cover Breathers - black anodized, Bowtie emblem
  197. FREE: Console frame, Instrument Panel frame, HVAC ducting - off my 96'
  198. FS: I/P lower trim panel off my 96' (the panel right above your shins)
  199. FREE: Console side trim carpet off my 96'
  200. F/SLT1 Waterpump
  201. FS: Passenger side airbag off my 96'
  202. F/s Lt1 Meziere Water Pump
  203. 1989-1996 C4 Corvette Blue Tint Removable Glass Top!
  204. 1984-1996 C4 Corvette Collectors Edition Black Seats!
  205. F/S QTP Electronic Exhaust Cutout Controller
  206. WTB Ball joints
  207. WTB 8 way L & R power seat switches for 87
  208. FS: ZR1 GM Service Manual 1990-3
  209. F/S 4L60E and convertor
  210. F/s Tpis Longtube Headers
  211. WTB power antenna
  212. All Corvette Car Covers 15% Off!
  213. NOS Corvette Pump To Gear Power Steering Hose, 1988-1990
  214. WTB: 90-96 Green or Clear Targa Top
  215. Looking For Used Sawblade Wheels
  216. WTB: L98 air pump eliminator bracket
  217. FS: C4 Interior trim pieces CLOSET SALE
  218. Need original oil dipstick
  219. WTT C6 Wheels for Black ZR1 wheels - Michigan
  220. FS Genuine Leather C4 Jacket, very nice!
  221. FS: Bose Gold Head unit and Reeiver
  222. WTB black outs
  223. F/S SBC EFI intake complete with fuel rails & fuel pressure regulator
  224. 3" Dynatech Vortex Insert Cones
  225. WTB ccm for 96 lt1
  226. WTB: parking brake cable. LT1
  227. WTB car cover for 94 C4
  228. tires f/s
  229. Fs: 90 & 92 Corvette Gm Factory Original Vhs Owners Tape
  230. Beware of scootert96!!!!
  231. F/s C4 Rear End Dana 36-3.08 Posi
  232. Stock exhaust FREE 96 LT-4, 92 LT-1
  233. 1984 magazine fold-outs - The New Corvette!
  234. Bosch 42lb Green Giants
  235. F/S: Flowmaster cat back for 92-96 C4
  236. WTB-BFG G-Force T/A KD 275/40-17 L+R
  237. FS: Targa top conversion mounting hardware.
  238. short throw shifter
  239. 91 vette stock exhaust
  240. wtb - light beige sport seat
  241. Zr-1 For Sell.. Crome..
  242. for sale:95 black seats, door panel (pics)
  243. C4 Steering column
  244. F/S D44 Ring and Pinion
  245. Front Y pipe...
  246. FS Siemens 60lb injectors
  247. FS LT1 adjustable Fuel Pressure Regulator
  248. Fs: Acell Gen 7
  249. Pedals From a T-5 F-body FS
  250. F/S 350 TPI & Trans
