View Full Version : C4 Parts for Sale/Wanted
  1. FS Headlight assemblies
  2. Headers coated or not
  3. FS,Nylon bumper mask 91-96
  4. FS: 89-96 CAGS 6-Speed Skip Shift Bypass Plug with Tech Instructions
  5. FS Exhaust parts
  6. gm 16134302 ANHU memcal 90-91
  7. WTB 94 AC/Heater control
  8. WTB: 89-93 Tan Seat Savers
  9. Accel / Holley / Edelbrock High Performance TPI Kit
  10. FS: Lingenfelter Autographed Intake / C4 hood
  11. Tires
  12. New LT1 Accessory Drive Bracket and other LT1 parts
  13. ZR1 Front & Rear Leaf Springs
  14. ZR1 Rear Sway Bar
  15. WTB Breadbox/Glovebox
  16. FS-1990 zf 6 speed transmission
  17. fs 87 under dash very good wiring harness 60 shipped
  18. Corvette 1995 Rims and F-1 Eagle tires
  19. ***f/s*** 1986 wheels and tires
  20. wtb
  21. Parting out 89 convertable
  22. 95 vette manual
  23. Targa Top Sides..84-96
  24. 1996 stock shifter nob
  25. Need 91 targa mount covers.
  26. WTB: (1) QA1 ALN4855 Shock
  27. F/S: Right Front Spoiler $14 shipped
  28. 1995 coupe weatherstripping
  29. Parts for sale...
  30. F/S: 1984-91 GM Chevrolet Corvette Parts and Illustration Catalog - $70
  31. 94 Factory Service Manual (White Edition)
  32. new 88 engine
  33. For Sale or Trade SPEC Billet Steel Single Mass Flywheel
  34. For sale right front tps sending unit
  35. FS: Autometer 10190 dual gauge pod for pillar
  36. FS: LT1 MAF Sensor - descreened
  37. WTB C beams
  38. WTB Luggage Carrier
  39. WTB stock LT1 exhaust pipe
  40. C4 Front & Rear Emblems
  41. FS: ZF6 Tranny Conversion Kit & more HP Parts
  42. LT1 MSD Wires and Stock Throttle Body.
  43. FS: C6 Wheels, With or without tires
  44. WTB: front bumper air inlet.
  45. fs rear compartment plastic inserts left and right sides 15 shipped right sides10 p
  46. 1989 corvette z51 wheels 16x9.5s for sale
  47. fs off a 87 abs sensors 60 shipped
  48. WTB:RR tire pressure sensor for 92
  49. FS CDM from 91
  50. ZF Transmission
  51. WANTED: Hypertech Chip or ? for 1992 Vette
  52. TPI setup
  53. 1996 zf bellhousing magnesium
  54. 1996 zf dual mass flywheel
  55. F.S Canton 7qt oil pan with pickup tube and HV pump
  56. C4 Parts and Accessories (In Ont. Canada)
  57. FS in AZ (pick-up only) 89 L98 long block
  58. Evaporator New in Box fits 90-93 (90 91 92 93)
  59. WTB A/C COMPRESSOR 90 corvette
  60. For Sale or Trade - D44 3.91 ratio
  61. nitrous hp nx268h cam for sale
  62. Dana 44
  63. Powder Coating Special for C4 Brake Calipers
  64. WTB...... AC Compressor for 89
  65. 87-91 AIR Pump delete bracket F/S
  66. 1988 Corvette 350 Engine Block
  67. Chrome ZR1 5 Spokes for sale/w tires
  68. Wtb - 87 abs pump - anyone?
  69. wtb. master cylinder for 1985 corvette
  70. dash pad
  71. FS: Remasted power antenna from a '94.
  72. Moates ALDL cable/ Burn2 F/S
  73. Driveshaft for sale 90 auto
  74. Orginal GM Flame red carpet pieces cheap
  75. Wanted Front License plate cover for 96
  76. Motorsport Tech - The finest Wheel Adapters, Wheel Spacers, and Hub Rings.
  77. LT1 / ZZ4 pistons for you
  78. 91 Standard Seat overs i vg
  79. WTB Grand Sport Flares
  80. Wtb ac delete pulley lt!
  81. FS: GM Perf Aluminum Roller Rocker Arm Set 12370838
  82. FS: new LT4 heads and EFI intake; spare LT4 head; LT4 carb intake
  83. WTB: Flame Red Seat Cushions 1992
  84. WTB: Flame Red Rear Center Carpet 1992
  85. Wanted: 94-96 6spd Shifter Upper Trim Plate
  86. new tpi lingenfelter throttlrbody
  87. FS: Nearly new factory GM sawblade wheels 93+ 8.5/9.5
  88. WTB C4 to C5 caliper bracket adapter
  89. 1984-1985 horn contact plate, new.
  90. WTB clutch safety switch,1991.
  91. WTB: '96 CE Set of Wheels
  92. F/S: 1984-91 GM Chevrolet Corvette Parts and Illustration Catalog
  93. Parting Out 1985 Z51 Springs Bars Bilsteins
  94. c4 bellhousing with fork $125
  95. wtb: 90-96 rearview mirror
  96. FS: R-D Camber Brace 85-89
  97. WTB: CORSA Mufflers
  98. WTB 91 Cluster
  99. FS: Air Cleaner Assembly for L98 with MAF & Air Duct (1985-1989) Picture
  100. ABS Control Unit from my 1990
  101. FS: Center Bolt Valve Covers (86L-92) NOS (Picture)
  102. 1986E L98 Parts for Sale
  103. *** need a oil dip stick 1988 c-4 l-98 ***
  104. 1991 TPI Plenum,runners,manifold
  105. 95 Corvette Video Tape
  106. 86 ENGINE for sale
  107. Parting out Quasar blue 91
  108. WTB 91-93 air bag
  109. chrome C5 ZO6 style rims for sale (pics)
  110. Leftovers for sale
  111. ****WTB*** 1986E Valve Covers****
  112. wtb 96 vert frame and black top
  113. F/S: C4 & C3 Parts
  114. F/S: 1/8 Scale 1985 Corvette C4 Model Kit
  115. WTB A/C compressor w/clutch, accumulator, orifice tube and seals
  116. F/S 1996 Grand Sport F45 Front Shocks
  117. SS Braided brake lines
  118. C4
  119. 1987 Complete TPI
  120. 1985 Window Regulators
  121. FS: 1996 Service Manuals (2 book set) - OEM Red (Final Ed.)
  122. FS: 1992 Exhaust Manifolds
  123. Fs: 1990-91 ecu 01227727
  124. WTB ZR-1 Rocker Panels
  125. FS: 94 Steering Wheel
  126. fs 87 engine wiring harness 75 dollars pluss shippin
  127. 1992 Corvette Wheels & Tires
  128. For Sale. 14089936 MAF RELAY
  129. Aftermarket LT4 heads
  130. WTB: PKE module for 95 coupe!
  131. Trade my Dana44 3.33 for 3.07 or taller.
  132. Free to Good Home; Rear Bumper Cover; C-4
  133. shop manual
  134. glass tagar roof panel for 1994
  135. For Sale: Alternator Bracket Freshly Painted
  136. For Sale: Spare Tire Hanger
  137. For Sale: KC4 oil cooler
  138. Trickflow pushrods 7.200
  139. FS (?)- Borla LT-1 Exhaust system complete
  140. 96 AC Compressor with clutch
  141. WTB 1984 Z51 rear spring shims
  142. 87 corvette hood for sale 225 dollars
  143. WTB 1991 right wheel
  144. FS - Prothane 7-1205-BL Rear Strut Rod Bushing Kit - 88-96 Corvette
  145. Want to buy 1985 targa top
  146. F/S C4 86 Factory Rims and Tires
  147. Hood wheelcovers and fuel rail
  148. WTB: Corvette roof panel attach screws-front
  149. WTB: 1990-93 black door panels
  150. WTB: Oil dipstick for 1992
  151. FS:95 sawblade set with caps
  152. early c4 cluster wanted
  153. WTB: Factory Bronze Targa Top '89-'96
  154. fs: 1989 corvette street/strip in nj
  155. Emergency hatch release handle??
  156. WTB-throttle body for 86'
  157. 88 heater control wtb
  158. WTB Speedometer Gear 45Tooth
  159. F/S: 1/8 Scale 1985 Corvette C4 Model Kit
  160. WTB: 90/91 Seat recliner switches
  161. FS: 16188051 ECM - perfect for track car
  162. Jegs Electric Billet Water Pump
  163. FS: CCW Blank Billet Polished Center Caps
  164. WTB RADIATOR and SLP CLAW INTAKE
  165. F/S: C4 & C3 Parts
  166. Fs.lt1 comp cams soild roller camshaft
  167. '89 wheels free to good home
  168. WTB:Power seat track for 90 corvette
  169. WTB 1 Goodyear Eagle GT+4 Tire
  170. FS headlite module
  171. FS A/C aux cooling fan
  172. FS spoiler center section W/red valance
  173. ZF 6 Slip Joint For Sale
  174. FS: Removable Hard Top
  175. FS 90_95 ZR-1 Rear Bumper
  176. DRM brackets and VB&P hemi trailing arms f/s
  177. WANTED: Rear Suspension Spindle rods (4 pcs)
  178. 1974-82 Rear Bumper
  179. Voxx rims for sale
  180. Looking for two interior items 92-93
  181. Customized Wall Clocks - now at DD MODS!
  182. 84 Lt side underdash panel
  183. For Sale: 1984-1991 GM Chevrolet Corvette Parts & Illustration Catalog
  184. 4 sale; n.o.s. upper wheel wells, c4 nos weatherstripping
  185. 86 Side Pipes
  186. C4 stereo parts for sale
  187. Corvette Doug Nash 4+3 Overdrive Unit Needed
  188. WTB: drivers side footwell cover
  189. c 4 parts going to carlisle
  190. WTB: Battery Panel for a 93 Polo Green Corvette
  191. Banski, Momo, Valve covers....more for sale
  192. 1997-04 caliper brackets for rear
  193. Complete Bose system, tape head + all 4 pods
  194. FS: Stock LT1 exhaust manifolds
  195. AFSM bar and tinted top FS, Carlisle delivery available
  196. FS: 91-94 driver side fender gill
  197. C4 race harness bar and mounts, RD, Brey-Krause Carlisle delivery
  198. '89 Z51 bars/springs,D44 3.45 rear Carlisle delivery
  199. FS: Variety of things
  200. F S: Slp claw intake
  201. Sensor Test Tool for sale
  202. FOR SALE: C5 Matte-Black Wheels w/ Nitto NT555‏/Nitto NT05 Tires
  203. FS 1984 crossfire air cleaner assembly
  204. FS: C4 5-spoke wheels 17x9.5 all 4
  205. ac delco altenator ,35 shipped
  206. WTB windshield wiper circuit board for 86
  207. 1996 Collector Edition Wheels
  208. WTB: Torch red carpet pieces for my 96 coupe
  209. FS: 90' air bag
  210. Wanted a/c condesor for 95
  211. Chrome C4 ZR1 Style Wheels @ JWM
  212. Wanted : Slp Triple Air Intake "Claw"
  213. WTB: LTCC Coil Conversion system
  214. WTB: 88-89 MAF sensor
  215. FS: C4 Original Dealer Sales Brochures
  216. New Car Cover - $50 shipped obo - NJ
  217. 94-96 Seat Covers (Slip on) Gray
  218. FS: TPiS Oil Cooler Kit and Accel 30lb Fuel Injectors
  219. 1989-1996 Targa Top Painted White
  220. c4 ABS Kent Moore Tester
  221. hood release cables and handle assy 35 shipped
  222. Parking/Fog Light
  223. WTB: 84-87 LH Visor
  224. L98 exhaust parts LT1 mufflers w/tips
  225. 85 Corvete left overs
  226. 85/90 CORVETTE CENTRAL Mufflers "Brand New"
  227. F/S D44 C Beam and DS
  228. WTB deck lid lock actuator
  229. WTB : Supercharger for '88
  230. '84 seats and breadbox
  231. FS: 89-96 Bronze tinted GM factory Targa removable roof
  232. F/S: C4 & C3 Parts
  233. EFI to carb conversion parts...blowthrough
  234. WTS Kent Moore Crankshaft Hub R&R Tool J39046 for LT1
  235. Renegade for sale - $600.00 Firm Shipped is the USA.
  236. duplicate post
  237. fuel rail, injectors,regulator $50 plus shipping
  238. F/s 1990 c4 parts
  239. C5 Fronts F/S
  240. Wanted 1991 LCD speedometer
  241. Stock cataylic Converter 1990
  242. WTB or rent: "How to" vhs or DVDs
  243. Wanted Tech 1a Scan tool
  244. cluster C4
  245. TPI setup
  246. FS: Edelbrock Hi Flow TPI Base Manifold
  247. 94-96 lt1 parts
  248. F.s 94 automatic shifter with boot
  249. Automatic shifter cable
  250. 94-96 Automatic Shifter Upper Trim Plate
