- Cool C4 Corvette Posters (and Prints)
- WTB: LT4 Knock Sensor Module
- 3 qts Royal Purple Synchromax - $20+shipping
- Jackets Up To 20% Off
- Wanted:96 rack & pinion cylinder lines
- GM Corvette Parts and Illustration Catalogue for 84-90 C4/ZR-1
- C4 Conv Luggage Rack
- FS: C4 Headlight bucket .RH
- FS: C4 Windshield Washer Bottle/Pump
- FS: C4 Radiator Coolant Reservoir
- F/s 1985-1988 bbk 52mm throttle body
- 1989 maf
- F/S 1991 calipers,pads, rotors and shocks
- 88-96 New in box Hawk HPS Brake Pads
- F/S Fast Burn Heads mk II--NIB
- WTB 88 Front Bose amp
- WTB Left 95 / 96 fender
- TrickFlow LT1 heads with Comp 918 springs and Magnum rockers
- fs a pair of newer style door regulatsand motors 165 shipped
- FS: 1996 OEM Cat
- LOOKING for Cluster (Gauges) 84 vette
- FS 86-91 rear Y pipe without Y 3" dia extention
- WTB: Mass Air Flow Sensor for 89'
- WTB: SLP headers 85 vette
- WTB: ZF Stock Shifter or trade for a Hurst
- FT: 4 Centerline Convo Pros
- FS: (4) 255/45/17 & (2) 295/35/18 Firestone Firehawk Wide Oval Tires
- F/S: 1993 Corvette owner's manual, good condition!
- F/s USED TPI CRUISE CONTROL SERVO / MOTOR / DIAPHRAGM AND CABLE
- F/s NEW OEM TPI THROTTLE CABLE BRACKET
- F/s TPI NEW IN WRAPPER OEM THROTTLE CABLE
- wanted
- Heads for a 1986 350 corvette
- F/S 84-87 GM LH rear speaker covers NOS
- Wanted: Brackets for a 1989 Roof Panel/Targa top
- Wanted CFC Brochure for 1995 LT1
- WTB: BMH or BMF rear spring
- wanted stock FPR cap 90 vette
- FS: C4 Battery Tray
- wanted
- wanted
- wanting to buy : junk front brake parts
- good 89 replacement leather interior
- F/S - New OEM Weatherstrip set for 95 coupe
- F/s 96 CRUISE CONTROL MOTOR / ACTUATOR / DIAPHRAGM
- Corvette parts Houston
- F/S (2) 84-87 offset A-Mold 9.5" Wheels/Tires
- 1991 C4 bose audio system
- fs 95 plumen and throttle body 50 dollars pluss shippin
- wanted, srcrew, nuts for 1986headlight assembly.
- WTB: aftermarket leaf spring, front & rear
- For sale tire pressure sensors
- FS neoprene seat covers 86
- f/s New gm frt license plate cover
- Front Coil Overs Bilstein Eibach
- eguyett1985
- For Sale: Manual Trans Convertion Kit 84-88
- FS: Melrose Smoke Top 84-86E
- fs pioneer super tunner3 mosfet 50w x4
- *FOR-SALE* Custom ANALOG Dash Cluster For early C4s’. Get rid of your digi-dash !!!
- WTB: Supercharger Complete
- F/S - TBI Insert
- F/S - Black Visors - Pair
- F/S Center Console Lid - Grey
- WTB: Aluminum spacer that is taken out of front leaf spring when lowering.
- wanted muffler eliminators
- WTB BBS gold crosslace
- WTB 95 Front Upper Control Arms
- instrument cluster
- Proform perimeter valve covers $70
- 85 thru 88 shift buttons
- 1 wheel
- FS: Stock-Style Mufflers from an 85
- FS: 1984 Service Manual - OEM
- WTS 24mm Solid OEM rear Sway bar
- FS: Set of Valve Covers Parameter Bolt Pattern (84-86E)
- C4 seat belts for sale torch red
- 1996 clutch slave
- 1996 calipers
- fs D.I.C. OFF A 85 ,VERY NICE 36 SHIPPED
- Where can I get an Engine Wiring Harness
- 1984 Interior parts
- Clutch and Brake Pedal Assembly
- FREE C4 PARTS in WI
- ASR cable / WHO BOUGHT MY ASR?
- 91-96 Complete bumper change over kit, including wheels!
- 86 upper plenum intake runners distributor cover
- Chrome 86 throttle body
- Wanted:Air Pump tube to converter
- i need car parts
- FS White Targa Top off an 89
- sunvisors and rear light and tag louvers
- Free 88 corvette frame
- FS - 92-96 3" BB Tri-Flow Exhaust
- FS - C4 Aluminum Gas Pedal Mount
- FS 94 LT1 heads
- BBS RS 16" Gold basketweave wheels $1200 (Ma)
- F/S Heavy Duty Kwik Lift
- NCRS ALERT!!! Genuine GM 91-96 Center Caps ZR-1 and Non
- F/S C4 Euro amber taillight lenses, NOS
- FS - High Performance Aluminum Mass-Air Housing
- WTB: Left front speaker/amp to fit a '93.
- Black Sport Seats $350
- front Y pipes after market & others wanted
- FS: Michelin PS1 Tires, 315s and 275s excellent tread
- New rear wheel bearings, 2 available
- wtb 90 ZR-1 PASS REAR RIM
- Wanted: Delteq. Just need the Opti box.
- '88 with supercharger and '90 ZF transmission
- J55 Calipers
- Wtb 85 fsm
- WTB Lt front upper wheelhouse and Lt door mirror
- - F/S LH Headlamp Assembly Complete
- wtb 1.6 roller rockers
- - F/S Front Spring FHU spring Code - Front I think
- - F/S C4 Steering Knuckle Assembly (Rotor/Caliper/Bearing/Spindle) LH 14035699
- - C4 Z51 Lower Controll Arms
- FS: 84-91 red and black seat covers $100
- Looking for Front License Cover for '87
- FS: J55 Grand Sport Calipers, brackets, stainless lines!!
- FS: SuperRam Intake (Lid, Plenum, Runners and Base)
- FS - Mid America 84-96 Lowering Kit 602712
- 1996 2 volume service manuals
- FS - Passenger side door panel - Grey/ Silver
- Fs - power antenna 84 vette
- Power Antenna $50
- 1987 corvette rear fiberglass bumper
- fuel rail
- ATI Procharger kit TPI non-intercooled $2200
- 1992-1996 Hatch Seal $40.00 shipped
- Fs - 84 sawblades / like new tires
- Parting my '85. Miniram II, gmpp heads, dana 44, glass top, etc!
- Rear factory speakers-c4
- WTB Door Handles w/Keys C4 84 or newer
- WTB - ONE wheel bearing/hub assembly
- ***RSD Line Loc for C4***
- FS 88 4+3 tranny 475 ohio pic up might ship
- WTB: 94-96 black door panels
- F/S - 1986 C4 Calipers Front and Rear *USED* *CHEAP*
- Collector Edition 96 Caps (new condition / cheap)
- 88 ecm/prom f.s
- FS Red, 1992 Corvette Factory Service Manuals Vol 1 & 2
- who has a climbate control
- F/S Big Mouth Air Dam
- F/S Brand New GM Front Bumper Absorber
- F/S Plenum
- WTB: 91-96 Front Bumper
- Free shipping for PayPal customers this week at CruiserBlvd.com >> Corvette Posters
- WTB 87 parts TX
- K&N 33-2035 and black sun visor
- License plate filler
- differential bearing set
- FS:1990 L98 Short Block
- 1989 c4 corvette dana 44 3.54 rearend 3.54 gears
- wtb smog eliminator pulley
- left side hood support with brackets
- aux fan and digtal climate control
- 1987 sterring colum with key
- 88 vette dash panel and speaker grills
- fs 88 foglights and hood/fender seals
- f s 88 rear hatch carpet @ console lid
- FS: 1988 17 inch 9.5 track wheels
- FS: Camaro wheels ! LOL
- FS: 1996 Front suspension
- Parting out 87.
- Pay it Forward...Rotors
- FS: C4 Parts
- Feeler: Original Gatorback Tires 255/50/16 new takeoffs NCRS
- WTB two 17x9.5 Dymag wheels
- FS windsheild washer res /w pump
- FS air pump assembly
- FS:Rear Knuckle LS
- FS rear wheel bearing
- Fs 1 half shaft
- FS body wiring harness
- L98 Nitrous
- WTB fuel door bezel for 88 coupe
- F/S USED set of C4 front and rear bearings
- 2 horns for sale
- wtb early graphite or black seats
- 88 C4 Parts
- WTB 4 post lift, pre owned
- F.S. Glass tops/Solid Tops many colors
- F.S. 2 ZF 6 speed transmissions
- Good dealing with C409
- WTB Fog light housing asembly for 91-96
- Wtb 4 good used 255-50-16 in nj area
- Mojave (Chad) Good Buyer
- WTB Bose rear spks for 86-89 conv.
- WTB 1990 Front carpeting (black)
- F/S 1 LT4 Head
- TPIS Big Mouth intake manifold $300
- Fs: Drivers side lightlight ass. W/o motor
- LT1 DRM oil cooler package
- WTB Flywheel
- Euroheadlight upgrade package******
- Fuel Rails/AFPR for HSR/Edelbrock EFI Single Plane/PP EFI manifolds
- '91 ZR-1 Complete Exhast w/ Less than 1000 miles
- Wtb
- Factory Oil Cooler & Lines
- Xcellent dealing with member ron degutis
- Fs: 1990-95 corvette zr-1 complete thermostat housing
- F/S New Blue Acrylic Targa top
- FS: C-4 Seat track with brand new AC Delco motor
- 1991 Lic. plate cover (WANTED)
- WTB 1984 cluster working condition
- just a few things
- WTB: 275/40/17 Goodyear GS-C'S L/R
- FS: Vortex Ram Air Kit
- cheap and free parts from my 85: part 2
- rear end for sale Dana 36
- WTS/WTT: BBK 58mm TB pre-88
- (wtb) zr1 exhaust system
- Not mine, just posting the link
- WTB - MSD Opti for '92 p/n #8381
- WTS C68 from 1988
- Wanted 96 black floor mats
- FS: 85-86 AC Platinum Spark Plugs - $25 Shipped
- parting out 1989 c4 corvette parts for sale w/ 6 speed tranny
- LT4 stuff for sale
- Ported LT1 Intake
- 88-96 Targa top, blue acrylic
- Wanted Dana 44 Bearing Caps
- Trans Electrical Connections
- WTB: '85 L98 AC compressor mount
- WTB LT4 Knock Module 16214681
- Wtb a.s.a.p
- Earls Corvette Braided brake lines...
- WTB - manual A/C control head for a 91
- Parts needed for 85 vet!
- FS: Polished GM Amolds 17x9.5 and widened 17x12 rears
- 53 back issues CORVETTE MAGAZINE - every issue #1 - Present
- WTB: 1990 Factory Rims
- Wtb used operational supercharger for l98 5.7, 1986
- F/s custom c4 hood
- FS Origional 1992 Corvette N.O.S. video owners manual
- WTB OD Cooler Lines
- FS: dual mass ZF6 flywheel
- ZF 6SP Shifter@ Hurst T handel
- Stock & Performance LT1 Parts
- Z06 Speedline wheels & tires in CT.
- targa top 89 up
- F/S Precision Industries Vigilante torqe converter
- WTS 1984 parts that don't race.
- WTB Dana 36 3.31 posi ring and pinion or...
- Wanted: L98 Roller Engine
- WTB J55 caliper brackets.
- NJ FS corvette black book
