View Full Version : C4 Parts for Sale/Wanted
  1. Glass roof
  2. Fs: 1990 ltpws
  3. WTB misc parts for 92
  4. heater hoses bypassed heater
  5. Replica ZR1 Powder Coated Black 17x11 and 17x9.5
  6. FS:Comp. Cams 3/8" P. Rod guide plates
  7. FS: Summers Brothers 31 spline outer stub axles and wheel bearings, $900
  8. 1994 OEM Exhaust System 4 Sale
  9. Fs 1 new injector
  10. F/S Rear compartment trays
  11. Good dealing w/LMP-Chris
  12. WTD Caliper park brake brackets
  13. Great Transaction with Wheelsup
  14. WTS C68 blower control module '88
  15. FS-LT1 Road Race Engine w/ Build Sheet
  16. rear bose speakers from 84 c4
  17. 1989 Corvette
  18. need climbate control.....
  19. WTB --Coil overs for 1994 ZR1
  20. Fs sport seat clamshells
  21. Fs c5 brake calipers and brackets
  22. Fs c4 sport seat switches
  23. Fs c4 lower steering shaft
  24. FS: Bosch design three injectors, 30 lb / 36 lb
  25. WTB wheels
  26. Sub, Amp, Box, and XM adapters
  27. WTB Connectors to C4 Door Ajar
  28. LT-1/4 Motor Mount
  29. LT-1/4 Muffler Hangers
  30. LT-1/4 MSD Coil
  31. Gas Pedal
  32. Targa Top Stowage Latch
  33. 94 glass roof panel
  34. FS. fuel pressure gauge autometer
  35. FS BBK 52mm TB and LT4 28 lb injectors
  36. 85 vette
  37. FS. 1992 saw blade rims
  38. Wanted: Misc. Stuff For My 85
  39. wanted rear brake line block
  40. Need 87 Auto Mem-cal
  41. WTB 95 front liecens plate cover
  42. WTB - Black to for '93
  43. F/S Head Lights , and Side Mirrors from an 86
  44. wtb: LTPWS 93 corvette
  45. WTB 1984 Factory Service Manual
  46. WTB Mufflers with Tips
  47. complete black tag, spec steel flywheel look inside
  48. Kuhmo MX Tires 2ea 255/45/17 and 2 ea 285/40/17, like new
  49. ZR1 Wheels Gunmetal Gray, Like new
  50. wtb; seat tracks
  51. 1986 Corvette - Body pieces / '01 wheels, etc. Colorado
  52. 1986 Corvette Parts - Cleaning out the Closet
  53. Great working with USAonlyway
  54. JWMotoring Is Good To Go
  55. 88-96 C5 brake upgrade
  56. Secondary Air Injection Switches
  57. FS 87 fsm manuals
  58. FS - Set of ZR1 (Silver) rims and Sumitomo Tires
  59. FS - OEM C5 Z06 Speedline rims and Goodyear Supercar Tires
  60. wtb long tube lt1 headers
  61. F/S Bronze tint Lexan roof for C4
  62. LT4 Heads, Hot Cam w/ GMPP 1.5 rr kit, Intake,
  63. F/S Front and Rear Hawk Ceramic brake pads
  64. WTB late 90's rear view mirror
  65. rear diff with gears from 1994 ZR1
  66. front Y pipe with precats
  67. F/S rear Y pipe
  68. OEM ZR1 wheels
  69. Wtb
  70. FS:SRP Pistons #148988 for 396 SBC stroker .030" over (moly/ceramic coated)
  71. F/S high flow cat...fits 86-91
  72. Need air/heater fan speed control knob
  73. Reese 89072 c4 trailer hitch
  74. FS-LT1 Road Race Engine
  75. Fs: 90 gm zr1 wheels
  76. FS: AFS C6 Style POLISHED WHEELS 17X8.5 18X10.5
  77. Fs: Accel proram intake setup
  78. Fuel Tanks for sale
  79. For Sale 1993 Sawblades
  80. 88-96 rear knuckle needed
  81. WTT 93 Glass top for torch red top or WTB red top
  82. WANTED crossfire injection manifold and throttle bodies.
  83. WTB '96 coupe key fob case
  84. Fs -84 power antenna / after market - new
  85. Fs 1984 gm service manual ++
  86. Fs 84 to 98 gm service manuals
  87. WTB 1999 Keyless entry fob-Used
  88. 91 Stock Cat Backs - Free
  89. F/S 86 cast iron heads
  90. car cover
  91. Steering wheel components, 1990-1996
  92. FS - 84 sawblades / Like New tires
  93. F.S. OEM Automatic Shift Knob (perfect) PHOTO >>>>
  94. F/S NIB GM 91-96 Corvette Crossed Flags Nose Emblem
  95. F/S NIB Corvette Crossed Flags 40th Anniv/Grand Sport Nose Emblem Chrome (GM)
  96. CT FS: 2 BFG KD 315/35 x 17
  97. Wanted: Four 275/40-17 tires
  98. Fs cruise control servo n.i.b.
  99. Fs 88 washer resivoir w/pump
  100. FS 1 HALF SHAFT W/ camber arm
  101. FS air pump w/ valves & selnoids
  102. WTB trailing arms,rear hub, wheels
  103. Led reverse lights
  104. F/S: Rear Non-Bose Speakers
  105. 3+ sets of aftermarket Wheels, Crays, ZR1s, drags.Tires. E.Ts
  106. FS: (2) Used C4 Rear Outer Spindle axles
  107. FS: New LT1/LT4 Felpro #1074 head gaskets .039"
  108. FS:84-96 MAM Noah car cover (gray)#602186E
  109. F/S LT-1 exhaust with cats
  110. Cut lid for 1996
  111. WTB a set of Sawblade wheels
  112. Bilstein shocks
  113. Bose Enclosures - MAF Sensor - Headlight Motor F/S
  114. WTB: Stock LT4 Cam
  115. Comp Cams 918 springs NEW in box.
  116. F/s 96 SUN VISORS BLACK
  117. NEW HMSL Lens for 1985-90 Cpe & ZR1
  118. WTB: Interested in '91-'96 Third BRake Light Housing
  119. WTD: 1989 power steering, smog and alternator brackets
  120. Magnetic Red Luggage Trailer For Sale
  121. FS: Dana 36 C-beam
  122. Offy CFI Intake
  123. Heater core out of a 96
  124. Dana 36 parts and c beam for auto
  125. Parting out complete 357 LT1 Callies, JE, Manley, etc...
  126. WTB Wiper Delay Board
  127. 1989 corvette 6 speed tranny 89 for sale kit
  128. WTB 84 Door Ajar Switch(es)
  129. WTB: Driver Power Seat Transmission
  130. F/S 1993 Service Manual
  131. 91 Dealer Poster, Unopened Owners Manual, Service Manuals
  132. TPI Intake Base and Runner For Sale Cheap
  133. WTB: LT1 complete engine and/or harness and/or pcm
  134. I need a center console door 84-89
  135. FS: Speakers and amps
  136. WTB 94-95 17" 9.5" rear stock wheels
  137. B&M Ripper shifter for ZF 6-speed
  138. C4 Lowering setup - springs and hardware
  139. Hardtop brackets
  140. FS: 2 New Spicer OEM Solid Driveshaft U-joints 5-786x
  141. C4 brakes $100
  142. fs 86 long block 150, pic up in ohio
  143. FS: New Dana 44 1310 series pinion yoke 29 spline
  144. FS:New MC Bias spring/ Super blue brake fluid
  145. 1991-1996 European Tail Lights
  146. Looking for set of shocks to fit 95
  147. '84 horn button and horn contact
  148. Flatout Imaging Corvette Posters on Sale for $9.95 (while supplies last)
  149. LT4 throttle body
  150. LT4 exhaust manifolds
  151. FS Prom Burning Stuff
  152. Clutch master and slave
  153. 96 HVAC parts
  154. WTB -- Borla or Magnaflow catback for 94 ZR1
  155. ARP LT1/TPI Head Bolts
  156. WTB:C4 accessory bracket/tensioners
  157. F/S 1991 Bose Gold Audio Components
  158. FS: Fox Raincoat 1989-96 C4
  159. FS: Dana 36 3.07 Center Section, Nice
  160. Wanted fender badges
  161. WTB: NYU Code spring
  162. WTB : Gray or Gray-Black Door Panels
  163. Seat belts
  164. Transmission shop in SE CT?
  165. WTB Long Tube Headers
  166. 2 grand sport 11" wheels
  167. rear frame section
  168. Another dash cluster needed
  169. WTB Gray Carpet
  170. LT4 powersteering parts
  171. 1996 factory service manuals
  172. hubs
  173. ZF6 with master and slave
  174. 2 C4 horns
  175. Factory Jack
  176. Bendix brake pads - 1996
  177. roof panel - bronze tint
  178. Hatch Vent
  179. Great dealing with kg1922001
  180. LTx Single Plane Intake Conversion
  181. Canton 15-240M Oil Pan
  182. Wheel Spacers
  183. VBP C4 Extreme Front Spring
  184. A Few C4 Parts
  185. LT1-LT4 Parts
  186. 96 AC Programmer
  187. 1984-1990 Clear Front License Plate Cover
  188. Bright Red (1992) License Plate Cover
  189. 84 - 96 dash carpet/matt Black
  190. FS...... Mini Starter/ Spec Flywheel
  191. WTB 84-87 Lt Front wheelhouse panel
  192. FS CT Gransport 17 x 11 with BFG KD's
  193. BBK TB For Sale 85-88
  194. WTB Black under dash carpet 84-89
  195. Halloween Weekend Sale - Hubs, Window Regulators, Radiators 20% off!!!
  196. F/S C4 Intro tech used LIKE NEW car cover
  197. Assorted C4 Items, Some Ruby Interior Parts
  198. WTS GM repo sunvisors
  199. 93 94 95 96 Corvette Power Antenna Mast Kit GM 12525955
  200. F/S Big Mouth Air Dam
  201. Push rods
  202. WTB: Mouldings for 1987 & equivalant
  203. WTB: 86L-88 Roof Targa Roof Panel
  204. WTB:Bilstein shocks for '87 (for rebuilding)
  205. WTB Center console door
  206. FS two 01227727 ECMs 90-91
  207. Few parts from LT4 vette
  208. FS: Fiberglass Roof Panel
  209. c4 Lt mirror glass
  210. WTB C4 94-96 ABS mounting plate
  211. LOWER PRICES and FREE SHIPPING
  212. F/S Water Pump 1984-1991 $165 shipped
  213. F/S A/C Accumulator1986-1989 - $25 shipped
  214. 88 s-charge,6spd, dana 44, z52 suspension
  215. 96 brake pads
  216. WTB 3.73 D36 gears or diff
  217. WTB 1.6 rocker arms for 1990 L98
  218. FS 17” CCW wheels & Hoosier A6 tires
  219. Cool C4 Corvette Posters (and Prints)
  220. WTB: LT4 Knock Sensor Module
  221. 3 qts Royal Purple Synchromax - $20+shipping
  222. Jackets Up To 20% Off
  223. Wanted:96 rack & pinion cylinder lines
  224. GM Corvette Parts and Illustration Catalogue for 84-90 C4/ZR-1
  225. C4 Conv Luggage Rack
  226. FS: C4 Headlight bucket .RH
  227. FS: C4 Windshield Washer Bottle/Pump
  228. FS: C4 Radiator Coolant Reservoir
  229. F/s 1985-1988 bbk 52mm throttle body
  230. 1989 maf
  231. F/S 1991 calipers,pads, rotors and shocks
  232. 88-96 New in box Hawk HPS Brake Pads
  233. F/S Fast Burn Heads mk II--NIB
  234. WTB 88 Front Bose amp
  235. WTB Left 95 / 96 fender
  236. TrickFlow LT1 heads with Comp 918 springs and Magnum rockers
  237. fs a pair of newer style door regulatsand motors 165 shipped
  238. FS: 1996 OEM Cat
  239. LOOKING for Cluster (Gauges) 84 vette
  240. LOOKING for Cluster (Gauges) 84 vette
  241. FS 86-91 rear Y pipe without Y 3" dia extention
  242. WTB: Mass Air Flow Sensor for 89'
  243. WTB: SLP headers 85 vette
  244. WTB: ZF Stock Shifter or trade for a Hurst
  245. FT: 4 Centerline Convo Pros
  246. FS: (4) 255/45/17 & (2) 295/35/18 Firestone Firehawk Wide Oval Tires
  247. F/S: 1993 Corvette owner's manual, good condition!
  248. F/s USED TPI CRUISE CONTROL SERVO / MOTOR / DIAPHRAGM AND CABLE
  249. F/s NEW OEM TPI THROTTLE CABLE BRACKET
  250. F/s TPI NEW IN WRAPPER OEM THROTTLE CABLE
