- WTB : Injectors 38#
- FS 87 bose tape deck
- f/s 87 cluster
- LT4 water pump
- LT4 throttle body
- Stock air box LT4
- Composite lt1/lt4 valve covers
- 3.45 ring/pinion gears
- 1996 half shafts (2)
- LT4 heads/intake
- Wanted High mount 3rd brake light (86-90)
- WANTED: TPiS Longtubes For A '94
- TPI runners, base, plenum for sale off a 91 SD setup GREAT SHAPE
- Cleaning Out The Workshop--Lots Of C4 Exterior and Interior
- WTB: 92-6 Catalytic Converters
- FS: Polished GM 5-spoke wheels
- A few L98 parts on CL from my 89
- 1996 FSM (Factory Service Manual)
- hood emblems
- WTB 2 x ZR1 5 spoke 17 x 9.5 chrome wheels
- WTB 89 engine harness with ecm
- GS brakes/wheels
- WTB ZF6 reverse ring
- I am looking for a 406 short block
- WTB/WTT LT1 oil pan, chrome with oil level sensor, or a great deal on a bigger pan??
- Kenwood KDC-X592 $150 iPod, Satellite radio, USB, Bluetooth, MP3 ready
- corvette sports seats
- WTB: Staggered Sawblades
- ***Polk Audio 12" db1240 sub brand new in box***
- Baer Eradispeed Rotors, plus Calipers, brackets, etc for sale
- C4 Racing Stuff
- 88-96 XLNT Power Seat Track $100+Ship.
- ZR-1 sawblades (17x9 front, 17x11 rear)
- NEW: Carroll LT-1, LT-4 Corvette Supercharger System
- fs automatic shifter
- Fs 88 wiring harness
- WTB: automatic shifter assembly
- TPI / LT1 / LT4 TB coolant crossover assembly
- WTB 93 LT1 Throttle Coolant Bleeder Screw/Valve
- ZR-1 polished oil filter cover FS
- 1986 coupe Halo
- FS,84 parts.
- C-4 Corvette wheels/tires 17x9.5 - $350
- F/S ZF-6 trans BLACK TAG
- LT1 intake swap parts,thermo,-10ANs ,FPR, ECT
- wts ZF6 black tag transmission
- WTB small rubber hatch bumpers
- Wtb: New j-55 hd rear brake rotors (zr-1)
- FS: 1985 Service Manual - Red Helm OEM - Same as dealerships use
- C4 RH side headlight bezel
- WTB 84-87 Brake Calipers
- wanted red driver side seatbelt for my 84
- Airbrushed fuel rail covers....eye candy!
- zz 383 crate motor
- C5 Brakes
- WTB....Corsa Mufflers only for '91
- F/S 1996 original GM Grand Sport rims
- wtb washer pump
- looking for 91/96 targa top brackets
- wtb 1986 dash pad
- FS TPiS MINIRAM Intake and Fuel Rails
- WTB: GM Hot Cam
- fs rear glass fits sevearal years ,, 85 thru 95 ,,50 dollars
- Parting out select C3's,C4's, C5'S (LooK!!)
- I need a chip to a 1990
- Leather Seat Back and Bottom Cushions for one Seat
- Power Seat Track(1) XLNT
- WTB 3.54 rear end.
- WTT: Cross-Brace for Targa Truss
- FS - ECU from 89 automatic Plus other parts
- 90 Hood
- FS: Bose Gold series front speakers
- WTB : Window/Mirror Switch trim (93 Coupe)
- F/S 94-95 corvette wiring harness
- WTB Shelby Series 1 Wheels
- WTB Battery Tender
- Passenger headlight motor and passenger window motor! needed
- WTB Exhaust Cutouts
- Black Rectangular LT1 Tips
- A I R pump for 1989
- WTB 4L60-E Houston, Texas area
- Need a chip
- Wet okoles or Iggee's around?
- FS: Aftermarket GS wheels (17x9.5 and 17x11)
- WTB: c4 sawblades
- wanted right 91 lower fender panel
- Wanted: Smog pump
- Magnaflow mufflers for LT1
- F/S 1993 Sawblades
- WTS: 1984-96 Haynes Manual (pic)
- WTS: Daytime Running light kit (pic)
- WTB: Reverse switch ZF6 Speed
- F/S 1995 Optispark distributor
- C4 Parts WANTED!
- wtb outside mirror control switch
- 84-87 red corvette seats
- 16" ARE Rims and Tires for sale $400 Shipped
- Stock C4 wheels for sale - NJ
- FS: dana 36 2.59
- FS: dana 36 3.07
- whats it worth??
- DM flywheel, clutch and pressure plate
- Kwiklift for sale at AC
- throttle body
- WTB 6 speed shifter knob
- 1984 car for sale for parts
- WTB 94-96 Throwout Bearing for Lt1
- F/s 97-07 NIB AC DELCO INNER TIE RODS
- F/s 85-87 rebuilt everco ac compressor & new delco clutch
- WTB: Flywheel
- Unused Removable Hard Top
- White gas tank lid (coupe only)
- 85' Drivers Door Panel and some dash trim Needed
- WTB: Adjustable Fuel Pressure Regulator
- LT-1 intake - complete
- FS-C4 Chrome Door Sills
- LT1/LT4 valve covers
- WTB: 88 Up front suspension
- Front Lower Valance
- want 700r4 automatic gear shift lever and cable mounting bracket
- Wtb good used A/c compressor for '93 Lt1
- Factory mass maf sensor 85 corvette
- 85 corvette dash wiring harness
- fs 85 and 86 altenator , 35 each shipped
- 1984 - anyone know where to find an EGR solenoid???
- WTB: C4 emblems
- WTB - new 84-90 body side molding
- WTB - 1984 Corvette Air Cleaner Heat Stove Elbow
- F/S AR TT II's
- WTB : EGR Vacuum Solenoid Valve TPI
- WTB: black halo trim
- Cleaning My Garage Out - Misc 1992 Parts for Sale
- 4 Polished Sawblades with tires 17x8.5 and 17x9.5 $150
- WTB 91/96 front bumber lights
- F/S Targa Hardtop Torch Red
- FS Nitto NT555R P275/40R17 on 17X9.5"
- WTB Front Bumper molding 90
- Misc C4 parts
- WTB Targa
- Speakers / AMPS needed for 91 C4 Coupe
- magnacharger mp90
- Wanted automatic transmission tunnel donor piece
- F/S Front License Plate Filler
- C4 Hood FS
- WTB LT1 intake
- WTB: Front 91-96 White Filler Plate
- FOR SALE: No curb marks, brand new tires off of my 85'
- c4 1985 wheels $75 pick up long island ny
- ACDelco Knock Sensors IN STOCK - $29.39 each
- 17"/18" TSW Nurburgring wheels - Corvette specific - Lightweight
- L98 Engine and 4+3 Transmission
- F/S: FHA (Z07) front spring
- 2 C4 Tail Light Lens
- WTB: Dualmass flywheel L98 - LT1 - LT4
- WTB Differential cover for 85 or 86 C4 with Dana 44
- Red Fuel Rail Covers
- Hypertech PP III 96 LT1 DFW
- 700R4 trans out of an 88 Vette F/S
- Accel 24# injectors
- FS: Saw Blades off 92 with tires
- 91-93 Vette Side Fenders
- FS GrandSport A-Molds
- NOS 1984 AC Delco Air Filter...
- WTB: 88-96 DANA 36 Rear Center Section
- fs 92 GM MANUAL
- WTB-Front Drag 17/18" rims
- WTB: convertible top and wstrips for 89 vert
- wtb: 94-95 admiral blue targa top & front license cover
- Set of ZR1 style wheels and tires f/s
- Left headlight motor
- '84 K&N Air Filter $35 - good as new
- F/S Shifter Nob- Leather
- WTB - CDM for Bose
- New '93, '94, '95, '96 PKE Fobs Available
- WTB: Pro Custome Targa Truss Brace '95
- fs 86 long block l98
- FS - Torch Red Sill Plate Extensions
- FS:90 Saddle Carpet Pieces + Rear Bose Speaker Covers
- Owners manual
- Great deal with Danah92LT-1
- FS: 1993 Lt1 engine...
- FS:91 Vette AC compressor, condensor, and evaporator
- F/S Many Big parts-FI,Dana 44, 4+3, roof, wheels,etc.
- WTB vacuum lines engine compartment 88-91 TPI car
- **c4 parts car & parts**
- WTB- Airbag Sensor for '91
- For Sale - Pair of Door Hinges
- Backup Light Switch for 89-96 Corvettes
- 1995 Corvette Factory Service Manuals
- 1995 coupe, manual trans-misc parts
- New tires, stock rims for sale.
- WTB: 17" ALLOY Grandsports For A '94 Base
- Super 421 Street Engine
- Wanted- 88-89 Wheel Centercaps
- FS: 1994 Auto Steering Column With Key + Lots of Other Parts
- Head light Motor
- Passenger side rocker panel
- WTB ECM Housing
- J55 front caliper hangers
- 1991 Bose Passenger Side Front Speaker wanted!
- F.S. headlight assembly
- WTB 85-92 TPI fuel rails
- New Tires Michelin 335/35/17, 275/40/17, ZR1 Wheels, Fender Flairs, Clutch/FW,Exhaust
- WTB: 1988up Hood Prop conversion for my 86e
- FS: Brand New Pioneer AVIC Z110BT Head Unit/Navigation/BlueTooth/USB/IPod!
- WTB Engine crossmember braces
- For sale again. ZR1 exhaust from a 1991
- wanted from a junk C4 hood
- FS: NEW FEL-PRO Part # VS50443R Valve Cover Gasket Set
- FS: NEW Uncut GM VATS Keys #6 B26-P6 $5
- FS: NEW Hood Latch Drain Kit 84-96
- FS: NEW Metra 99-3051 Radio Install Kit 90-96 Vettes
- FS: FelPro 9966 PT, 12551488 Head Gasket 92-96
- Wanted-Oil Pan
- wtb Auto Center Console Trim Plate
- WTB 101 Projects for Your Corvette : Richard Newton
- WTS Stereo install parts Drivers Mirror, Pass. Marker light
- Corsa Exhaust Discount 33% off MSRP
- Wtb headlight
- Fs; tinted top off 1985
- FS 84-89 Corvette Bose Cassette
- WTB correct ignition wires for '95 LT1
- 1995 new tensioner pulley FS
- FS: 2 CCW Classics 17x12.5
- WTB-Air Filter housing
- Wanted vert x-brace for 91 complete or close.
- C5 thinspoke wheels one front one rear - $125
- Ruby Lloyd Embroidered 3 pc Mat Set - NEW
- WTB Grey leather Seat
- FS - 1996 Corvette Service Manual
- WTB-RF saw blade
- 89-96 Glass Top
- FS: Accel Large Tube Runners
- I have alot of random parts for c3 corvette
- FS C4 Light Housings 84-90
- CCW ZR-1 Wheels for sale. Wider is better!
- Dispute with Gstjohn over so called Polished TPI Runners
- WTB: 1992 manuals (3 books)
- wtb odometer motor
- VB&P sway bars-new never mounted
- (2) USED Michelin XGT Z4 tires. [275/30/19]
- WTB 113 heads
- Corvette Windshield Sun Shade
- Wanted:Lower air pump bracket for a 88
- F/S Z06 Rims for a C4
- wtb GTO rear spoiler
- Garage Sale
- FS: Targe roof removal ratchet orig GM
- 1995 seat bottoms needed
