View Full Version : C4 Parts for Sale/Wanted
  1. Stock LT-5 heads
  2. Corvette Sawblade Rims Set Of 4
  3. LT-5 w BH, FW, and Engine Harness
  4. Dana 44 w 3.45 available
  5. C4 to C5 brake conversion kit
  6. I am in need of a pair of 315/35-17 tires that are new or used in good condition
  7. WTB: Engine Accessory Brackets
  8. Dana 44 on Ebay, cheap if you live in CA
  9. window regulator/motor newer style passenger side
  10. WTB left and right door molding 91-up
  11. Wanted blue Acrylic Targa top
  12. 89 Factory Service Manual
  13. FS:1991-D36 Differential Cover (Batwing)
  14. Heater core w/ Ducting, etc.
  15. WTB sun visors
  16. wtb: set of aluminum 113 vette heads
  17. FS: 9.5" Polished 92 Sawblades
  18. FS or trade.
  19. FS Passenger side access panel
  20. Looking to swap a 85front liscense cover for a 91-96
  21. FS: Bilstein Xtreme Shocks 1986-1996 Like New
  22. stock exhaust
  23. c4 corvette headlight bezel (WANT)
  24. Excellent Transaction with GS163
  25. WTB:Anybody have an ATI aluminum damper for LT1?
  26. FS-Holley 52mm Throttle body
  27. FS: Delco/Bose Gold Series System
  28. WTB: Wiper Motor Board for a 95'
  29. Stretch Fit Front Masks **$99.99**
  30. WTB: 11x17 Sawblades
  31. ** FS Bose speaker boxes **
  32. FS Billet Headunit mounting bracket 90-96
  33. FS Holley Stealth Ram already modded to fit C4
  34. WTB self-aligning 1.6 roller rockers
  35. F/S Moates, BURN2 Chip Programmer for LT1, complete
  36. WTB: 1990 interior light halo courtesy light cover
  37. FS: 17" C5Z06 wheels
  38. Wtb
  39. ZR-1 blower box parts etc FS (evaporator housing etc)
  40. Member LLFormato parts seller ROCKS!
  41. WTB 88-89 Temperature Heat Blend Door Actuator
  42. WTB 2 wheels
  43. WTB 94-96 Door panel 'Push Pins' (along bottom)
  44. WTB: C5, C6 base caliper brackets
  45. Fidenza alloy flywheel and 6-puck sprung clutch pack for sale! LT-x
  46. TPIS Long tube 1 5/8 LT-x headers for sale!
  47. K & N air filter.
  48. WTB x brace and camber brace for 91 coupe
  49. c4 dana 44 rear end
  50. member kgl922001/parts
  51. FS: Set (2) 1991 GM Service Manuals & Update Bulletin Supplement++Plus ZR1 LT5 90-93
  52. Fs 88 fsm
  53. FS 1990 Wiper Motor
  54. LT1/4 Crankshaft Hub Remover and Installer Tool
  55. 15Lb NOS brand Nitrous Bottle - $125obo
  56. **Now In Stock Polished ZR1 Wheels**
  57. WTB High Pressure AC line 89 Vette
  58. Bride Gias Racing Seats...blowout offer and lowballs accepted
  59. Wtb chrome sawblades
  60. F/S front plate filler, bezels and more
  61. C4 Wheel Sensors with bands
  62. GP on wideband O2 sensors and controllers
  63. RC-44 chrome radiator cap.
  64. CORSA Group Buy
  65. Need a/c temperature blend door actuator 1989
  66. WTB: 94-96 Black Passenger Side Door Panel Armrest
  67. Holley 58mm Throttle Body.
  68. FS: 1989 Service Manual - OEM Red (Final Ed.)
  69. 4 sale : NOS zr1/lt5 wires & NOS zr-1 ZF trans
  70. 90-91 Radio Bezel FS
  71. Could someone provide ACDelco/GM part numbers for the following item on a 1995 coupe
  72. '84-'90 Gas Door Emblem Wanted
  73. WTB LT1 Intake...
  74. WTB: headlight motor(s), digi dash, and hood support for my '84
  75. Wtb pke fob
  76. C4 Luggage Carrier
  77. WTB Speaker Enclosure for NON Bose 91 Vette
  78. Wtb 4+3 case
  79. FS: 84 parts
  80. 2 Hoods from 1986's
  81. F/S Convertible X-brace
  82. 1996 vette Hypertech Power Programmer
  83. Corvette Accel 300+ digital performance ignition
  84. 1991 corvette TPS tune-up
  85. FS: 1990 tan door panels
  86. 1985-91 Corvette IAT sensor relocation kit
  87. 1991 corvette waterpump GM NOS
  88. 8 never used ACCEL 24lb injectors $100 shipped
  89. TH-700R4 B&M Kickdown Kit
  90. Need hood that works with 89 Corvette
  91. FS 84-87 KYB Shocks
  92. F/S Franklin Mint Corvette Models - Most 1:24 Scale
  93. WTB - Toyo RA-1 275/40/ZR17
  94. 90 Wiper Delay Board - New
  95. WTB: Transmission
  96. WTB: '87+ L98 engine
  97. FS: Optima Red Top, local sale only
  98. Wtb holley 58 mm throttle body...
  99. FS: A different kind of dash cover and a black cargo mat
  100. FS: R-D Crossbar
  101. FS: Lloyds front mats, red, embroidered C4 emblem
  102. FS: Iggee's black/red seat covers
  103. Wtb bose left front speaker grill c5
  104. WTB (4) ZR-1 wheels
  105. FS: Left or drivers side "gill" or battery cover
  106. 1989 sawblade wheels and tires.
  107. NOS 90-95 ZR1/ZF - 6 (new in GM Box).
  108. FS/ bose gold rear speakers
  109. FS 88 exaust manifolds & cat con
  110. Could someone provide ACDelco/GM part numbers for the following items on a 1995 coupe
  111. WTB: 91 A4 Transmission dipstick.
  112. Wtb chrome sawblades
  113. FS -> Air Bags++ from a 1995
  114. afr 195 non eliminators ready to bolt on $950
  115. 89 Saw Blades, buy or recondition
  116. Wanted good used fuel sender, 1986
  117. WTB wire harness to convert Camaro radio...
  118. WANTED: 96+ LT1 PCM Dead/Alive
  119. WTB passenger side cat
  120. Sawblade Wheels and Tires '92
  121. FS/ LT4 engine AFR 220 heads shaft rockers DIAMOND PISTONS 30 OVER
  122. Wanted 1989 EGR Temp Sensor
  123. ported polished super ram 1100 obo
  124. WTB: Black seat BACK RESTS
  125. WTB rear speaker grills for an 86
  126. *FS* C4 OZ Futuras FL
  127. For Sale Crane Gold Roller Rockers 1.6 ratio
  128. LT1 Corvette Fuel Rail Covers
  129. Moving Parts South, Then North, Have Room
  130. MadVette Motorsports Update and Thanks!!
  131. 93 Corvette Seat Cushions Black 40th Anniversary
  132. FS : Fuel Injectors 27.8 lbs/hr
  133. Doug Nash 4+3 Trans
  134. Fs new bosch a.b.s relay
  135. fs 2 new I.A.C for crossfire intake
  136. WANTED- LT-1 Tools
  137. BBK 52MM throttle body and asm runners
  138. 1992 ZF 6 speed with shifter
  139. WTB:1989 interior parts
  140. WTB Looking for used 700r4 tranny tools
  141. Plastic headlights for a 1995 wanted that don't function
  142. FS: Bright red targa top
  143. how do I reach DoctorDon....
  144. 1993 Ruby Red Coupe Window Sticker
  145. Where can i get a cross bar...
  146. Freebie. Two wheel spacers
  147. 1984 C4 parting whole car out
  148. 2 C4 Radios...cheap!
  149. JET MAF, new!
  150. Door panel and window regulator
  151. WTS 4 Dymag Gen I's 17X9.5
  152. Hooker header reducers
  153. two C4 rear bumper covers for garage/wall art 84-90 and 91-96
  154. 84-93 Parts & Illustration Catalog
  155. WTB: C4 to C5 brake adapter, Catback exhaust and/or longtubes, and Center console
  156. Gauging interest - Air Bags
  157. WTB Trailer hitch for 91 vert
  158. Saw Blade Center Caps
  159. Free shipping offer from GmPartsDirect.com
  160. F/s c4 parts
  161. WTB: 24mm rear sway bar for 85 vette.
  162. WTB 91-up bodyside molding
  163. 95 LT1 Parting Out & New Parts Clearing Out
  164. C4 parted out: complete rear end assembly
  165. Lingenfelter 219 Cam For Sale.
  166. F/S 1990 beltline molding, from fenders back 10 pieces
  167. Mufflers and exchast pipe and tail papes
  168. bose speakers and amps front and back 60 shipped
  169. 1990 part out
  170. FS 1990 front fenders ... White
  171. need 3000 to 3500 stall and a radiator
  172. FS....Black Carpet, Drivers Floor 90-96
  173. FS: VBP 32/26mm front & rear sway bars/bushings
  174. WTB: Interior console door in good condition
  175. WTB Unicorns: 86-89 Medium Blue interior pieces(seats too)
  176. Wanted Memcal/Prom
  177. Corvette Magazines
  178. Blue Smoke Glass Top for sale
  179. WTB: Front license filler 91-96
  180. WTB 4+3 shifter assembly
  181. Covercraft Dash Mat & Goodyear serpentine Belt
  182. LT-5 Throttle Body for Sale-$300
  183. 4 FS 87 front and rear suspension
  184. FS-A arm dust covers
  185. FS-Tail light gaskets
  186. FS-Red GS floor mats
  187. Black console carpet
  188. FS-Black & Red wheelskin
  189. FS-Late model C4 tail light lenses
  190. Need torx screw for a/c vents 94-96 dash
  191. WTB car cover
  192. FS,new horn button for 84-85.G.M.
  193. FS, new OEM heater controller,84-?
  194. FS,84-90 front driving lights new OEM.
  195. Dana 44 SF bay area wanted
  196. 4Sale: NEW 92-96 LT1/LT4 bare block
  197. $169 headers?
  198. WTB a sawblade
  199. wtb: starter/o2 sensors for 96 LT1
  200. Front license plate filler - fit 1996 CE
  201. 4 sale 87 hood
  202. 94-96 Passenger Side Knee Bolster Panel
  203. Any Used headers for sale? 150-200?
  204. LT5 starter FS
  205. 87 black rear bumper complete with all lits and crash bar ect 75 dollars pic up
  206. Spare tire and carrier FS
  207. new style headlite motors 100 shipped
  208. 92-96 complete stock exhaust system (stored takeoff)
  209. AFR 190cc LT Heads (C4) – Part number is 1593 complete $1,000
  210. IDLE AIR CONTROL VALVE for a 1993 Best Prices?
  211. Miniram Intake, Fuel Lines and Ford "red" 30LB injectors for sale
  212. Fs gm training video/manuals
  213. WTB Backup Lights
  214. COMPLETE J55 13" brake conversion for 84
  215. VKE-1000 remote door lock kit
  216. WTB front and rear emblems for 1990
  217. Wanted 1990/91 C4 Prom
  218. 93 zf 6 speed for sale
  219. 1996 flexplate fs
  220. Rear window package tray trim
  221. WTB 88 factory HEI distributor
  222. F/S - Driving Improvement Books
  223. API Cold Air intake / airbox and cut shroud
  224. Wts: 91 fsm
  225. WTS: 2 HATA VATS #2 key blanks
  226. WTS: 89 FSM, Binder form
  227. SPEED PRO 383 Hyper Pistons .040 over
  228. $750 Convertible Hardtop - Black w/brackets & tools
  229. 1990 Muffler Eliminators with Tips
  230. FS: Seat covers mounted on foam
  231. Wtb: supercharger kit that will fit 85 vette
  232. fs 1 new injector
  233. fs 94 GM SERVICE MANUAL
  234. fs 92 gm service manual
  235. F/S 94-95 ZR1 Stage 2 Spec Clutch & Flywheel
  236. WTB Set of Center Caps for Saw Blades
  237. WTB 90' Headlight Knob
  238. F/S - 1992 America Cup Promo CD
  239. WTB Sunvisor
  240. WTB: Corvette seat shells/frames
  241. Fs - chm pro chrome moly push rods
  242. ZF6 speed change over $1450
  243. Running a super ram? you might want these...
  244. WTB: '87 shop manual
  245. WTB: black rear cargo retracting cover shade
  246. FS: 84 Dealership Broshure - Have Qt. 3 - $10.00 each shipped
  247. FS: Callaway Corvette Dealer Brochure Printed in Sept 1990 for 1991 model year - $12.
  248. FS: 1990 Dealer Brochure - $12.00 Shipped
  249. WTB Driver's side hood hinge NO SLOP
  250. WTB: 92 Factory Service Manual
