- FS-used Sumitomo 275/40/17 local pick up only Greensboro NC
- Free Hood for 1985 (great to cut up)
- FS: misc C4 parts
- WTB: Stock LT1 Exhaust system
- FS: Rear Bumper 1984
- wanted info , on who buys targa top cores
- FS: 84 Targa Top
- It's not too early to be thinking about your Christmas Gift
- Innovate LM -1 for sale
- wiper switch 1996 lt-4
- FS - SLP runners and ported plenum
- F/S: set of 16 GM LT4 roller rockers
- WTB Fuel Rail Cover Emblems
- Repro C6 Z06 Wheels FS
- 1988 corvette engine parts minus TPI
- air housing, k&n filter and open lid for sale
- FS 1992-1996 EGR Valve
- WTB,clutch safety switch 89-96.
- WTB TB IAC housing (aka coolant cover)
- Wheels and Tires off of a 1985 $300 OBO
- FS 84' Air Filter, LeBra, 84-91 Repair Manual, & 87 Wheels
- 6 Piston Front Calipers for C4,C5,C6 Corvettes
- Help I need a electronic climate control unit for a 88
- WTB 85 Dash Pad
- WTB memcal for an 86
- WTB: 90-96 R&L Front Lower Control Arm
- Bulldog Invisiguard Dopplar (motion) detector
- hope this helps someone
- ZF6 Reverse Lock-out Lift-Ring collar (89-93?)
- Spare Parts For Sale
- LT1 & L99 Water Pump Drive Seal Install Tool
- FS: Genuine AC Delco 25513052 Speedo Gear 45T
- Mallory 685
- WTB: Timing Chain Set for an LT4 / LT1
- WTB power window switch, left side
- WTB..LT4 rocker studs and Rocker nuts..
- FOR SALE LT1 Meziere 100 Series Electric Water Pump WP118
- 92 part out in SF Bay area
- f/s soft top for targa top
- C4 Parting out
- WTB Intake
- FS: FOUR C4 Grand Sport reproductions in the ZR1 widths with Goodyear Eagle F1 Tires
- WTB- Targa Roof
- wtb nuts for shifter boot to shifter plate
- WTB: trip or fuel reset button
- 84 steering column lock
- Wanted: 95 Clutch/Brake Pedal Assembly
- 85 tbi
- 85 tbi
- Black 89-96 Hardtop for convertible
- Want: AC brace and EGR tube
- FS: 30# Lucas Fuel Injectors
- FS: NIB Rosewood dash kit (89 ZF w/o Z51)
- WTB: Long Tubes for a 95'
- FS 1996 Waterpump bad seal
- 4 sale: misc ZR-1 stuff
- FS- LT1 SS dress up
- RD camber brace $150 + ship from a 93 lt1
- WTB C beam and DS D36
- 1986 kyb gas shocks rear
- WTB: misc parts for my new '96 LT1 coupe
- 875-16 lifters, 30# injectors
- new owner need help
- WTB: Arizona Speed & Marine (ASM) Harness Bar
- APU1 Autoprom Moates WTS
- EARLY LT1 LUNATI timing set, NEW
- 315/35/17, 275/40/17 Brand New Vredestein Tires
- WTB: Door panel COURTESY LIGHT/LAMPS for 1985 Corvette
- Wanted: CCW Wheel Centers
- 4+3 transmission for sale
- Fs - 84 - 86 chilton repair manual - small size
- Fs- 84 - 87 2 rear tail lights
- WTB ***** late C4 audio wiring harness
- FS 84-87 QA1 Front Adjustable Shocks
- WTB 1986 oem wheels
- F/S headlight darken kit
- F/S sawblades and Goodyear Eagles
- WTB ZF6 speed
- FS Red Grand Sport floor mats
- FS Inner console carpet
- Need Help 1996 Info Center plastic
- FS 1 Carmine Red upper / lower seat 1985
- WTB factory injectors
- FS: 84 Parts
- Want those Longtube headers, Catback, Don't quite have the cash WE HAVE YOUR ANSWER
- FS 84-89 Iggee Black Seat Covers
- Lt4 "Grand Sport" throttle body plate.
- WTB 91-96 fog light lens
- C4 ZR-1 Wheels for Sale
- wtb L98 short block
- FS: 95 LT1 Engine & Accessories
- Canton Oil Pan for sale
- WTB : Tech-1A
- 1996 Factory Service Manual 2 books
- ElmScan 5 usb OBDII scanner. Brand New
- Hood Seal Felt Brand New $22.00 shipped
- Air Foil Brand New $22.00 shipped...
- WTB: Catback w/ stock mufflers for '89
- FS couple of stock C4 parts
- WTB: nice set of original '86 wheels
- WTB #7 Spark Plug Wire '96
- F/S Moates APU1
- F/S 90-91 ecm w/memcal
- WTB: Stock LT1 Exhaust For an 85
- WTB : Edelbrock Victor EFI Intake Manifold
- L98 short block FS and L98 heads FS
- FS:94 PKE Remote
- FS: "Skintight" 91-96, 2 piece bra, black w logo
- FS : '88-89 Gray Std Seat Cushions
- FS : Sport Seat Frames
- WTB 85 RH Door Lock Accuator Rod and clip
- WTB Anti-Flex Support Bar / Targa Truss
- C4 Rear Wheel Hubs / Bearings - Set of two
- 3 Day Master Blaster Memorial Day Blast Off $299 Delivered w/ FREE wall mount
- Wtb: Good quality LED fog lights for 89' vert.
- WTB: 3" to 2.5" Header reducers
- FX-3 Module
- For Sale: 60lb. Fuel Injectors
- WTB: Set of LT1 Heads
- Egr
- Bright Red Rear Speaker Covers For 1994-1996 C4
- WTB: VSS Gear for 700r4
- front spring retainer bracket
- FS 88 exhaust manifolds & cat converter
- Hood Light Plastic Lens Cover for 89
- 1996 sawblade wheels for sale... full set
- I need 2 brand new BCM 95-96
- Miniram 1206 FS
- 1996 Collector edition A-mold wheels for sale!
- I broke the bracket.....sort of
- '88 red sport seats for sale
- FS: Stock Exhaust Manifolds and Air Pump from an 88
- 52 mm OEM Thottle Body for sale
- Misc Parts for sale LT1 92-96
- Bought a broken parking brake handle
- wtb TORX PLENUM BOLTS - L98
- WTB Targa bolts
- 1993 Corvette Service manual
- 1993 owners manual
- WTB: 89 Corvette "Hood pin bushing".
- WTB Passenger Side Center Dash vent 94-96
- F/S AC Compressor-Bad clutch FREE SHIPPING
- Callaway Promo Vinyl Banners
- WTB Stainless Steel Brake Lines.
- C4 parts/garage cleanout/sold my C4
- FS GENI Dymags Four Wheels 17x9.5
- FS GENII Daymags Four Wheels 17x9.5
- F/S Like New 92-96 Air Lid Filter Cover
- FS Bose speakers and amps
- WTB Harness Bar
- Best place to buy parts?
- Need head light knob & head light switch..
- FS: Parting 84 w/ LT1 & 4L60E
- actuator frt.
- WTB End Plugs for Wheelhouse Seals
- FS: 93-96 PKE Passive Keyless Entry System
- WTB red 95-96 seatbelts
- WTB. Corvette air pump delete kit 1989
- WTS Polished TPIS BigMouth Intake and other stuff
- Summit plug wire looms for center bolt valve covers
- WTB-Red interior parts 95/96 conv.
- Wanted 84-95 Instrument Cluster Circuit Board Connector (Female)
- F/S Chambered Exhaust System for 96 Lt4
- Cluster
- *****WCC parking lot sale***
- Wanted: Original filter lid. 1992
- WTB: 1984 Z51 rear spring
- WTB 86 Water Pump
- WTB Parking Handle Cover
- 1993 ZR1 Front & Rear Bumpers 4 Sale
- FX-3 Module
- Msd 6al
- F/S 275x40x17 like new
- F/S Rear Tire pressure sensors
- 4+3 trans and OD For Sale
- Sbc 350 tpi long block - $550!!!
- FS: 84 targa top
- WTB: 87 Owners manual
- WTB: 95'LT1 Headers
- FS RPO LT5 Service Manual Supplement
- Auto Xray Scan Tool For Sale
- L98 '85-'89 Camber Brace for sale
- 1984 Crossfire Corvette Parting Out
- Brand new precision u-joints
- FS-84-96 22mm Rear Sway Bar Bushings & Link Bushings (Polyurethane)
- LTPWS band
- WTB wheel spacers 3/4"
- WTB 91 Accel/SLP/AS&M Runners
- WTB 94-96 Power Sport Seat Switch
- To Corsa Or Not To Corsa
- FS : 2 C5 Z06 17x9.5 DR Wheels Dark Gray
- WTB horns and underhood light pod
- spare parts
- 2 A - molds
- Main dash harnesses out of 88 and 91
- WTB 84-87 door panel
- WTB 84-87 Driver Door Sill
- Need Seat Back Release Trim
- F/S like new radiator
- WTB: Lt1 Ported or Aftermarket Heads
- Delteq opti-box (brain)
- fs out of 87 , heater water valve 25 pluss shippin
- Free Shipping!! All Fiberglass!!
- FS: LT1 Fuel-Rail Cover Emblems
- WTB: muffler eliminators
- WTB sidepipe covers
- WTB New B&M Short Shifter Knob
- WTB: Heater Control Valve
- WTB Plastic Seat Frame for driver's side 93 Vette
- Need a 1986 front bumper brace
- Dashmat Dash cover "suedemat" FS (black)
- WTB engine for 88
- FS:Cryoed' Driveshaft for C4
- some c4 parts for sale!!
- WTB: Miniram
- WTB non scratch late C4 drivers window
- WTB Intake tubing
- WTS 89 wheels complete
- ** Super Low Pricing on Black C6 Z06 Wheels With Red Lip For C4**
- 92-93 LT1 fuel rails
- F/S Car Hauler
- WTB GS fender flairs
- FS: Rebuilt 383 L98
- Fs: 88 corvette service manual 20.00
- Wanted: '89 vintage Bose radio
- WTB: Drivers side door glass, scratch free
- WTB Targa Storage Latch plastic covers
- WTB Crossfire air cleaner base seals
- WTB: GM Brake Booster for '95
- pro torque 2400 stal converter llow miles
- Wanted Electric antenna for '90 Vette
- Hypertech thermomaster chip for 88 auto $50.00
- FS: Trans Pan 700R4 / 4L60E
- FS: Stock 94 LT1 Cam
- FS: hatch struts
- FS: 84 Parts
- FS power steering pump pulley and braket
- WTB 1990 Steering Wheel
- c4 hardtop
- Egr
- WTB 93-96 front air dam center support
- WTB: air pump delete kit
- For Sale: Universal/REVERSABLE 12" Electric Cooling Fan
- WTB Air bleed screw radiator 96
- WTB damaged 89 stock wheel
- WTB - pair of 91-94 front fenders
- WTB; LT1 oil dip stick tube
- Lt1 corvette nitrous kit
- 1991 Bose Parts - CD, amps, speakers
- Wanted Targa Top Frame for 94 Corvette
