View Full Version : C4 Parts for Sale/Wanted
  1. wtb: 1993 c4 glass top (smoke)
  2. Super Ram for sale
  3. WTB Accel dfi gm wire harness for tpi
  4. (2) rear ZR-1 wheels (17 X 11 36mm)
  5. wanted: 94 CORVETTE black Pass SeaT Bottom
  6. 93 HardTop in Mint Condition 40th Aniversary
  7. WTB: Exhaust for 89 L98
  8. FS: 84 body parts
  9. WTB steering wheel for an 86
  10. FS: American Racing 398's Mesh wheels 17x9.5
  11. F/S: GM Brake Caliper Guide Pins
  12. Aluminum pullies
  13. wtb seats for 87 coupe
  14. Fs: C5z & c6z style repro wheels & tires
  15. F.S. Original/NOS Seat Leather, Bottoms/Backs
  16. F/S: 95' LT1 OEM Mufflers
  17. FS 96 shift trim and radio trim
  18. Pioneer deh-43dh direct fit c-d radio for c-4's delco bose gold
  19. performance chip
  20. WTB CORSA Center Muffler
  21. Ccw drag pack rims and tires
  22. WTB - FSM for a 1996 corvette
  23. WTB 89-96 front speaker mount
  24. Fast dfi
  25. WTB: Shift boot for 1989 Manual (ZF6)
  26. Fs brand new professional products throttle bodies tpi/lt1
  27. Bloomington Gold Tickets for Sale - 4-Day Passes
  28. Greenwood spoiler
  29. Sylvania 891 BP bulbs, high mount stop
  30. WTB Complete Door Panels 85
  31. Leather Manual shift boot, 1990-1994, MT6 ZF6
  32. 84-87 headlight motor fs
  33. Zip Corvette 24 Hour Sale - Store Wide
  34. 90-96 door weatherstrip
  35. FS: Dymag Gen 1's
  36. rear trim section center
  37. 85 tbi
  38. carb feed line
  39. WTB sawblades
  40. WTB Targa brace
  41. WTB Car cover
  42. 1986 Indy Pace Car Decal Set F/S
  43. OBD II scanner
  44. WTB plenun runner/rails torx bolts
  45. WTB original hang tags and instuction booklets for 1989 convertible
  46. 1985-87 A/C for sale
  47. WTB: T56 C-beam bracket
  48. WTB 1996 LT4 instument cluster / speedometer
  49. Polished magnaflow 3" cat converter
  50. Harness bar for 87 convertible
  51. Need Xeon Repacement Instrument Cluster Bulbs For My 87
  52. Dash Cluster
  53. Accel Distributor Cap/Rotor and stock coil.
  54. FS 1990 C4 parts
  55. FS Polished C4 Corvette Sawblades
  56. 1986 MEM/CAL wanted
  57. Differential Cover Batwing
  58. batwing
  59. C4 Removeable Hardtop for sale
  60. FS: Vette Tires
  61. FS: Almost new L98 Distributor cap/rotor with ignition coil
  62. Bolts needed asap
  63. 2 goodyear eagle f1 gs-d3
  64. C-4 side windows
  65. Spare Misc Parts/Screws...Pay shipping
  66. WTB: Horns for 87
  67. For Sale
  68. Free for postage: New '94 OptiSpark
  69. WTB: Blower Control Module p/n 16061602
  70. Calling Bobwhite85
  71. wanted fuel door assembly 86 coupe
  72. Bronze Center Console Cushion FS
  73. WTB 1986 Power steering Pulley
  74. WTB: Shift Plate Console
  75. Wanted: Turbowerx scavenge pump
  76. F/S: Rear outer tie rod end, 84-91
  77. F.S. 86-88 Med. Gray Painted Targa Top
  78. F/S Front Glass Window Guides
  79. F/S Ventmaster Rear Hatch Vent
  80. for sale new 10088113 zz take offs
  81. WTB Renegade Intake for L83 CFI
  82. Wtb - ccm '90my 16146671/16146688
  83. WTB: drivers side armrest for 85
  84. FS Beige carpet from 96 polo green lt4
  85. 85 heads+tbi
  86. WTB ZF Blue tag release bearing plastic insert
  87. WTB: Interior Items for 1991 Convertible
  88. Need C68 option HVAC blend door actuator
  89. PS PW sw w/harness for sale
  90. WTB - Seat Belt Trim for 88 Vert
  91. 1994-96 Goodridge Stainless Steel brake line kit for sale
  92. FS: 85 Dana 44 Rear Hub ,Brake assembly
  93. Wtb - 89 dash pad and super ram system
  94. FS: CAT Performance LT1 Fluid Damper with Hub
  95. WTB C4 Raincoat
  96. FS: Comp Cam Pro Mangun 1.6 Roller Rockers
  97. FS: Comp Cams Pro Mag 1.52 Roller Rockers
  98. Wanted pke
  99. To all that has parts coming from bobwhite85, az monument fire is at our house!!!!
  100. soft top latches and posts
  101. 1985 Corvette top wanted
  102. MAF, ECM, Chips, Distributor etc (88 car)
  103. FS 84 Vette dash cluster
  104. WTB NEW brake calipers 95
  105. FS: Iggee Seat Covers, Armrest Pad, Shift Boot
  106. Adam's Detail Spray Gallon
  107. Some more parts for sale
  108. WTB: 1986-1989 A/C Blower and Blower resistor
  109. WTB/half shaft safety loops
  110. WTT iPad 64GB 3G for polished TPI Setup
  111. WTB 94-96 Corvette LT1,LT4 Fuel rail
  112. F/S used headers
  113. F.S. C4 Radio Head Units
  114. For Sale C4 Seats
  115. F/S: Chrome Lug Nut Caps
  116. F/s hardtops
  117. FS Grand Sport Euro Flare Extensions
  118. FS: 1993 side mirrors, black
  119. FS: DRM stainless steel power steering line
  120. FS: 1993 Master Cylinder
  121. WTB Automatic Shifter Upper Trim Plate
  122. F/S Saw Blade Rims
  123. WTB: zf6 Beam plates
  124. wipers dont work on timer
  125. Free: Courtesy Light Delay Timer Circuit Board
  126. Wanted: 1991 Shifter Surround Console
  127. Bad azz small block heads with extras F/S
  128. FS: Original 1996 C4 Owner's VHS Videotape
  129. 85 Dash Cluster
  130. kwick lift
  131. WTB 89-96 Targa fiberglass
  132. Custom Forged Ross Pistons
  133. grand sport rims
  134. WTB - miscellaneous parts for my 96 coupe, FSM
  135. rear reinforcement bar
  136. FS: Black driver's door panel 1996
  137. In Need of hypertech 345752
  138. 87-91 flywheel
  139. 4 sale 85-87 L/R upper wheel well panels NEW/N.O.S.
  140. FS : 9.5" Triple disc 2800 stall Vigilante Converter
  141. FS: One Rim and Tire
  142. Fikse Spring wheel sale
  143. LT1 Corvette Upstream Bosch O2 Sensor
  144. F.S. Rare Corvette Promo Collection
  145. Free for postage: set of '86 injectors
  146. WTB:APU1 AutoProm Package: USB Version
  147. WTB: 93-96 Blue RHF Tire sensor 10161855
  148. FS LT1 Open lid and Accel filter
  149. WTB LT1 engine accessory bracket
  150. FS: Cleaned and iested injectors
  151. F/S USM 1985-1989 Corvette Dash Upgrade film
  152. WTB seat belts for 85
  153. FS NOS ac delco 84/96 wheel hub & bearing assbly
  154. Want to upgrade cam
  155. C4 Global West Del-a-lum front bushings.
  156. 1990 Accelerator cable
  157. wtb hardtop for c4
  158. ac compressor 85_87
  159. Late C4 K&N Air Filter
  160. FS-HARDTOP for 1989
  161. C4 Light assemblies & Misc
  162. F/S 1985-89 RD Camber Brace-New
  163. F/S-VBP Rear Spring
  164. WTB: Specific accessory bracket castings for serpentine conversion for BBC in C4
  165. Power Programmer 1994-1997
  166. F/S: FHA (Z07) front spring
  167. FS: body lock pillar weatherstrip - upper front right
  168. F/S: Rear outer tie rod end, 84-91
  169. F/S: 32 mm solid front sway bar
  170. FS: 84-90 Frt License Plate Cover
  171. F/S: rear toe rod assy with rod ends
  172. F/S: BMH rear spring
  173. Parting out C4
  174. FS c4 parts
  175. FS: BFG T/A KD's 275/40/17 & 315/35/17
  176. Lots of LT1 parts-stock and performance
  177. For Sale: 91-92 Rear ZR-1 Wheels
  178. WTB 92-96 LT1 engine motor mounts and frame mounts
  179. FS: air pump kit complete
  180. fs used abs bump for parts with computor 35 shipped
  181. Free for postage: '85 window regulators
  182. WTB 1 inch adaptors.
  183. Just Added More C4 parts With Free Shipping
  184. near perfect , midyear black top. for trade(long)
  185. WTB 85 pass seatbelt
  186. F/S Dewitts Alum Radiator
  187. F/S Exotic Muscle Long Tubes / Corsa Extensions BRAND NEW
  188. cargo & floor mats
  189. F/s 1986 rims and tires
  190. WTB: AC Clutch 94-96
  191. FS: PS Pwr window sw from 94 w/harness
  192. Wanted: 3.45 Gears for Dana 44
  193. FS jack assembly
  194. Wts red door panels
  195. 24 Lb. Ford/Bosch injectors for sale
  196. WTB AC Compressor with clutch for 1988
  197. 87 saw blades and tires
  198. Stainless Works headers for 85-96 C4 on Special
  199. Head Light Assembly Left and Right & Wing
  200. 84-96 Upper and Lower Ball Joints
  201. 84-96 Upper and Lower Ball Joints
  202. WTB set of dash bezels 1985
  203. Me needy some 94 parts
  204. WTB: Valve Stem Covers and Chrome Caps
  205. fs 87 abs brake pump and the computor 65 shipped
  206. WTB Trailing Arm
  207. WTB: Timing Adv./Ret. Cam Bushing Kit
  208. to good not to pass on
  209. Boyd Coddington original off 66 vette fs mint condition
  210. WTB: Corvette Information Center Cover Plate, With Bowtie & LT4 Logo
  211. WTB '93 a/c compressor bracket
  212. Lt4 Heads and spirngs!!! cleaned and decked!!
  213. Kwik lift
  214. gotti 17x9.5 17x11
  215. Mint in Box: Eureka C4 Corvette hand vacuum!
  216. Time to sell my Factory Bose.
  217. How Much
  218. C4 Corvette new parts for sale.......
  219. WTB ac brackets
  220. Wanted to Buy NOS GM Air Dam for 91-96
  221. 1986 sales packett
  222. WTB 95 vert center console and speaker grills
  223. WTB 95 vert center console and front speaker grills
  224. FS--OEM Lug Nut Covers
  225. WTB: Stock LT4 camshaft
  226. WTB 1989 ECM & Prom
  227. Kwiklift
  228. to aprt or not to part, qnyone have lifters/pushrods?
  229. 84-85 Dash [ad
  230. FS: 1990 Corvette ZR1 Wheels
  231. 1990 engine and zf 6 speed
  232. 93+ LT1 engine wanted complete
  233. Willcox Summer Sale Starts Now... 10 Percent Off Entire Site
  234. WTB: Hardened Pushrods
  235. WTB 87 targa top
  236. Parking Brake Handle
  237. FS - 4 Michelin Pilot PS2 tires
  238. WTB Black door carpet for an 87
  239. FS - 84-96 Prothane 7-2013BL Black Total Kit
  240. 92-96 C4 Turbo Kit with Intercooler
  241. WTB : Hard top
  242. :: WTB :: Black Center Console Door Assembly ::
  243. MidAmerica Fan upgrade $150 shipping included
  244. FS-used Sumitomo 275/40/17 local pick up only Greensboro NC
  245. Free Hood for 1985 (great to cut up)
  246. FS: misc C4 parts
  247. WTB: Stock LT1 Exhaust system
  248. FS: Rear Bumper 1984
  249. wanted info , on who buys targa top cores
  250. FS: 84 Targa Top
