- Too good to be true? ZR1 for $8000?
- Want to talk custom sound system.
- Case of missing ground wire
- Saw a new Z06 today
- ZF lube
- Looking for Jim Waldschmidt
- Tuner Question
- Single GT40 turbo charger for the Z - disccusion?
- Power steering pump
- What would it take to do 200 MPH in a ZR1?
- Better 60' times
- Engine refinishing
- Original owners
- Ok Im a idiot, How to measure valve lift?
- 94 Exhast What It Si Worth
- 93 "clone" on Ebay...when will they stop being so stupid.
- Drivers License - Public Information
- How long do tires last
- Question for you ZR1 guys...LT1-->LT5 swap?
- intermittent "ABS Enabled" warning
- Just FYI on ACDelco plug wires
- R&D and the results------>
- What happen to Cliff (LOTU5)
- Need some help...Batt.Problem??? Other questions...Long
- I Am Screwed.....or Smitten
- HELP -- A/C guru Needed !
- owners with 4:10's
- 1994 81k $22 .. ?
- Doctor Dons
- Buddy is getting a '91 ZR1
- chip/tune
- Stock rotor size for 1994 (searched ZR1 thread)
- '91 saw blades- what are they worth?
- Stainless Works says thanks with money for you!
- Those who have been asking plenum pull questions
- What am I doing wrong - cant sell?
- Does anyone know where to get a 94 to 95 ECM
- So who all is going to the SGC gathering this year?
- Saleen Mustang
- Mustang guy talking smack about the Z
- 2005 Gathering
- Beemer parts in our cars?
- Infl rest
- Might buy 91 Z..Need Help!!
- F.S 1990 ZR1 Jeal 368
- Injector size Question
- Where Is...How Difficult...Etc...o2 Sensor
- 18x10.5 60-64mm offset wheel - How will it fit?
- Another how high can she go ..Ebay ZR-1 with 32 Miles
- im thinking of selling my z .
- CLeaning carbon from cylinder head and valves
- Dunn heads Part II
- Exhaust (revisited) gurus inside
- Aftermarket Ignition Wires, any recommendations?
- LT5 rebuild at 75K?
- What's this '93 Ruby Z worth?
- Help my cars sick
- R&M Classic car Auction
- ZR1 automatic or convertible?
- oil change time
- Need part# for LH&RH horns for '91
- It's not a ZR1, but . . .
- I'm getting a Z!!!
- ZR1 Video's????
- pin outs on a 90 vs. 91 harness different at the ecm?
- New ZO6 test on Speedvision
- Need help putting a 94 LT5 in 91 ZR 1
- '92 Quasar Blue In Atlanta
- Looking at a '91
- 94 ZR1 E-Bay
- Needed TPS for '91 ZR-1
- Hurricane Wilma
- In need of coil packs
- Las Vegas , Nv , Zr1 Owners
- Latest GMHTP
- An observation re: C6Z06 threads
- SDM module
- CAT elimination
- Coolant Smell?
- plenum gaskets stinkin 70 bucks plus shipping .
- I need everyones help on this one!
- Free! '94 cat-back stock exhaust system
- Mobil 1 oil filter
- Trying to Post
- Post Picture
- Trying to post new Avatar
- Going to sell my ZR1 - trying to guess fair price...
- Wanted=1990 ZR1 Rear Wheels 17x11
- Considering A 1990 Zr-1
- CORVETTE ~ ZR-1 License plate ~ NEW in package
- Long tube headers vs. alternatives
- putting some stuff up for sale
- Going to change injectors what size?
- Std. size/offset wheels wanted with>BLING!
- LT5 Heads (FS)
- Tach reference
- Another Rebuild
- FS: 90 LT5 2bolt engine block!!
- Who's going to Eckler's
- Unloading ZR1's
- Tire and Wheel Help - Also VSS question
- How high will she go? 90 ZR-1 191 Miles
- anyone help me with a carfax on a ZR1
- Anyone use their ZR1 as a daily driver
- Hurst short throw shifter
- AutoXray Scanner
- Sometimes..
- Bans ?
- 18" Wheel Fitment...
- oil drain plug size
- big block ZR1
- Refinishing Hard Top
- Vette's @ OC MD this weekend
- battery choice ?
- Backyard Buddy en-route!
- Coolant circuit
- R&R Parking lights and lenses
- Won't start, then does later?
- fuel presure regulator
- Sport Seat Bladder Problem
- Viper rear gears???
- Before and After intake pics
- 94 - 95 ZR1 Wheels
- I am moving to Georgia
- Good ZR-1 Videos
- Straight Pipes!
- Brake Fluid Suggestions
- Life time Oil filters
- removing the valves
- Looking for a 1991 ZR-1 Full Power Bypass Harness
- 10 MPH Punch
- The shinoda meers kit is available
- New Dyno #s for the 415
- Goodyear Supercar Tires - EMT? Or not?, Best Deal?
- Good source for Weatherstripping
- ZR-1 questions....
- Setting up the Throttle position sensor.
- Another Injector Q
- Replacement injectors
- ECM for my 1990 ZR-1
- $13425 fot this!!! you got to see it.
- Clutch Release
- Oil Filter Question
- Dry NOS kit
- Crusing in 6th at 70, Should it feel boggy???
- Gordon Killebrew
- Spent $3k on my Z
- photo and dimension of damper
- screw up on zr1 rim
- LT5 Upgrade
- Zf6 1992 / 1995
- Lt5 1992 / 1995
- Damn Converters
- ZR-1 purchase advice please!
- Paint quality ??
- {{{1990 ZR1 Short Block}}}
- battery trouble ?
- 1990 ZR1 rim for sale
- Need pics of oil pan, pick up, and baffel
- ZR1 Door Panel
- Amsoil Or Mobil-1?
- PCV question
- Codes Cleared - Thanks Jeff and Hooked
- seat noise
- They don't melt
- Getting to know all this other stuff,AFR's :eek:
- Congratulations to Ted and Karoline Dempsey
- Lost another ZR-1 its up for auction
- 1991 exhaust for ZR1
- Running lean
- What shifter to buy ?
- Tech 1 users jump in
- CCM (Central Control Module) question
- Body kits on zr1's- post some pics
- Finally resolved fuel pressure drop off
- Not that I was looking...
- Where to buy 4.10 gears?
- Hallsville, tx CLOSED!
- Tried New Zaino on the KOTH Today(56k Bend Over)
- Sensor's Answered
- 60' times
- FS: '93 ZR-1 Polo Green/Tan (Chicago)
- Oil Catch Can Works!
- Very nice ZR1 for sale
- "MATCHING NUMBERS"?
- Silicone Coolant & PCV Baffle hose Kits
- Need Sensor Advice
- Tidying up the Electrics.
- ZR1 CD changer died - help
- zr1 wires
- Resonators Revisited ~ exhaust gurus, step inside
- xlr8nflorida in Corvette Fever
- 3" Inlet SS Mufflers
- Lt-5 Trim Emblem
- Sweet Z on Ebay.
- Sway Bar Opions Question
- Got $400.00+ for Some LT5 Plug Wires?
- Paint Color Polish
- ZR1 Misfire
- Couple pics of the 90
- Red '90 ZR1 emblems
- Radiator
- New parts website finished, take a look.
- Does anyone here run Carbon fiber driveshafts?
- Couuld ZR-1's come with telescopic steering wheel?
- Looking to buy some items
- Cleaning out oil cooler.
- Calibration.
- 94-95 Zr1
- New Stablemate
- FS: red/saddle 1990 ZR1
- Tasty
- Windshield Polished ?
- 2nd trip to the strip for ZR-1
- ZR-1 vs. 96 LT4 SE
- Speedometer
- need some insight pistons conecting rods and clearance
- Do you want the good news or the Bad news
- Corvette Values - Owner Age Factor
- dyno graphs
- King of the MSRP Hill
- ZR1 with a AUTO question???
- Is it hard to finance a ZR-1?
- No Cooling fans
- LT-5 - 2 Bolt/4 Bolt
- Mid-America Access Tool
- 93-95 Windshield wanted
- Water Drain For B&B Triflo
- Nu Shooz for the Ride
- ZR-1 Net Registry Forum Raffle
- guess what now
- 1990 ZR1 value, Need help please
- twin-turbo kit for sale in Germany !!???
- LT-5 Spark Plugs
- Buying / Selling LT-5/ZR-1 Parts
- FS 1990 Polo Z (NM)
- Coil Pack Part Numbers
- Lotus engines: LT5 is king of the hill?
- Need help on Bose system problem
- Its getting Close.
- ZR-1 belt tensioner Q
- FS '95 ZR1 wheels, stock and original
- Any out there? ZR1 bellhousing, tranny?
- Baby seat for ZR1
- Spare LT5 for sale on Ebay
- Bassani Exhaust
- New '71 big-block roadster arrived today!
- HUGE thanks for all the Gulf Coast help!
- LT5 Techs in central or N. California.
