- value of stock gears?
- Anyone need some ZR1 tires?
- Still trying to get a new run of late ZR1 windshields produced and..
- 93-95 windshield
- Air Condition
- 415 engine only FS
- Long live the ZR1
- Dual Mass spec's?
- DRM chip for 93-95 Z
- FS: Anyone need a set of CCW's? Spearfish next week.
- ok stumbling on acceleration
- cam cover emblems
- pop quiz hotshot
- New trans locater for ZF-6
- ZR-1 Z06 picts...
- Added Pictures - 91 Z BL/BL FS 11,000mi
- Custom exhaust update (with dyno results!)
- Dyno pics
- gear swap question
- Dyno pics
- 91 415 F/s
- good price on GM waterpump?
- Engine mount needed.
- A/C Panel Probs. - Quick Fix?
- Lt5?
- GT500 like the 1990 ZR-1?
- Nervous:
- You Must See This
- air conditoning chg prob. HELP
- 90' ZR-1 What was "Standard"...
- Car Lifts, who has one, and are you happy?
- How Bout Some Lowered ZR1 PICS
- Re-activating the A/C.
- Clutch Reservoir Fill
- *AnYbOdY using the Denso Iradium plugs???
- Dynoed the general today
- Saw one of these in Orlando!
- Blowing a fuse
- If carter was a dog
- Brake pad change question
- Wideband bung on stock 90 headers?
- Plenum
- i was wondering?
- 2 questions...ron K ? you around
- License plate suggestions anyone ??
- Tell me why I should buy a.......
- Check out this little EVO rocket.
- Raining in Vegas...ZR-1ers watch out!
- newbie with a question
- Gill plate ss inserts...lookey
- Beware - '90 F/S on Ebay
- ECM Cover
- 4.10 gears
- jennifer love hewitt..gives me twig
- Low Oil Light
- crank main bearings
- 90' ZR-1 in Vegas $14K...The rest of the Story
- ZR1 Convertible
- Bananna Thread
- I need a couple of emblems, can anyone help?
- What is the best way to...
- Bad experience of 'polishing/wax shop'.
- Highway MPG after headers..
- Climate control problem ?
- Why did the Z keep the chmsl?
- flywheel balancing?
- 7000 rpm grin
- How cool is this?
- Wtf??
- 3:92 rear F/S
- code 55 and 64
- upgrades complete,check engine light on?
- front plate vcrappypics
- Georgia Events
- Does the K&N oil filter have the check valve?
- money well spent???
- I'm an official chrome-er
- People I would like to strangle ...slowly
- 2nd gear syncro
- Custom exhaust... for real this time
- Brooke Burke is homely
- Skates me the brakes :rofl
- This would be my wife
- Are there any suspension differences in ZR1s and normal C4s?
- 2 Bolt Block crank failure?
- On the block
- ecm chip question
- ok. I know...Who has cheapest ...Corsa
- so i took the Z to the body shop
- Throttle Sticking
- Battery voltage question...
- Tire Question
- VOTR - Who's all going?
- Yeah, I have antenna function again......
- New Billet Throttle body Plate
- Is bigger better?
- Pulling Hard To Right
- 3inch X-pipe
- AC Blower Motor...Tired ?
- ZR1 Handling question...
- 90 vs 91+ evap emissions system
- Carbon Fiber LP frame
- Is this a good deal on a ZR1?
- Car show on June 25th
- car show pics..June 25th
- Brand New Flowmaster Force II system FS
- can you use an IAT relcation kit from a L98 on a ZR-1?
- Zr1 Ecm
- New addition-What temps are you guys running?
- '92 ZR1 White/Black FS in N. California
- Haibeck chip and Borla FS
- '91 368 LPE For Sale
- Horsepower party....
- I'm holding my 1st car show- today
- cam covers coming off
- AeroBody Progress
- 1990 Zr1 Chrome Rims 4 Sale
- "The Beast" is fixed!!
- Black And White
- HELP! BLMS what ok?
- How the hell do you get clutch parts?
- New owner has a question.
- AMPS Gone bad, what to do???
- code 61. found no vacuum leaks any ideas?
- code 61. found no vaccum leaks any ideas?
- Stock 375hp Z's vs 405hp Z's
- Any Las Vegas ZR1 owners give me a hand?
- FS 90 ZR1 638 miles $41,500
- MAF or IAT Relocate Question
- Help - Purple Smash ZR-1 paint info needed
- Little shop of horrors
- Exhausting subject
- Re-install of the throttle body- now
- LT5 Cooling system
- Performance cams available now....
- For Sale: 94 ZR1 SGC 402
- Question for C5 and early model ZR1 owners
- Sound Clips of Aftermarket Exhausts?
- Cams wanted
- Custom exhaust... almost
- Going to Mod the Ruby and sell the 91
- Ok Shawn, where are the pics?
- I feel cheap and Used
- ecm vacuum hose to solenoid. how much vacuum?
- Link to PCV breather box?
- paint discontinued?
- headers
- Moved to NYC!
- almost done..throttle cables?
- Tach reads double on 1991, why??
- A Sad Thread
- Tops for ZR1
- Dipstick/handle-90
- Stainless steel brake line part question
- Has anyone documented...
- Horsepower party??
- front seal: either, or...?
- Backfire, then secondaries don't open?
- If I have 419 hp at the wheels....
- Pop Rivets In Intake
- Back to track.. 1/4 mile Drag Race.. :)
- virgin mechanic..be gentle
- I just had to do it
- Felt like a waxer today.
- ZR-1 on Father's Day
- LT5 #8 Plug change
- It was a rainy Fathers Day,,,,,,so I put a
- zr1 parts 4 sale
- Considering 4:10 Gears, I got Yukons
- My Experience w/ Jet Hot Coated Headers
- screw broke off..need immediate help??
- sagging roof
- Bloomington Gold
- First crank and she lives!
- dropped a throttle plate screw?? idea's?
- Are painted tops available?
- The Bud girls must like ZR-1s.........
- 1989 ZR1s what happened 2 them?
- AC o rings
- New HRE Wheels
- Went to the track - Results
- What size tire goes on a stock 1990 ZR1 Rim
- door panels
- '94 ZR1 for sale in Sacramento, CA
- Be careful, don't want to see any crushed Canadian Z's
- Parts availability, need some help from the Forum
- General ZR-1 Pricing Questions
- Wheel lock removal...
- Factory exhaust manifold help
- 90 ZR-1 in Vegas $14k
- Shifter Recommendation /zr1
- New Push Style Clutch with hyrdaulic Throw out bearing for ZF 6 speeds
- Vibrations -Not the good kind!
- anyone have a broken vacuum pump they'd part with cheap?
- Clutch Slave Cylinders
- zr1 headers?
- Regarding spongy brakes (90)
- ZR1 Rear shocks - OE replacements
- Bloomington Show
- ZR1 Dymags Second Design
- need help for small hydraulic fluid leak
- test drive tonight - I've got a question on shifting
- Help
- LT-5 Engine Weight versus.....
- My ZR-1 at Bristol Motor Speedway
- I'm back
- FYI: check your crank case bolts
- Fleetwood Farms Show
- ZR1 wanted
- Cowl hood & Intake finally painted...pics...
- Dayem Admiral blue Zs everywhere.........
- 1/4 Mile Times
- Riddle me this, answer me that...
- 1 mile Top Speed run yesterday..
- Dreaded No Start fixed... for good (hopefully)
- Oxygen sensor extension cables
- LT5 wiring diagrams?
- Build Sheet
- Need some advice.
- What do they do the1/4 in?
- Oil Pressure
- selling car out of country
- What do you do when GM drops you?
- 1994 ZR-1 BLK/Torch red #023
- 1990 Sport Seat Bolster switch
- Help Before Weekend
- Noob with his new 94Z! Thoughts...
- This forum is awesome..........
- Need a TB
- Save a bundle on diagnostics...
- help need a motor
- Rear ZR-1 clip
- link to 1995 lt5 injector housings for sale
- Project underway
- Peaven's on his way home.............
- PCV valve
- Spare headers?
- New ZR-1er to the board soon!
- Buying a 90 or 91 ZR1 - opinions wanted
- 40th Anniv. question
- Where are the ZF brains here?
- Damage head pics for those who wanted them
- DS lumbar motor needed.
- Tuner Control Module
- What tire pressure should I use at 1 mile run?
