View Full Version : C4 ZR-1 Discussion
  1. Riding the Tiger
  2. I bought IT!
  3. Accell Injectors help Please
  4. ZR1 Nickles balancing on the Intake...
  5. Oil Pressure
  6. Z parts for sale
  7. Introduction
  8. Eureka Springs Corvette Weekend?10/5-10/8
  9. Clicking noise is first gear.
  10. Can anyone ID the nice motor in this Video :)
  11. ZR1 Road Trip this Sat, NY to Vegas baby...
  12. ZF6 Drain/Fill Plugs
  13. Missfire Solved. Girfriend is Back!
  14. Why are the 93-95 Ex manifolds better?
  15. ZR1 logo
  16. Parts for sale!!
  17. PCV Connector
  18. LOW TIRE PRESSURE WARNING SYSTEM: LTPWS Transmitter/Receiver Control Module
  19. WTB 94 ZR1 Rear Caliper
  20. FX3 Shocks
  21. 1992 zr1 should I buy it???
  22. Rear latch switch question.......
  23. Calling all ZR-1's to Las Vegas
  24. Anyone Had Dealings with Golen Engine Service?
  25. Latest video
  26. To what point were 90' Motors hand built...
  27. Help with ECM codes
  28. oil pump question
  29. Amateur day under the plenum
  30. Serpitine Belt question - 91 ZR-1
  31. osurce for low temp. thermostat?
  32. (SIGH)....she's up for sale officially
  33. Valve cover decal
  34. Anyone using under drive pulleys?
  35. HELP poped ahead gasket can I do?
  36. Hey Peaven.......
  37. Anybody know who has 1992 #75
  38. FS: Secondaries, stock FW/Clutch
  39. Low speed misfire
  40. Startup time
  41. 93-95 Gaskets
  42. Any LT1 knowledge here? Oil pan removal
  43. Need some ZR1 Parts
  44. Part Numbers for Random Technology Cats
  45. What should I have expected?
  46. Parts Timing
  47. Paging JeffVette
  48. Old Windshields
  49. 91 Vac system rebuild
  50. Michael Jordans Z......hmmmm..
  51. Many ZR-1 parts for sale
  52. I'm in a parade today..more zr1 tutoring
  53. 2 questions
  54. How Callaway Zr-1's
  55. Help needed - failed emissions test
  56. running lights stay on
  57. Big Cubes & Open Road Racing
  58. FunFest
  59. Clear Display Hood
  60. ZR-1 Corvette Goodyear Eagle F1 GS-D3 Tire 315/35YR17 for sale
  61. 1990 Zr1 F/s
  62. Brake Conversion: C4 to C5 or C6, Anyone Done it?
  63. Mystery Missfire
  64. ECM needed for a 90
  65. 1994 ZR-1 on ebay Blk/Blk No Reserve!!
  66. OBDI or II
  67. 1990 Zr-1 $23,000
  68. ZR-1 polo 95 whats it worth
  69. ZR-1 Rocker panels?
  70. Secondary Solonoid Switch diagnoses
  71. Yet another Air filter lid question
  72. Anyone hear of the "Blue Devil"
  73. engine worth????????????
  74. Bad ZR1 habbit...
  75. LPE LT-5 engine paint
  76. gaskets for sale 405 block
  77. Which year ZR-1 is best
  78. fidanza flywheel
  79. ID Numbers on Blocks
  80. think I have a problem with my crank rear plug
  81. HELP! Accel Injectors, same problem different hole.
  82. SGC Gathering?
  83. Adoption News
  84. '95 Zr1
  85. Clean Z on EBay...
  86. best guesses needed - Injectors
  87. ZR1 TT Project
  88. whats the stock clutch part number
  89. Looking for '95 ZR1 in Trade
  90. Anybody got a map sensor hose
  91. Secondary Air Inlet Solenoid valve question
  92. ZR1 or C5? You guys might want to jump in on this!
  93. Improving lowend torque
  94. ZR1 - record for fastest accelerating car 30-70?
  95. 1993 Two Corvette ZR-1 Sebring 12-hours
  96. F/S..another 1990 Zr1...rolled...in newspaper!
  97. Air Filter Lid?
  98. Post Your Timeslips/Dyno #'s
  99. ZR-1 heads
  100. part numbers for fuel rail o-rings
  101. Anyone been to "Deals Gap"
  102. 1995 Red on Red
  103. Dohc Hemi
  104. Brake Pads
  105. Anyone use dot 5 fluid in thier clutch?
  106. ahhh.. the 91 ZR1 is home finally..
  107. 1993 Parts and Illustration Catalog
  108. Wtf Mate
  109. Zr1 Morons
  110. injector testing without pulling the plenum
  111. Doing some 427 LT5 work this weekend
  112. Who sells A-Molds with the correct offset?
  113. Wow...check this out.
  114. Interesting Build Sheet (Slow Load Time.)
  115. Triflow vs Corsa Exhaust
  116. New ZR1 owner
  117. Seat switches-Function?-90
  118. ok...everything i post gets moved?
  119. HEY! NEAT...STep inside
  120. Reset oil light/check eng temp-90
  121. Looking for ZR1 Opinions...
  122. Blown Fuel Regulator !!!!!!!!
  123. Bleed screw question
  124. Interesting tale about Lotus and the ZR-1
  125. coil spring compressor
  126. WTB: L/H 1990 - 1992 Header
  127. so late last night i'm driving
  128. google earth...eye in the sky..my house
  129. Accel Fuel Injectors, HELP
  130. Changing Trans Fluid
  131. funfest 2006
  132. please let the thread below die...
  133. Awesome
  134. ECM Needed
  135. New 1995 LT5 crate engine
  136. Engine numbers question
  137. Gaskets for sale
  138. Gathering West Registration is UP!!!
  139. A few engine questions...
  140. LT-5 motor for sale
  141. Great Working with Kurt White
  142. vin# 2003 1990 question.
  143. Dash parts ???
  144. Back from Carlisle
  145. What kind of wierd ZR-1 rear is this one?
  146. Rear hatch weatherstrip
  147. oil temp gauge readings
  148. Anyone seen LT5's like these before??
  149. Thermostat housings-$145
  150. Used Injectors
  151. Just Aquired some LT-5 Engines and parts...
  152. engine will not fire
  153. Quasar Blue 1992 ZR-1 for sale
  154. Primaries replaced and now
  155. First Plenum Pull
  156. Oil Sensor problems
  157. stock brake job
  158. What parts have been discontinued by GM?
  159. smilie..made me think of DEE white..aka..Painless
  160. needed - cam chain tensioner
  161. Windshield problem
  162. Rear crankshaft oil plug / seal
  163. WTB, need an unserviceable Cylinder head..
  164. Help me out guys... Missin somthing
  165. Why did I spend all that money...
  166. How did the ZR1 come to be? Check my story...
  167. Ever regret buying your ZR-1?
  168. 1991 ZR1 Brake question
  169. How exactly do you test the coil packs
  170. Snake Skinner ???
  171. Restoring engine appearance W/O refinish
  172. 91 woultdnt't start: SOLENOID IS HOT ? After about a 10 or 15 minute engine shut down
  173. looking for b&b resonator to replace x-pipe
  174. engine Gurus.. please step inside
  175. very cool book I bought
  176. newb wheel offset question..
  177. Off Topic - Blown 06 ZO6
  178. Spark Plugs/Wires
  179. Intake Backfire on initial start-up...
  180. Big problem bleeding my brakes
  181. Engine refinishing- best value advice
  182. Joining the gang!
  183. What is "normal" idle vacuum on LT5
  184. Those lookingfor thermostat housings
  185. JeffVette, you around?
  186. full engine power light is not comming on
  187. quick answer needed on vacuum pump
  188. *sigh* sudden misfire after restart
  189. ZR-1 prices back on the rise???!!!
  190. One reason to go with a ZR-1?
  191. Where are all the L.A. Z's at?
  192. Damn secondaries!
  193. '90 wheels, what are they worth?
  194. Ignition advance
  195. Making a 160 stat...
  196. Went to the local GM dealer today and...
  197. The Nefarious Stant 14068 Thermostat
  198. Dymags For Sale
  199. Kmoudy
  200. New Home-slovenia
  201. Sumitomo HTRZ's???
  202. FS: Tire pressure sensors
  203. Inquiring 1995 Callaway Supernatural 490 ZR1
  204. Interest in windshield buy.
  205. carsile whos going?
  206. LT5 + ZF for sale
  207. HOT TOPIC>>>Tell us your BURNOUT technique in a ZR-1!!!
  208. cooling system pressure...?
  209. shock gear realignment
  210. [Looking For An Estimate] 1990 ZR-1 With 4k Miles
  211. Stock exhaust
  212. HEY..Painless..Movie star..Doc..
  213. parts car, I guess $10,000.00
  214. Carlisle
  215. Ignition timing LT-5
  216. zr1 intake tract ducting
  217. have you guys seen this?
  218. Fuel Pump Discussion
  219. Any have pics of Borla System? Thanks!!
  220. Newest turbo ZR-1
  221. There goes the re-sale value!
  222. Maple Grove race way
  223. 91 zri shift light???????
  224. pretty good article...
  225. FS ZR1 wheels
  226. Slowwwww Vendor
  227. front bumper cover needed
  228. What radar detector is best?
  229. Fuel level reads low
  230. help radio problem
  231. Infl Rest Warning Light & The Codes
  232. Di-Electric Grease
  233. Radiator Trouble - Advice?
  234. some people still get it....
  235. Windshields
  236. Somrthing about the KOTH
  237. Convert A/C to R134
  238. need a transmission...here's the place
  239. Who makes the best modified prom chip for unmodified ZR-1's?
  240. cams
  241. Looking for track times
  242. Where is it?
  243. Anybody know who has the red zr1 in plano, texas
  244. 1 more Q on coolant bypass...
  245. Long Tube Header for 91 ZR-1
  246. Anyone familiar with a steelblue 91 around huntington beach?
  247. Guess who developed a miss after detailing
  248. is there a engine stand out there that works with the Lt5
  249. Camber settings for my '91
  250. Italian ZR-1 Guy
