View Full Version : C4 ZR-1 Discussion
  1. Need inspection for '93 anni in Jacksonville
  2. secondary vacuum pump needed
  3. secondary vacuum pump needed
  4. air duct
  5. HighWay Gas Mileage with Valet Key On?
  6. 1990 Dark Red Metallic ZR1
  7. Transmission temperature and Dana 44 HD with 4.10 gears
  8. They're out there
  9. Quasar Blue Registry/database
  10. o2 sensors how to tell whenbad
  11. 90ZR1-AirCon Pump Pulley Rattle / Vibration
  12. Is this worth looking at?
  13. Is this worth looking at?
  14. Help - Radio Quit - 91 ZR1
  15. Tail Lights question...
  16. coolant temp info
  17. re: So I went to the Reno Car show
  18. ZR 1 Dash mystery
  19. Is a 1990 ZR-1 more trouble some than
  20. ID/OD of cooler line hoses?
  21. ZR-1 alternator ?
  22. Asking the ZR1 owners
  23. Dominion 4 Valve Alum Heads !!?
  24. Who ported and polished your Man. & I.H ??
  25. Broke down in nashville,need a chip!!
  26. Selling my '91 HAT 350/500
  27. Zr1 Values Going Up.
  28. Quad Driver Module 1, 2 ..what do they control???
  29. Why is the LT5 not a high revving engine?
  30. Help Replacing Rear Rotors
  31. Another one gone
  32. battery relocation
  33. Do you know my car?
  34. Do you know my car?
  35. ZR-1 opinions
  36. Bloomington Gold
  37. Chicago suburb Zs
  38. Looking for ZR-1 cover
  39. Alum radiator blow up? Happen to you?
  40. 1989 preproduction 11" wheels
  41. Custom TB cap
  42. Buying a Car-Final Part-With Pictures!!
  43. Close encounter of the Z06 kind
  44. 95 #316 for sale, 18K miles, 34K.
  45. crackling sound when turning wheel
  46. high fill tank is broken, can it be fixed
  47. ZR1 sighting going Northbound on NJ 35 shore points
  48. C-5 brake conversion
  49. Vibration Above 70mph...Ideas To Save Money
  50. Vette Fest - Boise Idaho
  51. ZR-1 License plate covers
  52. tire pressure?
  53. Blown A/C fuse
  54. Adams Wax Discount for ZR1 owners
  55. I sure do miss Bowling GReen
  56. Trouble
  57. '94 #145
  58. ZR-1 Auction
  59. Selling my Red/Saddle 90
  60. How many ZR1 still alive around the world??
  61. Power Seat Switches in Bezel??
  62. Who knew Ford had the LT-5 first!
  63. 91' Zr1
  64. Opinions on ZR-1 Headers
  65. Zomg!!!it Has A Zr1 Motor!!!
  66. Materials to Improve Cabin Resonance/Heat Intrusion
  67. 90 zr value ?
  68. HELP! Question About Throwout Bearing
  69. Top Speed for each gear with 410s?
  70. Need some LT1 help - some of you folks might know the answer
  71. Windshields Update 2
  72. Rear compartment carpet?
  73. bad sound from clutch or Transmition? any one know it?
  74. power steering hose question
  75. Will C6 19X10 fit ZR1/w/315s?
  76. Some ZR-1 parts for sale
  77. How Many 1992 ZR-1 Do We Have On The Forum...?
  78. no start issue (grrrrrr)
  79. Emissions labels
  80. Ebay!!!!
  81. Internal Passenger Compartment Brace
  82. No Start
  83. shift light
  84. Windshield Update
  85. 17 x 11" Gunmetal Corvette ZR1 wheels
  86. Sunday Drive
  87. new Shirts available Tuesday
  88. 90 Zr1 Need Your Opinion !!!!!!!
  89. Clutch fluid
  90. anyone know anything about this C4??
  91. alternator issue
  92. re: Who owns 91 # 116 in Polo Green?
  93. Brake systems again
  94. Once in a lifetime
  95. 1990 ZR1 Orig. Owner 850 Mi.
  96. 4 wheel alignment
  97. 93 Quasar "HILKING" on to a new owner
  98. Rotor Vendors - Need HELP!
  99. Buying a Car Part 2 (Suspect ZR-1)
  100. PHROGS - check you forum mail!
  101. Issue with Fluid Changes
  102. Needing an old style driver coolant pipe....
  103. Needing an old style driver coolant pipe....
  104. Hey Keith....clean your box out !
  105. Need your opinion.
  106. Bearings Update & last price offer
  107. anyone here?
  108. Anybody know any more info on this?
  109. airconditioner wows Help
  110. ZR-1 vs LT4 insurance rates
  111. SF Bay Area Forum Cruise Yesterday
  112. I'm ready for mods! Has anybody done this?
  113. Power Effects Catback System
  114. Seat Belts
  115. Looking for part #10067705
  116. Donor ZR-1 manifold
  117. I'm psyched
  118. Rebuilt Exchanged LT5 Engines Poll
  119. shifting 4l80E at the track?
  120. Craigslist Callaway Z
  121. Steel Blue ZR1 for sale in WA
  122. dead battery
  123. Question from Australia: 90 ZR1 value
  124. Back from Henderson Performance
  125. Friend's 91' zr-1 climate control out of whack
  126. Cruising Out and About in the Temp Mid 70's
  127. Vibrations at high speeds
  128. Modding cars.......Badly
  129. Vettes and Planes
  130. Remind me again how many quarts of oil to put back in after an Overnight drain?
  131. question for the Zr1 experts
  132. A 1991 White/Red ZR-1...
  133. Central VA ZR-1 Owners
  134. Changed plugs in my Z last night, WOW!!!
  135. low cost rubber elbow
  136. Quick center caps question
  137. LTPWS light on
  138. Thunder In Stillwater
  139. Kurt@White Racing-Engine main bearings
  140. Wilwood Brakes
  141. Thanks JeffVette,Dwight & Everyone
  142. Automatic in a ZR1 - don't shoot me
  143. bellhousing
  144. Buying a ZR-1 from Canada
  145. Looking for Johnny (Phrogs)
  146. Picking up my ZR-1 #342 on Sunday
  147. aircon re-gass problem
  148. What shade of Black is on the Bumper?
  149. wtb: 91-95 right rear corner molding
  150. Question about frames.
  151. New Ruby is Home...
  152. How can you tell its a ZR-1 by just looking?
  153. Does anybody know the correct spark plug gap?
  154. '95 #74 & #112 where are they?
  155. broke a/c fitting
  156. The Suspect ZR-1 Saga (Unveiled)
  157. 95 #2 on registry
  158. TCB In a Flash......Thank You Verry Much
  159. According to forum "experts" you ZR1 guys can't drive worth crap.
  160. Original Battery '94
  161. Forgot to put spring back in lower hose
  162. Good deal?
  163. C6 Z0 6 Wheels on ZR-1
  164. Comp Yellow ZR-1
  165. Accel Injectors - Act fast! - ONE SET!
  166. re: Stainless engine bolt kit almost $200 ?
  167. Check in if you are going to Lone Star show
  168. rhanselman please clear your inbox.
  169. NOS Rear deck
  170. Picture of lug extension socket and clip located inside the console
  171. Spare parts list for a 93-Z
  172. Videos!! A few easy passes on my 427.65cid!!
  173. welding question
  174. Paint for frame
  175. Sources-ZR1 aftermarket pistons
  176. Twin Turbo LT5
  177. a bit of advice...
  178. WTB ZR-1: Part trade for GMC Typhoon
  179. local mechanic condems radiator. Rec Replacement?
  180. There's a new sheriff coming to town....
  181. A request for dyno sheets.
  182. $13,850 for a '92? What...
  183. Fat a$$?
  184. Big cubes in Cali?
  185. Looking for a Utah Owner of a black 91
  186. NitrousJunkies "Vette Fever" article on line...sweeet!!!
  187. '94 Admiral Blue/Black ZR1 for sale
  188. ZR1s going to Vette Magic
  189. YES< Bowling Green is still there..here's pics of o7 gathering
  190. Brake Fluid Brand?
  191. the Bowling Green WTF factor
  192. smoking from the Pass side.
  193. How Big Is Yours?
  194. More Questions: Fuel Pumps / Plenum Pulling
  195. Knocking/clanking noise whe idling in neutral
  196. What screws for the front license plate?
  197. what are your launch tec.with drag radials?
  198. high idel issue 91 zr1
  199. Did ZR-1's come in Automatic?
  200. re:New ZR-1 plate
  201. Special Tools for LT-5 (need photo)
  202. Code 32 1993 Z
  203. Jack-a-Vette, where to buy?
  204. Removing lower hoses
  205. wtb stock exhaust
  206. Jimmie Dolinger Sales Results
  207. loosing coolant & no leaks?!?
  208. Front License Tag cover removal?
  209. LT-5 Technicians
  210. 1989 pre production ZR-1s Atari Dash?
  211. Bowling Green Event 2007
  212. Attention Those At The Bg Gathering
  213. Need A Big Favor
  214. LT4 and LT5
  215. Stock vs. modified preference when buying?
  216. How quick did the ZR-1's run at Beech Bend?
  217. RED OEM LT5 Plug wires
  218. Any Minneapolis/St.Paul area forum members?
  219. Rolling Project
  220. First Bowling Green 07 drag pics!!!!!
  221. Rear Hatch Struts Recharge Source
  222. Black Smoke From 91
  223. OEM plug wires for sale
  224. Interesting blown quad cam......
  225. Is The Oil Drain Plug Different for the ZR-1?
  226. re: Daily driver oil consumption
  227. White Racing windshield
  228. plenum removal help
  229. The Official Bowling Green Thread
  230. Engine miss
  231. Anyone recognize this........
  232. Bowling Green Via Morgantown, WV ??
  233. engine pull
  234. New Ruby!
  235. autocrossing fun with new BFG R1 tires
  236. Value of a 90 ZR1????
  237. Subframes?
  238. gathering drag racing
  239. WI/IL Members - 2007 Cruises
  240. WI/IL Members - 2007 Cruises
  241. Paging Peaven
  242. Oil Pan Gasket
  243. 3 peice rim ?
  244. Dyno'd the 90 Saturday, kinda low numbers
  245. ZR1's in Northern Va / MD / DC / anywhere close
  246. Bowling Green
  247. Hey..frankie
  248. Best Place To Buy a Master Cylinder for a 92
  249. The Fruits Of Labor:Pictures Inside>>>>>
  250. Brand New Plenum...
