View Full Version : C5 Z06 Discussion
  1. header question
  2. FREE Online Owners Manuals!
  3. LS7 Engines & C5R Blocks In Stock!
  4. Best indoor car cover?
  5. Oil Leak on Differential
  6. Drag advice for this weekends Test & Tune!!
  7. Catch Can
  8. Fan?
  9. C6 Z06 shocks are on my '04 Z06...
  10. Loud?
  11. 7 Z06's at MIR
  12. What can I expect in today's market - '02 Black Z06 ~ 9,000 Miles - Mod Red Int?
  13. Best wheel/tire combo for racing/autocross
  14. New car brake in
  15. Porterfield R4-S brake pads
  16. Drag Radials?
  17. For those with cammed Z06's..
  18. Question about tire sizes and RA1's
  19. Looking for specific " DIY lowering" thread
  20. Rear Camber Rod to Knuckle torque specs?
  21. Vararam Air Intake
  22. Show me your 19/20"
  23. Testing the water...fs 2002 yellow z
  24. Wife hates sound of Borla's
  25. Zaino
  26. 01 vs 02 questions
  27. Runflat versus Non Runflat?
  28. i have bb bullet, and stock header/h pipe, if i gut pre cats, how much louder?
  29. Advise on maintenance
  30. C5 Z06 vs. C5 Convertible
  31. Z06 Stereo Dials Disintegrating!!! AAARRGGG
  32. Any one run Nitto's?
  33. Z06 times tonight
  34. Why you should not street race
  35. Is anyone running the Spec 2+ clutch
  36. 01 Z06 Hurst Shifter Part # ?
  37. drag radial question
  38. Lifting up your Z06
  39. Newbie to the Forum
  40. are these fair prices z's?
  41. C6 Z06 shocks on a C5 Z06...anyone using this set-up?
  42. --CORVETTEKEY.COM Free Shipping On All Orders For Corvette Key Mod---
  43. im out
  44. Temp with 160 thermostat
  45. Dyno ?
  46. any comments about Suburban Chev in Southwick
  47. RPM vs MPH with Gears.
  48. What size for CCW 505A's?
  49. Best track pass so far Video!
  50. Question What is the Best X-pipe to use
  51. Went GMPP shopping last week...
  52. The Best X-Pipe
  53. I'm about to order some Michelin Pilot Sport PS2's....but should I get wider?
  54. Thanks for the pics of silver Zs, got one!
  55. NJ Z Owners!
  56. Replacing the drip edge
  57. 01 Z06 - F11 + stock heads = good or bad gas mileage?
  58. Good Friend wants a Viper! Holy Cow!
  59. Have you used your GM warranty yet?
  60. MODS & TUNER IN OHIO
  61. Anyone using Michelins Pilot Sport Cup tires/
  62. Can anyone ID exhaust pipes?
  63. i had to disconnect the battery today (relearn?).....
  64. Clock/ Battery issue
  65. Good dearlership experience in NorCal
  66. E85
  67. Stock C5 vs C6 Z06 60' Times
  68. LS7 Engines In Stock 12,995!
  69. Radio lock out
  70. Best place to get h/c installed in Southern Cali?
  71. K&N oil filter?? is this a good filter for my Z?
  72. 02 Z06 Lowering problem
  73. Soon to be new Z06 owner with questions.
  74. My Z06
  75. Switching cams?
  76. Shifter knob
  77. Any problems with your stock master cylinder for those with aftermarket clutches!
  78. Need Part # for the rubber thing that hold the exhaust up...
  79. What is the best stock 1/4 mile....
  80. Stock bolt lowering
  81. Blinglight installation
  82. ZO6 Brakes
  83. Shaner polished TB
  84. New Z06 owner here
  85. 2 x 10's to lift car.
  86. RedLine bad for transmission?
  87. Targa Conversion For The Z....
  88. Sparco Milano II'S?
  89. New to the Forum!
  90. Need a New MAF, Any Suggestions??????
  91. Dyno pull at 20 PSI of boost
  92. 06 ZO6 runflats on 04 ZO6
  93. Trailering a Z06. Tie downs?
  94. Off Topic: really fun Ferrari video!
  95. LG headers/cats or no cats?
  96. aftermarket Cam/stock heads..horsepower?
  97. c6 headlights
  98. Looking for a pair of Speedline Z06 front wheels.
  99. C5R Blocks In Stock!
  100. 2006 Z06 Brake Packages For Sale!
  101. What exactly is a "dyno tune"?
  102. 390s in woot woot!!!
  103. Considering Tune
  104. Upgrade shocks with new tires?
  105. Florida Z06's!
  106. c5 Z06 vs c6 (non z06)
  107. Optima battery owners...
  108. Stock LS6 heads CNC'd and Milled.
  109. This weeks project
  110. About to pull the trigger
  111. Which Z06 should I buy
  112. 12" Z06 wheels?
  113. Different Column Lock letter
  114. 315 Tire any rubbing issues?
  115. Z16 (build # Name Plate)
  116. Fuel filter in the tank!!??
  117. Head/cam Install......
  118. Front license plate or not?
  119. Street Headers instead of LG Longtubes
  120. Column lock letter form GM
  121. Panama Vettes
  122. Dyno Tune
  123. something i recomend for all ZO6 owners oil related
  124. ARGH!! First cosmetic damage to Z!
  125. need wheel part numbers
  126. New owner -- Kirk roll bar question
  127. Air Intake Help - I know...I know...
  128. Swapping out stock c5 z06 clutch for c6 z06 clutch
  129. New owner -- Question about reverse
  130. Where to get a tune in central Pa????
  131. Long tube headers
  132. Textralia annouces our new double and triple disc clutch
  133. 02 Z06 - Need advice on Mods
  134. Mallett "D Ported Headers"
  135. kooks headers x pipe dyno
  136. Front wheels skipping when fully locked
  137. Are Hawk HPS pads a good choice?
  138. Lookinf for Goodyear SC Fronts
  139. Z06 Daytona 500 Pace Car
  140. pics of 19 and 20' zo6 chrome motorsport wheels
  141. The real LS7 specs....
  142. "competition mode"
  143. Idle Speed?
  144. WTB Z06 tires
  145. trunk lid doesn't "pop up"????
  146. Z06 used vs. Reg. C6 new
  147. First track day with Wide Ovals
  148. Need help w/Vararam Install
  149. New Wheels
  150. 02 Z06 new best with cam = smoked clutch
  151. Getting H/C for my 2001 Z06, what else I need?
  152. LS7 Engine In Stock 12,995!
  153. Can someone confirm that GTO spare will fit on a Z06?
  154. New Water Pump
  155. LPE High Flow Maf/Lpe Cold Air Intake C-5 System
  156. Do I have a 10 sec. car ????
  157. Anyone Lose Control Thanks to Active Handling Failure?
  158. Ideal auto-x setup?
  159. Earnhardt Jr. Autographed Z06 on Ebay
  160. Where to get side skirts??
  161. Worth the wait!..It's Home
  162. Need Tune in Jacksonville FL Area
  163. Radio trim doesn't quit fit?
  164. I finally found some time to take a few pics.
  165. My fuel door switch doesn’t work
  166. Z06 popularity and availability
  167. GM Customer Assistance on valve spring problem
  168. My Z06 IS Dead part 2
  169. Can someone run a VIN for me??
  170. 02 Z06 + LG Pros + Halltech
  171. Vararam=bucking? WTF?
  172. mileage out of raybestos quiet stops,
  173. Power Antenna
  174. 04"Z recalls??
  175. A clip sound of the LG5X2
  176. Which Exhaust Is Best??
  177. Stock Zo6 Flow #'s
  178. WTB 2002 Black Z06 - Atlanta Area
  179. Where to get my Z06 tuned in Canada??
  180. Z06 Help!!!
  181. Racing Seats
  182. Polishing The Standard 02-04 Speedline Z Wheel To Z16 Spec, Anyone Try This?
  183. Z16 pricing - help please...
  184. Short throw shifter
  185. Chrome Z06 Wheels Question
  186. Gto spare on ebay $50
  187. Electrical annoyances / glitches
  188. F/S K & N Air Induction System
  189. What size rims and tires?
  190. Tuner Software
  191. Wheel luges
  192. Tire pressure
  193. my Z06 IS dead
  194. LG Headers, CAI, Free-flow cats, x-pipe
  195. A reproduction chrome wheel weighs
  196. Warranty about to expire...help
  197. I Need Rehab To Stay Away From This Site
  198. Trade my ZR1 for your Z06
  199. column lock 2 birds 1 stone
  200. Cam numbers for my 02 Z06
  201. forged bottom end prices
  202. GM Service Manager Info - Steering Column
  203. video and sound clip of G5X-3 cam install
  204. Need pics of QS Zs....
  205. Think about this !!!!!!!!
  206. Best Valentine's Day EVER!!!
  207. WTB 3.90 Diff
  208. LS6 total production--all cars?
  209. Rearview mirror mount for radar detector...
  210. What speed does each gear top at?
  211. Need quick answer on code problem in TCS
  212. 03 Z06 Front Control Arm P/Ns?
  213. Z16 Value Question
  214. Pictures of my new (to me) Z06
  215. trans axle leak best fix
  216. I need pipes!!
  217. What have you done for weight reduction?
  218. Just got back from Auto show -2005 ZO6
  219. XM Radio Help
  220. Passenger side window won't go down...
  221. Nitto 555R or R-IIs on the front with 555R on the back?
  222. FRC to Z
  223. New Z06, What Color?
  224. How many Canadian 2006 Z06's do we have??
  225. G5x3 Cams, are they worth getting?
  226. cleaning wheels -brake dust using high pressure hose
  227. VB and P Bushings
  228. Bridgestone REO50a's VS pirelli pzeros
  229. I own a Z06
  230. which dealer to trust in central Pa??anxious Ed
  231. are C5 rotors and C5 Z06 rotors the same size?
  232. AC Vent
  233. Why can't my C6 brake as well as my 04'Z?
  234. New 01 Z06 owner with intake and exhaust questions.
  235. She's a Hottie...
  236. Bad Alignment???
  237. I need ideas. Help me out please.
  238. Octane Question
  239. LS1 edit what does it mean
  240. Almost getting a new Z!
  241. BPP Shifter
  242. Borla Exhaust + X pipe
  243. Coil Over Springs - Comfort Level?
  244. LS7 Engine 13,395!
  245. Fichtner Parts Specials...save $$$
  246. Nice Z06 comparison video's
  247. Need Help: Questions Regarding Tires & Tire Sizes?????
  248. New Member: 04 Z06 w/ 403 TT
  249. What makee Z06 have more HP
  250. Cats/x-pipe only.
