View Full Version : C5 Z06 Discussion
  1. Brake pads
  2. Rear Defroster Broken.
  3. Stock exhaust ?
  4. Praise for BlingLights Quality and Service.
  5. Purchasing a new ZO6
  6. Just saw Lou Gigliotti win 2nd GT Championship on Speed.
  7. Looking for METAL center caps
  8. Transmission Problem?
  9. Wanting open air again... dilemma.
  10. Probably a dupe, but I have a gage question..
  11. A good ending to a column lock issue
  12. Losing power??
  13. SouthernCarParts.com Orders From 7/25 and 7/26
  14. Question about Z06 front screens
  15. September R&T Comparison with Z06
  16. The best partitions just got better
  17. Z cam
  18. GD effen curb!!ARGGGGHHH!!!
  19. Repairing a minor scrape?
  20. Went into the City and took some pics - 2002 EB z06
  21. spraying causes engine to blow?
  22. 04 Lemans Blue Z06 CE questions....
  23. 04 G35 Greddy TT (510whp) vs. Stock 2006 Z06
  24. Baer rotor prices
  25. Which Z was first... Anyone?
  26. is the vin on the engine
  27. Nail in the tire
  28. LS7 Engines, C5R Blocks In Stock!
  29. Heads only or 1.8 rocker swap?
  30. *The Greatest RIM WHEEL Blowout Pricing That Corvette Forum Has Ever Seen!!!*
  31. alignment specs question
  32. Anybody heard of these rims?
  33. Firestone Wide Ovals-impressions!
  34. Just blew front passenger tire...ok to replace one only?
  35. need brakes, stock z06 pads or pfc z rated?
  36. Pics as Promised EB '02 Z06
  37. Some recent show shots.....
  38. What to look for when buying a Z06?
  39. Crisis:Stealership screwed me huge!!
  40. Z06 aftermarket wheels
  41. need some advice before I go to the track
  42. comments and question on last weekends z06 vett fest in bowling green
  43. C6Z Manifolds on C5Z?
  44. Need help with wheel/tire size.
  45. Z06 windshield
  46. What are the the specs for the stock C6 Z06 cam?
  47. Plug and wire change intervals?
  48. Z06 Fest Pics
  49. Just went by a huge empty parking lot and...
  50. Just went by a huge empty parking and...
  51. Blocking off air tubes on my 02??
  52. Hi guys few questions
  53. How hot should my coolant be?
  54. What gears do I have in my car?
  55. anybody switch to the "viper tires"?
  56. Opinions on exhaust switch
  57. Aligning my Z06 this week...
  58. New to the Z06 Forum
  59. 01 Z06 Dynoed Today
  60. Fred Beans Parts . Com C5 July Specials!
  61. Low washer fluid WTF
  62. Mixing oil weights?
  63. Need info changing transmission fluid
  64. Flowmasters.
  65. hit a hole, will it total my car?
  66. Screen in MAF question
  67. What's the deal...
  68. Sill Plates, Fender Covers, Throttle Plates New Prices!!!
  69. Cutout question
  70. Headers and Exhaust Question
  71. New Owner Advice?
  72. Feeling a little Blue... Electron Blue that is..
  73. lowering an 02
  74. brake pad?
  75. 01 vs 02 air box cover, how do i open it up?
  76. Dealer changing Mn6 and diff oil
  77. Why are these headers so cheap?
  78. C6R leads parade through downtown detroit
  79. Picking up my Z soon!!
  80. Are my times where they should be?
  81. CCW Wheel weight
  82. New Vararam gets me noticeably more power and SERVICE ENGINE LIGHT
  83. Pics of my 04 Z06
  84. Differential Fluid Change?
  85. AC Problem
  86. New Vette Owner.
  87. Who will insure for Track Days?
  88. Valve Spring Change-How Difficult
  89. Changing Gearbox Oil / need to add Modifier?
  90. Anyone have the Texas Speed long tube headers on their Z06?Dyno #"s?
  91. Finally bought a Z06
  92. Z06 alignment settings
  93. Anyone else have this leak, Pics inside
  94. Dress up mods? black Z.
  95. 295 or 305 on the Rear With 19" Wheels
  96. What is the factory oil filter part #?
  97. Z06 Carfax Question
  98. Decisions, decisions...
  99. question about tuning with only bolt ons......
  100. Another great DE
  101. Spring Mountain Driving School Discount
  102. Any tips or firsthand experience with clutch replacement?
  103. Rear Brake Vent Plastic
  104. Made a mini computer wallpaper poster of my Z...
  105. 1st ride in a Z06! FINALLY!
  106. Just took a joyride in a new C6 Z06. I feel inadequate!
  107. Stock z06 air box question
  108. brakes
  109. looking for brake pins
  110. looking for brake pins
  111. eng. check light
  112. Just detailed her with pics inside (56k go read a dictionary)
  113. My 02 Z is burning oil like an 01....
  114. Finally took some Pics!
  115. brake problem?
  116. Lp Mini Tubs
  117. ZO6 TigerSharks
  118. Michigan area tuners
  119. 2007 Z06 On the rig.
  120. question about Z06 screens
  121. West Coast Tuner...
  122. T1R's or RA1's
  123. '02 Z06 "Bucking" and Won't Idle - Newbie
  124. Mobil/Ethanol trouble codes
  125. c6 shifter for zo6
  126. reduced engine power code, please help
  127. A/C, heater control passenger side doesn't work?????
  128. stupid radio question pls.
  129. Leaded fuel in unleaded engine
  130. C6 Z shifter in the Z
  131. anyone got pics of a 295/35/18 on a 18x11.5 rim??
  132. [RANT] Fuel level sending unit goes out for third time, plus other issues...
  133. If you had to guess, how much power am i making?
  134. Check engine light
  135. Z06 Stock Alignment and Tire Wear?
  136. Cleaning her up.
  137. vararam issues....
  138. Z06 Wheel Spoke Size
  139. Would you be wary of this car?
  140. Knight Rider fans check this
  141. Should the larger SSM filter make a difference from the normal halltech filter??
  142. OEM Tires
  143. red and black door panels?
  144. Wow!
  145. Phew, I won't have to sell
  146. burnouts and doughnuts
  147. question about the Z06 Nurburgring time
  148. Wheels for Z06's shown on cars...
  149. Need help with wheel offset!
  150. Anything I should know before raising car.
  151. Recaro Pole Position...
  152. Z in NJ
  153. stock ZO6 car cover
  154. AutoX Basics, Weekend Warrior tips needed...
  155. 2003 Z06 temp ?'s
  156. Corsa Pace Car Exhaust
  157. will g.m fix this?
  158. Brake Booster replacement, aftermarket?
  159. 4 wheel alignment on a Z06 Question
  160. Highly modified Zo6 horsepower question
  161. Toyo T1-R shortage??
  162. C5Z vs C6 .... 1/4 matchup revisited
  163. MOST HORSEPOWER/TORQUE 346ci
  164. TSB on diff seals?
  165. almost a catastrophe, saved wheel, lost tire & $450.00
  166. Stereo Help
  167. mirror lights won't go off in my z06
  168. Remote bleeder problems
  169. Ac actuator issue
  170. Dic ????
  171. Headers Cams Mufflers ?
  172. How to tell if a Z's been ragged on?
  173. 1/4 mile time confusion...
  174. callaway honker
  175. Chrome Exhaust Tips
  176. Just got an OEM 03 Z h-pipe installed on my 01 Z....
  177. Kicked my Coupe to the curb
  178. Any Torch Red Wide Bodies?
  179. Where does it say speedline?
  180. Smashed E-blue on 270 in MD
  181. grudge match / Porsche turbo's vs. my '04 Z06
  182. Tire sizes
  183. Launch during drag racing
  184. I need a closeup of the Z06 badges on the car
  185. Can I use an 01' Z Shifter in my 00' C5?
  186. Tire size.
  187. Key FOB transmitter no longer unlocking driver side door
  188. C5 vs Z06 shifter
  189. Can someone PLEASE help me with my track times?
  190. New Guy on Board
  191. Covers on lug nuts
  192. Where do you guys get your autoX tires from?
  193. c5 silver-z06's with 06 z06 rims, pic's please
  194. Z06 & Run Flats
  195. AFR 205 59cc heads
  196. How do you guys like the Firestone Ovals for your Z06?
  197. Heart pounding Corvette video.
  198. were the 03-04 Z06's...............
  199. anybody have any good links to any C5 Z06 articles??
  200. tell me what u all think
  201. MY C5 Z06 w/ C6 Z06 Wheels
  202. Grrrrrr
  203. My crappy credit drama is finally over!
  204. 8 quart oil change.....WTF.
  205. Car Sputtering with check engine light on....
  206. GOAT to Vette: An Intro
  207. More CCW Porn!
  208. What could this be a sign of?
  209. Should an 04'Z owner buy a new Z?
  210. z06 color question?
  211. Switched my Ti exhaust for a Corsa Indy Pace
  212. Home-made Ramps For The Z
  213. Track tire pressures for Hoosier R6 slicks
  214. Zo6 Video From Miami
  215. Punctured BFG drag radials - possible to plug?
  216. can anyone suggest a good set up
  217. For the Z06 owners that have high miles on their car....
  218. air leak sound during braking question
  219. Craziest thing in your trunk?
  220. Stupid Question
  221. Best Extended Warranty Price?
  222. C6 gray competition wheels
  223. Pictures I took today....Z06, M5, black suprise...
  224. For the guys that have driven both Z06's.....
  225. 2004 Blk Z06 for sale - reposted
  226. I took the spring off of my clutch have a few ?'s
  227. Happy 4th Of July To All!!!!!!!!!
  228. I thought my Z06 would melt !
  229. Can you just get headers for an 04'Z?
  230. Lovin those Borla Quad tips!
  231. new jersey insurance rates on Z06 ??
  232. Lets see your EB Z w/ tint
  233. Need a little help on brake calipers
  234. 04 zo6brake sqeak,dust
  235. Some pics of the Z with CCW's
  236. 2003 z06 air intakes!
  237. Very close to pulling a different trigger
  238. NEW pictures - a few changes since I first got it....
  239. HUD install in a Z06 !! HELP !!
  240. Will 04 H pipe fit a 01 Z06?
  241. borla stingers + long tubes w/ or w/o cats
  242. New Member, HELP! Noise from tranny.
  243. Borla Straights
  244. This is apalling
  245. Light problems
  246. Joined the Z Club!
  247. What to look out for on buying a used Z
  248. Proud Papa!
  249. Weird noise #2
  250. What is the air hose connected to the side of the stock airbox??
