- CE LT4 Update---March 2, 09
- poor man's zero balance dual mass flywheel?
- 1986 Corvette Auto Shifting Problem Please Help
- Engine balancing
- 89 TPI crankshaft - snout question
- 87 ecm/pcm
- cam only for 95 vette
- Releasing ball joint from spindle.
- Who has experience with B&B Tri-Flow Exhausts?
- Hydraulic Roller Camshaft Spring Pressures
- Dangerous Suspension Problem
- Epoxy or Double Sided tape to hold Delrin to Aluminum.
- tranny swap
- 93 Starting issue
- 87 headlight problems-weird
- why does the clutch release bearing spin on just metal?
- Holley Stealth Ram Custom Plenum
- TV cable removal on a 1992 LT1 help
- Length of Swaybar endlinks
- 1990 Coupe. Electrical short. Need help.
- A/C Question
- Brake Caliper installation?
- strange problem
- Seat Cover removal
- Dana 36 Guru's step inside
- valve lash adjustment - heads already assembled
- new issue today
- Cooling Fans
- C4 rear view mirror screw size
- L98 owners High Performance Fuel Delivery options!
- Problem at restart.
- PKE Just shut off ?
- Heim Joint Maintenance
- Build me a L98
- 89 heater / ac digital controller
- Coolant problem
- Jerking of rear
- help-engine knocking!
- Heavy duty cooling system radiator question
- Dana 44 install in 85 auto
- Carrolls 4-link rear axle kits?? ??
- Timing Question
- Cowl Hood?
- rear wheel noise
- L98 Roller Rocker Lifter Retainer
- what sway bars would improve handling for a 93 corvette
- Replacing Distributor cap/timing disc fell off
- LT-1 knock sensor
- Flushing cooling system for C4
- Claw Replacement Filters???
- 87 electrical problem
- Need help quick stuck lifters!
- Auto rear transmission seal
- dual exhaust or headers
- difference between headers with egr and without
- Injector flow rates?
- external oil cooler for C4
- Upgrade to a more potent engine, if possible
- Best place to get headers?
- DeWitts Group Purchase
- My C4 with dual cone cold air intake
- Shiftlight
- Preventable Maintenance...New or Reuse...
- SMOG pump elimination HELP
- Spring protectors?
- looking to get another tranny
- Trick battery tender install?
- i though i had it down, and now old threads said i can weld the dual mass
- HiPo Cats for 96 LT4
- crate motor
- Lost power
- Estimate for the 1/4 mile
- What is the top speed of a stock 92 LT1 C4?
- Poor idle after header install
- Leak?
- Access Driver Side Wires @ Opti??
- A/C Stop Leak
- rebuilding rear suspension
- exhaust ? 84
- How do tranny coolers work on a ZF?
- Suspension question, maybe rear wheel bearings?
- SBC roller cam thrust plate question
- Twin Turbo C4. Wich engine block.
- Power steering pump questions
- 92 LT1 Rear wheel alignment question
- Front end Wedge Brackets
- Cam
- Radiator leak
- Does anyone have the wiring schematic for a 1990?
- what valve covers will fit the l98 with afr 195's and super ram?
- Vacum lines
- Windshield Wiper Question
- Corvette Heads
- Lookie what I came home too.......
- Cooling fan switch added to console
- 85 Oil Sending Unit and Thing Next To It
- Where to get good shifter bushings
- 52mm TB
- What distributor for 91 with stealth ram
- Crane Cams shuts down, workers laid off
- ECM experts step in please
- 89 code 33 Maf
- Intake port
- Hooker 2151 LT1 Install Question
- Smoke under the hood after first season start
- Antenna problems
- Swapping Heads and Intake on my 84'
- What is a Pulse Air Feeder???
- Noob Questions
- Torque Shock Bolts?
- Can I do my own ball joints?
- TB bypass
- Best head and intake manifold gaskets
- Recommended Plug Wires??
- help me pick a cam and converter for my 88 vette
- 1986 Vette dies when put into gear
- Vortex rammer review
- Vacum lines
- Induction Decision SLP Vs Vortech
- Crane Closes
- can someone recommend a new low cost flywheel?
- super ram and stock 89 valve cover interference
- stock flywheel is oozing oil
- Starting Issue
- Transmission bolt size?
- h54 and h74 codes
- 89 wheel tire combo
- Clunck, No Start, No Turn over
- I need pics PLEASE!
- Removing Upper control arms
- jump/charging Optima dry cell
- Cracked rear hatch weatherstripping ahhhh
- LT1 rebuild
- Pulling the engine (LT1)
- 1990 cam specs?
- 90 6-Speed RPM's @ 65 mph ???
- Head Bolt Question
- Far from normal!
- Locking header bolts
- squeaking suspension 89 coupe
- Radiator fans 1993
- Need a part for an alternator, where to find?
- Can TPIS run with the big names?
- Codes h54 and h74 in a 92
- Short Antenna? Can you even find one?
- "Bouncy Ride With Targa Roof Panel Off
- having a hell ofa time - rear bearing hubs
- 1996 Weather strip kit
- 1991 Engine rough Idle
- Freeze Plug
- help... hood will not open
- Rocker Combo.. advise please
- 89' No Heat !! 15* tonight
- 68 396 - 427?
- 95 dana 36 gear info
- Intermittent Gauges/Cluster
- passenger seat wont move
- Spark plug swap
- Tach Digital or after market
- Front Wheel Bearings
- The Never Ending Wheel Bearing Thread....
- MPG with ZZ4 or LT4 Hotcam
- What is an h74 code?
- Lifter Question
- TPI sealer Question
- Interior Lights
- Spark plug wire options
- Question on thermostats
- Wheel Center Cap locks
- Engine Overhaul Questions....
- 1990 corvette blown head gasket or warped head please look and tell me.
- FX3 Experts - Reset Procedure??
- Am I understanding this correctly....
- The Best Tools/Gadgets/Parts Thread
- 2 piece main 383 Flexplate?
- Dome Light Problem
- Ignition switch
- Whats the largest size rotors we can use w/ stock 17" wheels
- Disassembly of 2 pin connectors
- Clutch question.
- rim interchange
- what is this engine? suffix code UKA
- Spark Plugs
- 'Performance Consultants' ex-Colorado?
- Window stop
- Your Guess Is As Good As Mine (Or better)
- Extending the life of my Engine
- Question for the racers...
- Roller Cam how-to
- About to order a custom prom for a basically stock LT1. Need some input ...
- advice on push rods needed
- LT1 Heads (Interchangability)
- Coded keys
- AIR Delete-What else?
- 1995 Brake hard lines rusted
- Replace OPTI?????
- Intake Gasket - L98
- Low tire pressure sensing
- engine starts but dies soon afterwards
- 1989 intermittent rough start and stalling
- Right Size Head Gasket
- Hi mileage trans fluid change myth???
- Oil cooler w/thermostat
- What Coil Over Shock????
- RTV/ Intake?
- transmission ???
- Starting issue
- Speed Bleeder Problem
- 1985 C4 Tire and wheels question
- Removal of front cooling fan on 1989.
- Replacing front wheel bearings
- Bad Gas?: Update
- 86 oil pressure sending unit
- R & R Harmonic Balancer
- DRM 84 - 87 J55 brake Adapters?
- 84 Factory Cold Air Intake
- Alignment with differential change
- cam install... advise requested
- Cloyes Question
- Help with heater
- Back to my '89 heater problems
- leather seat skins
- New wheels, spacers or no spacers?
- Ideas to remove front brake rotor stuck to hub?
- Recliner adjuster on sport seat
- light problem
- 65 RWHP for $20.00
- crank case venting problems
- have used goodyear tires is there a way to tell what side they were run on before?
- Fuel/Ratio Gauge
- Synthetic Oil in 94 and tune ups
- 1993 Early vs. late
- Fuel Pump Question
- Tire/wheels sizes for 1990 coupe?
- source for Polycarbonate windows
- dana 44 vette Detroit truetrac now available
- A Budget 400ci build up.
- Refreshing the front end.
- LT4 re-build questions for SCCA BSP
- '85 Heater Control Valve
- XFI Comp Cam
- Paper Clip Method: Code Retrieval?
- Could this work with FI
- Electric water pump on an early c4
- Looking to buy, need help.
- clutch help please??
- lowering bolt size
- My A/c delete for my 84
- awesome just awesome
- Replacing the stock 84 engine
