- Why big brakes?
- Speedometer drive gear
- Help my friend out with this "piston to valve" clearance issue...
- THANKS, Jon, @ FIC & An L98 Intermittent Gremlin of Interest
- Is the 96's TPS Voltage Adjustable?
- service engine soon light
- Speedometer Drive Gear
- piston rings
- Just recieved my A/C delete for LTX from DRM !
- block hugger headers in an 88?
- Help: Headliner on Convertible Top 89 model
- Vats system
- Could someone verify light operation?
- High pitch sound and batt. light
- where is knock sensor? and ESC module?
- 1986 Climate Control delima
- FS: AFR 195 Eliminators
- Ongoing saga
- Zf6
- 86 Alternator Torque specs?
- Disabling factory Alarm in a '93
- how do i reset my change oil lite
- How to tell when Lifters need replacing????
- Starting the machine work on my 400 block. Anything else to do?
- High Speed Misfire Cured after 2 years
- Rainbow marks on opti???
- Want to play a game?
- modified lt1 intake for l98
- Question: Fluid Change in the 4+3
- 1989 C4 Sitting for Four Years
- Heads question
- Broken stud in Hub.. Help
- 90-96 interior in 84-89?
- 58mm Gasket?????
- Cylinder head temp sensor
- Do These Fit on a '85
- digital to analog gauges
- tail light lense removal
- leak between master cylinder and booster
- Overheating!!!!!
- vapor canister
- How many teeth are on a 1990 corvette flywheel?
- 1.66rr
- Shifter plate removal,1991.
- Fuel Rail Pressure Cap
- Where Can I Wire My Heated O2?
- Tak Wire
- Sharing information-Precision Bearing
- Injector removal
- tci TRANSMISSION sucks all the way
- New drag radial
- T56 Conversion
- 20grand ! not half bad
- Time for a new clutch?
- Front tires for '94
- Need some ignition parts
- Wow.. Nice rack
- 92 LT1 A/C Compressor failing. Convert to R-134?
- Issue with car idling at a stoplight...
- Bang for the buck tires?
- magnaflow dual exhaust system
- Should bore my engine over?
- Raising the Vette, What Material?
- HELP! Exhaust Setup!!
- 1996 CE front shakes with top out
- what pressure to run 19lb per hr injectors at to make 24lb per hr ??
- Problem with upgraded headlights-need advice.
- fuel issues
- asr/abs lights plus funny noises
- Interior courtesy lights wont shut off
- Throttle body cleaning
- how do i set up a mechanical fuel pump?
- ooopppsss
- 1.6 Rollers, Best Brand?
- FIC has another happy customer
- Please help, need advice
- i found an ebay ad to delete opti
- Door Panel Keeps coming off
- Cam is retarded...... Degreeing
- Need help tracking a wire. 1991 vert
- Looking for a speedo gear
- Permanent high beam indicator
- Ugh! All That Work—Still Can't Reach Wires!
- head gasket installed the right way?
- Is this a part from my Corvette ?
- Oil leak.. bad pan gasket?
- Drilling a Hole
- Starting problems when engine is warm
- A Strange Occurance
- 1993 6 spd Coupe - HVAC Issues
- Fuel pump wiring route?
- Pulling my Entire Rear Suspension out....
- Low RPM surge after upgrades
- 1990 C4 Exhaust Leak
- Brake job on 94 C4
- Final thoughts on changing old auto tranny fluid...destroys tranny or not?!?!
- How do you remove upper ball joints?
- upgrading to 1.6 roller rocker arms while running oem valve springs, possible?
- Targa Trim Adhesive
- Blowing Bubbles
- Problems after Radiator install
- NEED HELP SYS light what to do to fix??
- Anyone know of any post of step by step of opti replacement for a 94 vette
- 96 LT4 runs terrible after sitting hot
- AC Delco Water Pump Question
- I need you guys advice!!
- balancer looking thing on water pump
- Tire sensors
- Yet another PKE problem
- Fitment issues with 5-785x u-joints?
- Code 15 - Coolant Sensor Connector Location
- Possible big time troubles
- '89 heating and cooling?
- anyone ever see a built in airfoil in the bellow
- Magnetic drain plug
- Injector sizing calculator
- Help ! Anyone With a Service Manual - I Need a Bolt Torque Spec
- Brace for the AC compressor?
- Wheel Stud ?
- Engine Service Light
- LT4 Vacuum hose routing
- header install
- 92 LT1: Spark Plugs
- loose steering
- Zf6 drain/fill plug locations
- brake system question
- Replacing the w/s wiper switch
- LT4 almost there but a bad MAF?
- Emissions help, Please
- LT4 valve train question
- Cam kit
- Torque Specs for Shock Bolts
- Couple header questions.For an 84.
- Brown coolant
- What happened to this engine?
- LT4 running hot with 160 T stat and Hotcam
- installing pumpkin drain plug ...done search?
- Cranking and Dash Display Problems
- roller rockers only on an early 86
- R12 or R134a
- need help with putting my smog back on
- Reposting for help 87 coupe noise
- HELP New Radio Now Cranks But Wont Start!!
- replacing front rims on a 95'
- Chevy High Performance Magazine : RollerRocker discussion time !!! ZZ4 + 1.6s ????
- nuts
- New to the corvette world and car bog or drags on take off
- Search function
- 4+3 overdrive button
- Confused... *suspension*
- control arm torque settings?
- How can you tell a Dana 44 from a 36 by looking at it?
- How hard to add an oil cooler to an ltx ??
- 1988 Corvette OIL PRESSURE WIRE
- ZF6 gear oil change -1994
- how do i put photos in my thread?
- SLP or Vortex intake on 92 LT1?
- Emission Line Routing
- Ignition coil installation, good idea? any tips?
- 12 inch lowering bolt
- Urgent quick question...
- Auto door locks don't work
- Callaway Corvette tour
- Got a problem! Help please
- What's etiquette on modding supercharger to fit L98
- Worried about my PCM4LESS order
- Brake Flush: which brake fluid do i use dino or snythetic dot 3 brake fluid?
- intake Gasket question.
- Strange, It won't turn off
- 90 missing under load at full throttle.
- Pro Flo XT
- need info on alternator relocate for 85
- 86 mpg
- help driveshaft removal 87
- torque specs on dana 36 pinion nut
- LT4 Catalytic Converter studs
- 93 Vette - no power to anything
- Recommended mufflers for C4
- Worth it to port and polish stock L98 heads?
- recommend stroker cranks
- 94 Lt1 - Engine Serial number - where to find?
- 1993 air pump motor
- Voltage readings
- sway bar install questions
- LT4/LT1/L98 Full Length Header-GP by Exotic Muscle
- Reverse Lights Not Working
- Ring and Pinion Recommendation Needed
- Rebuildable C4 Front wheel bearings
- engine oil leak repair
- My oil temperature takes forever to come up???
- A little surprized
- california smogging without precats.
- big mouth Z-51 air dam ????
- Cam question
- 94 REAR wheel Bearing problems
- Buddy wants to race, I have slight mod L98, he has LT1 Firebird
- 700R4 question, please help?
- 94 Heater Problem
- Throttle Body
- Port heads before or after machine work done to them?
- Minimum car height to remove spring for lowering
- Daniel Stern Lighting Upgrade
- One of the worst engine combos ever
- Front Spoiler Brackets-Where Does This Go?
- C4 Exhaust Upgrades
- Horsepower / 4+3
- LT1 Engine Rebuild
- cd player keeps tripping fuse
- BG 44k
- Cost/Benefit Pros/Cons swapping to roller rockers?
- 89 TPI valve retainers
- Pete K. Please empty your P.M. folder
- EWP Gear removal.
- Replacement LT1? A Mystery...
- stinkin 85
- Blew my LT1?!
- Found a great header gasket
- **hot cam kits**
- Convertible Top Question
- 82 rear end
- Cruise Control-Where to look next?
- Shifter on a 4+3
- abs problems
- Considering rebuilding my 4+3 Super T10 with broken first gear
- Trans code for 87
- performance part ??
- Can I get a sticky please?
- 4+3 trans seal
- Adjustable fuel regulator.....
- Need Help Finding Place to Install Headers in SE MI
- Header Install - Weird Question
- Headlight blank offs
- Sport Seat Air Bladder Repair / Write-Up?
- Opti Questions
- N00b Question.....
- new carbotech performance brakes website
- Gears
- Could this be a fuel pump problem?
- bench testing a motor - how to - using stock tpi not carb set up
- MiniRam plus 4:11 gear users!
- How to remove the oil filter mount?
- Hey Guys Question About my rear Camber
- Need some wisdom on changing idler pulleys on 92 LT1
- Question about oil
- what exactly is suspension code FE1?
- Canton Oil Pan ?
- Wanted - crash course in twin turbo set up
- C4 Gathering at BG!!!
- Clutch to the floor!!
- Tire size suggestions needed // 17" 18" Mixed combo ???
