- How fast will a fuel pump fry when running dry?
- Bad Opti?
- Rear quarter panel replacement info
- water pump
- 87 L98 Electrical help please...
- Well, tomorrow's a big day in my build....
- Burning Smell?
- BBK Intake
- Noisy byproduct of 700r4 performance rebuild
- Classic Chevy 5-Speed is aquired by B&M Racing
- Running very rich and other things!
- R-D Racing Cross Frame group buy??
- Head Gasket Question
- Found A 91 Cheap
- roll cage
- 1989 judt doesn't roll smoothly
- 383 LT4 cam?
- Help!!!
- ABS technology - how good?
- Heater Core Part Number Check
- Normal Oil Pressure Range?
- accel fuel gauge
- 1986 4+3 with code 45, then code 44 ???
- ATTN: Electrical guru's
- How long??
- I know which wheels...I need feedback on size!!!
- What valve covers to get(383)?
- Fuel Rails
- C4 Making Tapping sound
- Drags tonight near St. Louis tonight 10/16
- oxalic acid flush - Dexcool sludge
- Ring and Pinion Gears
- c5 steering column in a c4?
- air conditioning removal
- Tilt column for steering, can we just weld that POS in the position I want?
- Fuel pump relay
- Does an LT4 have a keyed crank hub?
- 500chp and up driveline questions
- 96 Erratic Speedometer
- Twin Turbo LT-1 questions
- Melrose Headers
- I Just Want A Good Strong Street Car
- Adjust the cap between frontspoiler and hood
- Copper Coat Spray on Head Gaskets
- looking for members of a ga vette club
- my c-4 light kit progress
- Need info on modifications to a stock TPI.
- 1990 Stock Cam-free
- rocker studs
- Valve seals repaired for $10.00???
- Rock Auto Discount Code
- New best with videos...
- Check engine light
- Finally, a datamaster scan
- ECM and the OD
- Brake conversion C4->C5->C6 Z06?
- Photos please...Lt1 C4's with 17X11 rear wheels and 315x35x17 tires
- Electronic Superchargers
- ABS Light
- Things that make you go hmmmmm?
- whats the biddest nasty cam that will pass emmission on tpi?
- Need PN for ECM cover
- solid or hydraulic roller cam ??
- 1989 stock head and cam spec info wanted
- Moog Ball Joints? Anyone have a good cheap source for them?
- Mini-ram setup
- New best at the local track Friday night
- 84 4+3 still not going into OD
- Electrical Brain Fart!!!
- rear water outlet
- Change oil light? Help!
- Broke the new motor in today (Finally)
- First Post
- removing LT1 water pump: necessary to remove pwr. steering pulley?
- Change heater hoses from '92 to '96
- Help!! Optispark?
- 86 Cold Start Problem
- Cam's in.....Now the assembly starts....
- a/c clutch hub
- Timing cover suggestions?? Please!!
- LT1 intake geeks, inside!
- Scanned my car today: Results
- Intake Runners
- pulled codes on 94
- Exhaust affecting the EGR
- Rear End filler cross threaded
- need help with severe idle missing problem
- Great "mod" for you guys with "perimeter style" valve cover bolts...
- exhaust
- Oil warning light when I brake
- 84 spare tire
- head and cam?
- removing the 9th injector
- High Idle, slow to return to normal
- MAP questions - Block lean cell and voltage reading.
- Is there a unit that can display real time engine data on a Double Din radio screen?
- Removing vanity mirror from sun visor
- which heads?
- Another weatherstrip installation thread
- Intake Gaskets Questions
- Intermittent Electrical Problem
- 87 coolant overtemp - help
- 1996 LT4 engine question
- 1993 bose radio is junk
- Head gaskets 85 vette
- 94 LT1 engine rebuild
- Front end updates
- I love my new Exhaust
- Throttle body Bypass or Cap off Hoses????
- Push-ON Oil Filler Cap falls Off any ideas??
- asr on over bump
- I am not good at drag racing!
- Nail in tire
- Rims
- Airconditioning not working
- WTF is this plug and why is it leaking oil?
- Refinishing a Hood
- removing A/C
- Anybody have pics of mini ram engine
- modifying valve covers
- View Inside an Engine
- Would someone explain open loop/closed loop
- 90 L98 - Stalling, running rough when cold/damp
- hood interchange ?
- Need Help!!!!!
- elecetric water pump wiring problem
- Which Fuel Injectors for stock 88??
- 86L Electronic Climate Control Panel
- Happy Birthday Mr Mojo
- Brake light switch
- Alternator Bracket Torque Spec's
- Looking for suggestions - which injectors to go with Mini-Ram on (mostly) stock L98?
- Cut the air filter cover, Hmmm??
- Starter Replacement
- tire sensor
- what valvesprings do I need?
- Franklin quick change rear-end with independent rear suspension
- fuel pump whining
- 700-R4 T.V.cable Adjustment
- wPA,WV u looking for a dyno tune?
- Comp Cams Rebuilds Rockers
- '86 rear hub play?
- Harmonic balancer diameter??
- what dual valve springs for the 306 cam?
- need help
- HELP. LT4 swap won't start.
- off set differences
- TrePerformance fuel pump??????
- Opinions on cold air ind. "claw" on Corv. 1992?
- block off fuel lines question ?
- Lost keys?
- Shortie style headers on stock 88
- 10 second car owners I have questions ??
- 4+3 tranny
- decisions..decisions..
- ZZ4 Camshaft
- o2 on headers?
- 1993 hard starting in cold temp.
- Fuel rail bolt broke off
- Need to fab up Front Y-pipe: Will these work?
- Which CarSound Catalytic Converter do I need?
- help!
- Headlight will not pop up, has good bushings
- custom wheels
- New Dart LT1 / LT4 Heads
- # 8 plug
- Corsa exhuast modifying
- '89 electronic climate control
- Grand Sport flairs
- Master cylinders for late C4s
- Are an '85 and a '95 gas tank the same???
- 18'' wheels all around
- High Oil Temp - Help ASAP
- AIR Pump Removal
- Emmisions test help please
- engine dies
- spark plug puck
- Fuel Cutoff..
- onboard video from Sunday's autocross
- Headlamp motor won't stop running
- C.A.T. products
- Speedo Gear Question
- anyone know how to fix this?
- Is my FUEL pump enough???
- GARAGE FIND 1990 Vert HT with 384 miles
- need help please r.e oil catch can hook up ??
- LT1 383 Build
- 12" Caliper vs. J55 Caliper. Physical difference
- Pros/Cons of an HSR on my stock motor
- cold air intakes
- dead car?? starting problem?? electrical??
- performance chips
- Moving dead seat track
- Insides of a B&B muffler. Bad or good for high HP ??? (PIC)
- Still Can't Get This 88 To Run Right. Really Need Help
- In need of 1985 engine compartment pictures
- Will this swap make sense????
- Cam computer compatability for a 383
- straight pip??true duel?? x pipe?? please help a soldier out
- Where is the fog/driving lights fuse and relay?
- Wiper arm upgrade question?
- Straight Pipes
- Opinions...What style and size wheel looks best on the C4. Performance counts too!
- hot cam Questions
- valve cover bolts
- 2800 stall converter
- Replacing Oil Pressure switch - question
- Dana 36 gear change
- OPINION-power prog 3
- FMS Injectors no longer available ????
- Anyone converted a C4 coupe to a proper convertible?
- Today I Learned...
- What is this box?
- Glad I had a breaker bar for alternator replacement
- Cannot find PCM4less?
- Newbie ZF Questions
- Pete K.... you out there?????
- Lt1 On An L98 Intake Swap
- emisssions stuff
- Spicer 5-800X U-Joints - No longer available?
- Electric Door Lock Question
- TPI Poor Idle, Questionable AFPR Operation
- Couple Questions
- super ram
- 86 project in the works
- Paint and Body Question
- trans question
- Please tell me I am not looking at a new tranny!
- Lookin at an 1989 with 100k
- Going to coilovers with Penske shocks
- Idle Air Control Qauestion
- "New" 95 C4 - What should I know?
- Which window motor do I have
- Shocks
- Dead in the water
- MSD Opti Question
- Corvette + turbos + sucker fan = cool
- Anyone ever tried Dart 49CC heads?
- Motor Mount Insulation
- Too much cam? - LT1 Intake
- Alternator problems :)
- 89 Z51 w/ limited slip?
- Gears
- Tryed drifting for the first time what do you think?
- Removing MAF With The Blasted Cinch Clamps
- Problem re-starting a 89
- Anyone using this Catco Ypipe-Cat combo
- Happy I Took The Time To Retorque Heads
- 4+3 shifter problem
- limited slip......Isn't???
