- Smoke from exhaust
- Death of our LT4
- Is anybody here running a trans. cooler ?
- How to fix lose dipstick tube
- Engine Service Light Came On in my 87
- Engine Check Light Came On in my 87
- Aluminum Powder Coating of L98 Runners
- Rear Tie Rod Ends
- HP and ET's from Hotcam and LT4 Heads??
- Lowering on stock bolts
- MAF Screen
- what kind of injectors?
- Service engine light!!!
- Catalytic Converter for 96 LT4
- need comfirmation on half shaft
- Lower thermostat temp and earlier fan turn on?
- engine ??
- something loose in front end on 1994 coupe
- Power Steering Pump for 1994
- Rear intake oil leak
- Replacing front spring
- Max lowering
- Crazy timing advance on L98??
- Timing indicators ? worth it ?
- 1994 LT1 Long block options?
- 1994 intake manifold instructions
- 1/4 mile time, new injectors needed, redline?
- 1994 C4 Tranny fluid
- 1985 auxiliary fan switch?
- WTF is wrong with my horn now?
- Msd optispark connector
- 93 drivers window R&R
- Weight of LT1/4 Valves??
- rear main seal
- Door release rod.
- could a bad IAC valve stop it from starting?
- Ls7 lifters in GenI block?
- rims
- Beautiful C4 REAL Carbon Dashes *PIC*
- where is the fan switch on a 1990
- Changing Fuel Filter
- Porting an 84 xfire intake manifold!
- Engine harness question 1990 L98
- '93 LT1 vs LT5
- LOL to a exaust suggestion
- help, cant find air pump hose on 92 lt1
- LTX rockers
- Rear hub replacement
- runs bad
- Good mods
- Need valve guides
- Idle with new Cam?
- Rattiling noise
- Oh man I messed up BAAAD
- Water pump
- Ecm?
- Best rocker arm set to go with?
- What spark plugs for 92 LT1
- Idle around 1500
- CONVERT?! 92 a/c from r12 to r134?
- std or high volume oil pump.
- wheel speed sensor abs
- Corvette Brakes???
- Tach on 91' irratic?
- 02 sensor
- door courtesy light switch
- Steering Racks
- Shifter for a 4L60E
- wheel adapter question 84 c4
- tune me in please
- Mobil 1 & Corvette Spec.
- Spark Plug wires for a 92 LT1
- Sunvisors
- brakes acting weird
- Budget crossfire build!
- 3rd Brake Light
- Lifter Pop and Hiss
- Canton pan
- MISFIRE Comes and Goes
- LT1 TH400 Update (dial-up UNfriendly)
- air pressure sensor
- Air conditioning 89-C4
- 88 TPI vacuum problems
- Precision brand wheel bearings
- Trans Fluid Leak
- Fpr grrr
- c4 noise from front wheel
- 1994 vette valve cover gaskets
- Removing Injectors
- code 41 intermittent 86 Vert
- Battery Drain ... Again
- Brands of Gaskets/Seals?
- Help checking a short in headlights?
- Intake gasket replacement
- exhaust questions headers & magnaflow system
- Negative Battery Cable
- assembly of a 2000 ignition swich
- Trying to install engine with 700 R4 still in the car
- 85 corvette roots type supercharger
- Overheating
- ZF Transmission noise
- 409 SS Mandrel bent duals
- Air Pump Delete
- Won't start - left stranded
- Mystery Leak '90 L98 Solved
- Best Mufflers for Straight Pipes? Bullets?
- Dana 36 Capacity...
- Looking for front brake info
- 84 Window switch
- A/C was taken off by last owner, what would it take to put it back
- replace shift boot 4+3
- Coolant is Cool...Oil is 300 deg? Assistance Please
- Whats that round thing that screws into the zf6 and plugs into the skip shift called
- Sloppy gas pedal
- 4-3 clutch pushrod q
- Air always blows from defroster vent
- 91 Injector ?
- slow up top?
- Problem with my 1988 C4
- Engine Smoke
- changing rear end, changing wheel bearings?
- LT1 383 Cam Selection
- 91 vette error code
- 1985 Vats?
- A/C Compessor Rebuild
- 1985 coolant leak
- What is the best kind of engine gaskets to use?
- how do you remove the small gear off headlight shaft on 84 vette
- RSD Now Introduces The C4 Line Lock Kit!!!!
- Holley Stealth Ram
- Problem with the combustion leak test
- Transmission Help !!!!!!!!!!!!!!
- bruised, aching, dirty as hell, the battle is over
- spontaneous high idle
- '84 wont start when hot.
- Brake Question?
- NEW! C4 Brake Cooling Spindle Ducts – Special Introductory Price
- Low Fuel Pressure??
- Are Duralast parts form Autozone a smart way to go?
- engine temp
- Tach on '91 does not seem to run right?
- Nov-Dec 2008 Summit Catalog
- TCC Shutter, Solenoid replace?
- The latest on the problem when hot
- TPI firing order
- Spark plugs and richness
- Will these two pieces work together?
- Power, lights, click, no start :(
- Trip computer buttons don't do anything...
- Horn Question
- W T F is wrong with these roller rockers
- Removal of Spare Tire & Rack
- Asr problems
- No power to injector, causes?
- Opti-spark 1 vs. 2??
- Replacing Opti should I also replace?
- Tokico shock update
- 1996 coll ed LT4 inop trip monitor circuits
- fuel press regulator problem
- air mix/temperature door?
- Quick newbe motor tech question
- corbeau A4 wide in a c4- can it be done?
- Coil over shock mounts
- Digital Dash
- 1986 rough running
- 1984 won't start when hot
- pro flo xt intake?
- Wrong control Arms???
- Air/Fuel Gauge
- Looking 4 headers that don't rust and Fit
- StealthRam 398 - 10.59@129
- Whats the oil capacity on a dana 44
- 1985 c4
- Passive Lock System ***
- Loose dash on my 86
- What part number?
- Changing Differential Oil...
- Front Spring Retainers Cracked
- Infl Rest Light
- IAT Connections - 1989
- 383 with exhaust system in place vibrates - with open headers is smooth???
- My fan never turns on need help.
- Ignition coil module replace: use GM supplied heat-sink or store-bought stuff?
- Difference in pre/post 86 heads
- Thinking of changing gears with D44 and my 396LT1
- 90 coupe
- '96 Vette Power Window Question
- Shop Press Questions
- Head job
- Raptor Shiftlight keeps blinking
- Replacing 1990 L98 with 1987 L98.
- 86 C4 Troubleshooting error code 15
- Engine rebuild vs zz4?
- Best price on a 96 MAF
- almost stock 86 l98
- Rear Wheel Bearing Clarification
- Lope, rough idle= IAC....
- in. lbs. of torque vs. ft. lbs. of torque
- Passenger Bank Runs Very Lean
- TPMS Disable?
- New stroker motor bogs down at full throttle
- L98: Possible to replace front cranksaft seal with engine in car?
- Pushrod length needed
- onepantera
- Fog lite operation
- 87 C4 coolant loss
- Brake Lines
- '92 Steering Column Replacement Gremlins
- Slippage
- ZF fill hole bolt socket
- MAP operation??
- Ebay Motors Discount
- 85 window speed ?
- Funny post have a laugh :)
- 95 LT-1 auto w/sulphur odor I'm at a dead end
- Big misfire after injector swap or something electrical.......
- the MOTHER of all problems... hood release!
- Rough Idle & Stall
- Manual Fan Switch
- New Thermo Switch JUNK?!?
- flywheel recomondation
- Removing Plenum - How to get to Torx Bolts
- Bleeding Clutch Questions
- Where does this bracket go??
- FE1 car what would you do improve suspension?
- Anti-Lock Light Still On
- Are "Factory Reproduction" wheels DOT approved?
- Close call
- 96 LT1 Real time Damping
- Whats that part called again? Can I delete it?
- GM Part Number?
- Q About fuel pump replacement on '96
- LS1 springs?
- Front or Rear Wheel Bearing?
- Newbie - servicing my DN 4+3 - advice?
- Look at this engine, should I NOT buy it?
- Noise after new drive belt...
- 4+3 OD help
- 85 engine specs please
- Which shocks to purchase for my 1990 C4 Vette w/ 383.
- 1986 C4 Aftermarket speakers??
- Clutch question.
- atf for c4 1987
- 1993 corvette security system
- Corsa Vs. Billy Boat
- Power Steering Issues
- coolant temp too high
- 88 C4 auto transmission shifting problem
- Wires On! Piece of Cake!
- Whats next?
