- ABS Light - Fail inspection?
- ECM Install
- oil dip stick anyone has a opicture of it mounted?
- New best et on motor
- Anybody use a cone air filter on there l98?
- drill hole in dist. cap for more power?
- Pulled antenna coax out if the connector
- Targa bracket question
- tranny problem
- does a 1990 have addition a/c braces????
- Need new injectors for 1989 any recomendations??
- Horn Problem
- Video/Sound Clip...Need input....
- Rocker Noise
- Question on stock 89 exhaust
- Lowered - correcting bump steer?
- Heads Q
- cross-drilled rotors
- Both Fans On
- Lighting Question
- 1995 Vette having problems starting after cars been running, any suggestions?
- Electrical system completely dead
- Cheap for my c4
- charcoal canister vacum hose routing 90
- fixing shifter indicator 90 auto?
- Transmission Sensor Leaking
- why is my anti lock light on?
- LT4 Cam upgrade
- Inflatable Restraint Light Question
- C4 to C5 non-GM special bracket kit for front C5 calipers
- I just ordered Valve seals and was wondering if I should change rocker arms
- Burnt fuse-able wires (links)
- car not running right
- I want to polish my tpi. Any suggestions?
- picking a cam
- 1996 C4 standard front brakes, 12" or 13"
- 1.6 RR's
- 1995 6-speed shift knob
- 1992 valve cover questions
- ? Weight difference in 96 GS OEM wheels vs repros?
- 89 FSM question
- Front end shake on a '96 lt4???
- New ZR1 performance parts!!!
- Any affordable C4 Dana 44 re-gear service for ratio change?
- Location of Number One Plug On Distributor
- seems to run way hot manifolds
- Do to overwhelming demand we will continue to shower you with 20% off through April!
- 1/4 mile Guess...
- 1/4 mile Guess...
- Power to the ground
- 1996 Lt1 - Door Handle Stuck
- Frisbee Removal
- Will 1990 convertible hard top work with..
- LS2+ZF6 trans in a C4 questions.
- I cant the new motor to run right yet, looking for Idea's..
- Cant Get It Up!!
- Specific Info on 1995 Vette Engine
- Adjustable Fuel Pressure Regulator Needed with New Mods???
- Injectors on left side engine bank don't work. 88 TPI vette
- 700R4 binding/resistance?
- Water pump test?
- electric WP relay failures
- Pressure tubes, where?
- Corvette America's suspension parts, ball joints, tie rod ends
- Does this Exhaust Hanger have rubber insert
- 92 strange dash problem
- JBA, Pacesetter shorty headers are they worth the money?
- low tire pressure monitoring?
- Has anyone programmed their converter to lock up at WOT?
- tpi manifold install gone wrong
- 9-3145 Timing Chain on 1993 Vette???
- keeping sill protectors in place
- Vaccume Lines 1985
- C4 rack & pinion, inner tie-rod replacement
- What re-program chip for cooling?
- LT4 Tensioner Pulley Replacement Question
- FX3 Shocks- where to buy?
- PS rack, (flush)
- How Much??????
- dash light and gauge back lighting, color change
- New member with a problem
- Valve covers?
- New Lower Carpet Prices 1984-1993
- my 1989 won't start
- Stock 400 crank
- Pre-airbag steering colum help!
- lt4/lt1 valve springs question
- Hood assist lift, anyone have a video of a new one installed?
- no start after rough idle question
- Is my vette a Z52 with 3.07 gear?
- Flowmaster muffleer question
- Lug nut replacement
- type of brakes for street use on a 95
- Changing valve springs and seals with the head still on the block in the car
- Car doesn't roll backwards/driveline friction?
- how about a bad odometer question
- Question on 19" wheels
- They are going to crush old vettes...bill just passed,
- will my 2.59 carrier Dana36 cover fit my 3.54 carrier?
- Advice on side Yoke /pumpkin installation
- ASR problems
- Rough Idle on a cold startup
- looking for heads/cam combo for the crossfire
- 1985 Interior Lights
- How much power can a 2 bolt handle??
- What is a super ram worth?
- 160 t-stat in my 94 lt1
- SES Light Code
- Astro Tops -- are they at least "OK"?
- 1989 TPS question
- Bosch III install (LT1)
- Suspension Bushing Options
- interior lights staying on
- front bumper rivets, where to buy them?
- A/C Delta "T" Question
- Can a code scanner cause an engine problem?
- 383 build - Ported "stock" heads or AFR?
- Interior quiestion
- Digital Dash problems
- Proper T45-Torx Bit For Rear Hub R&R...?
- 383 Stroker oil pan? Canton 15-240t anybody will they clear headers
- SLP Runners
- Heater water shut off valve
- L98 water pump bolts
- Odd A/C performance..
- Recommend a cam for a stock L98?
- 1985 runs rough after full tuneup
- Smokey exhaust
- Code 22. Houple seconds after start up. High idle.
- holley stealth ram help?
- Lt4 cam
- Will these bolts work ? (lowering)
- whats the sensor on the fan shroud for?
- How long to swap a LT1?
- Anyone Running Dart's LT1s?
- Do I dare ask this question
- My '90 IT LIVES! .....startup vid...
- LT-1 bolt-on dyno results
- 4.10 gears
- HID headlight Install - How To
- 1988 c4 won't start. security problem?
- 6spd ???
- Nice calculator
- New head bolts?
- A/C Compressor rebuild?
- Lug nut torque?
- Converting to Z07 Suspension
- 93 need help re: oil pressure sender/sensor options
- Strong smell from front
- Where does this go on a 1991?
- Dangerous C4 Clutch Problem
- If you thought a solid axle in a C4 was diehard
- Brake Caliper Question
- i hate my neighbor and his fx3
- first problem...Vette cutting out
- Optima Batteries for C4
- 1984 Lockup Vacuum Switch
- rear cliking
- 85 wont start.....
- Code H15--
- custom made rear Y-pipes anyone ever done it?
- Fic injector :)
- Faulty Instrument Cluster?
- valve adjusting?
- Is there anyone in Central NY that can fix a C4 with computer problems?
- Need advise with tune up problem
- Hooker Super Comp fitment...
- teflon washer
- VBP Height Adjustable Front Spring
- search dotnt work
- cat removal?
- Good book to learn about corvette fuel inj.
- Fuel tank removal
- 85 Oil pan Gasket
- C-4 Calipers Sticking
- Strange 'surging'/misfire? problem after replacing plugs & more
- C4 LS2 or LS3 swap
- motor and Tranny swap
- 93 LT1 Coil check info needed!
- Source for instrument(gauge) panel overlay?
- Adjusting TV Cable to lower shift point?
- removing top dash cover ?? help
- Rough Idle on a 1991
- 700R4 Tailshaft
- Annoying noise coming from the heads !
- Clutch Replacement Cost??
- Gas Gauge Always Full
- L98 TPI to Carb
- Just Got Back From TPIS
- Heater Temperature Door Erratic
- best valve covers
- Question about "128" alum heads - studs and guideplates
- leaking oil
- Leak in brake lines (PICS)!!!!
- main cooling fan
- AHH stupid trouble code...
- Collapsed Cat or Pre Cat 1990 L98 ?
- AC Pressure check
- brake lines
- FIC Injectors
- Upper ball joint, removal of rivets
- Key fob
- Throttle Sticking
- Help! Drivers side headlight Out.
- CSR EWP wiring???
- spark plug wire routing
- Lowering Retainers
- Balljoints and Tie-rod ends...cha CHING!
- LT4 knock module in an LT1...?????
- lt4 hotcam swap
- Dizzy gear questions. 1990 L98
- Valve cover help needed....
- steering click
- where's a good cheap place to buy c4/c5 brake adaptors and abutment brackets?
- 4.11 gears and others
- What is a good unit to buy for checking codes?
- Best unit to Buy for checking codes
- Pinging problem solved.
- Replacment ECMs....will they work without being flashed?
- Help build my LT1 (going in faster than planned)
- NEED EM Longtube exhaust routing pics
- Racers; Head exhaust flow v cam?
- Digital dash parts.
- Daytime running lights
- Rough idle again!
- FAST EFI XFI Engine Management System GM Chevy L98 TPI
- 91-96 rotors on a 1990? will they fit?
- painting the vette
- L98 timing chain problem with PICS, please help
- What could this be??? rough idle when hot outside.
- 87 wouldn't start warm
- LT1 Engine code Galore
- Axle Nut Size?
- Polyurethane bushing into the sway bar?
- new exhaust tips
- Yepppee; New Vigilanti 2800 stall is in!
- Anyone ever remove the CCM from a C4?
- 95 vacuum hose disconnected - can't find it's home
- 92 coolant temp sensor ?
- Novice at C4 and Need HP Add On Advice
- L98 Acting Up
- 93 auto help
- Replacing Clutch Master
- Comp cams XR288HR
- ??? - Catalytic Converter Air Tube
- requier cam?
- my exhaust delima
- For the guy who needs bigger than 22 injectors. Check out these
- engine code
