- 1995 mild stumble at acceleration
- If it ain't broke....
- Replace Antenna Mast (w/o removing antenna)
- Questions for those who've had FX3 shocks rebuilt/re-valved...
- T-56 Swap Master Parts List
- 90 Center console harness routing
- Torque Converter Lock Up
- 86 vete rich air fuel mixture
- 86 vete rich air fuel mi ture
- Smoking vents!!
- 96 LT1 Power steering Fluid change
- 93 Lt1 missing backfiring loss of power.
- Don't use K & N air filter? Huh?
- Light Bulbs?
- reading codes???
- Rebuilding Suspension
- early c4 to late rear knuckel interchange?
- Oil leak inside passenger side
- Clutch Hydraulic Question
- high idle 93 .!!!!!!!!!!
- Stock Bottom End Capability
- Saturday Morning Musings--- Thermostats
- reman ecm seems to have done the job - BUT.....
- removal of instrument panel trim - 1996 corvette
- New Best ET:10.21@137.71
- Installing Upgrade Relay Wiring
- procedure for breaking in a new motor? - use regular oil?
- front right head light - gets stuck flipping up
- AFR Heads for stock L98
- Taking out the Cats on a 1992
- Fuel Pressure ?
- 1995 Pulled Codes ??? Ping
- 1993 just dies !!!
- rear clunk
- 1996 Manifold Air Temp sensor
- 1991 RPM Gauge Problem
- Thermastat '85
- Anyone using an aftermarket steering wheel on a pre bag C4
- Does anyone know where to disconnect the factory alarm...
- 383 Stroker Opinion
- 87 vette ( 400hp)
- Instrument gauge cluster differences for transmissions?
- Relocating Oil Pressure Sender L98
- 84 vette heads straight plug or angle
- Trick Flow top end kits
- ZR1 sway bars
- fuel rail covers and after market valve covers
- Beautifying 1995 LT1 muffler tips
- Cruise Control Clutch Switch Adjustment, How?
- Code 33 and 34
- N20 shimmy in rear end assembly ?
- 700r4 transmission governor cover
- Harmonic options
- Proper Operating Coolant temp. 86vette
- Digital dash lcd out
- wheel painting?
- Dana 44 installation
- Can't get ASR to turn Off
- Engine Problem
- Small orange spring from TH700R???
- Hood badge replacement
- got another 86 vette
- alternator? - low battery voltage issue...
- I think it is the opti again..... can I get an amen?!?!
- 1994 LT1 Cooling Fan Temperatures
- 3 dyno charts, NA, juice, boost, 2 timeslips, from one lt1 and one dyno.
- 1988 won't start
- 92 few questions about history and maintence
- D.U.I. or MSD?
- lets stop this motor building madness!!!!!!
- autocross alignment done
- Cruise control and shift indicator issues
- Change my coupe to a convertible
- Oil pump on 84
- Help Identify Exhaust Please
- D36 to D44 swap question
- 1996 cranks but surges and,stalls, and won't start
- headers for straight plug heads
- Distributor ajustment wrench tool
- door glass index
- 1995 Pinging
- Looking for IGN Tester From the 80's
- Runs bad after engine warms up.
- 85 Pulley changover, can I get some info on this? here?
- New Fuel Pump Pressure Question
- 1996 Corvette won't start, kicks back
- Frustrated at Me
- "INST" fuse keeps blowing
- 86 Brake issues Hard pedal no stop
- Speedometer Cluster
- Stuped Mecanic Timming Issue
- Waterpump
- headlights will go up, not down...
- need help with c4 headlight and running light wires
- Balancer
- To good to be true?
- 1990 C4 Problem
- Is this a D44 or D36
- cant get it too take fuel...
- new. distributer which one? ??
- FX3 Working or not?
- Which Type Of Runner???
- 383...problem
- Couple of 1985 motor questions
- Blowing some smoke, advice?
- Brake pads, How do they go on?
- Wanted: Pics of LT1/4 with 8.5mm Spark Plug Wire Looms
- My A/C Contro, module is gone nuts!
- No alternator power with ¨D¨ geared.
- ZF Transmission and "whining sound"
- 1987 ignition/distributor problem
- car loses power when warm.
- Sammy's C4 Dana 44 Buildup /3.45:1 Gearset
- Car not running right after battery jump.
- Buyer beware!!!
- Need C4 wiring
- Rocker arm studs, which one to use?
- What does a C4 fuel pump sound like?
- 1984 Corvette Performance ?'s
- Pivot pin part #
- Vibration problem
- Power Steering problem 94 LT1
- Timing chain choices, I need some help
- no start, no codes
- Finding rear gear ratio in an 84
- Hard starting, code 15, help needed
- Aluminum power steering reservoir, does anybody make one?
- Pinion Depth Gauge recommendation
- New Corvette Owner How do you jack it up
- I need help !
- please help
- service asr light !!!
- Narrow a C4 rear end?
- Gear Shift Knob
- iac 1984
- 85 C4 Engine Bay Mods/Improvements Question
- Headers
- Track Day Tires
- WARNING: SawBlade Center Caps at the Track
- Steam coming out of vents
- Rusty brake rotors from Corvette Central
- Budget 383 build with leftovers
- 87 RT Cooling Problem and Clicking Noises
- Cruise/Turn Signal Lever Replacement
- 85 Vette huge problem
- 383 engine swap question
- Digidash LCD change and color film?
- ZF6 transmission noise with no throttle
- Analog Gauge Kits
- 10.38@137 video
- two questions, timing marks and fuel pressure
- 92 vette h64 code
- '92 LT1 is Vaccum hose missing on MAP????
- FIRST Injection and EGR for '88
- Need advice on 3.55 differential
- 84 with 96LT1 fuel pump question
- Mechanic Recommendation Minneapolis
- Royal Purple Synchromax?
- rear toe rod bushings worn out?
- Motor Mounts
- L98 coil and ignition module
- Weird Problem with a '93
- 1994 c4 check engine light and ltpws
- 92 LT1 block the same as a 96 Caprice Police Cruiser???
- Engine suddenly dies.
- ZZ4 in "85" ???????
- speed chips
- Fuel Pump Replacement 1990 C4
- Rear Coil Over Shock Sugestions on C4 Solid Axle Conversion Home Brewed
- 92 LT1 Clutch
- hard braking pull (both sides)
- C4 PEK and IGN KEY
- New fuel injectors/MPG readout now reads correctly
- More horse power question
- engine comparment harness availability?
- car wont turn over and sounds wierd after manifold swap
- C4 stub shaft True Arc Snap Rings discontiued by GM
- New suspsension?smoothing out ride
- Sway Bar Size???
- change to toe in the hubsWhat cause rear rotor
- Rear Hubs
- How low should I go
- Did something wrong!
- EFI-ECM harness changes
- Cant get my pilot bearing out with puller
- Ferrari 458 vs. Corvette ZR1 vs. Nissan GT-R
- hi flow water pump - who makes a good one?
- Exhaust gasket?
- Growling after I let off the gas. Please help
- Werd starting problem
- 89 runs poorly
- Need some desperate help. Car dies sometimes...
- Lazy eye (headlight)
- She's Up & Runnin' But.....
- Any easy (er) way to change out air blend actuator???
- C4 - Rear Suspension - Dogbones
- Stupid Headlight
- Energy Suspension Poly spindle rods/torque link bushing questions.
- LT4 intake valve stuck
- fixed . vat. deleted chip / pcmforless !!!!!!!
- air conditioner
- EGR leak Again
- Retarded Timing Issue (I think)
- C4 Vacuum pump
- Head gasket replacement in 89
- testing coil on 93 LT1
- L98 Recurring "Off the line" stumble...
- Dana 36: Richmond Gears vs. Randy R&P (Yukon Gear)
- coilovers?
- Help out a C5er. Remove tail light assembly
- auto lockup concern
- Exhaust question, resonance
- Dynoed the 89 last night
- Which trans fluid is everyone running
- Freon 12 A/C longevity 1990?
- radio problem
- 421 dyno run!
- Use of recirculating ATF in 4+3 T10 transmission
- rear lowering amount ???
- Shuts off @ WOT ! HELP PLEASE !!
- Identify a ccm/bcm part number.
- Fog light bulb for a 92 Vette?
- check gauges/Fuel level sensor
- wierd brake problem
- 85 corvette - steering noise
- Starting Problem - VATS?
- 93 A/C programmer
- 113 heads
- Ticking head lights but they still move
- shifting problem lt4
- 1985 700r4 to 4l65e?
- 85 corvette fuel problem.
- 93' Sometimes doesn't start
- Passive keyless entry problems
- 1985 tach lighting up but not working!
- Open Air Cleaner Lid
- 1986 seats
- Linkage Problems no 3rd or 4th gear?
- Low oil pressure and more
- what is the best after mkt cold air intake for LT1
- 12 volt distribution block
- Lower rear suspension
- car will not start
- Cags zf s6-40
- Grind noise under load.
- What is dual removable roof panels?
- Transmission Problem
- Electric Water Pump into 85 corvette
- Stiff, Stubborn Top
- New injectors/cold start problem/no rail pressure
