- 6-Speed Transmission Fill / Drain Plug Tool?
- Shocks
- Car wont start out of no where 6 days after wires/plugs changed
- Replace lifters and timing chain same time??
- Starter Gurus Please help
- What the heck is it???
- lt4 vs l98 valve springs
- Edlebrock heads
- Water on Driver and Passenger side FloorBoard
- New 3.54 gear.. how fast am I going?????
- Need a little help :(
- gear lube
- coolant loss
- stock lt4 rockers with cam swap?
- Start then die issue
- Need help with part #for oil press sending unit. Dealership cant help.
- Wiper Blades hood clearence?
- Shock Removal
- flywheel/clutch advice needed.....
- Adjusting Windshield Wipers
- Gas Gauge not reading
- Upper wheel wells
- 1995 Vette code 36 which is opti do I just replace cap and rotor?
- My 1986 need's a motor
- Fuel pressure
- "vette" article
- Dusting off the '95 - Fluid Capacities?
- Ever see a Cold Start valve do this?
- Using the Prestone back flush kit: good or bad idea?
- brakes questionable on a 90
- Bad Engine Stumble After Leaving starting Line
- Any brand name front poly bushings not to buy?
- Indicator light burned out
- Priming new ltx engine
- Battery drain at 2.1 amps, fuses pulled, etc. Ideas?
- Launching my C4.............
- need help 91 vette
- C4 hood opening tool...any good?
- Does fuel injector o ring size matter
- 1986 TPI 6-speed conversion Which Flywheel?
- FI numbers
- 88 anti-lock brakes
- Fuel Pump Help Needed.
- whats the position of your bumper bolts on the frame rails?
- 86 rocker panel
- 12" lowering bolts
- Turn One power steering pump
- Lt1 advice needed for replaceing opti spark
- Antenna Quite Going Up & Down
- Finally done but.....
- 90 l-98
- clutch problem
- Is there a AC consensor?
- Unobtanium, front timing cover for lt4
- 90 Vette-LS3 engine
- Oil Leak Help
- For those with PROFORM rockers watch out !
- Temp Gauge Transmission
- LT1 rebuild advise needed!!!
- does cat size matter??
- C4 Fuel Pump Assembly Sale
- Where to get a cheap replacement cam?
- Any tips on removing/installing engine?
- Crane's Out Of Business
- L98 No start problem
- Sweet! I think I might finally have the car running right and it catches on Fire.
- Need Help With Intake Install
- info panel
- oil pressure sending unit, what happenes when they fail?
- Silicone or not
- mass air flow sensor code
- EFI to Carb
- Cam and tune
- Cold Air Intake for 91
- Edelbrock Intake Install (little long)
- C4 Brake Non-Power Brake M/C info needed
- no power/ hard starting? fuel line question
- Thought my opti died last night
- 406 with 4+3 trans
- Frankenstein SBC with LS Heads
- Loose steering column
- 1990 C4 Horn Problems
- splicing/soldering a heated 02
- Headers for LT1
- air conditioner controller problem
- sys blinking on the dash?
- Brake Problem
- 96 lt4 won't start
- Whats the regular temp for a 84?
- vibration over 60 mph
- Rocker swap dyno results
- Mat sensor
- Will wheel from a 03 z06 fit
- C4 aero body parts specific to racing
- Another EFI to carb conversion question
- 1985 antenna limit swtch tests
- What size line wrenches do I need?
- Difference between 87 and 90 injectors?
- Third Brake light and back up lights not working
- Could I mount these shocks...
- Will Crane gold 1.5 s/a narrow body roller rockers fit edelbrock 4246 valve covers ?
- Optispark flooded by the dead waterpump
- Roller Lifters?
- 89 Vette Oil in the Radiator and overflow
- Building a 383. I need your help
- Any experience with Spicer or TRW ball joints & tie-rod ends?
- Great news: Half-shaft and spindle destroyed!
- LT Hedder Clearance
- Coolant overheating, many tests done, unsure of cause.
- Which one is bigger?
- Would This Exhaust Setup Work???
- 95 LT1 opti hoses (which is which?)
- Dana 44 center section interchange...?
- Sealant required on 94 WP bolts?
- Anyone running Borla catback #140082 the newer "stinger" type?
- what type of gas and engine oil
- ARP Header Studs - Opinions?
- Custom Ground Cams - LSA and Duration Spreads
- relocation sensor
- Got a Cam!?
- BBK Intake?
- Smaller diameter balancer?
- Throttle position Sensor
- Thought I was done, NOT! Pics
- ABS Wire harness
- Exhaust manifolds vs Block huggers
- mustang dynometers, what do they correlate to on a dynojet
- Where to buy correct motor mount 85' C4
- Miniram/LTx intake cfm flow #'s.
- Where is the easiest place to put a kill switch in?
- Camshaft???
- Window
- Anyone know where to get opti and how to put in 95 Vette?
- Had my intake manifold gasket replaced now i smell exhaust fumes, whats gone wrong?
- I will buy you lunch if you can tell me what my freakin problem is on my C4
- Headers next to worthless in some cases
- Interior Lights Not Working Correctly
- Need some advice......
- An Intro to our project car, Stage 1: Chassis and Suspension
- Chambered Exhaust Systems?
- Electric fan switch
- Lets Talk 383 Combos...Scat VS Eagle VS ????
- 85 clutch rebuild on a 4/3 Transmission
- MAF sensor gone bad???
- valve adjustment ???? timing??? 90 vette
- 90 cruise control module removal ?
- Serpentine Belt
- C-beam plates
- way to bypass reverse light/ directional fuse?
- 1993 Emission/PCV valve question
- Need lots of peoples opinion
- flushing coolant system
- R.R. and x pipe advice
- whats this? supposed to be cracked?
- Heat always on
- Another 1.6 Rocker Arm question, please be patient with me.
- 96 LT4 Cranks but wont start
- Willcox C4 Carpet Sale Now until April 30
- clutch pedal has some flop?
- 1996 Antenna
- Fuel tank depth?
- Rear wheel bearings - puzzlement
- will a cheaper magnaflow suit my car well?
- Can I re-pin a connector
- The Radio Blues
- Spark plug wires
- Can someone help with these codes car won't run
- intake manifold gasket replacement
- Fans always on?
- Replacing shocks
- 96 lt4 manual trans removal
- Fuel Pump relay Location on 1991
- Tech advice on suitability required
- Rearview Mirror Rattles and Droops
- Starting Problems
- Replacing torx bolts on intake manifold side
- Magnaflow Cat-Back SS--CE LT4 Update
- heim joints on rear control arms & camber rods
- Need advice with search function
- Need help finding part number for headlight control unit
- 700r4 swap
- cam lift vs rocker lift
- Need help selecting torque converter.... <-- click here :)
- 1985 finial (ball) on top of antenna removal
- ECM needed?
- Tire recommendations/opinions
- Big sway bar blues
- LTX shootout
- Valve cover torque specs?
- 1 tooth off?
- Difficult Cold Start
- Paint Body of '89 Vette
- Fuel Injection problem // Big misfire pt. II // TPI test morning
- I feel sorry for the dealers, but...
- Mass Airflow (MAF) Sensor
- replacing calipers are caliper mounting bolts one time use?
- CD install on a 91 bose
- In car video of my 85 w/383 six speed...take a look
- 90 Corvette Air Bag Code
- Gauging Interest in "BIG" CID LT1 Block
- Who's running Mickey Thompson ET Streets?
- Super Rich and no headway
- 1990 that idles at 1500rpm what could be the cause?
- Rhino cost ss sill covers
- Transmission Cooler Size
- What is the difference between ceramic coated and thermal coated headers?
- 1986 Z51 Won't Start
- 1985 antenna mast replacement kit
- hood leading edge to bumper gap ???
- ABS Light - Fail inspection?
- ECM Install
- oil dip stick anyone has a opicture of it mounted?
- New best et on motor
- Anybody use a cone air filter on there l98?
- drill hole in dist. cap for more power?
- Pulled antenna coax out if the connector
- Targa bracket question
- tranny problem
- does a 1990 have addition a/c braces????
- Need new injectors for 1989 any recomendations??
- Horn Problem
- Video/Sound Clip...Need input....
- Rocker Noise
- Question on stock 89 exhaust
- Lowered - correcting bump steer?
- Heads Q
- cross-drilled rotors
- Both Fans On
- Lighting Question
- 1995 Vette having problems starting after cars been running, any suggestions?
- Electrical system completely dead
- Cheap for my c4
- charcoal canister vacum hose routing 90
- fixing shifter indicator 90 auto?
- Transmission Sensor Leaking
- why is my anti lock light on?
- LT4 Cam upgrade
- Inflatable Restraint Light Question
- C4 to C5 non-GM special bracket kit for front C5 calipers
- I just ordered Valve seals and was wondering if I should change rocker arms
- Burnt fuse-able wires (links)
- car not running right
- I want to polish my tpi. Any suggestions?
- picking a cam
- 1996 C4 standard front brakes, 12" or 13"
- 1.6 RR's
- 1995 6-speed shift knob
- 1992 valve cover questions
- ? Weight difference in 96 GS OEM wheels vs repros?
