- anyone rebuilt an OD unit?
- 1991 vette L98 auto scanner
- Front brake vibration
- Intake plenum and runners-which is stock?
- 1991 vette L98 6spd problems
- Track times for the 383/TFS heads/Mini-ram
- Operating Temperatures for '89
- Winshield wipers wacking back of hood
- Aftermarket gauge company!!
- 1990 temperature
- Random Miss....
- Digital Dash Dissasembly Circuit Chared (w/pics)
- Red Alto clutches
- 87 Battery drain and Pulse in the dash
- Performance question
- Coolant Temperature Gauge Failure
- major pain
- Optispark Replacement - DFW
- OBD-I Code Help
- Hookers are on
- lt1 questions
- Cooling fans not working.
- Injector problems and more...
- Plastic vs metal blower fan
- Popping sound after suspension rebuild
- heater control valve
- help on TH400 tranny needed
- Rear End Lube
- new vette lookin for a tune
- Cost to paint front bumper, hood and gills?
- Calderone's step by step injector swap video guide !
- Turn key off, car still runs??
- It is about Balance...LT4
- Sanding rubber spring ends to lower front.
- 1990 theft deterrent system problems
- Oil Pan for 383?
- 1984 Engine Replace
- Question, Shimmy at 25 to 32 mph and 55 to 65 mph
- Need HyperTech programming - Dallas TX
- carbon fiber roof skin
- 1984 speedometer
- Question about a bad brake booster
- 1995 Coolant Leak Right Side of Block
- ZF Transmission Question
- Clearing Codes
- Posting Pictures
- Alternator Question
- Bad heater core? '91
- fuel pressure gauge
- Lowering Front: Sanding Bushings
- rear suspension problem?
- Muffler suggestions for true duals, 7 months and the cases broke
- '94 Emergency Brake
- Electric Gurus step in!
- 1988 TPI Smog Delete
- 2.5 inch magnaflow y pipe does not fit
- 1990 - trouble shooting brakes - ??? and a little input
- Auto Transmission Question
- the Fattest tires on 1991
- injector question
- Infl Rest - Still don t understand?
- 383 LT4 Piston
- MiniRam users with simular builds.
- Tpis roller rockers
- Crossfire cold air intake
- A friend of mine just bought this shaft mount rockers,what u think ?
- Anyone have any '84-'97, and/or '88 - up front spring lying around - quick question
- HELP NEEDED FUEL PUMP 84 vette coupe
- Brake Lines and Module ?
- hard starts when hot
- Vibration Problem - Unresolved.
- Stability at higher speeds
- How far can you drop a c4 and not have it bottom out?
- 85 mass air flow on a 86?
- air intake temp sensor question
- New owner of 1984 Vette
- 84 cooling fan
- Still have clutch problems
- Hollow sounding Knock
- Brake M/C ?
- MAF Retainer clamp picture ?
- Replace master cylinder and brake lines
- Looking for1/2" NPT Caps
- When to use Over Drive ?
- What I bought and what I need to buy
- HP rating of stock clutch?
- digital dash light problems
- 1991 vette L98 6 SPD Performance Chips
- Anyone have a catback with true duals and no cats
- Anyone seen or used these Roller rockers before
- Porting and Polishing Heads/Intake Manifold
- Clockwise?
- can you c4 owners help me please..
- is the base circle on hotcam same as stock cam
- 1995 Will Not Start
- Magnaflow cat back system
- 1991 vette l98 line lock
- 1991 Best cat back exhaust
- AC & Heater Blower
- Help my brakes
- Big cube LTx...maybe?
- Stupid act with a positive result.
- C5 wheels on C4 question
- Are all 1.6 RR's the same net effect?
- Help
- new or remaned injectors?
- edelbrock runners and base with speed density
- A/C Question
- General question about c4 targa tops
- Correct Rear End Ratio???
- are stock lt4 pushrods hardened?
- The heads are here. Yay
- torque converter recommendation?
- Help - no speedo
- Universal Joints - General Questions
- EGR Temp Sensor
- 1.6 rocker size? 3/8" or 7/16"
- hate to ask, but..... will these wheels fit my 85?
- fix the 4+3, or bolt on a 6 speed
- Suspension help, Getting traction!!
- Vette shops around north new jersey
- 1991 corvette L98 problems
- Thinking of upgrading to zz9 cam, what other parts to buy?
- 1986 AC compressor help
- First Time Vette Owner HELP
- Stainless Steel braided lines
- no start please help
- Optispark and water - the car wash
- Clutch Master Cylinder Question!
- Custom exhaust setup
- This miss will NOT go away!
- Fog light covers stripped '93 (The plastic, not bolt)
- 91 vette wheel question
- How Much TQ Loss With Miniram/Superram/Aftermarket Intake?
- Golen Engines
- fuel pressure check
- Delay Relay for interior lights 1985 Coupe
- Question on duration split
- TBI Colant Hose Bypass
- Throttle position Sensor
- Oil pressure with engine oil cooler??
- AC Compressor wire question
- Exhaust for '85
- Cork or Rubber
- Edelbrock Intake Install Complete
- I got Service ASR and ABS lights
- Switching and porting plenums
- New Antenna masst and wont go down
- What controls the oil change dash light
- Steering Clumn shaft (engine side) keyed?
- C4 Car Craft Artical very interesting!
- coolant hose routing on a 90
- Vette Tech Tri-Y header update
- Modifying 1989 programming
- Roller Rockers
- Castrol AC Retrofit Kit - Opinions??
- Auto trans advice
- trashed engine what to do what to do
- Rear Carpeting with Rollbar? ANy tips?
- stealth ram on stock zz4?
- threaded in plug in a 1990 head. what size tool to remove?
- Part Throttle Hesitation
- Thought I was done, NOT! More problems
- fsm help
- Pumpkin swap
- Plz help me Identify Two Connectors So I can Diagnose my 93 PKE
- Retard stock cam?
- 95 LT1 (VIN J) coolant air bleeders
- Looking for shocking advice
- best heads to use on stock 350 l98
- Need an A/C electrical diagram for an 89
- 3 easy mods $10 huge bang
- Jon @ FIC
- LT4 injectors same as LT1?
- Check out my suspension specs
- Cold start injector o-rings
- cam suggestions????
- Best Source for a Hurst STS (1996 LT4)?
- Intake Install Up Date
- Oil pump
- Quick engine pull question...
- Accessory support mounts on headers
- 383, TFS heads, XFI cam: Got it going this weekend
- need a source for solid motor mounts
- 350 4 Bolt Main Block
- Exhaust finally together
- Welding precautions?
- advise on speeding my car up
- Is there a gasket
- D36 3.73
- how exactly does the CTS and ECM turn on the fans on a 1990?
- Rouch idle problem....checked codes..
- 105K Maintenance?
- No passing gear after tranny rebuild
- My Engine Swap Project
- Cloyes timing set clearance
- Steering Wheel "fix" or replace?
- I get a weird noise when drifting
- How much compression....
- 1991 Factory HP
- '84 oil temp gauge shows 'lo'
- Expected clutch plate life
- Vacuum Hose?
- fog lights dont work on a 1990
- 85' rear main seal change
- Help with A/C pressure readings
- Anyone ever use a Brake Bias Spring?
- 1991 corvette losing power
- Stuck Oil Filter
- Heated o2 on an '85
- another cracked brake booster!
- Misfire, Plug Reading Help!
- Sport Seats not working
- Brakes pull
- Where can I get lt4 10mm rocker studs?
- kicken a dead horse: what advanages are there with the 160 thermostat?
- mini starter
- Does my 85 really need all that
- No more sticky console YEAAAA
- ZF 6 spd to non LT block
- 58 psi Fuel Pressure
- jasper engines?
- Cruise control common issues?
- Code 22
- 4th gear grinding
- LT1 Conversion, Which Distributor?
- Results from fuel pressure test, please analyze
- Warm it up?
- 1993 Cooling Fan Question
- How can I tell the difference in tops
- Rattle and Hum
- harmonic balancer out of balance
- valve cover help
- Intake & MAF Problems
- Stainless cat back for 85
- vacume line?
- Splicing wiring questions?
- Tach Filter
- Don't laugh but a stupid spark plug question
- The BBK TPI Intake Is About to Arrive (Maybe)
- Electrical gremins attacking my 88
- brake bleeding
- Dynomax Super Turbos for 96 LT4
- How well do BF Goodrich drag radials last on the street?
- 1994 corvette starter
- front brake pads
- 12 volt keyed source
- is there a way to manually move my electric seat back?
