- clicking sound
- 383 Build Questions
- Can Someone with an FSM Look Up a Spec for Me?
- 1990 corvette window issue
- Price
- Help-Help Gear
- Cooling Tip for you
- New guy with a few Vette problems
- supercharger or 383 stroker but for a cherokee
- Help with shock replacement
- Inflatable Restraint Light -1990 C4
- Is there a solution for a loose seat back?
- Have questions about speedo display
- Engine question
- Random Misfire?
- Hot starting issue
- 0 Rings
- RRs : "Reduction in friction alone accounts for a 20-25HP increase w/o ratio change"
- Do you have Sumitomo tires ? Please step in !
- 1994 Lt1 - Tune up, cost?
- Transmission self destruct @ 70mph.
- Does a front camber change affect ride height?
- Input on What clutch to buy for 96 LT4
- WTB key fob
- 1987 L98... not much oomph, and hard starts when warm
- Differential Drain Plug Kit??
- Indexing wheel to hub???
- Pease Help, THIS IS KILLING ME!
- Xtreme Energy 270 comp cam
- ly1 header with custom exchust
- 1988 C4 Coupe will not run - HELP!!
- Right Head light doesw snot rotate all the way
- '93 intake install question
- Speaker wire routing or splice locations
- who here has rebuilt there 90'ish sport seats
- Brake Master Cylinder Resevoir
- High Horsepower and the 700R4?
- Spark plugs
- Std. or HV oil pump, what would you use?
- Z51 Rack Identification
- alternator regulator replacement?
- New Lt4 wont start.
- Solid motor mounts
- Help with small wires on outside of distributor cap
- dragstrip let down
- Electrical wiring harness
- exhaust question, cross pipe?
- Moog Ball Joint Zerk Fitting Install
- 92-93 PCV valve. where is this at?
- bent power steering pulley??? 93 lt1
- 87 E Brake question
- 84 Leaking Valve Covers
- C4 fan wiring power location ALT or BAT
- CFI to Carb to LT1 swap help
- LTCC , Come inside....
- Accessory bracket braces
- Cloyes double roller 9-3145
- 92 LT-1 surging at idle
- Got a CODES today P0100 and P0507
- who knows powersteering pumps?
- lt4 no spark.
- LT-4 PROS and CONS of long tube headers
- Lunati Voodo Cams
- Gotta cut the hood - best repair options
- locating intake and exhaust valves
- '94 LT1 running rich on left bank, intermittent code 43
- fuel pressure question
- Engine died and won't start
- Need help with changin alternator belt
- sys light
- who says you can't adapt LTx headers to a Calilfornia L98
- Idle right after starting
- problems idling engine
- Hooker Aero-Chamber mufflers
- Z-Rated tires
- Finished up the blower box
- Rear Hubs 90 Coupe
- installing a lt1 from a 94 camaro
- 1990 A/C system, help if you have done a/c work.
- LT-1 EGR system - anyone eliminate it
- need info on a trick flow cam
- Still Runs Like Crap When Cold
- ECM for 89 Best sources?
- Hard to start when warm
- 90 Corvette Hesitation and Missing
- What lenght belt?
- condenser cleaning
- Lt-4 engine mods?
- help power steering fluid everywhere
- information for installing a waterpump
- Heating and AC cotroller question
- C4 Stock Wheels
- Accelerator paddle problem on right turns??
- Scratched Nav screen
- BIII Injectors loose at tops.
- Radiator question
- Dyno numbers are in for the 383/TFS heads
- Part number for the D44 side yoke / stub axle clips ?
- Valve cover question
- my lt1 is kaput, crap. Now what, stroker?
- Vette mag. yellow 383 SC LT1...385rwhp?
- 94 no air from vents
- 1988 anti lock brake light
- C4 HVAC Blower Motor Whine
- $3000 in Gift Certificates
- water in gas?
- what batteries are you guys running?
- 96 auto transmission mount
- RPM gauge show about 1500 RPM to much
- Roller Rocker tips
- Valve stem measurement
- mini starter
- 93 lt1 oil pan gasket ... use sealer at the 'trough' in the front and rear?
- Poly Upper Bushings???
- 1994 C4 LT1Parking/Fog/Instrument Light Problem, Relay location?
- Ok- please speak performance- slowly- to the newbie.
- Source for C4 rear control rod rubber bushings?
- any consequences from running very rich for 3 weeks?
- TRW tie rod ends any good?
- 92 up K member
- c4 oil change
- Help vette runs and dies
- American Racing Wheels
- LTPWS interchange
- How much of a power increase?
- 1986 L98 weird stuff
- Who has done manual brakes on their C4?
- ring and pinion change
- Brake Repair question
- Seafoam/brake vacume line trick
- Need to Polish A/C Comp.
- 96 6-speed clutch pedal noise
- LT4 Harmonic Balancer (Damper)
- Rotor specs J55
- Easier ways to replace Master Cylinder?
- 1992 C4 Rough Idle & No Power
- Replacing clutch in 03
- HELP...Electric fans and thermostats
- Six speed behind the L98
- Mating a ZF 6 speed to a '93 LT 1
- Strange issues with shifting, etc. 84 Auto.
- blown motor???
- Long starts, rich rich smell
- Pete K torque converters?
- Need A Few Parts
- Wire Looms hunt!
- similar to wheel cribs...
- 84 Vette 700r4 same as 88 Vette 700r4?
- 1985 horns two questions.
- front spoiler replacent(86coupe)
- Rear brake question
- carb style EFI manifold on a C4?
- ZF6 swap???
- Door Ajar signal & interior lights
- Power steering pump - direction?
- Looking for very good C4 mechanic in Ft. Lauderdale
- Need Help. Rear bearing/hub stuck on spindle
- Any of you guys with Hedman 68448 headers ?
- Full Service GOOD Tranny Shop Phx Az area?
- cruise control vacuum ?
- 96 headlamps are inop.need help
- EVAP failed emission test, california
- Torque Converter Help
- L98 heads worth it?
- Oil Leak
- Magnaflow X Pipe...Why---?
- Coolant Sensor has bad reading. 100 at off using scanner.
- Tach signal loss
- Is it worth fixing?
- Valve Cover ??
- 1988 Corvette Head Flow Chart
- Newbie here with a IAC valve question
- Will these components work together???
- Vats 46 code
- Must have tunes
- Vortec 906's vs 062's
- Looking for more input. New miniram motor still not right.
- Heater Hose Routing
- How do I clean a block?
- huge favor: can anyone look up timing chain cover and oil pan gasket pn for me?93 lt1
- any tips on replacing optispark (alignment of shafts, etc.), 93 vette
- LT-1 intake on an L-98??
- Engine dies when put in Drive.
- So what happened?
- 1991 L98 engine Thermostat
- Safely Starting after winter storage
- lt1/lt4 valve seals
- I NEED to run 12's!!
- UP DATE , Shimmy at 25 to 32 mph and 55 to 65 mph
- Those running 1.6 RR's
- ???'s about ZF6 Transmission mount
- Need Help With Level 10 Shift Kit Changes
- ZF 6 drain fill plug
- A/C AIR pump removal
- Crawling under Vette ?
- Odd little "turbo" looking thing under the hood?
- Need 1990 L98 Overhaul Photos
- Eng revving, stalling problem with '95 SOLVED
- hood adjuster people step in
- FIRST injections intake
- Adj. Fuel Pressure Regulator on 91
- Question about using Stabil
- Trying to Find Info
- 1984 5.7 crossfire intake removal
- LT-1 problems
- change oil light
- Upgrading to Roller Rockers 85 Vette - Got some questions
- Need some help???
- #4 sparkplug arcing off header
- 1984 C4 loss of power to dash
- Dana 44 Question
- How do you bleed the air out of a LT1 cooling system?
- wheel swap
- Best way to remove hood
- No Courtesy Lights
- air injection delet?
- removal of harmonic balancer and hub. 93 corvette
- best fuel injectors to buy?
- Looking for some skinnies that will clear my.....
- Squeaky Shocks
- Pics of ECM bracket on 90 and newer
- why does a 90 crank excessively before it starts
- Any carb experts here?
- making a 90 vette rattle and squeek free lets hear your fixes
- thermostats whats the best?
- hard starts when hot
- 96 Sport seats -- white connector
- I hate my transmission!!!
- 1984 corvette engine swap
- 1991 l98 fuel injectors
- Seat motor ratcheting
- Where to place jackstands
- LT4 need some input Pure Grunt!
- LT4 New Clutch Help 96 Corvette
- 1985 Tail Lamp Replacement
- question for tranny people
- Evaporator Cleaning ?
- engine bolt sizes
- Vibration... Engine or Trans
- Those have replaced their ECM...
- A two year odyssey
- Single 4bbl throttle body conversion pics?
- Question on brakes
- Brakes making Hissing sound.
- Leak from Fuel Tank Sender Unit Gasket
- New best times on the bottle yesterday
- [electrical] Switch issues: '88 Vert
- Siamese or not to siamese??
