- Would A/C Comp. need to be removed?
- Best style starter for an 85?
- Differential drain plug
- air fuel ratio gauge question
- Hotcam with s/c?
- Betty's Alive and Well
- Experience with CompCams XFI cams
- hp gains with miniram on stock 91?
- 84 Corvette
- TPI performance replacement engines?
- 84 water through heater core
- HELP w/ Steering Wheel Adapter
- need pic of brace for alt
- Need To Get Windows Down!
- 96 LT4 O2 sensors
- 86 Roadster - Low Coolant Sensor?
- 89 C4 Jerks Below 1100 Rpms
- Rear window grid
- Meziere Water pump instructions and pics, anyone have them they can email?
- Finally in the 11's
- Aftermarket power steering Hose 1987
- oil in opti ????
- Underhood lamps - need a little help figuring out how they're wired...
- '90 High Idle
- Brake Dust Shields 1993?
- intake #?
- X-ram intake for crossfire injection?
- gas mileage change in going to dana 44
- AFPR Recommendations
- Can I find TDC using a compression guage?
- Inspection Out, Need Help...1985 L98
- Quick question needs answers QUICK!! Please Help
- CCW w/ 335 x 18 fit a C4?
- Need Thread Size of O2 Sensor...
- Heads/Cam/Intake surgery started!!!
- Water pump questions....
- LT1 Timing Set & Case
- Anyone deal with "theenginestore.com"?
- LS1/LS6 conversion cost?
- Brake Pedal Travel & Firmness Question
- Clutch master and slave retrofitting
- C4 Front Spring Info? HELP!!!!
- 383 tuned port injection
- Trunk Ajar... But it's not?
- Is ths a toy supercharger ?????
- Stock water pump rotation
- Anyone out there with a turbo
- Lowering Bolts?
- freeze 12
- Security Light and ASR
- 1984 Corvette crossfire injection help?
- Painting a C4
- SLP Headers
- Maf Sensor???
- Theft/Keylock
- Carpet Replacement
- 1996 CE Z51 Conversion??
- Power Steering Pump or Rack?
- Want to see: pics of sheetmetal/fabbed dashboards
- 87 L98 Original color intake plenum/runners
- Will a 94-96 Steering Wheel Fit on a 92?
- TPIS cats: anybody used em??
- More HP out of your headers ????
- Fuel pressure Regulator
- HP figures for N/A 396 LT1...
- Bad switch?? HELP!!!
- Update on Blown head gaskets
- Good Product
- Mini Ram w\ 58mm TB ducting question
- 1992 Clutch
- will this cam work with my stock ECM?
- A/C Compressor 1993 lt1 question
- 87 console lock problem
- headliner
- Clutch, flywheel question
- C4 rotor mimimum thickness???
- "Sticky" gears
- 84 Rack & Pinion
- TPI gaskets
- Throttle Body Bypass
- Mocha-Latte milkshake from somewhere... :(
- 2,4,6,8 not firing
- Couple 4L60E questions
- '94 Oil Temperature Gauge
- Question On Build
- Production code NN5?
- MSD Cap & Rotor
- WOT switch
- 12.5 MM (1/2 inch) Wheel Spacer and Stock Lugs ????
- M-1 Prowler Air Dam
- sluggish when fist start
- What is this hole for?
- Speed Shifting a 6 speed
- Clutch release HIGH
- Question,..Dynomax Super Turbo Direct Fit Mufflers
- TPI plenum holes
- 86 Failed CA emissions - New test as of Dec 1, 2007.
- need windshield swap info/help
- Opti spark......
- Stock LT1 heads flowed (chart)
- Head light conversion kits
- Stock L98 Picture needed for Plug Wire Routing
- Stock Spark Plug Wire Looms work with 8.5mm wires?
- Cold Weather Horn
- Adjustable ride suspension (FX3 option) question
- 94-96 LT1 manifold Tech question
- Rear passenger tire wears faster than the others
- Removing the "guts" of the catalitic conv.
- bumper
- Work Meister S1 wheels
- Problems converting a stock carb setup to a TPI???
- 1985 govener
- Solid Rear project started! WOOHOO! Pics inside . . . .
- pillar post gauge holder
- clutch problems
- 89 ECM question
- X-Brace on Coupe Vette
- Need help with a 4x3 tranny
- i got prices from my shop today just wanted yalls opinion
- Vacuum Diagram 86 ???
- Another Carb conversion ??
- 1986 brake upgrade
- Who makes adj swaybar end links?
- Happy Holiday Sale @ Vbp
- which brand forged pistons to suit forged 3.875" stroker crank please ??
- j55 upgrade
- DIY rear o2 simulators
- MAF for power!
- Targa top from 89 fit my 84
- 89 TPI Throttle Body Question
- I have a few questions about an 88.
- oil pan for ls2 swap
- TPI parts interchange/etc.
- brake pads
- Code 32 -- EGR
- Coolant plugs for LT1 heads?
- Evap emiss VAPOR canister / valve / solenoid
- Another 4L60E problem...
- 1986 Tuned Port
- C4 1993 Heat Cabin Issue
- for those of you with SW headers...
- LT Headers on a '90 L98
- Electric Window Problem
- 700R4 Servo
- TPI - most complicated intake ever
- Long Trip Help
- LTPWS question
- Help with 93 LT1 please..
- Window wiring?
- Static CR
- Starter not disengaging
- 1990 Steering Wheel Replacement
- Testing A Coil
- Can LT-1 Mufflers go bad? How are they built?
- Window Wiring Schematic
- AFR Experiences?
- need ZF6 trans info...
- Rebuild L83 or not
- C4 microfiche/parts catalog available?
- What the hell is this in my transmission?
- Weighed the Vette today...how does this compare?
- What length rocker arm stud to buy?
- LT1 question
- Street Fighter Corvette, how would you build it?
- 84 Crank Pulley Below Crossmemeber, Help!
- who's done the C5 brake upgrade?
- Distributor Shaft End Play
- Camshaft recommendation for a California 91 L98 AT
- water pump seal replacement
- My 91 L98 has a ticking sound at idle???
- Super Ram Accel Base question....Pictures..
- How Delicate is an Alternator ?
- 1989 Injector problem?
- 93 LT-1 Running Rough
- Yet another Tachometer question for all
- head light wiring
- running rough when warm?90 l98?
- 4+3 reverse lockout install
- Starter is intermittent: Please help.
- 1992 Corvette Conv,t 50 K 6spd
- Bolt Sizes Please
- Guideplate Install
- TC / Tranny Question - total weirdness
- Pics of a Stock L98 PLEASE
- cheapest place to buy 383 forged 3.875" stroker crank ??
- What To Do On a Crappy Day
- 17" Wheels
- 1985...1 Piece or 2 Piece Rear Main Seal???
- Transmission leak at the rear
- Brake caliper bolt torque
- C4 LT-1 Missing Above 3500 RPM's Sometimes
- Think I need some help here,,,,
- Roller Rocker question
- Comp Cam 7-306-8 in LT1? Any users on here?
- Where can i buy a super ram for my 91 L98?
- Headers
- targa top trim ring removal for painting
- Rocker adjustment thought
- can someone please answer my question about wheels ?
- Why is my fan running so much and so loud?
- B&B Exhaust Sound Clips ???
- Mods ain't cheap
- Tangled wipers?
- Gear Whinning
- Oil Cooler Gasket keeps Busting on Startup...HELP!
- Seattle Area: Need Chromoly 1 5/8 by .083 tubing?
- Distributor won't drop.
- No Fan of the Cold
- C4 ball joints same as C5 ball joints?????????????????
- 95' 4l60e advise ?
- TPIS headers vs. all others?
- Now a header question...
- 4.56 Gears
- wheel clearance issues '94 C4 w/ '06 wheels
- 1885 corvettte digital dash
- GASKET info
- Anyone Upgrade from Stock 3.07's to 3.73 or 4.10's ?
- Where to start? Diagnosing a 93 Ruby...
- Southern Indiana & Northwestern KY Folks
- all I want for christmas....
- Fan switch accuracy?
- Cabin Heater Coil Leak
- Anyone put in a stock non Vett crate engine ?
- Pedal Mount Issue
- rebuild and upgrade my 91 L98 AT ,$2.5k Limit
- my 1st vett
- Electric Waterpump?
- Corsa-Ecklers Exhaust Problem (long)
- 84-89 Analog Conversion
- 90 L98 Smog Pump Bypass Pulley
- What ocate for an 87 Vette ?
- AFPR fuel leakage
- Pushrod length dilemma
- TPI fuel rail
- Softer ride
- Flashing CPU in my 85'
- DTC code P1641 on a LT4
- Two Fault Codes 34& 36
- Any comments on this RR procedure?
- loss of oil presure reading
- need advice on injectors!
- Lifter Question
- Front hub needed
- Good price for a super ram?
- Sputtering problem
- Will a Magnaflow 3" x-pipe fit an 84?
- LT1 Heads on L98
- Engine Timing off
- Headers for 1986 w/iron heads
