- Aftermarket Radiator Questions
- 1986 Speedometer LCD
- Balancing a Rotating Assembly
- Fuel Level Repair
- Brake fluid?
- Line Lock Suprise
- cold air intake??
- Electric water pump
- I Can’t believe MY vett won’t Crank
- what exactly connects to the air cleaner housing on my 90
- Hard starting in the morning
- I am going to weld to ricer mufflers on
- 90 digital odometer lighting issues or normal?
- Vacuum lines on 89
- 86 C4 Starter R&R
- 96 A/C Problem
- Crank Sensor on a 95???
- Ground Effects
- Oil dip stick tube
- 406
- CTS problem from hell, please help!
- 84 A/C Control Panel Vac Routing
- Cooling Fans stayed on
- maf sensor
- best oil seal
- To those with a FSM for an 85
- Wheel Sensor Stuck
- Need help with crossfire run and die
- plenum bolt vaccuum leak
- Holy crap i won
- LT1 oil leaks
- Venting!!!
- GM Workers
- How do i check my TPS with this?
- 86 oil issues..
- vibration with top off
- Need help gauge cluster flickers on & off
- 4 speed shifter problems in first and second gears
- Digital Screen Not Working
- Road Trips and C4's
- what bolt to use on exhaust flange to manifold
- best paint?
- Repair Help
- FE1 upgraded to Z51 can it be done
- Shock swap
- 86 Auto Coupe intermittent No Start
- oil question
- throttle body pictures?
- sport spring or factory spring
- Battery Issue on a 1986
- 84 wont start
- 1993 PROM swap fixed engine start problems.
- Freon 134a -- Caution on using 'with leak sealer'
- can't get heads off and about to loose my mind!!! Help please
- do magnaflow cat back drone for everyone who owns one?
- Do new Rockers = New pushrods
- Rough running 87 -Code 15, 32
- Water pump
- Need advise on 85 Suspension rebuild
- a/c compressor`
- Alignment Specs.
- just got from the dyno shop,what is std correction?
- Another Exhaust Thread
- I have new precats in my 2.5 inch magnaflow Y pipe, they smell bad
- C4/C5 front rotor offset
- Help with brake pedal
- What is this handle/thingy for? (Pics)
- Just ordered custom chip
- Valve train components
- Is there such a thing as a lower temp fan switch?
- Filling ZF6 Fluid Question
- why is my thread locked?
- C4 brakes - upgrades?
- Fuel selection
- 406 ci Fuel Injector Pressure questions?
- is my 92 lt1 slow or what?
- What is it?
- HELP!! 95 Died and will not start!
- Out of ideas - Cranks really slow
- ABS System Test Repeating
- Is the rear glass adjustable??
- Lowering results
- Diagnostic Code Problem - 95 LT1
- Help with 1986 targa fiberglass top
- 140 amp Vs 200 amp alternators
- Misfires....
- help, serching for video or advise
- Code 15
- A/C leak ?
- May I get some assistance?
- 90 vette tach, not working?
- Blown Head Gasket-Looking for New Heads
- Steering column interchange question
- What's the stock front brake rotor size on a 95?
- welding craked head ?
- Ride quality
- New engine Lt1 N/A setup. Any ideas?
- Low Oil Pressure.....PLEASE HELP?
- How can't I burb my cooling system
- Do you adjust the AFPR first then tune?
- Opti Spark/Water Pump Replacement
- weird noise after installing roller rockers - video included
- I need Blose speaker wiring diagram,
- Screw Broken in engine
- 1988 vette engine trouble
- Oil Pressure
- Track Day Alignment Specs?
- Compression Test.....Pressures ??
- hard start when hot
- Rods
- Intake off, what to replace?
- 94 vette ac compressor clicks on/off 5-10 second
- Glyptal .....Ever use it or Never use it.
- Master Cylinder Locked UP!!!
- brake booster leak? tb idle and starting.
- front shock replacement question
- whats the stock ohm spec for stock 92 lt1 inj
- Track Day front tire size?
- is 12 ohms good for stock 92 inj
- Ball joints and outer tie rod ends
- Secondary FAN won't turn on...1994 LT1
- 94 A/C and Cooling fan problems
- For a 1986 Vette - 14102187 casting 305 head modification,outperform a 350 head ???
- No Brakes!!!
- how reliable are link-bar lifters?
- water pump, now oil leak
- Need Powder Coat/Ceramic Painting - DFW
- 4+3 to 700r4 swap
- 1988 Vette Spark Plugs
- Intermittant no start, car has stranded me several times.
- Wiper sweeps past the windshield
- "87 TPI vacuum diagrams wanted
- Need help with speedo after rearend gear swap
- 87 Upper radiator hose
- Oil cooler pipe
- Shift points?
- C4 D44 swap into c3 frame
- Raising the back of the seat
- 89 running rich and poor idle may be solved
- Clutch fluid reservoir
- Fuel Pump Relay & Alternator Fuse - linked?
- Car / transmission is back from the shop ~ Pete K is my hero!
- HELP hood wont open.
- 96 Corvette air box lid
- Opti spark cap and rotor
- Intake manifold help needed
- lt rear noise
- 1989 Factory Options List Location
- The 434 is alive!
- Quick timing gear clarification required
- C4 Runs fine, then just dies.
- Blow out sale on new 30lb bosch red tops
- Hypertech dizzy kit question
- 396 Block
- 86 C4 No Power
- Opti rotor
- 30# injectors and a stock corvette
- C4 interiors questions
- Clutch Decisions.....
- Roadracers First Time on the Dragstrip!!
- Beer bottles balance the bestest ya know
- Ran Seafoam in the Crossfire
- 94 LT-1 problems
- Help
- Need help for my 88 (trans I hope not)
- Proform valve cover broke while installing. HELP!!!
- Fuel Rail Schrader Valve
- Shocks for a '96???
- &@#^$# Headlights! New bushings, new Module, no ups!
- Question for you engineering-types...
- 84 Shorted, Not Getting Gas
- Replace What Wiper Arms? Blade with bracket,or just refill?
- how long does it take a shop to change trans fluid and filter (700r4)?
- Which head gasket?
- Does freeing up the exhaust Lean, Enrich, or Does nothing.
- Analogue Gauges in an '84: Goodbye Cruise Control??
- L98 block intake system questions
- Interior Light Staying on, Clicking Noise, Dome Light Not Working??
- Transmission Shop Recommendation
- Need Help with Codes
- trying to bolt up ported plenum and LTR
- Dumb question...voltage?
- I found the miss I finally fixed it.
- 4+3 leak
- 1990 Clicking Clutch issue
- Differences in LT1/LT4 short block
- 1995 c4 tranny upgrades?
- Tranny not shifting
- Can you identify this part, inside rear bumper?
- 1992 stock cut off backfire???
- Air Filter - K&N?
- Tachout's Project....
- LT-4 won't start
- New motor LT4 Hot Cam question
- rear bumper alignment advice
- Steering Wheel Lock
- Help I did something Stupid. How do I pop the Hatch
- Aftermarket K member
- Wheel Spacer Needed
- Idle air valve horror story!
- Part number help please?
- out of options, tested everything Cyl 6 not firing
- I am about to descreen my maf.
- May be getting a 87 vette
- 89 Corvette detonation....
- 2 issues looking for input
- LT1 Engine stalls, no start except w/ starting fluid
- Coefficient of Drag ?
- h32 and h44
- Anybody know anything about these roller rockers?
- high idle
- Need main cap bolts
- AC kompressor engages in non AC mode
- Hooker headers and 84-88 Clutch slave clearance
- Powersteering problem, need advise!
- Parking Brake Handle Help Needed
- Coolant reservoir cap question
- Optispark Question
- weatherstripping - glue or not glue?
- So why doesn't anyone want to Drag Race at the Cruise In??
- Oops... any help?
- Help me build my 383
- looking for l98 ideas
- Ignition key stuck, will not move
- OK, Just rebuilt the headlight motors... How do you change the tail light bulbs???
- Newby to the C4 Environment
- Is this normal??
- 95 LT1 - Missing, cutting out during acceleration
- Rear Brake Pad Replacement Question
- Anyone using :Corvette Throttle Performance Switch
- 95' vs 96' Ride Quality
- 1985 Antenna bypass switch help please.
- 95' Brake Rotors Directional?
- LS-1 in a C-4
- Are LTx spoilers shorter than L98's
- To get a tune yet or not?
- Thoughts on these RR's
- I don't know how to rev my car safely yet agressively
- 1996 Windshield Wiper Arm Upgrade
- Starter heat soak with headers
- 1985 AC fuse
- 94 LT1 Vacuum lines ...HELP
- Heat shield, Do I need it?
- Help - stuck - coupe rear glass removal
- A/C High Pressure Cycling Question
- Early Dana 44 to 89 auto swap ???
- 1995 Bilstein front gas shock "WP", rear "JY" shock
- Help-Can't mount camber brace on my 91
- RE; Tuned
- oil temp
