- '92 wiring info/stereo question...
- Main engine connector
- Alternator wiring help
- Is there a specific wiper blade for the 89 Vette?
- knuckle buster "92"
- Headlight shaft bushings..the other ones
- 1986 EGR Removal??
- L98 exhaust resonance advice
- Installed new AC compressor...connector does not match
- Anyone here of Trick Flow G1 Twisted Wedge Heads?
- P/S Pump issues....
- Calling all opti experts
- Tapered Wheel Hubs Life?
- clutch changed, overdrive not working now
- Brake Fluid Color.....Green???
- Shorting out plug wires and coil
- exact water path lt1
- Intermittent starting
- 92 vette oe wheels on 94 vette
- Feels a little sluggish
- c4 85 corvette fuel pressure regulator
- Staggerd?
- ZF6 Drain plug
- Adding a High Brake Light (85) - Question
- First Intake
- LT4 winter project suggestions
- Possible failing ECM or PROM
- 84 door handle
- fuses
- New AC/Heater Replacement 1993?
- Intake Air Temp sensor
- 1991 Fuel Injector Problems
- Which Anti freeze??
- Tpms
- Need advise on lowering a C4
- engine push start button
- Odd wiper problem
- Rebuild LT1 engine
- Clutch problems
- Hey Brian
- Engine Idle Dies when clutch depressed
- Wiring Advice / Request
- Need Help
- torque convertor
- Any Magic out there?
- 90 inflatable restraint sensor
- Rear Break Issues
- Service ABS light
- Lt4 Conversion ?
- Cigarette lighter removal
- what did i get myself into... why wont my door panel pull off?
- Clutch reservior cap problem & solution(s)
- car (93) always feels sluggish right after reconnnecting battery..how long before
- Opti Replacement?
- Worst time with rocker arms and push rods :(
- steering noise
- C4 Ignition Key Prob's
- 96 Coupe - fans vs heating
- ECU Swap ?
- Divisional finals
- Thought my PKE receiver was long dead but maybe not??
- Please help 1990 throwing codes
- 92 conv. 6 speed misses under a load, getting worse.
- 91 Corvette Hood and Center Console Lights
- well i found out why it shifts a little high... always about 20% higher rpm...
- Odometer Failure, Replacement Required - Assitance Please
- Correct wiring for 1992 Idle Air Valve Pigtail
- Willcox Fall Sale Inclds: Interiors, Weatherstrips, Carpet and 10% off
- knock counts - realistically what are you guys getting?
- 85 vette sensor
- oil pressure switch 1991
- 92 steering column
- Trying to find odd part
- Random Misfires Code
- I think Comp sux too! With Pics
- It's running but??????
- Change fuel pump on 90 vette?
- NEW Sale from VBP, October 1st - October 31st, 2011
- Lots of Crankcase Smoke
- Throttle Body Size - Why do you need a bigger one?
- My 396 build is finished! On to Tuning
- Catalytic converter question.
- Dist Timing-1987 C4
- glass polishing
- C4 to c6 z06 brakes
- CR2450 battery replacement help
- 94 power antenna nightmare
- Experience with rear wheel bearings from Corvette Central?
- 84 C4 instrument cluster removal
- Bose Amps for rear 1991 from 1999 corvette
- J55 Heavy Duty 13' Break Rotors
- How does an MAF problem cause a no-start?
- Codes 34 and 44
- 86 getting hot
- 87 with C5 dual piston calipers need a bigger master cyl
- Alarm is causing havoc.
- Distributor Question
- History Codes ??
- Runs like crap in open loop, fine in closed
- Cornering Lights and Backup Lights Inop.
- 383 needs torque
- Wilwood SL6 Calipers - which wheels fit?
- 85 Corvette digital dash going haywire!
- TPI won't run w/o false air
- Thoughts on my exhaust setup
- good vendor for new fuel tank?
- DTC 42 means?
- What should the idle speed be for an 84?
- water pump leaking
- 85 and 88 maf interchangeability
- voltage dropoff in rear hatch circuit
- Do I need a alternator
- Center console harness connector question
- C4 a Good Drag Car?
- 1987 l98 charging system question
- used zf-6 speed, how much?
- 95 Auto Digital A/C Cuts Out after 15 minutes
- strong exhaust fumes
- A c4 owner today told me the drivers side wheels ran a different offset ???!!!
- Who is making c5 brake adapters nowadays?
- Mysterious Brake Light
- C4 door removal??
- Changing 1995 O2 sensors?
- 1986 Intake Air Sensor Relocation
- 93 Heater and A/C Solenoid Removal
- Need help setting initial timing
- LCD Display and need to 'Flash'?
- idle problems still!
- C4 Rear hatch drains DIY-
- LT4 Head insert question
- FX3 Suspension - fixing the actuator? is it rebuildable?
- Temp problems
- Code 32 question for a 90 with a L-98
- 85 C4 blue smoke
- '87 L98 question
- ok problems... need help...
- Chambered vs straight pipe muffler elims
- DIC and interior lights
- Fixing the horn: how do you know which part?
- fuse diagram 1990
- Windshield weatherstrip retainer
- Do sawblades bend easily?
- Great Experience With Carbotech Brakes!
- External or Internal Balance ( LT-1 ) ????
- 85 A/C vent flow question
- Scanner Advice
- 96 wipers just don't like each other
- Replacing waterpump drive seal
- intermittent sys flash after removing pass. pwr seat..is this normal?
- Code 25
- '84 Wiper problem
- Stereo wiring
- will an 86 rear end bolt into a 90?
- Auto box kicks down too easily - er, maybe
- sneaky leak!!!
- LT4 Springs on L98 113 Heads
- 93 lurching or stuttering in all 6 gears
- Is something missing?
- Electronic Speed Sensor Adapter for C4???
- 1990 Fuel Injectors
- 1990 Headlight Issue
- How to adjust the MSD Optispark???
- 94 A/C Clutch
- 383 stroker fuel problem help!
- Fuel Flow Problem Please Help
- Knock Sensor Removal
- power steering hose leak from reservoir
- L98 factory oil cooler
- mass air flow relay
- Differences between years of transmissions?
- Yippee, the SES light is out (update)!!!!!!!!
- N20 jet ?
- I need diagnostic advice:
- Still......no rear brakes on my 90
- 1984 radio problem
- "85 Intermittant No Start
- Fitment of C5 Vararam Intake?
- ECM Relearn Procedure?
- 1990 won't start
- 84 restoration ongoing but now running rough
- Slow cranking and code 34 (85 Vette)
- Grand Sport (C4) question
- 87 Coupe - cooling fan does not seem to come on...
- Occasional Low Idle (possibly fuel related) Issues.. ?!
- Radio/speaker popping noise
- 1994 cooling fan switch install need help
- proper dist/coil wiring L98 MAF TPI
- keyless entry/engine start
- Engine Bogging!
- maf info
- Evap vapor canister orientation?
- Lt1 in my '94 coupe seems to remain hot long after shut down
- C4 backup lights
- evaporator outlet?
- 90 L98 runs crappy(ier)
- Opinions before I start dropping big money!
- Spark Plug Wire Retainers
- Tech question on PKE
- Electronic Gauges
- C4 convertible key stuck
- anyone start a block that's been sitting for years by...
- C4 D44 batwing fit C3 iron diff hoghead???
- 92 six speed shifter problem
- my '94 auto to zf6 finished
- "bat"
- Newbie with A/C Question
- problem restarting
- C-4 Manuals?
- ZF6 transmisson yoke
- Total windshield and frame removal..
- 91 cluster ~ not showing inst/mpg - just gives sys error?
- 91 Custer Issues
- 86 power steering pump problems
- Please Help My Misfiring TPI. Video Included.
- lt4 383
- Headlight sticks !!! annoying
- My 85 Down for the Count
- Where does this ground wire go????
- Strange noise after i back up n go forward.
- reset blm's ~ connect positive terminal to negative terminal?
- ******ultimate engine builder challenge!!*****
- a moment of silence for motor #7.5
- Locking lug nuts-no socket!
- 383 LT1 running very rich
- Buget of 2,000. new 87 owner help spend my cash!!
- FYI A/C Compressor
- Air Pump Delete Hose??
- 1996 LT4 reverse lockout
- ANYONE have a performance slave cylinder?? Or a good brand one?
- TPS voltages & idle rpm
- My clutch is slipping under high torque, high rpm's
- '87 on a diet for better et times!
- Headlight motor runs a few seconds after it closes
- Oil leaks driving me nuts!
- C5 parts on a C4
- Lt1 died while driving
- Gas Pedal Replacement
- No Dash Lights and No Tail Lights At Night??
- Which one is right?
- Best bang for your bucks on cats???
- 1995 mild stumble at acceleration
- If it ain't broke....
- Replace Antenna Mast (w/o removing antenna)
- Questions for those who've had FX3 shocks rebuilt/re-valved...
- T-56 Swap Master Parts List
- 90 Center console harness routing
- Torque Converter Lock Up
- 86 vete rich air fuel mixture
- 86 vete rich air fuel mi ture
